Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This target wants to check full SPL size, BSS included.
Remove CONFIG_SPL_MAX_SIZE definition and instead define
CONFIG_SPL_MAX_FOOTPRINT.
Remove SPL-related ASSERT() in arch/arm/cpu/u-boot.lds
as this file is never used for SPL builds.
Rewrite the ASSERT() in arch/arm/cpu/u-boot-spl.lds
to separately test image (text,data,rodata...) size,
BSS size, and full footprint each against its own max,
and make Tegra boards check full footprint.
Also, output section mmutable is not used in SPL builds.
Remove it.
Finally, update README regarding the (now homogeneous)
semantics of CONFIG_SPL_[BSS_]MAX_SIZE and add the new
CONFIG_SPL_MAX_FOOTPRINT macro.
Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Rework the waiting for transfer completion loop condition
to continue waiting until both Transfer Complete and DMA End
interrupts occur. Checking of DLA bit in Present State register
looks not needed in addition to interrupts status checking,
so it can be removed from the condition. Also, DMA Error
condition is added to the list of data errors, checked in the loop.
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
The cache should invalidate the read buffer for
the SD card interface after the transfer complete,
not command-complete.
Tested-by: Andrew Gabbasov <Andrew_Gabbasov@mentor.com>
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Commit 3ebd1cbc introduced compiler-generated __bss_start
and __bss_end__ and commit c23561e7 rewrote all __bss_end__
as __bss_end. Their merge caused silent and harmless but
potentially bug-inducing clashes between compiler- and linker-
generated __bss_end symbols.
Make __bss_end and __bss_start compiler-only, and create
__bss_base and __bss_limit for linker-only use.
The glitch in the SPI clock line, which commit 3cea335c34 (spi: mxc_spi: Fix spi
clock glitch durant reset) solved, is back now and itwas re-introduced by
commit d36b39bf0d (spi: mxc_spi: Fix ECSPI reset handling).
Actually the glitch is happening due to always toggling between slave mode
and master mode by configuring the CHANNEL_MODE bits in this reset function.
Since the spi driver only supports master mode, set the mode for all channels
always to master mode in order to have a stable, "glitch-free" SPI clock line.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
When swi instruction is executed, it is expected to get message
"software interrupt" in console and dump registers and reboot, as
do_software_interrupt() in arch/arm/lib/interrupts.c.
But, actually it causes data abort accessing wrong address in get_bad_stack_swi
macro in arch/arm/cpu/v7/start.S.
This patch fixes this problem.
The same mistake in arch/arm/cpu/{arm1136,arm1176,pxa}/start.S.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
TPM command library implements a subset of TPM commands defined in TCG
Main Specification 1.2 that are useful for implementing secure boot.
More TPM commands could be added out of necessity.
You may exercise these commands through the 'tpm' command. However, the
raw TPM commands are too primitive for writing secure boot in command
interpreter scripts; so the 'tpm' command also provides helper functions
to make scripting easier.
For example, to define a counter in TPM non-volatile storage and
initialize it to zero:
$ tpm init
$ tpm startup TPM_ST_CLEAR
$ tpm nv_define d 0x1001 0x1
$ tpm nv_write d 0x1001 0
And then increment the counter by one:
$ tpm nv_read d 0x1001 i
$ setexpr.l i $i + 1
$ tpm nv_write d 0x1001 $i
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
This is used on some Exynos 5250 variants.
Add a driver for the I2C TPM from Infineon.
Signed-off-by: Rong Chang <rongchang@chromium.org>
Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org>
When building for the Sandbox version, the casts in this change are
necessary to avoid compilation issues.
Signed-off-by: Taylor Hutt <thutt@chromium.org>
This enables the device tree library on the Integrator platforms
so we can pass a device tree when booting.
As this board has NAND and supports YAFFS2, add CONFIG_MD_NAND_YAFFS
Cc: David Müller <d.mueller@elsoft.ch>
Acked-by: David Müller <d.mueller@elsoft.ch>
drivers/video/exynos_fb.c
ext3 should not be used on SD cards, so use ext4 instead.
Cc: Sricharan R <r.sricharan@ti.com>
The processor is hopefully running with M(ega)Hz and not with m(illi)Hz.
Signed-off-by: Manfred Huber <man.huber@arcor.de>
This reverts commit 239cb9d904cfa8ab50d840a47b3306189d695c75.
This reverts commit 81a4f7098ba137ea1961cb997ca16d57de2b3483.
The previous timings were done on the internal-only A1 board which has
different DDR part than all later revs. The timings need a slight
adjustment to be correct in all cases with later revs.
This board is from a u-boot point of view a mixture between kmnusa and
a standard km_kirkwood board. We have our u-boot environment in the spi
NOR flash, but we have a direct connection between the kirkwood and the
piggy. A FPGA is connected via the PCIe interface. So we only have to
select the specific features in the board setup.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
Switch from 1-bit ecc to 4-bit ecc.
commit 9660e442 cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INIT
removes BOARD_LATE_INIT and uses CONFIG_BOARD_LATE_INIT instead.
Therefore we have to use this define.
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
If CONFIG_NAND_ECC_BCH is set use 4-bit error correction code instead of
the 1-bit error correction code on the NAND device.
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Acked-by: Scott Wood <scottwood@freescale.com>
The conversion of mx31pdk to SPL NAND fixed the boot issue, but we start seeing
resets in loop, which prevents us from reaching the U-boot prompt.
Until the proper fix can be identified, disable watchdog, so that mx31pdk
can be functional again.
Let all ARM linker scripts handle properly -ffunction-sections
and -fdata-sections. This will be useful for future changes in order to create
symbol-specific sections in common .S files.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Following the removal of the smdk6400 board, the MMU setup code in
arm1176/start.S becomes unused, so remove it. It will still be possible to
restore it later from the Git history if necessary, in which case it should be
moved out of the relocate_code() function.
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so
remove associated code. It will still be possible to restore it later from the
Git history if necessary.
This reverts commit 1285a2808a254f3d1a809c1a541f0c0f746e03d7 since the migration
of boards from Makefile to boards.cfg is now complete.
The migration of boards from Makefile to boards.cfg was due for v2012.03, but
smdk6400 did not follow, and it does not build, so move it to scrapyard. It will
still be possible to restore it from the Git history before fixing it.
This image combines the SPL with the i.MX header, the FCB and U-Boot.
For i.MX25/35/51, the FCB is ignored by the boot ROM, so this image is just
useful because it can be programmed on a NAND Flash page boundary.
For i.MX53, the FCB is required by the boot ROM.
This does not support i.MX6 so far because its FCB is more complicated.
This image combines the SPL with the i.MX header and U-Boot. This is a
convenient way of having a single image to program on some boot devices.
The i.MX header has to be added to the SPL before appending U-Boot, so that the
boot ROM loads only the SPL.
make never uses the SHELL variable from the environment. Instead, it
uses /bin/sh, or the value assigned to the SHELL variable by the Makefile. This
makes the export of the SHELL variable useless for sub-makes (but still useful
for the environment of recipes). However, we want all makes to use the same
shell.
This patch fixes this issue by moving the SHELL variable setup and export to the
top config.mk, so that all Makefile-s including it use the same shell.
Since BASH is used by default, this makes it possible to use things
like 'echo -e ...' in sub-makes, which would otherwise fail e.g. with /bin/sh
symlinked to /bin/dash on Ubuntu.
Reviewed-by: Tom Rini <trini@ti.com>
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of
ARM's relocate_code() useless since it moved the code handling them to crt0.S.
So, drop these parameters.
This also fixes support for mx31pdk and tx25, which had been broken by commit
e05e5de7fae5bec79617e113916dac6631251156.
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Automatically build the 'u-boot.imx' (i.e. imx header + u-boot.bin) and 'SPL'
(i.e. imx header + u-boot-spl.bin) make targets for all imx processors
supporting this header, so for arm926ejs, arm1136 and armv7. Some combinations
were missing.
At the same time, fix the build of SPL targets not supporting the imx header on
arm1136. For arm1136, the 'SPL' make target was forced to build in all cases if
CONFIG_SPL_BUILD was defined, even for non-imx platforms or imx setups without
an imx header.
Change CONFIG_SPL_PAD_TO from a link address to an image offset since this is
more handy and closer to the purpose of this config.
Automatically define CONFIG_SPL_PAD_TO to CONFIG_SPL_MAX_SIZE (or 0 without
CONFIG_SPL_MAX_SIZE).
Test that CONFIG_SPL_PAD_TO >= CONFIG_SPL_MAX_SIZE if CONFIG_SPL_PAD_TO is
non-zero.
Give more flexibility to define configs that can be interpreted by make, e.g. to
define fallback values of configs like in the example below.
Before this change, the config lines:
#define CONFIG_SPL_MAX_SIZE 2048
#define CONFIG_SPL_PAD_TO CONFIG_SPL_MAX_SIZE
would have been changed in autoconfig.mk into:
CONFIG_SPL_MAX_SIZE=2048
CONFIG_SPL_PAD_TO="CONFIG_SPL_MAX_SIZE"
Hence, a make recipe using as an argument to $(OBJCOPY):
--pad-to=$(CONFIG_SPL_PAD_TO)
would have issued:
--pad-to="CONFIG_SPL_MAX_SIZE"
which means nothing for $(OBJCOPY) and makes it fail.
Thanks to this change, the config lines above are changed in autoconfig.mk into:
CONFIG_SPL_PAD_TO=$(CONFIG_SPL_MAX_SIZE)
Hence, the make recipe above now issues:
--pad-to=2048
as expected from the defined config.
