2011-10-06ublimage: NAND block size isn't set at build-timeLoïc Minier
mkimage's ublimage support can't depend of build-time board configs; instead, this should be set in ublimage.cfg. Since currently no configs in u-boot override the NAND block size, hardcode it as such in ublimage.h to fix a build failure with "make tools": gcc [...] -o ublimage.o ublimage.c -c In file included from ublimage.c:37:0: ublimage.h:31:20: fatal error: config.h: No such file or directory Cc: Heiko Schocher <hs@denx.de> Cc: patches@linaro.org Signed-off-by: Loïc Minier <loic.minier@linaro.org> Acked-by: Heiko Schocher <hs@denx.de>
2011-10-06Safer timestamp_autogenerated.h generationLoïc Minier
Generate timestamp_autogenerated.h as safely as version_autogenerated.h. Cc: patches@linaro.org Signed-off-by: Loïc Minier <loic.minier@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-06Build timestamp_autogenerated.h without configLoïc Minier
Tools such as mkimage include version information but are config-agnostic; build timestamp_autogenerated.h even when config.mk isn't generated to fix "make tools" build failure: gcc [...] -o mkimage.o mkimage.c -c In file included from include/version.h:27:0, from mkimage.c:26: include/timestamp.h:27:37: fatal error: timestamp_autogenerated.h: No such file or directory Cc: patches@linaro.org Signed-off-by: Loïc Minier <loic.minier@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-06Tell git to ignore asm-offsets.sLaurence Withers
The generated file asm-offsets.s may be found at various depths in the arch subdirectories, so simply ignore it throughout the tree. Signed-off-by: Laurence Withers <lwithers@guralp.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05SPL: Make path to start.S configurableMarek Vasut
Introduce CONFIG_SPL_START_S_PATH to configure path to start.S file. It's not always fitting to use CPU's start.S . Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-10-05cmd_sf: Fix compiler warningKumar Gala
cmd_sf.c: In function 'do_spi_flash': cmd_sf.c:164:9: warning: 'skipped' may be used uninitialized in this function Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Simon Glass <sjg@chromium.org>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05net: drop !NET_MULTI ns7520 driverMike Frysinger
This driver was never converted to NET_MULTI, and no board uses it. So punt it and be done. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05net: drop !NET_MULTI bcm570x/tigon3 driversMike Frysinger
These drivers have never been converted to NET_MULTI, and they are only used by one board (BMW). So drop the drivers until someone feels like rewriting them for NET_MULTI support. Rather than punting the BMW board completely, just disable net support in its board config. Seems to build fine without it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05mkconfig: start deprecating Makefile config targetsMike Frysinger
Now that we've got boards.cfg and most people have converted over, start warning people who have yet to so we can phase board configs completely out of the Makefile. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05MAKEALL: rename coldfire list to m68k to match archMike Frysinger
The m68k tree is the only one where `./MAKEALL <arch>` does not work. So rename the existing coldfire list in the MAKEALL script to m68k, and add an alias from coldfire to m68k. This makes scripting around MAKEALL easier. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05mkimage: Add variable lenght header supportStefano Babic
Some images have not a header of fix lenght. The patch will be used for the generation of AIS images, because this header has a variable lenght. The patch adds also the parameter "-s" (skip) to not copy automatically the passed image file. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-10-05mkimage: ublimage must return if the header is not verifiedStefano Babic
Each image handler must return a not-zero velue if the header is not recognized to allow the main program to iterate to the next handler. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2011-10-05km_arm: enable POST for these boardsValentin Longchamp
The current km_arm boards have a Power-On test jumper. When this jumper is set, this triggers some Power-On tests on the board. This patch enables the support of this jumper for starting the memory_regions test when the jumper is set. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-10-05km_arm: change CONFIG_SYS_TEXT_BASE to end of RAMValentin Longchamp
This allows to test a larger part of the RAM in the memory tests. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Cc: Heiko Schocher <hs@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-10-05POST: add new memory regions testValentin Longchamp
This test is similar to the actual POST memory test but quicker and far less complete. It checks the address and data lines and then only tests some regularly placed sub regions of the RAM. This can be useful when we want to test the RAM but we do not have enough time to run the full memory test. The POST memory test code was rearranged in order to avoid code duplication between the two tests but the memory test functionnality remains the same. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Ackey-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05POST: drivers/memory.c coding style cleanupValentin Longchamp
This is needed for a further patch adding a new memory test. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05POST: make env test flags fetching optionalValentin Longchamp
Some boards have the environment variables defined in a slow EEPROM. post_run accesses these environment variables to define which tests have to be run (in post_get_flags). This is very slow before the code relocation on some boards with a slow I2C EEPROM for environement variables. This patch adds a config option to skip the fetching of the test flags in the environment variables. The test flags assigned to the tests then only are the ones statically defined for the test in post/tests.c. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2011-10-05POST: add post_log_res field for post results in global dataValentin Longchamp
The current post_log_word in global data is currently split into 2x 16 bits: half for the test start, half for the test success. Since we alredy have more than 16 POST tests defined and more could be defined, this may result in an overflow and the post_output_backlog would not work for the tests defined further of these 16 positions. An additional field is added to global data so that we can now support up to 32 (depending of architecture) tests. The post_log_word is only used to record the start of the test and the new field post_log_res for the test success (or failure). The post_output_backlog is for this change also adapted. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-10-05POST: allow redefinition of post_word_load/storeValentin Longchamp
The predefinde post_word_load/store functions do not fit all boards, so we introduce a way to define post_word_load/store as externs in post.h that then can be defined in board specific files. This is done with the CONFIG_POST_EXTERNAL_WORD_FUNCS #define Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2011-10-05POST/arm: adaptations needed for POST on ARM to workValentin Longchamp
For post to run on ARM, 3 things are needed: - post_log_word to be defined in gd - a post.h include in arch/arm/lib/board.c Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped.
2011-10-05Makefile: remove mx31pdk exceptionStefano Babic
An entry in the main Makefile for the mx31pdk board is not necessary, and the board is added to boards.cfg as all other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-10-05Makefile: drop imx31_phycore from general MakefileStefano Babic
2011-10-05Makefile: remove tx25 exceptionStefano Babic
An entry in the main Makefile for the tx25 board is not necessary, and the board is added to boards.cfg as all other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-10-05PPC: Cleanup tqm8xx_pcmcia.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2011-10-05TQM8xx: make room for growing code size due to I/O accessor cleanupWolfgang Denk
Commit "PPC: Cleanup tqm8xx_pcmcia.c" will clean up the PCMCIA code to use I/O accessors instead of plain volatile pointer accesses. This will result in about 300 byte bigger code. Fix custom linker script to make room for this. While we are at it, drop unmaintained u-boot.lds.debug linker script. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de>
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
* 'master' of git://git.denx.de/u-boot-nand-flash: PPC: Fix socrates NAND problem PPC: Fix fsl_upm.c by renaming nand handling functions NAND: Make page, erase, oob size available via cmd_nand mtd: eLBC NAND: remove elbc_fcm_ctrl->oob_poi NAND: Add -y option to nand scrub command NAND: Add nand read.raw and write.raw commands NAND: Really ignore bad blocks when scrubbing spl, nand: add 4bit HW ecc oob first nand_read_page function mxc_nand: fix a problem writing more than 32MB mxc_nand: fixed some typos (cosmetic) nand: increase chip_delay in mv kirkwood nand driver
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/p3060: Add SoC related support for P3060 platform powerpc/85xx: Add support for setting up RAID engine liodns on P5020 powerpc/85xx: Refactor some defines out of corenet_ds.h fm-eth: Add ability for board code to disable a port powerpc/mpc8548: Add workaround for erratum NMG_LBC103 powerpc/mpc8548: Add workaround for erratum NMG_DDR120 powerpc/mpc85xxcds: Fix PCI speed powerpc/mpc8548cds: Fix booting message powerpc/p4080: Add support for secure boot flow powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASH powerpc/85xx: Add PBL & SECUREBOOT support on P3041/P5020DS boards powerpc/p2041rdb: remove watch dog related codes powerpc/p2041rdb: updated description of cpld command powerpc/p2041rdb: add more ddr frequencies support powerpc/p2041rdb: set sysclk according to status of physical switch SW1 powerpc/p2041rdb: update cpld reset command according to CPLD 2.0 powerpc/mpc8349emds: Migrate from spd_sdram to unified DDR driver powerpc/mpc83xx: Migrate from spd_sdram to unified DDR driver powerpc/mpc8xxx: Add DDR2 to unified DDR driver powerpc/mpc8xxx: Fix picos_to_mclk() and get_memory_clk_period_ps() powerpc/mpc8xxx: Add SPD EEPROM address for single controller 2 slots powerpc/mpc8xxx: Fix DDR code for empty first DIMM slot and enable DQS_en powerpc/85xx: Refactor P2041RDB to use common p_corenet files powerpc/85xx: refactor common P-Series CoreNet files for FSL boards powerpc/85xx: Enable CMD_REGINFO on corenet boards powerpc/85xx: p2041rdb - Remove unused 'execute' perm in TLB entries powerpc/85xx: Fix USB protocol definitions for P1020RDB powerpc/corenet_ds: Use separated speed tables for UDIMM and RDIMM powerpc/mpc8xxx: Move DDR RCW overriding to common code powerpc/mpc8xxx: Extend CWL table powerpc/85xx: Cleanup how SVR_MAJ() is defined on MPC8536 powerpc/85xx: Cleanup extern in corenet_ds board code powerpc/p2041rdb: Add ethernet support on P2041RDB board powerpc/85xx: Add networking support to P1023RDS powerpc/hydra: Add ethernet support on P5020/P3041 DS boards powerpc/85xx: Add FMan ethernet support to P4080DS powerpc/85xx: Add support for FMan ethernet in Independent mode powerpc/mpc8548cds: Cleanup mpc8548cds.c powerpc/mp: add support for discontiguous cores powerpc/85xx: corenet_ds - Remove unused 'execute' perm in TLB entries fdt: Add new fdt_create_phandle helper fdt: Rename fdt_create_phandle to fdt_set_phandle powerpc/85xx: Fix compile warnings/errors if CONFIG_SYS_DPAA_FMAN isn't set fsl_ifc: Add the workaround for erratum IFC A-003399(enabled on P1010) powerpc/P1010: Add workaround for erratum P1010-A003549 (related to IFC) fsl_ifc: Add the workaround for erratum IFC-A002769 (enable on P1010) powerpc/85xx: Expanding the window of CCSRBAR in AS=1 from 4k to 1M powerpc/85xx: Add NAND/NAND_SPL support to P1010RDB nand: Freescale Integrated Flash Controller NAND support powerpc/85xx: Add basic support for P1010RDB powerpc/85xx: Add support for new P102x/P2020 RDB style boards powerpc/85xx: relocate CCSR before creating the initial RAM area powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macros powerpc/85xx: Enable internal USB UTMI PHY on p204x/p3041/p50x0 powerpc/85xx: Add ULPI and UTMI USB Phy support for P1010/P1014
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
* 'master' of git://git.denx.de/u-boot-i2c: I2C: mv_i2c: fix multi-bus init issue I2C: mv_i2c: fix build issue when enable debug option
2011-10-04Merge branch 'emaclite' of git://git.denx.de/u-boot-microblazeWolfgang Denk
* 'emaclite' of git://git.denx.de/u-boot-microblaze: net: emaclite: Use dynamic allocation net: emaclite: Remove baseaddress from xemaclite net: emaclite: Use calloc instead of malloc net: emaclite: Remove deviceid property net: emaclite: Change driver name and add address
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-microblazeWolfgang Denk
* 'master' of git://git.denx.de/u-boot-microblaze: microblaze: Enable FDT/FIT support microblaze: Remove address offset for uart16550 microblaze: Do not select NFS for platforms without ethernet microblaze: Clean up reset asm code microblaze: Save and restore first unused vector microblaze: Setup MB vectors if feature is enable for u-boot microblaze: Remove debug saving value
2011-10-04Revert "GCC4.6: Convert various empty macros to inline functions"Wolfgang Denk
This reverts commit 60ce53cf9f408d9ad721f8e7a87d6a564e6d5bac. The commit causes build breakage for a number of boards. This results from the fact that now the arguments of debug() actually get referenced (even if there is hope that the compiler will optimize away the debug() call). The obvious fix to that probem (change the code to always declare the referenced variables and data structures) increases the code size, and was this rejected. So it was decided to revert this commit until a better solution is found.
2011-10-03PPC: Fix socrates NAND problemMarek Vasut
nand.c:36: error: static declaration of 'nand_read_buf' follows non-static declaration /home/marex/u-boot/include/nand.h:139: error: previous declaration of 'nand_read_buf' was here Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03PPC: Fix fsl_upm.c by renaming nand handling functionsMarek Vasut
This avoids colision with nand subsystem's functions. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03NAND: Make page, erase, oob size available via cmd_nandMarek Vasut
The "nand info" and "nand device" now set shell/environment variables: nand_writesize ... nand page size nand_oobsize ..... nand oob area size nand_erasesize ... nand erase block size Also, the "nand info" command now displays this info. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> [scottwood@freescale.com: removed unnecessary memsets] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03mtd: eLBC NAND: remove elbc_fcm_ctrl->oob_poimhench
The eLBC NAND driver currently follows up each program/write operation with a read-back of the page, in order to [ostensibly] fill in ECC data for the caller. However, the page address used for this read is always -1, so the read will never work correctly. Remove this useless (and potentially problematic) block of code. v2: fix broken mailer Signed-off-by: mhench <mhench@elutions.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03NAND: Add -y option to nand scrub commandMarek Vasut
This allows the scrub command to scrub without asking the user if he really wants to scrub the area. Useful in scripts. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03NAND: Add nand read.raw and write.raw commandsMarek Vasut
These commands should work around various "hardware" ECC and BCH methods. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> [scottwood@freescale.com: s/write the page/access the page/] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03NAND: Really ignore bad blocks when scrubbingMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> [scottwood@freescale.com: use chip instead of redundant priv_nand] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03spl, nand: add 4bit HW ecc oob first nand_read_page functionHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03mxc_nand: fix a problem writing more than 32MBHelmut Raiger
When writing 0x4000 to the unlockend_blkaddr register, large writes to a 2k page NAND sometimes fail. The current kernel driver writes 0xFFFF to this register for V2 of the nand controller. However on an i.MX31 this also fixes writes larger than 32MB. The datasheet is very unspecific, but (0x4000=16384)*2000 roughly fits the limits we're encountering with NAND writes. This problem might be NAND chip specific. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03mxc_nand: fixed some typos (cosmetic)Helmut Raiger
2011-10-03nand: increase chip_delay in mv kirkwood nand driverStefan Bigler
The new SAMSUNG NAND Flash K9F1G08U0D require a bigger chip_delay. The Data Transfer from Cell to Register is >= 35us. Other Vendors and older chips normally use >= 25us. To have enough margin 40us is selected. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Stefan Roese <sr@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03powerpc/p3060: Add SoC related support for P3060 platformShengzhou Liu
Add P3060 SoC specific information:cores setup, LIODN setup, etc The P3060 SoC combines six e500mc Power Architecture processor cores with high-performance datapath acceleration architecture(DPAA), CoreNet fabric infrastructure, as well as network and peripheral interfaces. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03powerpc/85xx: Add support for setting up RAID engine liodns on P5020Kumar Gala
Add support for Job Queue/Ring LIODN for the RAID Engine on P5020. Each Job Queue/Ring combo needs one id assigned for a total of 4 (2 JQs/2 Rings per JQ). This just handles RAID Engine in non-DPAA mode. Signed-off-by: Santosh Shukla <santosh.shukla@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03powerpc/85xx: Refactor some defines out of corenet_ds.hKumar Gala
Move some SoC/board specific defines out of corenet_ds.h and into the corresponding P3041DS/P4080DS/P5020.h. We moved CONFIG_MMC, CONFIG_PCIE3, & CONFIG_FSL_NGPIXIS because the P3060 SoC/reference board does not have these devices and it will share the same board code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03fm-eth: Add ability for board code to disable a portKumar Gala
The SoC configuration may have more ports enabled than a given board actually can utilize. Add a routinue that allows the board code to disable a port that it knows isn't being used. fm_disable_port() needs to be called before cpu_eth_init(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
