All in-tree boards that use this controller have CONFIG_NET_MULTI
added
Also:
- changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111
- cleaned up line lengths
- modified all boards that override weak function in this driver
- modified all eeprom standalone apps to work with new driver
- updated blackfin standalone EEPROM app after testing
following build warning was observed
mv88e61xx.c: In function ‘mv88e61xx_busychk’:
mv88e61xx.c:208: warning: dereferencing type-punned pointer will break strict-aliasing rules
This patch fixes the same
Patch tested for rd6281a board build
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
On 405EZ the RX-/TX-interrupts are coalesced into one IRQ bit in the
UIC. We need to acknowledge the RX-/TX-interrupts in the
SDR0_ICINTSTAT reg as well.
This problem was introduced with commit
d1631fe1 [ppc4xx: Consolidate PPC4xx UIC defines]
Signed-off-by: James Clough <james@rtetc.com>
The random_port() is meant to be used by other net code, but without a
prototype, we get fun warnings like:
dns.c: In function 'DnsSend':
dns.c:89: warning: implicit declaration of function 'random_port'
This patch adds support to detect the amount of DDR2 SDRAM
on PMC440 modules. Detection is done by probing through
a list of available and supported hardware configurations
from 1GByte down to 256MB.
The static TLB entry is replaced by dynamically created entries.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch merges the ECC handling (ECC parity byte writing) into one
file (ecc.c) for all PPC4xx SDRAM controllers except for PPC440EPx/GRx.
This exception is because only those PPC's use the completely different
Denali SDRAM controller core.
Previously we had two routines to generate/write the ECC parity bytes.
With this patch we now only have one core function left.
Tested on Kilauea (no ECC) and Katmai (with and without ECC).
Cc: Felix Radensky <felix@embedded-sol.com>
Cc: Grant Erickson <gerickson@nuovations.com>
Cc: Pieter Voorthuijsen <pv@prodrive.nl>
Reorganize DDR2 ECC handling to use common code for
SPD DIMMs and soldered SDRAM. Also, use common code
to display SDRAM info (ECC, CAS latency) for SPD and
soldered SDRAM variants.
Signed-off-by: Felix Radensky <felix@embedded-sol.com>
The Linux kernel has changed the way it numbers serial ports, so update
the default command line to match it.
The u-boot image has outgrown the current space and overflowed into the
env sector. So move the env to the next available sector (we've already
allocated the first few sectors anyways for u-boot).
Don't include get_law_entry as part of the NAND_SPL build since the
code isnt used.
Add boot from NAND/eSDHC/eSPI description
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
The MPC8536E is capable of booting from the on-chip ROM - boot from
eSDHC and boot from eSPI. When power on, the porcessor excutes the
ROM code to initialize the eSPI/eSDHC controller, and loads the mian
U-Boot image from the memory device that interfaced to the controller,
such as the SDCard or SPI EEPROM, to the target memory, e.g. SDRAM or
L2SRAM, then boot from it.
The memory device should contain a specific data structure with control
word and config word at the fixed address. The config word direct the
process how to config the memory device, and the control word direct
the processor where to find the image on the memory device, or where
copy the main image to. The user can use any method to store the data
structure to the memory device, only if store it on the assigned address.
The on-chip ROM code will map the whole 4GB address space by setting
entry0 in the TLB1, so the main image need to switch to Address space 1
to disable this mapping and map the address space again.
This patch implements loading the mian U-Boot image into L2SRAM, so
the image can configure the system memory by using SPD EEPROM.
MPC8536E can support booting from NAND flash which uses the
image u-boot-nand.bin. This image contains two parts: a 4K
NAND loader and a main U-Boot image. The former is appended
to the latter to produce u-boot-nand.bin. The 4K NAND loader
includes the corresponding nand_spl directory, along with the
code twisted by CONFIG_NAND_SPL. The main U-Boot image just
like a general U-Boot image except the parts that included by
CONFIG_SYS_RAMBOOT.
When power on, eLBC will automatically load from bank 0 the
4K NAND loader into the FCM buffer RAM where CPU can execute
the boot code directly. In the first stage, the NAND loader
copies itself to RAM or L2SRAM to free up the FCM buffer RAM,
then loads the main image from NAND flash to RAM or L2SRAM
and boot from it.
This patch implements the NAND loader to load the main image
into L2SRAM, so the main image can configure the RAM by using
SPD EEPROM. In the first stage, the NAND loader copies itself
to the second to last 4K address space, and uses the last 4K
address space as the initial RAM for stack.
Obviously, the size of L2SRAM shouldn't be less than the size
of the image used. If so, the workaround is to generate another
image that includes the code to configure the RAM by SPD and
load it to L2SRAM first, then relocate the main image to RAM
to boot up.
By nature of being based off the MPC8548CDS board, this
board inherited an ENV_SIZE setting of 256k. But since
it has a smaller flash device (8MB soldered on), it has
a native sector size of 128k, and hence the ENV_SIZE was
causing 2 sectors to be used for the environment.
By removing the unused sector, we can push TEXT_BASE up
closer to the end of address space and reclaim that
sector for any other application. This also fixes the
mismatch between TEXT_BASE and MONITOR_LEN reported by
Kumar earlier.
Since this board also supports the ability to boot off
the 64MB SODIMM flash, this change is forward looking
with that in mind; i.e. the settings for MONITOR_LEN
and ENV_SIZE will work when the 512k sectors of the
SODIMM flash are used for alternate boot in the future.
* Converted all white space to tabs
* Converted all types to u8/u16/u32
* Reduce lines to fit in 80 columns
* Renamed MPC85xx_{Q,B}MAN -> FSL_CORENET_{Q,B}MAN
I accidentally left v2 of "NAND: DaVinci:Adding 4 BIT ECC support"
applied when I pushed the tree last merge window, and missed these fixes
which were in v3 of that patch.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Refactoring the OneNAND IPL code
and some minor fixed:
- Remove unnecessary header file
- Fix wrong access at read interrupt
- The recent OneNAND has 4KiB pagesize
Also Board can override OneNAND IPL image
The commit ecad289fc6bd9d89ef4d5093cc7b6fd712fd0d29 (OneNAND: Remove
unused read_spareram and add unlock_all as kernel does) forgot to remove
a local reference to read_spareram in board/micronas/vct/ebi_onenand.c,
which causes the following build failure when configured with OneNAND:
ebi_onenand.c: In function 'onenand_board_init':
ebi_onenand.c:196: error: 'struct onenand_chip' has no member named 'read_spareram'
make[1]: *** [ebi_onenand.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make: *** [board/micronas/vct/libvct.a] Error 2
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Files in directories which are symlinked to were not dereferenced
correctly in last commit. E.g., with a symlink
/boot/lnk -> /boot/real_dir
loading
/boot/lnk/uImage
will fail. This patch fixes that by simply seeing to it that the target
base directory has a slash after it.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Additionally some whitespace coding style fixes.
The latest PPC4xx register cleanup patch missed some SDRAM defines.
This patch now changes lower case UIC defines to upper case. Also
some names are changed to match the naming in the IBM/AMCC users
manuals (e.g. mem_mcopt1 -> SDRAM0_CFG).
The latest PPC4xx register cleanup patch missed the UIC defines.
__i2c_read always ends with a STOP condition thereby releasing
the bus. It is cleaner to do the STOP magic in i2c_read(), like
i2c_write() does. This may also help future multimaster systems which
wants to hold on to the bus until all transactions are finished.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
The latest AN2919 has changed the way FDR/DFSR should be calculated.
Update the driver according to spec. However, Condition 2
is not accounted for as it is not clear how to do so.
Acked-by: Wolfgang Grandegger <wg@grandegger.com>
Some boards need a higher DFSR value than the spec currently
recommends so give these boards the means to define there own.
For completeness, add CONFIG_FSL_I2C_CUSTOM_FDR too.
After issuing a STOP one must wait until the STOP has completed
on the bus before doing something new to the controller.
Also add an extra read of SR as the manual mentions doing that
is a good idea.
Remove surplus write of CR just before a write, isn't required and
could potentially disturb the I2C bus.
some LCRR bits are not documented throughout the 83xx family RMs.
New board porters copying similar board configurations might omit
setting e.g., DBYP since it was not documented in their SoC's RM.
Prevent them bricking their board by retaining power on reset values
in bit fields that the board porter doesn't explicitly configure
via CONFIG_SYS_<registername>_<bitfield> assignments in the board
config file.
also move LCRR assignment to cpu_init_r[am] to help ensure no
transactions are being executed via the local bus while CLKDIV is being
modified.
also start to use i/o accessors.
Commit 804d83a5 allows us to move all the configuration
variation tweaks out of the top level Makefile and down
into the board config header. This takes advantage of
that for the sbc8349 board.
With this patch we can change QE USB mode without need to hand-edit
the device tree.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This patch fixes various ethernet issues with gigabit links handling
in U-Boot. The workarounds originally implemented by Kim Phillips for
Linux kernel.
Since commit 5c2ff323a94e27e481f70c44838d43fcd844dd46 ("mpc8360emds:
rework LBC SDRAM setup"), LBC SDRAM is available for use in Linux.
Though, it appears that QE Ethernet in Gigabit mode can't transmit
large packets when it tries to work with a data in LBC SDRAM (memtest
didn't discover any issues, is LBC SDRAM just too slow?).
With this patch we can still use the board without DDR memory, but
if DDR is available, we don't use LBC SDRAM.
Headers should include headers containing prototypes and defines they
depend on, don't assume that they're included by somebody else.
This will be needed for MPC8360E-MDS boards with rev. 2.1 CPUs.
Commit 4abd844d8e extended the fdt command parser to handle property
strings which are split across multiple arguments but it was broken for
byte streams and strings.
Byte stream parsing:
* Fixes where it would terminate early or go into an endless loop.
* Fixes a 0x00 being inserted into the data if there is a space after
'[' or a separate argument.
* Fixes dereferencing the argument pointer after the last argument.
* Checks for bad characters.
String parsing:
* Treat multiple arguments as a string list. This fixes an issue where
only the last argument was stored.
Signed-off-by: Ken MacLeod <ken@bitsko.slc.ut.us>
U-Boot can detect if an IDE device is present or not.
If not, and this new config option is activated, U-Boot
removes the ATA node from the DTS before booting Linux,
so the Linux IDE driver does not probe the device and
crash. This is needed for buggy hardware (uc101) where
no pull down resistor is connected to the signal IDE5V_DD7.
- As these boards are similiar, collect common config options
in manroland/common.h and manroland/mpc52xx-common.h
for mpc5200 specific common options for this manufacturer.
- add OF support
- update default environment
Minor edit of commit message.
Commit 002741ae86 modified include/asm-ppc/mmu.h such that the LAWAR_
defines were only enabled for the 83xx platform, but they are also
needed on MPC512x system. Enabling these for E300 systems seems thus
more appropriate.
Signed-off-by: Martha M Stan <mmarx@silicontkx.com>
Minor coding style cleanup.
Minor cleanup:
Re-ordered default_mddrc_config[] to have matching indices.
This allows to use the same index "N" for source and target fields;
before, we had code like this
out_be32(&im->mddrc.ddr_time_config2, mddrc_config[3]);
which always looked like a copy & paste error because 2 != 3.
Also, use NULL when meaning a null pointer.
