This change is needed for mgcoge because it uses two ethernet drivers.
Add a check for the presence of the PIGGY board on mgcoge. Without this
board networking cannot work and the initialization must be aborted.
Only allocate rtx once to prevent DPRAM exhaustion.
Initialize ether_scc.c and the keymile-specific HDLC driver (to be added
soon) in eth.c.
Signed-off-by: Gary Jennejohn <garyj@denx.de>
sh_eth used old network API. This patch changed new API.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
This patch changes the reg_read/_write to smc911x_reg_read/_write
and defines then as weak so that they can be overridden by board
specific version.
This will be used by the upcoming VCTH board support.
Some images can be quite large, so add an option to compress the
image data with gzip in the U-Boot image. Then at runtime, the
board can decompress it with the normal zlib functions.
A couple of buffers in the fat code are declared as an array of bytes.
But it is then cast up to a structure with 16bit and 32bit members.
Since GCC assumes structure alignment here, we have to force the
buffers to be aligned according to the structure usage.
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
Higher spi flash layers expect to be given back a pointer that was
malloced so that it can free the result, but the lower layers return
a pointer that is in the middle of the malloced memory. Reorder the
members of the lower spi structures so that things work out.
Signed-off-by: Brad Bozarth <bflinux@yumbrad.com>
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
When compile u-boot with the 2.18 binutils the following
warning messages for each object file in post/lib_ppc/fpu/ is
produced at the linking stage:
post/libpost.a(acc1.o) uses hard float, u-boot uses soft-float
This is because of the fact that, in general, the soft-float and
hard-float ABIs are incompatible; the 2.18 binutils do checking
of the Tag_GNU_Power_ABI_FP attribute of the files to be linked, and
produce the worning like above if these are not compatible.
The incompatibility of ABIs is concerned only the float values:
e.g. the soft-float ABI assumes the float argument passing in the
pair of rX registers, and the hard-float ABI assumes passing of
the float argument in the fX register. When we don't pass the float
arguments between the functions compiled with different floatness,
then such an application will work correctly.
This is the case for the FPU POST: u-boot (compiled with soft-float)
doesn't pass to (and doesn't get from) the FPU POST functions any
floats; there are no functions exported from the post/lib_ppc/fpu/
objects which would work with float parameters/returns too. So, we
can reassure the linker not to worry about the difference in ABI
attributes of linking files just by setting the 'soft-float'
attribute for the objects in post/lib_ppc/fpu. And this patch does
this.
Also, to avoid passing both soft- and hard-float options in CFLAGS
when compiling the files from post/lib_ppc/fpu (which is OK, but
looks rather dirty) this patch removes the soft-float string from
CFLAGS in post/lib_ppc/fpu/Makefile.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Initial support for the DS4510, a CPU supervisor with
integrated EEPROM, SRAM, and 4 programmable non-volatile
GPIO pins. The CONFIG_DS4510 define enables support
for the device while the CONFIG_CMD_DS4510 define
enables the ds4510 command. The additional
CONFIG_DS4510_INFO, CONFIG_DS4510_MEM, and
CONFIG_DS4510_RST defines add additional sub-commands
to the ds4510 command when defined.
The iteration limit is passed to mtest as a fourth parameter:
[start [end [pattern [iterations]]]]
If no fourth parameter is supplied, there is no iteration limit and the
test will loop forever.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Moved driver vcth.c to vct.c to better reflect the VCT board series.
This driver is now used by the VCT platforms:
vct_premium
vct_platinum
vct_platinumsvc
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Support bootdelay=0 in abortboot for the CONFIG_AUTOBOOT_KEYED case
similar to the CONFIG_ZERO_BOOTDELAY_CHECK support for the
!CONFIG_AUTOBOOT_KEYED case.
Do this by reversing the loop so we do at least one iteration before
checking for timeout.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Generic i386 reset - #define made redundant by weak function
CONFIG_SC520 is now used for conditional compile
Reset function specific to AMD SC520 microcontroller - Is more of a
'hard reset' that the triple fault.
Requires CONFIG_SYS_RESET_SC520 to be defined in config
I would have liked to add this to a new file (cpu/i386/sc520/reset.c)
but ld requires that a object file in a library arhive MUST contain
at least one function which does not override a weak function (and is
called from outside the object file) in order for that object file to
be extracted from the archive. This would be the only function on the
new file, and hence, will never get linked in.
Moved from interrupts.c to cpu.c and made into a weak function to
allow vendor specific override
Vendor specific CPU reset (like the AMD SC520 MMCR reset) can now be
added to the vendor specific code without the need to remember to
#undef usage of the generic method and if you forget to include your
custom reset method, you will always get the default.
This allows for future tidy ups and functionality that will require
set_vector ()
Brings i386 in line with other CPUs with a reset vector and frees up reset.c
for CPU reset functions
Right now this is only used by keymile.
This patch extracts the identical config options for the
keymile boards mgcoge, mgsuvd and kmeter1 in a new
common config file keymile-common.h.
Check the presence of the PIGGY on the keymile boards mgcoge,
mgsuvd and kmeter1. If the PIGGY is not present, dont register
this Ethernet device.
Acked-by: Ben Warren <biggerbadderben@gmail.com>
This patch adds support for the kmeter1 board from Keymile,
based on a Freescale MPC8360 CPU.
- serial console on UART 1
- 256 MB DDR2 RAM
- 64 MB NOR Flash
- Ethernet RMII Mode over UCC4
- PHY SMSC LAN8700
Add a do_div() wrapper, lldiv(). The new inline function doesn't modify
the dividend and returns the result of division, so it is useful
in complex expressions, i.e. "return(a/b)" -> "return(lldiv(a,b))"
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
We move all IO addressed (CCSR, localbus, PCI) above the 4G boundary
to allow for larger memory sizes.
The eLBC only handles 32-bit physical address in systems with 36-bit
physical. The previos generation of LBC handled 34-bit physical
address in 36-bit systems. Added a new CONFIG option to convey
the difference between the LBC and eLBC.
Also added defines for XAM bits used in LBC for the extended 34-bit
support.
Use the new BR_ADDR macro to properly setup the address field of the
localbus chipselects used by NAND.
This allows us to deal with 36-bit phys on these boards in the future.
This patch updates e500 freqProcessor to array based on CONFIG_NUM_CPUS,
and prints each CPU's frequency separately. It also fixes up each CPU's
frequency in "clock-frequency" of fdt blob.
Signed-off-by: James Yang <James.Yang@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
The wake up ARP feature need use the memory to process
wake up packet, we enable auto self refresh to support it.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
For light loaded system, we use the 1T timing to gain better
memory performance, but for some heavily loaded system,
you have to add the 2T timing options to board files.
Some 85xx processors have the advanced power management feature,
such as wake up ARP, that needs enable the automatic self refresh.
If the DDR controller pass the SR_IT (self refresh idle threshold)
idle cycles, it will automatically enter self refresh. However,
anytime one transaction is issued to the DDR controller, it will
reset the counter and exit self refresh state.
- The DDR3 controller is expanding the bits for timing config
- Add the DDR3 32-bit bus mode support
According to the latest 8572 UM, the DDR3 controller
is expanding the bit mask, and we use the extend ACTTOPRE
mode when tRAS more than 19 MCLK.
Introduce a new define to seperate out the virtual address that PCI
IO space is at from the physical address. In most situations these are
mapped 1:1. However any code accessing the bus should use VIRT.
memory is at from the physical address. In most situations these are
Use the _MEM_PHYS defines instead of _MEM_BUS for LAW and real address fields
of TLBs. This is what we should have always been using from the start.
Use CONFIG_SYS_PCI*_IO_BUS for the bus relative address instead
of _IO_BASE so we are more explicit.
Use CONFIG_SYS_{PCI,RIO}_MEM_BUS for the bus relative address instead
of _MEM_BASE so we are more explicit.
Added a CONFIG_SYS_FLASH_BASE_PHYS for use as the physical address and
maintain CONFIG_SYS_FLASH_BASE as the virtual address of the flash.
Added a PIXIS_BASE_PHYS for use as the physical address and maintain
PIXIS_BASE as the virtual address of the PIXIS fpga registers.
