In a714321 we add a check at the end of findfdt to make sure we have
updated it from undefined and if not, warn the user. This however
forgot a ';' on the end of the previous last test.
Fix:
misc.c: In function 'misc_init_r':
misc.c:210:3: warning: dereferencing type-punned pointer will break
strict-aliasing rules [-Wstrict-aliasing]
misc.c:211:3: warning: dereferencing type-punned pointer will break
misc.c:212:3: warning: dereferencing type-punned pointer will break
Update inp_clk, vco_clk and flb_clk for mcf5441x as those
items were moved to arch_global_data.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
SDRAMC_DARCn_BA() macro worked fine when the BA is 0x00000000 even
though the macro is incorrect. It causes the BA to be set incorrctly
for other base addresses. This patch fixes the macro so that base
addresses other than zero can be used with the MCF5235.
Signed-off-by: Steve deRosier <derosier@gmail.com>
There is a debug call in board.c befor serial interface was initialized.
This moves the debug code behind serial_initialize call.
Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Align the list of default commands mentioned in the configuration options
paragraph of the README with the actual definitions found in
include/config_cmd_default.h
Signed-off-by: Vincent Stehlé <vincent.stehle@freescale.com>
With CONFIG_SYS_64BIT_LBA, lbaint_t gets defined as a 64-bit type,
which is required to represent block numbers for storage devices that
exceed 2TiB (the block size usually is 512B), e.g. recent hard drives.
For some obscure reason, the current U-Boot code uses lbaint_t for the
number of blocks to read (a rather optimistic estimation of how RAM
sizes will evolve), but not for the starting address. Trying to access
blocks beyond the 2TiB boundary will simply wrap around and read a
block within the 0..2TiB range.
We now use lbaint_t for block start addresses, too. This required
changes to all block drivers as the signature of block_read(),
block_write() and block_erase() in block_dev_desc_t changed.
Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de>
This patch introduces support for command line arguments to Plan 9.
Plan 9 generally dedicates a small region of kernel memory (known
as CONFADDR) for runtime configuration. A new environment variable
named confaddr was introduced to indicate this location when copying
arguments.
Signed-off-by: Steven Stallion <sstallion@gmail.com>
[trini: Adapt for Simon's changes about correcting argc, no need to bump
by 2 now]
Add a description of how to implement verified boot using signed FIT images,
and a simple test which verifies operation on sandbox.
The test signs a FIT image and verifies it, then signs a FIT configuration
and verifies it. Then it corrupts the signature to check that this is
detected.
We want to sign and verify images using sandbox, so enable these options.
While signing images is useful, it does not provide complete protection
against several types of attack. For example, it it possible to create a
FIT with the same signed images, but with the configuration changed such
that a different one is selected (mix and match attack). It is also possible
to substitute a signed image from an older FIT version into a newer FIT
(roll-back attack).
Add support for signing of FIT configurations using the libfdt's region
support.
Please see doc/uImage.FIT/signature.txt for more information.
Add a function to find regions in device tree given a list of nodes to
include and properties to exclude.
See the header file for full documentation.
Normally, multiple public keys can be provided and U-Boot is not
required to use all of them for verification. This is because some
images may not be signed, or may be optionally signed.
But we still need a mechanism to determine when a key must be used.
This feature cannot be implemented in the FIT itself, since anyone
could change it to mark a key as optional. The requirement for
key verification must go in with the public keys, in a place that
is protected from modification.
Add a -r option which tells mkimage to mark all keys that it uses
for signing as 'required'.
If some keys are optional and some are required, run mkimage several
times (perhaps with different key directories if some keys are very
secret) using the -F flag to update an existing FIT.
When signing an image, it is useful to add some details about which tool
or person is authorising the signing. Add a comment field which can take
care of miscellaneous requirements.
When signing images it is sometimes necessary to sign with different keys
at different times, or make the signer entirely separate from the FIT
creation to avoid needing the private keys to be publicly available in
the system.
Add a -F option so that key signing can be a separate step, and possibly
done multiple times as different keys are avaiable.
FIT image verification requires public keys. Add a convenient option to
mkimage to write the public keys to an FDT blob when it uses then for
signing an image. This allows us to use:
mkimage -f test.its -K dest.dtb -k keys test.fit
and have the signatures written to test.fit and the corresponding public
keys written to dest.dtb. Then dest.dtb can be used as the control FDT
for U-Boot (CONFIG_OF_CONTROL), thus providing U-Boot with access to the
public keys it needs.
Keys required for signing images will be in a specific directory. Add a
-k option to specify that directory.
Also update the mkimage man page with this information and a clearer list
of available commands.
Reviewed-by: Marek Vasut <marex@denx.de> (v1)
RSA provides a public key encryption facility which is ideal for image
signing and verification.
Images are signed using a private key by mkimage. Then at run-time, the
images are verified using a private key.
This implementation uses openssl for the host part (mkimage). To avoid
bringing large libraries into the U-Boot binary, the RSA public key
is encoded using a simple numeric representation in the device tree.
Add support for signing images using a new signature node. The process
is handled by fdt_add_verification_data() which now takes parameters to
provide the keys and related information.
Add a structure to describe an algorithm which can sign and (later) verify
images.
Add configs to enable tracing when it is needed.
Some changes are needed to x86 timer functions to support tracing. Add
these so that the feature works correctly.
Add tracing to Exynos5 boards, so that tracing can be enabled when building
with 'make FTRACE=1'. We use a 16MB trace buffer.
For tracing to work it has to be able to access the microsecond timer
without causing a recursive call to the function entry/exit handlers.
Add attributes to the relevant functions to support this.
Implement this feature on ARM for tracing.
It would be nice to have generic bootm support so that it is easily
implemented on any arch.
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
For tracing it is useful to run as much of U-Boot as possible so as to get
a complete picture. Quite a bit of work happens in bootm, and we don't want
to have to stop tracing before bootm starts.
Add a way of doing a 'fake' boot of the OS - which does everything up to
the point where U-Boot is about to jump to the OS image. This allows
tracing to record right until the end.
This requires arch support to work.
At present the bootm code is mostly duplicated for the plain 'bootm'
command and its sub-command variant. This makes the code harder to
maintain and means that changes must be made to several places.
Introduce do_bootm_states() which performs selected portions of the bootm
work, so that both plain 'bootm' and 'bootm <sub_command>' can use the
same code.
Additional duplication exists in bootz, so tidy that up as well. This
is not intended to change behaviour, apart from minor fixes where the
previously-duplicated code missed some chunks of code.
At present the arguments to bootm are processed in a somewhat confusing
way. Sub-functions must know how many arguments their calling functions
have processed, and the OS boot function must also have this information.
Also it isn't obvious that 'bootm' and 'bootm start' provide arguments in
the same way.
Adjust the code so that arguments are removed from the list before calling
a sub-function. This means that all functions can know that argv[0] is the
first argument of which they need to take notice.
It is difficult to automatically test tracing on most architectures, but
with sandbox it is easy enough to do a simple sanity check.
Support tracing on sandbox by adding suitable CONFIG options. To enable it,
compile U-Boot with FTRACE=1.
The timer functions are marked to skip tracing, since these are called from
the tracing code itself, and we want to avoid an infinite loop.
This tool provides the facility to decode U-Boot trace data and write out
a text file in Linux ftrace format for use with pytimechart.
Add hooks for tracing to generic board, including:
- allow early tracing to start early as possible in U-Boot
- reserve memory for trace buffer
- copy early trace buffer to main trace buffer after relocation
- setup full tracing support after relocation
Use -finstrument-functions when tracing is enabled (make FTRACE=1).
Tracing is not currently supported by SPL even if sufficient memory is
available.
When tracing is enabled, we #define FTRACE. This can be used by
board config files to conditionally enable the tracing options.
Add a trace command with sub-commands to start/stop tracing, print out
statistics and dump trace information to memory for later upload to a host.
Add a library which supports tracing of execution using built-in gcc
features and a microsecond timer. This can be used to record a list of
function which are executed, along with a timestamp for each. Later
this information can be sent to the host for processing.
Move bootstage's numbering printing code into a generic place so that it can
be used by tracing also.
The unstash code is a bit loose with its printf() types, which gives
warnings on sandbox. Correct this.
When this test fails it is useful to see the output from U-Boot. Add
printing of this information on failure.
For some reason this does not normally cause a compiler warning, but the code
seems to be incorrect. Add the missing return.
Enabling FIT produces a compile error. Fix this.
I am not sure of the meaning of extern inline, but this gives errors
when building with function instrumenting enabled. Change these functions
to static inline.
This patch initiates cros-ec in board_init() to enable it for smdk5250.
This patch depends on the patch in the MMC series that brings in exynos5-dt.c.
Refer to http://patchwork.ozlabs.org/patch/240084.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Signed-off-by: Hung-ying Tyan <tyanh@chromium.org>
This patch adds cros-ec related device nodes to exynos5250-snow.dts.
It also adds a gpio node to exynos5250.dtsi.
This patch adds the driver for keyboard that's controlled by ChromeOS EC.
Signed-off-by: Randall Spangler <rspangler@chromium.org>
This patch adds LPC support for carrying out the cros_ec protocol.
