2016-10-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-10-08ARM: AM437X: Add Silicon ID supportLokesh Vutla
Add silicon ID code for AM437x silicon. This can be used to print the cpu info using CONFIG_DISPLAY_CPUINFO. Also printing "CPU :" along with cpu name in order to be consistent with other OMAP platforms. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-10-08spl: saveenv: adding saveenv support in SPLB, Ravi
By default saveenv option is not supported for SPL. This patch enable the support for save environment variable for SPL build. Enable save environment support in SPL after setenv. By default the saveenv option is not provided in SPL, but some boards need this support in 'Falcon' boot, where SPL need to boot from different images based on environment variable set by OS. For example OS may set "reboot_image" environment variable to "recovery" inorder to boot recovery image by SPL. The SPL read "reboot_image" and act accordingly and change the reboot_image to default mode using setenv and save the environemnt. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Simon Glass <sig@chromium.org> change in v1: - dropped SUPPORT, use CONFIG_SPL_SAVEENV - updates the comments in mmc_private.h
2016-10-08cros_ec: Honor the google,remote-bus dt propertyMoritz Fischer
Boards where ECs that use a I2C port != 0 specify this in the devicetree file via the google,remote-bus property. Previously this was ignored and hardcoded to port 0. Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de> Cc: u-boot@lists.denx.de Acked-by: Simon Glass <sjg@chromium.org>
2016-10-08board: ti: dra7xx: complex definitions should be protected with parenthesesMugunthan V N
As a standard practice complex definitions should be protected with parentheses, as it might fail when used in a complex if statements. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-08ARM: dts: dra72: add rev C evm supportMugunthan V N
Add DTS support for dra72 evm Rev C which has the following changes * Two ethernet ports now instead of the single one in rev B. * DP83867 ethernet phy instead of DP838865. Cc: Vignesh R <vigneshr@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-08arm: Add return value argument to longjmpAlexander Graf
The normal longjmp command allows for a caller to pass the return value of the setjmp() invocation. This patch adds that semantic to the arm implementation of it and adjusts the efi_loader call respectively. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-08env: tool: add command line option to input lockfile pathB, Ravi
The default lockname is set to /var/lock. This limits the usage of this application where OS uses different lockfile location parameter. For example, In case of android, the default lock path location is /data. Hence by providing the command line option to input lockfile path will be useful to reuse the tool across multiple operating system. usage: ./fw_printenv -l <lockfile path> Signed-off-by: Ravi Babu <ravibabu@ti.com>
2016-10-08dra7x: dfu: qspi: increase the qspi spl partition to 256KB, Ravi
The SPL size for dra7x platform increased beyond 64K, increasing the size to 256K to cater for future enhancement. Signed-off-by: Ravi Babu <ravibabu@ti.com>
2016-10-08dra7xx: config: cleanup: moved to kconfig for CONFIG_SPL_ENV_SUPPORTB, Ravi
removing CONFIG_SPL_ENV_SUPPORT defined in header files due to moved to kconfig option for CONFIG_SPL_ENV_SUPPORT Signed-off-by: Ravi Babu <ravibabu@ti.com>
2016-10-08Revert "ns16650: Make sure we have CONFIG_CLK set before using infrastructure"Masahiro Yamada
This reverts commit 82f5279b0cd99a9163d34cfe926d0316d9dc0d37. The build failure of k2*evm boards was fixed in a different way by the previous commit. It is nasty to patch generic drivers around with #ifdef CONFIG_CLK just for the KeyStone's matter. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-08ARM: keystone: rename clk_get_rate() to ks_clk_get_rate()Masahiro Yamada
The KeyStone platform has its own clk_get_rate() but its prototype is different from that of the common-clk (clk-uclass) framework. Prefix the KeyStone specific implementation with ks_ in order to avoid name-space conflict. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-07board: ge: bx50v3: Pass video bootargs for b850v3Ken Lin
Due to clock source restrictions on i.MX6, certain pixel clock rates can not be supported. Hence default the resolution/frame rate during boot to a supported value by passing video bootargs 1024x768@60 for HDMI (Display Port1) and LVDS (Display Port2) on B850v3. Signed-off-by: Ken Lin <ken.lin@advantech.com.tw> Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
2016-10-07ARM: keystone: remove declaration of unused functionsMasahiro Yamada
These two functions are neither defined nor referenced. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-07kbuild: generate u-boot.cfg as a byproduct of include/autoconf.mkMasahiro Yamada
Our build system still parses ad-hoc CONFIG options in header files and generates include/autoconf.mk so that Makefiles can reference them. This gimmick was introduced in the pre-Kconfig days and will be kept until Kconfig migration is completed. The include/autoconf.mk is generated like follows: [1] Preprocess include/common.h with -DDO_DEPS_ONLY and retrieve macros into include/autoconf.mk.tmp [2] Reformat include/autoconf.mk.dep into include/autoconf.mk with tools/scripts/define2mk.sed script [3] Remove include/autoconf.mk.tmp Here, include/autoconf.mk.tmp is similar to u-boot.cfg, which is also generated by preprocessing include/config.h with -DDO_DEPS_ONLY. In other words, there is much overlap among include/autoconf.mk and u-boot.cfg build rules. So, the idea is to split the build rule of include/autoconf.mk into two stages. The first preprocesses headers into u-boot.cfg. The second parses the u-boot.cfg into include/autoconf.mk. The build rules of u-boot.cfg in Makefile and spl/Makefile will be gone. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07kbuild: make dependencies in scripts/Makefile.autoconf more readableMasahiro Yamada
I do not remember why I wrote the code like this, but let's make it a bit more readable. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07kbuild: move no_new_adhoc_configs_check to "all" target commandMasahiro Yamada
I am going to move the build rule of u-boot.cfg. Before that, no_new_adhoc_configs_check must be tweaked to not depend on it. The ad-hoc option check can be done at the end of build, along with other checks. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07check-config: fix wrong comment about how to build whitelistMasahiro Yamada
The command suggested in this comment block is wrong; it would not rip off CONFIG options that had already been converted to Kconfig. Instead, we should use the scripts/build-whitelist.sh tool. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07config_whitelist: remove bogus optionsMasahiro Yamada
These are not CONFIG options (detected by my eyes). CONFIG_SPL_BUILD and CONFIG_TPL_BUILD are build options defined only for building SPL and TPL, respectively. The others are just mentioned in comment blocks. Now, scripts/build-whitelist.sh never picks up new options. Once we kill these false ones, they will never revive. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07config_whitelist: sync by toolMasahiro Yamada
It is a good practice to drop an option from the whitelist when we convert it to Kconfig, but we may sometimes forget to do that. So, it might be a good idea to sync the whitelist from time to time. This commit was generated by: scripts/build-whitelist.sh Looks like we had a bit progress... Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07build-whitelist: do not add new options to whitelist when updateMasahiro Yamada
If somebody adds references to new CONFIG options in source files, they will be added in the whitelist when we sync it. (For example, if we run scripts/build-whitelist.sh against commit 42f75050667b, new options CONFIG_SPL_DFU_SUPPORT and CONFIG_USB_XHCI_UNIPHIER will appear in the list.) In order to make steady progress of Kconfig migration, we want to only decrease whitelist options, but never increase. So, when we update the whitelist, we should create a temporary list, then take the intersection of the temporary one and the current one. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07vexpress: disable cci ace slave ports when booting in non-sec/hyp modeSudeep Holla
Commit f225d39d3093 ("vexpress: Check TC2 firmware support before defaulting to nonsec booting") added support to check if the firmware on TC2 is configured appropriately before booting in nonsec/hyp mode. However when booting in non-secure/hyp mode, CCI control must be done in secure firmware and can't be done in non-secure/hyp mode. In order to ensure that, this patch disables the cci slave port inteface so that it is not accessed at all. Cc: Jon Medhurst <tixy@linaro.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Acked-by: Jon Medhurst <tixy@linaro.org> Tested-by: Jon Medhurst <tixy@linaro.org>
2016-10-07common/console.c: ensure GD_FLG_SILENT is set or clearedChris Packham
When CONFIG_SILENT_CONSOLE is defined and the default environment has silent=1 it is not possible for a user to make the console un-silent if the environment is not available when console_init_f() is called (for example because the environment is in SPI). Add a new helper function console_update_silent() and call it from both console_init_f() and console_init_r(). Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07arm: dra7xx: Move fastboot options to defconfigSemen Protsenko
Now that fastboot options are available in Kconfig, we can migrate them from DRA7 header to corresponding DRA7 defconfigs. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-10-07ARM: vf610: use strcpy for soc environment variableStefan Agner
To create the soc environment variable we concatenate two strings on the stack. So far, strcat has been used for the first string as well as for the second string. Since the variable on the stack is not initialized, the first strcat may not start using the first entry in the character array. This then could lead to an buffer overflow on the stack. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-10-07configs: enable device tree for Colibri iMX7Stefan Agner
Enable device tree configuration and specify default device tree for Toradex Colibri iMX7. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-10-07colibri_imx7: use Ricoh RN5T567 to reboot the boardStefan Agner
Use the external PMIC Ricoh RN5T567 to reliably restart the system. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-10-07arm: dts: imx7: add Ricoh RN5T567 PMIC nodeStefan Agner
Add device tree node for Ricoh RN5T567. Currently we do not need the individual DC/DC converters or LDO's (and they are also not yet supported by the driver). Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-10-07power: pmic: add Ricoh RN5T567 PMIC supportStefan Agner
Add device model enabled PMIC driver for Ricoh RN5T567 PMIC used on Colibri iMX7. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07colibri_imx7: remove legancy UART platform dataStefan Agner
We now use device tree to provide SoC data to the UART driver, there is no need for the legancy UART platform data. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-10-07colibri_imx7: remove legancy I2C supportStefan Agner
Remove legancy I2C config and code in favor of upcomming DM/DT enable I2C support. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-10-07arm: dts: imx7: add basic i.MX 7/Colibri iMX7 device treeStefan Agner
Add base device for NXP i.MX 7Solo/7Dual. The two SoC are very similar and hence can share the same device tree for boot loaders purpose. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07arm: dts: imx7: add pinctrl definesStefan Agner
Add pinctrl defines for NXP i.MX 7Solo/7Dual SoC. The pinctrl format is compatible to the Linux kernel, hence this file is a simple copy from the Linux kernel (commit 97f5c1817b7e). Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-10-07pinctrl: imx: do not announce driver initializationStefan Agner
It is not usual that drivers announce when they have been initialized. use dev_dbg to announce device initialization. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07dm: imx: serial: support device treeStefan Agner
Support instatiation through device tree. Also parse the fsl,dte-mode property to determine whether DTE mode shall be used. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06scripts: Add script to extract default environmentLukasz Majewski
This script looks for env_common.o object file and extracts from it default u-boot environment, which is afterwards printed on standard output. Usage example: get_default_envs.sh > u-boot-env-default.txt The generated text file can be used as input for mkenvimage. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06ARM: Add register defines for am33xx ePWM registerstomas.melin@vaisala.com
Register definitions needed for configuring the ePWM module. Signed-off-by: Tomas Melin <tomas.melin@vaisala.com>
2016-10-06doc: typo fix addess -> addressJelle van der Waa
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
2016-10-06ARM: OMAP5+: Override switch_to_hypervisor functionKeerthy
Override the switch_to_hypervisor function to switch cpu to hypervisor mode using the available ROM code hook early in the boot phase before the boot loader checks for HYP mode. Based on the work done by Jonathan Bergsagel jbergsagel@ti.com. Cc: beagleboard-x15@googlegroups.com Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06ARM: Introduce function to switch to hypervisor modeKeerthy
On some of the SoCs one cannot enable hypervisor mode directly from the u-boot because the ROM code puts the chip to supervisor mode after it jumps to boot loader. Hence introduce a weak function which can be overridden based on the SoC type and switch to hypervisor mode in a custom way. Cc: beagleboard-x15@googlegroups.com Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06configs: dra7xx_evm_defconfig: Enable LPAE modeKeerthy
Enable Linear Physical Address Extension mode which is a prerequisite for hypervisor mode. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06configs: am57xx_evm_defconfig: Enable LPAE modeKeerthy
2016-10-06omap: Set appropriate cache configuration for LPAE and non-LAPE casesKeerthy
Cache configuration methods is different for LPAE and non-LPAE cases. Hence the bits and the interpretaion is different for two cases. In case of non-LPAE mode short descriptor format is used and we need to set Cache and Buffer bits. In the case of LPAE the cache configuration happens via MAIR0 lookup. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06omap: Remove hardcoding of mmu section shift to 20Keerthy
As of now the mmu section shift is hardcoded to 20 but with LPAE coming into picture this can be different. Hence replacing 20 with MMU_SECTION_SHIFT macro. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06PWM: Correct misspellings of "module" in context of PWMRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Heiko Schocher <hs@denx.de>
2016-10-06ARM64: Add support for some of atomic64 operationsAdam Oleksy
These functions are needed in UBI/UBIFS on ZynqMP platform (ARM64). Signed-off-by: Adam Oleksy <adam.oleksy@nokia.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2016-10-06cmd/onenand.c: block align warningLadislav Michl
An attempt to write non block aligned data fails silently, add warning and set result. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2016-10-06search.h: Numerous grammatical fixes, comment updatesRobert P. J. Day
Tweaks (no functional changes) to include/search.h, including: * use standard multiple inclusion check * fix spelling mistakes * have comments match actual names in function prototypes * remove obsolete reference to "do_apply" * replace "hashing table" with "hash table" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-10-06ARMv8/sec-firmware: fix a compile errorHou Zhiqiang
When enabled sec firmware framework, but lack of definition of the marco SEC_FIRMWARE_FIT_IMAGE, SEC_FIRMEWARE_FIT_CNF_NAME and SEC_FIRMWARE_TARGET_EL, there will be some build errors, so give a default definition. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
