Use the function 'mmc_send_status' to check the card status.
only when the card is ready, driver can send the next erase command
to the card, otherwise, the erase will failed:
=> mmc erase 0 1
MMC erase: dev # 0, block # 0, count 1 ... 1 blocks erase: OK
=> mmc erase 0 2
MMC erase: dev # 0, block # 0, count 2 ... mmc erase failed
1 blocks erase: ERROR
=> mmc erase 0 4
MMC erase: dev # 0, block # 0, count 4 ... mmc erase failed
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
CC: Andy Fleming <afleming@gmail.com>
CC: Marek Vasut <marex@denx.de>
Signed-off-by: Andy Fleming <afleming@freescale.com>
This code adds call to mmc_init(), for partition related commands (e.g.
fatls, fatinfo etc.).
It is safe to call mmc_init() multiple times since mmc->has_init flag
prevents from multiple initialization.
The FAT related code calls get_dev high level method and then uses
elements from mmc->block_dev, which is uninitialized until the mmc_init
(and thereof mmc_startup) is called.
This problem appears on boards, which don't use mmc as the default
place for envs
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Cc: Andy Fleming <afleming@gmail.com>
mmc_set_clock is set to the hard-coding.
But i think good that use the tran_speed value.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
* 'master' of git://git.denx.de/u-boot-i2c:
mx28evk: Add I2C support
mxs-i2c: Fix internal address byte order
mxc_i2c: remove setting speed at each start
mx6qsabrelite: add i2c support
mxc_i2c: specify i2c base address in config file
Add I2C support.
Tested by placing a 24LC16 EEPROM into the U50 slot which comes empty from factory.
Large EEPROMs, e.g. 24lc32, need 2 byte to address the internal memory.
These devices require that the high byte of the internal address has to be
written first.
The mxs_i2c driver currently writes the address' low byte first.
The following patch fixes the byte order of the internal address that should
be written to the I2C device.
Signed-off-by: Torsten Fleischer <to-fleischer@t-online.de>
CC: Stefano Babic <sbabic@denx.de>
CC: Fabio Estevam <fabio.estevam@freescale.com>
Other then being very weird, this code was also wrong.
For example, say I set speed to 100K. I'll read back the speed
as 85937. But the speed is really 85937.5, so we I reset
the speed to 85937, I'll get 73660.7. After a couple of transactions
my speed is now exactly 68750 so it will remain there.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
The following platforms had their config files changed
flea3, imx31_phycore, mx35pdk, mx53ard, mx53evk, mx53smd
and mx53loco.
The clean up patch missed an &, so we end up passing an int rather than
a pointer to the sprintf function.
arp.c: In function 'ArpReceive':
arp.c:197: warning: format '%p' expects type 'void *', but argument 3 has type 'int'
When support sh7734 of sh-ether, ECSIPR_BRCRXIP and other were removed.
Therefore SH7757 and SH7724 can not build. This revise this probelem.
Tested-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
* 'master' of git://git.denx.de/u-boot-arm:
tegra: define fdt_load/fdt_high variables
tegra: enable bootz command
tegra: usb: Fix device enumeration problem of USB1
tegra: trimslice: set up serial flash pinmux
tegra: add pin_mux_spi() board initialization function
tegra: add GMC/GMD funcmux entry for SFLASH
tegra: bootcmd: start USB only when needed
tegra: bootcmd enhancements
tegra: add enterrcm command
tegra: enable CONFIG_ENV_VARS_UBOOT_CONFIG
Add env vars describing U-Boot target board
tegra: usb: fix wrong error check
tegra: add ULPI on USB2 funcmux entry
tegra: fix leftover CONFIG_TEGRA2_MMC & _SPI build switches
tegra: Add Tamonten Evaluation Carrier support
tegra: Use SD write-protect GPIO on Tamonten
tegra: Implement gpio_early_init() on Tamonten
tegra: Allow boards to perform early GPIO setup
tegra: plutux: Add device tree support
tegra: medcom: Add device tree support
tegra: Rework Tamonten support
beagle: add eeprom expansion board info for bct brettl4
Fixed the compiler warning message.
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
* 'master' of git://git.denx.de/u-boot-usb:
CONFIG: EXYNOS5: USB: Enable USB 2.0 on smdk5250
EXYNOS5: USB: Fix incorrect USB base addresses
EXYNOS: Add power Enable/Disable for USB-EHCI
USB: EXYNOS: Set USB 2.0 HOST Link mode
EXYNOS5: Add structure for PMU registers
EXYNOS5: Fix system register structure
USB: EXYNOS: Incorporate EHCI review comments
These variables act like loadaddr, but for a device tree image. Defining
them in the environment allows boot scripts to be identical on Tegra20 and
Tegra30, which have different memory base addresses, and hence need
different values for these variables.
Signed-off-by: Tom Warren <twarren@nvidia.com>
bootz is just like bootm, except that it can boot a raw zImage, without
requiring it to be wrapped inside a uImage.
A known hardware issue of USB1 port where bit 1 (connect status
change) of PORTSC register will be set after issuing Port Reset
(like "usb reset" in u-boot command line).
This will be treated as an error and stops later device enumeration.
Therefore we clear that bit after Port Reset in order to proceed
Signed-off-by: Jim Lin <jilin@nvidia.com>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
When Trimslice is booted from serial flash, the boot ROM does this, so
U-Boot doesn't need to. However, booting from the SD slot for recovery
purposes, the boot ROM does not set up the pinmux for serial flash. Add
code to U-Boot to set this up, so that an SD-based recovery U-Boot image
can upgrade the U-Boot in serial flash.
Boards can override this to set up the pinmux correctly to access serial
flash.
This is used on TrimSlice.
Instead of initializing USB as soon as bootcmd is executed, defer it
until the first boot device that (potentially in the case of network)
uses USB is scanned. This avoids initializing USB when booting from MMC,
so speeds that up.
Place the list of searched boot devices, file-system types, boot file
locations/prefixes, and boot script names into variables. This allows
the user to override them directly (e.g. to change boot order, or select
the specific values they use) without having to edit the main bootcmd
and script_boot variables.
The default boot order is changed from USB, MMC, DHCP to MMC, USB, DHCP.
This speeds up the typical MMC boot case. People who want USB boot can
now edit variable boot_targets appropriately.
Also, reformat BOOTCMDS_COMMON to fit within 80 columns.
Potential future enhancements might be:
* Allow boards to specify which of bootcmd_mmc0/... should be defined,
based on the HW they contain.
* Allow boards to influence the order that the boot targets are added
into the boot_targets variable.
Tegra's boot ROM supports a mode whereby code may be downloaded and flash
programmed over a USB connection. On dev boards, this is typically entered
by holding down a "force recovery" button and resetting the CPU. However,
not all boards have such a button (one example is the Compulab Trimslice),
so a method to enter RCM from software is useful.
This change implements the command "enterrcm" to do this, and enables it
for all Tegra boards by default. Even on boards other than Trimslice,
controlling this over a UART may be useful, e.g. to allow simple remote
control without the need for mechanical button actuators, or hooking up
relays/... to the button.
So that all Tegra boards define environment variables that describe
themselves.
This can be useful for generic scripts. For example, rather than hard-
coding a script to ext2load tegra-harmony.dtb, it could load
${soc}-${board}.dtb and hence not need adjustments to run on multiple
boards.
loop_count runs down from 10000, so the correct condition to error out
is ==0.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
CC: Stephen Warren <swarren@wwwdotorg.org>
CC: Tom Warren <twarren.nvidia@gmail.com>
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
This is needed as a prerequisite for Tegra USB ULPI support
within U-Boot.
CC: Tom Warren <twarren@nvidia.com>
Missed some boards after my tegra2_mmc.* -> tegra_mmc.* change, and
one instance of CONFIG_TEGRA2_SPI. MAKEALL -s tegra2 AOK, Seaboard MMC
AOK. Didn't test Tamonten, Paz00 or TrimSlice, as I have none here.
The Tamonten Evaluation Carrier is an evaluation board for the Tamonten
processor board. More information is available here:
http://www.avionic-design.de/en/products/nvidia-tegra-tamonten-system-en/nvidia-tegra-tamonten-evboard-en.html
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
GPIO PI6 can be used to obtain the write-protect status of an SD card
inserted into the SD slot.
The PI4 GPIO is used on Tamonten to reset carrier board peripherals.
Power sequencing hardware on the carrier pulls the reset low before
powering up the Tegra, and the CPU is supposed to signal readiness,
and therefore bring peripherals out of reset by pulling PI4 high.
The new gpio_early_init() function, which does nothing by default, can
be overridden by boards to configure GPIOs at an early stage.
Device tree support is required for working USB host support, which in
turn enables ethernet support.
This commit uses the common Tegra board implementation instead of
duplicating a lot of the code. In addition, the Plutux and Medcom
specific board files can be removed as the MMC/SD setup is common
among all Tamonten-based boards.
this is for a prototyping board
vendor/product ids have been added to
http://elinux.org/BeagleBoardPinMux#List_of_Vendor_and_Device_IDs
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
This patch corrects the base addresses for USB_PHY and USB_OTG.
Acked-by: Chander Kashyap <chander.kashyap@linaro.org>
This patch adds functions to enable/disable the power of USB
host controller for EXYNOS5.
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
This patch adds a function to set usb host mode to USB 2.0 HOST Link
for EXYNOS5
This patch adds power mananagement registers structure for exynos5 SoC.
This patch corrects the SYSREG structure.
We have removed the sysreg.h added in the previous patchset
version as the sysreg structure is already defined in system.h.
This patch incorates the review comments given by Minkyu Kang for
EHCI support on EXYNOS
when -O0"
This reverts commit fa042186b932e9b9ee9a2fd8a04a3acf7c70d224.
It causes build warnings like this:
cpu.c:48:1: warning: -fstack-usage not supported for this target
[enabled by default]
Commit 896bbb5 "fdt: avoid bad MAKEALL status" added logic to capture
the result code from dtc by echoing $? to stdout and capturing it using
$(). However, dtc emits some diagnostics to stderr and some to stdout.
The diagnostics send to stdout ended up getting captured via $() rather
than being echo'd to the user. This caused those diagnostics to be passed
to the exit command, which would then fail with the following cryptic
error message:
/bin/sh: line 1: exit: too many arguments
Solve this by redirecting all dtc output to stderr so that $() does not
capture it. This allows the user to see the actual error message from dtc.
Cc: albert.u.boot@aribaud.net
Cc: Tom Warren <twarren@nvidia.com>
This warning was introduced in 436da3c "ext2load: increase read
speed":
ext2fs.c: In function 'ext2fs_read_file':
ext2fs.c:458:19: warning: 'blocknxt' may be used uninitialized in this function [-Wuninitialized]
this change makes it go away.
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Jason Cooper <u-boot@lakedaemon.net>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
mkenvimage does not build due to missed os_support.o and unsupported
file modes S_IRGRP S_IWGRP.
Tested with mingw 4.2.1 on ubuntu 12.04.
Signed-off-by: Vladimir Yakovlev <nagos@inbox.ru>
