Add define used to determine if PCI1 interface is in PCI or PCIX mode.
Convert users of the old PORDEVSR_PCI constant to use MPC85xx_PORDEVSR_PCI1
Signed-off-by: Andy Fleming <afleming@freescale.com>
The current code will cause the creation of a 4GB window
starting at 0 if we have more than 4GB of RAM installed,
which overlaps with PCI_MEM space and causes pci_bus_to_phys()
to return erroneous information. Limit the size to 4GB - 1;
which causes the code to create one 2GB and one 1GB window
instead.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Acked-by: Andy Fleming <afleming@freescale.com>
Prevent further viral propogation of the unused
symbol CONFIG_L1_INIT_RAM by just removing it.
Removed while(1) hang if memctl_intlv_ctl is set wrong.
Remove embedded tabs from strings.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
since commit be0bd8234b9777ecd63c4c686f72af070d886517
tlb entry for socrates DDR SDRAM will be reconfigured
by setup_ddr_tlbs() from initdram() causing an
inconsistency with previously configured DDR SDRAM tlb
entry from tlb_table:
socrates>l2cam 7 9
IDX PID EPN SIZE V TS RPN U0-U3 WIMGE UUUSSS
7 : 00 00000000 256MB V 0 -> 0_00000000 0000 -I-G- ---RWX
8 : 00 00000000 256MB V 0 -> 0_00000000 0000 ----- ---RWX
9 : 00 10000000 256MB V 0 -> 0_10000000 0000 ----- ---RWX
This patch makes the presence of the DDR SDRAM tlb entry in
the tlb_table dependent on CONFIG_SPD_EEPROM to avoid this
inconsistency.
All mpc8548-based boards should implement the suggested workaround
to CPU 2 errata. Without the workaround, its possible for the
8548's core to hang while executing a msync or mbar 0 instruction
and a snoopable transaction from an I/O master tagged to make
quick forward progress is present.
we need TLB entry for DDR at !SPD case.
Signed-off-by: Dave Liu <daveliu@freescale.com>
The DDR controller of 8548/8544/8568/8572/8536 processors
have the ECC data init feature, and the new DDR code is
using the feature, and we don't need the way with DMA to
init memory any more.
This caused the operation to be needlessly repeated if there were
no bad blocks and no errors.
Signed-off-by: Valeriy Glushkov <gvv@lstec.com>
This BSP should be outside u-boot source tree.
The second reason is that xilinx ppc405 was moved to generic platform.
This patch disables some unused features from the PCI405 configuration
to keep U-Boot image size below 192k.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch fix the broken boot from NOR Flash on AT91RM9200 boards, if
CONFIG_AT91RM9200 is defined and nor preloader is used.
Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
With this patch UBI can be used on CFI flash chips.
Signed-off-by: Piotr Ziecik <kosmo@semihalf.com>
Remove a printf() from add_mtd_device(), which produces spurious output.
Add cfi-mtd driver, which exports CFI flash to MTD layer.
This allows CFI flash devices to be used from MTD layer.
Building of the new driver is controlled by CONFIG_FLASH_CFI_MTD
option. Initialization is done by calling cfi_mtd_init() from
flash_init().
Add interface for flash verbosity control. It allows
to disable output from low-level flash API. It is useful
when calling these low-level functions from context other
than flash commands (for example the MTD/CFI interface
implmentation).
Export flash_sector_size() function from drivers/mtd/cfi_flash.c,
so that it can be used in the upcoming cfi-mtd driver.
This patch defines all flash access functions as weak so that
they can be overridden by board specific versions.
This will be used by the upcoming VCTH board support where the NOR
FLASH unfortunately can't be accessed memory-mapped. Special
accessor functions are needed here.
To enable this weak functions you need to define
CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS in your board config header.
Otherwise the "old" default functions will be used resulting
in smaller code.
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Currently the size parameters of the UBI commands (e.g. "ubi write") are
decoded as decimal instead of hex as default. This patch now interprets
all these values consistantly as hex, as all other standard U-Boot commands
do.
This patch enables support for EXT2, and increases the
CONFIG_SYS_BOOTMAPSZ size for the default configuration
of the katmai boards to use them as the RAID-reference
AMCC setups.
EXT2 enabling allows one to boot kernels from the EXT2
formatted Compact Flash cards.
CONFIG_SYS_BOOTMAPSZ increasing allows one to boot the
Linux kernels, which use PAGE_SIZE of 256KB. Otherwise,
the memory area with DTB file (which is placed at the
end of the bootmap area) will turn out to be overlapped
with the BSS segment of the 256KB kernel, and zeroed
in early_init() of Linux.
Actually, increasing of the bootmap size could be done
via setting of the bootm_size U-Boot variable, but it looks
like the current U-Boot implementation have some bootm_size-
related functionality lost. In many places through the U-Boot
code the CONFIG_SYS_BOOTMAPSZ definition is used directly
(instead of trying to read the corresponding value from the
environment). The same is truth for the boot_jump_linux()
function in lib_ppc/bootm.c, where U-Boot transfers control
to Linux passing the CONFIG_SYS_BOOTMAPSZ (not bootm_size)
value to the booting kernel.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Expanded OCM TLB to allow access to 64K OCM as well as 256K of
internal SRAM.
Adjusted internal SRAM initialization to match updated user
manual recommendation.
OCM & ISRAM are now mapped as follows:
physical virtual size
ISRAM 0x4_0000_0000 0xE300_0000 256k
OCM 0x4_0004_0000 0xE304_0000 64k
A single TLB was used for this mapping.
Signed-off-by: Dave Mitchell <dmitch71@gmail.com>
Added include/asm-ppc/ppc4xx-isram.h and moved internal SRAM and
L2 cache DCRs from ppc440.h to this new header.
Also converted these DCR defines from lowercase to uppercase and
modified referencing modules to use them.
The definitions of bits in SDR_CFG are incorrect, and not used within
U-Boot. Therefore, they can be removed.
The naming of the sdr_ddrdl/sdr_cfg registers do not follow conventions,
and are unused, so they can be removed too.
A definition for SDR0_DDRCFG is added.
Signed-off-by: Steven A. Falco <sfalco@harris.com>
Convert IO macros to readx/writex.
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
This patch corrects a small bug in the "if" condition:
the parameter "flag" is 0 and the "if" condition is always true.
The result is - the boom command doesn't start the kernel.
Affected targets: all arm based.
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
At least some (old ?) versions of the AT91Bootstrap do not set up the
PLLB correctly to 48 MHz in order to make USB host function correctly.
This patch sets up the PLLB to the same values Linux uses, and makes USB
work ok on the following CPUs:
- AT91CAP9
- AT91SAM9260
- AT91SAM9263
This patch also defines CONFIG_USB_STORAGE and CONFIG_CMD_FAT for all
the relevant AT91CAP9/AT91SAM9 atmel boards.
Signed-off-by: Stelian Pop <stelian@popies.net>
Introduce AT91_CPU_CLOCK and use it for displaying the CPU
speed in the LCD driver.
Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the
corresponding board clocks.
This is needed on Canyonlands which still has an exception pending
while running relocate_code(). This leads to a failure after trap_init()
is moved to the top of board_init_r().
modify the CAS timings. my understanding is that these
settings decrease various wait times in the DDR interface.
Because these wait times are in clock cycles, and the DDR
clock on the 8315 RDB runs slower than on some other 83xx
platforms, we can dial down these values without a problem,
thereby decreasing the latency of memory a little.
Signed-off-by: Howard Gregory <Greg.Howard@freescale.com>
To enable UBI on Apollon you need to uncomment the CONFIG_SYS_USE_UBI
macro.
This patch adds these UBI commands:
ubi part [nand|onenand] [part] - Show or set current partition
ubi info [l[ayout]] -Display volume and UBI layout information
ubi create[vol] volume [size] [type] - Create volume name with size
ubi write[vol] address volume size - Write volume from address with size
ubi read[vol] address volume [size] - Read volume to address with size
ubi remove[vol] volume - Remove volume
This patch adds basic UBI (Unsorted Block Image) support to U-Boot.
It's based on the Linux UBI version and basically has a "OS"
translation wrapper that defines most Linux specific calls
(spin_lock() etc.) into no-ops. Some source code parts have been
uncommented by "#ifdef UBI_LINUX". This makes it easier to compare
this version with the Linux version and simplifies future UBI
ports/bug-fixes from the Linux version.
This MTD part infrastructure will be used by the upcoming
UBI support.
