This avoids the following checkpatch warning in later patches:
ERROR: "(foo*)" should be "(foo *)"
ERROR: space required before the open brace '{'
ERROR: space prohibited before that close parenthesis ')'
ERROR: spaces required around that '||' (ctx:WxV)
WARNING: space prohibited between function name and open parenthesis '('
WARNING: line over 80 characters
This fixes all the white-space warnings/errors in my subsequent patch,
and within this current patch. A number of other checkpatch warnings
and errors are still present in this patch itself, but are beyond simple
whitespace fixes, so are not solved by this patch.
v2: New patch
Add the Silicon Image series PCI Express to
Serial ATA controller support, including Sil3132,
Sil3131 and Sil3124.
The SATA controller can be used to load kernel.
The features list:
- Supports 1-lane 2.5 Gbit/s PCI Express
- Supports one/two/four independent Serial ATA channels
- Supports Serial ATA Generation 2 transfer rate of 3.0 Gbit/s
- Supports LBA28 and LBA48
Signed-off-by: Tang Yuantian <b29983@freescale.com>
Signed-off-by: Aaron Williams <Aaron.Williams@cavium.com>
Tested-by: Lan Chunhe <b25806@freescale.com>
Documents and READMEs for NDS32 architecture.
It patch also provides usage of SoC AG101 and board ADP-AG101.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Add evaluation board "adp-ag101" configuration file adp-ag101.h.
Add adp-ag101.c board config and related settings.
Add board adp-ag101 into boards.cfg
Add support of NDS32 to common commands bdinfo, bootm, and image format.
Add standalone program related support for nds32 architecture.
Add Makefile, board.c, interrupts.c and bootm.c functions
to nds32 architecture.
SoC ag101 is the first chip using NDS32 N1213 cpu core.
Add header file of device offset support for SoC ag101.
Add main function of SoC ag101 based on NDS32 n1213 core.
Add lowlevel_init.S and other periphal related code.
This version of lowlevel_init.S also replace hardcode value
by MARCO defines from the GPL version andesboot for better
code quality.
Add N1213 cpu core (N12 Core family) support for NDS32 arch.
This patch includes start.S for the initialize procedure of N1213.
Start procedure:
start.S will start up the N1213 CPU core at first,
then jump to SoC dependent "lowlevel_init.S" and
"watchdog.S" to configure peripheral devices.
Signed-off-by: Greentime Hu <greentime@andestech.com>
Add NDS32 support into common header file.
Add generic header files support for nds32 architecture.
Cache, ptregs, data type and other definitions are included.
The print_str() helper function for cmd_bdinfo can print any string, but it
is only used to print MHz values. Replace it with print_mhz() that takes
a number and converts it to a string internally.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Not draining the FIFO and waiting for the UART to be non-busy
before changing baudrate results in crap characters on the
console, so let's wait for the FIFO to drain and the last
character to be clocked out before we do that.
The examples/api is not configured with USE_PRIVATE_LIBGCC. This makes
building examples/api break on certain boards that do not/cannot use the
public libgcc.
Nevertheless, this patch has to also touch the top-level Makefile to fix
this problem because the current top-level Makefile does not specify
libgcc as a prerequisite of examples/api, and explicitly builds
examples/api _before_ libgcc.
For testing this patch, I added the following to configs/seaboard.h and
ran demo.bin on a Seaboard.
+#define CONFIG_API
+#define CONFIG_SYS_MMC_MAX_DEVICE 2
+#define CONFIG_CMD_NET
+#define CONFIG_NET_MULTI
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
The code had two paths depending on whether the card was to be
accessed from plain memory or the IO region. However the error
path checks whether IO region was obtained - twice. Fix up the
error path according to the probable intention.
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
This patch move the reset function from initialization to
driver register procedure.
Some embedded system supports wake on lan nowadays. On this kind of system,
the ftgmac100 will be still supplied power after the system has been
shut-down by Linux. Hence the register used by linux won't be clear
when the system has been powered-off.
The origin ftgmac100 driver in u-boot will only register
driver and functions to network stack and won't reset the ftgmac100
hardware if the network won't be used during boot-up.
This will lead ftgmac100 continue receiving packets and then might corrupt
linux kernel when booting up.
So we reorder the hardware reset function earlier to force the hardware
to be reset whether it will be used or not.
This header is unneeded due to code which was removed in the
past.
cc: Wolfgang Denk <wd@denx.de>
Calucations of PRAM needs to take into account the 'rootfssize'.
Memory available to the linux kernel 'mem=' is in all cases set to the total
memory size minus the pram size.
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
This prevents u-boot to print out "Can't overwrite "ethaddr""
each time a powerpc board starts.
Patch fixes this issue:
fw_env.c: In function ‘fw_setenv’:
fw_env.c:492:5: warning: format ‘%u’ expects argument of type ‘unsigned int’, but argument 3 has type ‘size_t’ [-Wformat]
fw_env.c: In function ‘flash_write_buf’:
fw_env.c:806:6: warning: format ‘%u’ expects argument of type ‘unsigned int’, but argument 3 has type ‘size_t’ [-Wformat]
Signed-off-by: Luka Perkov <lists@lukaperkov.net>
The current km_arm boards have a Power-On test jumper. When this
jumper is set, this triggers some Power-On tests on the board.
This patch enables the support of this jumper for starting the
memory_regions test when the jumper is set.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
This removes static modifier from images variable in cmd_bootm.c.
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
* 'master' of git://git.denx.de/u-boot-mpc85xx:
mpc85xx: Add inline GPIO acessor functions
powerpc/85xx: wait for alignment before resetting SERDES RX lanes (SERDES9)
powerpc/85xx: Fix P2020DS booting
powerpc/85xx: Update USB device tree status based on pin settings
fdt: Add new fdt_set_node_status & fdt_set_status_by_alias helpers
powerpc/85xx: Add support for RMan LIODN initialization
powerpc/85xx: Update device tree handling for SRIO
powerpc/85xx: Update setting of SRIO LIODNs
fm: Don't allow disabling of FM1-DTSEC1
fm-eth: Don't mark the MAC we use for MDIO as disabled in device tree
* 'master' of git://git.denx.de/u-boot-coldfire:
ColdFire: Clean Makefile _config rules
ColdFire: Move boards with simple _config rules to boards.cfg
ColdFire: Fix compilation with CONFIG_SYS_DRAMSZ1 defined
ColdFire: Merge differentiated linking files into a sigle one by board
ColdFire: Add $(obj) before cpu lib to correct build
ColdFire: Cleanup lds files for multiple defined symbols
* 'master' of /home/wd/git/u-boot/master:
cosmetic: Fixup fixup_silent_linux() for checkpatch
Correct dependency rule to fix SPL build
Move timestamp and version files into 'generated' subdir
sandbox: Makefile changes to build sandbox architecture
Add generic gpio.h in asm-generic
Adjust dependency rules to permit per-file flags
sandbox: Use uintptr_t for 32/64-bit compatibility
sandbox: Add basic config file
sandbox: Add serial uart
sandbox: Add main program
sandbox: Add OS dependent layer
sandbox: Force command sections to be 4-byte aligned
sandbox: Disable standalone/API support
sandbox: Disable built-in malloc
sandbox: Add bootm support
sandbox: Add board info for architecture
sandbox: Add sandbox board
sandbox: Add architecture lib files
sandbox: Add cpu files
sandbox: Add compiler defines to support a 64-bit x86_64 platform
sandbox: Add architecture image support
Fix use of int as pointer in image.c
sandbox: Add architecture header files
arm: ca9x4_ct_vxp: enable PXE BOOTP options support
arm: ca9x4_ct_vxp: enable pxe command support
Convert ca9x4_ct_vxp to standard env variables
net: bootp: add PXE/RFC 4578 DHCP options support
Add pxe command
lib: add uuid_str_to_bin for use with bootp and PXE uuid
README: document standard image variables
Replace space and tab checks with isblank
cosmetic: remove unneeded curly braces
Add isblank
common: add run_command2 for running simple or hush commands
common, menu: use abortboot for menu timeout
Add generic, reusable menu code
DM9000:Add a byte swap macro for dm9000 io operation.
kw_gpio: fix error in kw_gpio_direction_input
Blackfin: bfin_spi: fix build error when DEBUG is defined
Blackfin: define CONFIG_SYS_CACHELINE_SIZE
video: Moving mx3fb.c to CONFIG_VIDEO
mx31: make HSP clock for mx3fb driver available
MX5: Make IPU display output and pixel format configurable
VIDEO: MX5: export pix format
VIDEO: MX5: Switch MX5 to CONFIG_VIDEO
video: update the Freescale DIU driver to use linux/fb.h
powerpc: cpm2 boards: update fcc register logic
To ease the implementation of other MPC85xx board ports, several common
GPIO helpers are added to <asm/mpc85xx_gpio.h>.
Since each of these compiles to no more than 4-5 instructions it would
be very inefficient to call them out of line, therefore we put them
entirely in the header file.
The HWW-1U-1A board port which these were written for strongly prefers
to set multiple GPIOs as a single batch operation, so the API is
designed around that basis.
To assist other board ports, a small set of wrappers are used which
provides a standard gpio_request() interface around the MPC85xx-specific
functions. This can be enabled with CONFIG_MPC85XX_GENERIC_GPIO
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
The work-around for P4080 erratum SERDES9 says that the SERDES receiver
lanes should be reset after the XAUI starts tranmitting alignment signals.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Anton Staaf <robotboy@chromium.org>
Commit 4750884 introduced a change in the dependency generation which
breaks SPL, because the source files being built are not initially present
and are symlinked as part of the build.
The .depend file must depend not only on the files in the DEPS list but
also on the sources which did not contribute files to the DEPS list, since
these sources will otherwise not get a dependency and will not be built.
Tested-by: Wolfgang Denk <wd@denx.de>
Remove unused mkdir, and add missing ones.
Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com>
A temp variable was used but not declared, with CONFIG_SYS_DRAMSZ1
defined. This variable is now declared in the functione when needed.
The spa, stm, int, 32 and 16 linking files are identical so there is
no need to differentiate them. A single lds file is now used, and
_config rule are simplified.
Missing $(obj) prevented the build of ColdFire boards in a directory
than sources
Lds files cleened to remove multiple defined section and modified to
be compliant with --gc-sections added for ColdFire platform in a
previous patch.
The following commit removed the code that set odt_rd_cfg and
odt_wr_cfg. With out this code P2020DS board will not boot:
commit 712cf7ab0b58e51a69e339397457d3591b6b650e
Author: York Sun <yorksun@freescale.com>
Date: Mon Oct 3 09:19:53 2011 -0700
powerpc/mpc8xxx: Merge entries in DDR speed table
For P3060 and P4080, USB pins are multiplexed with other functions.
Update the device tree status for USB ports based on setting of
RCW[EC1] & RCW[EC2] which describe if pins are muxed to usb.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Add common function fdt_set_node_status() to assist in various locations
that we set a nodes status. This function utilizes the status values
that are part of the EPAPR spec (on power.org).
fdt_set_status_by_alias() is based on fdt_set_node_status() but uses an
alias string to identify the node to update.
We also add some shortcut functions to help the common cases of setting
"okay" and "disabled":
fdt_status_okay()
fdt_status_disabled()
fdt_status_okay_by_alias()
fdt_status_disabled_by_alias()
Finally, we fixup the corenet_ds ethernet code which previously had
a function by the same name that can be replaced with the new helpers.
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
This patch is intended to initialize RMan LIODN related registers on
P2041, P304S and P5020 SocS. It also adds the "rman@0" child node to
qman-portal nodes, adds "fsl,liodn" property to RMan inbound block nodes.
Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com>
Update device tree handling for SRIO controller to support updated
fsl,srio device tree binding.
We handle disabling of individual ports, the whole controller, RMU, and
RMAN. Additionally, we setup the SRIO related LIODNs in the device
tree.
Properly set the LIODN values associated with SRIO controller. On
P4080/P3060 we have an LIODN per port and one for the RMU. On
P2041/P3041/P5020 we have 2 LIODNs per port.
Update the tables for all of these devices to properly handle both
styles.
The MDIO controller to talk to external PHYs is on FM1-DTSEC1 so don't
allow disabling. If we disable it we end up powering the block down in
the SoC and thus can't communicate to any external PHYs.
FM1-DTSEC1's MAC was being marked as disabled if the port was not
configured based on the SoC configuration. However we utilize the MAC
interface for MDIO and thus should NOT mark it disabled.
There is a rather subtle build problem where the build time stamp is not
updated for out-of-tree builds if there exists an in-tree build which
has a valid timestamp file. So if you do an in-tree build, then an
out-of-tree build your timestamp will not change.
The correct timestamp_autogenerated.h lives in the object tree, but it
is not always found there. The source still lives in the source tree and
when compiling version.h, it includes timestamp_autogenerated.h. Since
the current directory is always searched first, this will come from the
source tree rather than the object tree if it exists there. This affects
dependency generation also, which means that common/cmd_version.o will not
even be rebuilt if you have ever done an in-tree build.
A similar problem exists with the version file.
This change moves both files into the 'generated' subdir, which is already
used for asm-offsets.h. Then timestamp.h and version.h are updated to
include the files from there.
There are other places where these generated files are included, but I
cannot see why these don't just use the timestamp.h and version.h headers.
So this change also tidies that up.
I have tested this with in- and out-of-tree builds, but not SPL. I have
looked at various other options for fixing this, including sed on the dep
files, -I- and -include flags to gcc, but I don't think they can be made
to work. Comments welcome.
At this point U-Boot will build and run on x86 under Linux.
The idea is to define a new architecture called 'sandbox', alongside ARM
and x86. This runs natively on Linux to suit the host machine. All
hardware access is either omitted or emulated.
The purpose of this system is to test the bulk of the non-hardware-specific
U-Boot code. We can mock the SPI flash, GPIOs, UART and keyboard, then test
that U-Boot behaves as we wish.
Since we want want to have a standard GPIO interface, this adds a definition
for this into include/asm-generic/gpio.h.
The dependency rules are currently done in a shell 'for' loop. This does not
permit Makefile variables to adjust preprocessor flags as is done with normal
compile flags, using the CFLAGS_path/file.o syntax.
This change moves the dependency generation into the Makefile itself, and
permits a CPPFLAGS_path/file.o to adjust preprocessor flags on a file or
directory basis.
The CPPFLAGS_... variable is also folded into CFLAGS during the build.
This fixes a problems when building on some 64-bit machines.
