The patch adds a utility function and defines
to set the pad as it is done in linux.
The patch adds the possibility to update the QONG
FPGA (a Lattice XP2-5E) with u-boot using some GPIOs
to drive the JTAG interface.
The patch adds support to load a Lattice's bitstream
image (called VME file) into a Lattice FPGA. The code
containing the state machine delivered as part of
Lattice's ispVMtools is integrated.
The FPGA is programmed using the JTAG interface. The
board maintainer must provide accessors to drive the
JTAG signals TCK, TMS, TDI and to get the value of the
input signal TDO.
The patch adds support for TTECH vision2 board.
The board has 512MB RAM, SDHC slot and 4MB SPI
device from StMicron.
Due to wrong dependencies, it is not possible to include imx_regs.h
inside the board configuration file.
The actual SPI driver for i.MX31 and i.MX51 controller
use a wrong byte ordering, because it is supposed
to work only with Freescale's devices, as the Power
Controllers (PMIC). The driver is not suitable for
general purposes, because the buffers passed to spi_xfer
must be 32-bit aligned, as it is used mainly to send
integer to PMIC devices.
The patch drops any kind of limitation and makes the
driver useful with devices controlled sending commands
composed by single bytes (or by a odd number of bytes), such as
spi flash, sensor, etc.
Because the byte ordering is changed,
any current driver using this controller must be adapted, too.
The handling of the SPI_CPOL bit inside the SPI
driver was wrong. As reported by the manual,
the meaning of the SSPOL inside the
configuration register is the same as reported
by SPI specification (0 if low in idle, 1 is high
on idle). The driver inverts this logic.
Because this patch sets the logic as specified, it is required
to clear the CPOL bit in the configuration file to adapt
to the correct logic.
Signed-off-by: David Jander <david.jander@protonic.nl>
As stated in 272017853339f5b9685f9488bdaf5405812d12a4,
the mx51evk has not CPLD and all references must be removed.
This patch drop a .h file that still remains in board
directory.
Calls WATCHDOG_RESET() inside serial driver
for boards enabling watchdog.
Add pins definitions to set up RAM pads. Pins have only
a pad, there is no entry in the multiplexer.
The OMAP3 cpu directory contains a syslib file with some utilities
that can be shared by all targets using arm cortexa8 processors,
not only OMAP.
The patch adds support for setting gpios to the
MX51 processor and change name to the corresponding
functions for MX31. In this way, it is possible to get rid
of nasty #ifdef switches related to the processor type.
include/ppc4xx.h
Commit 800eb0964 "POST cleanup." removed file
arch/powerpc/cpu/mpc512x/common.c but failed to remove the reference
to it from arch/powerpc/cpu/mpc512x/Makefile which causes somewhat
obscure build errors:
make[1]: *** No rule to make target `/work/wd/tmp-ppc/arch/powerpc/cpu/mpc512x/.depend', needed by `_depend'. Stop.
Fix these.
This patch adds missing pinmux setup for 4 GPIO signals used on the Beagle xM:
- USB hub reset (gpio_56)
- P8 USB hub reset (gpio_63)
- DVI enable (gpio_129)
- P8 DVI enable (gpio_170)
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Calculate the SDRAM size from DMM configuration registers instead of using
hard-coded values. This gives correct values for all different boards.
It's assumed that DMM sections do not overlap memory areas.
Signed-off-by: Aneesh V <aneesh@ti.com>
Tested-by: Steve Sakoman <steve@sakoman.com>
This patch corrects the pinmux settings to enable proper functioning
of the wifi/bluetooth module.
Signed-off-by: Thomas Weber <weber@corscience.de>
Add OSE as operating system for mkimage and bootm.
Signed-off-by: Torkel Lundgren <torkel.lundgren@enea.com>
The version numbering scheme was changed in Oct, 2008.
This patch brings the documentation to the actual level.
The description is taken from:
http://www.denx.de/wiki/U-Boot/ReleaseCycle
Changed text slightly.
Commit 2ee951ba (UBI: Enable re-initializing of the "ubi part" command)
reset mtd_devs in ubi_exit() but missed ubi_init()'s failure path.
Signed-off-by: Karl Beldan <karl.beldan@gmail.com>
Cc: Stefan Roese <sr@denx.de>
This change lays the groundwork for the BOOTFLAG_* flags being removed.
This change has the small affect of delaying 100ms on PCI initialization
after a warm boot as opposed to the optimal 1ms on some boards.
included the mpc8308_p1m board.
continuation of commit 39da1ba923d55f316f9f1bb3a960e4ed91dc17ac:
"e300: increase CONFIG_SYS_BOOTMAPSZ to allow booting large kernels"
Configuring for MPC8308RDB board...
pcie.c: In function 'mpc83xx_pcie_register_hose':
pcie.c:143: warning: assignment makes pointer from integer without a cast
This patch provides support for MPC8308 P1M board with the following
set of features:
Dual UART is supported
NOR flash is supported
Both TSEC Ethernet controllers are supported
PCI Express initialization is supported
Both I2C controllers are supported
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This patch cleans up the Freescale MPC8308RDB Development board support.
Things fixed:
- Removed unused PCIE2 definitions from configuration
- SICR{L,H} defines used for System I/O Configuration Registers values
instead of hardcoding
- CONFIG_SYS_SCCR_PCIEXP1CM used to enable PCIE clock instead of
writing to SCCR from the board code
- sleep mode stuff removed as MPC8308 has no support for deep sleep and
PMCCR1 register. board_early_init_f() removed.
- MPC8308 has no ERRATA for DDR controller so workaround removed
- 'assignment in if statement' issues solved
- use LBLAWAR_* defines instead of hardcoding
This patch adds defines to set supported fields in System I/O
Configuration Registers High and Low on Freescale MPC8308 CPU.
This patch adds support for setting PCIE clocks in cpu_init.c by
providing CONFIG_SYS_SCCR_PCIEXP{1,2} in configuration.
MPC8308 has only one PCIE host controller so we want it to compile
without CONFIG_SYS_PCIE2_CFG_{BASE,SIZE} defined.
Newer Linux kernels can overrun the initial memory window used for
booting with their BSS area. When this happens, they overwrite the FDT
and silently fail to boot.
On e300 CPUs, the Linux kernel uses an initial BAT covering the first
256MB of RAM. See arch/powerpc/kernel/head_32.S for details. Increase
the value of CONFIG_SYS_BOOTMAPSZ to accommodate the maximum value
allowed by Linux. This will allow very large kernels to boot.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
The default partition table matches the .dts files for these boards in
Linux. This allows these partitions to be used by name with U-Boot's
"nand" command.
By default the trace broadcast is enabled on 44x systems.
To reduce power consumption when instruction tracing is
not needed, disable trace broadcast.
Check External Debug Mode (EDM) bit to detect if it should be
disabled or not.
Resetting system via a debugger will set the DBCR0[EDM] bit.
Resetting via u-boot or OS will not.
Signed-off-by: Victor Gallardo <vgallardo@apm.com>
This patch cleans the PVR detection code in check_cpu() up a bit.
Basically the strings are better seperated, resulting in an easier
to understand and maintain code version.
The #ifdef's couldn't be removed easily because of two reasons:
- Some SoC revisions have the same PVR, so need a way to differentiate
between those two SoC's.
- In some case statements registers only available in this SoC variant
are referenced.
Instead I moved the CONFIG_440 #ifdef a bit, so that 405 platforms don't
add this 440 detection code and vice versa. Resulting in this U-Boot
image size change:
405EX (Kilauea): 408 bytes less
440EPx (Sequoia): 604 bytes less
460EX (Canyonlands): 564 bytes less
Remove some unused functionality to make U-Boot build again.
Especially PCI is not used on the board.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO
feature from U-Boot. It has only been implemented for PPC4xx and was not
used at all. So let's remove it and make the code smaller and cleaner.
Acked-by: Detlev Zundel <dzu@denx.de>
CONFIG_UART1_CONSOLE was a PPC4xx specific implementation and is now
removed since the move from the 4xx UART driver to the common NS16550
UART driver. Let's remove all references to this define now.
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
This cleanup is done by creating header files for all SoC versions and
moving the SoC specific defines into these special headers. This way the
common header ppc405.h and ppc440.h can be cleaned up finally.
As a part from this cleanup, the GPIO definitions for PPC405EP are
corrected. The high and low parts of the registers (for example
CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in
the wrong order. This patch now fixes this issue by switching these
xxxH and xxxL values. This brings the GPIO 405EP port in sync with all
other PPC4xx ports.
This patch starts a bit PPC4xx header cleanup. First patch mostly
touches PPC440 files. A later patch will touch the PPC405 files as well.
This patch moves some ppc4xx related headers from the common include
directory (include/) to the powerpc specific one
(arch/powerpc/include/asm/). This way to common include directory is not
so cluttered with files.
This patch changes the behaviour of the fdt_fixup_nor_flash_node()
function. Now it doesn't patch the size of the "reg" property with the
chip-select size, but with the size returned from the new function
flash_get_bank_size(). This function will return per weak default the
flash size of the bank (bank = chip-select numer) detected by the flash
driver. If this does not fit your needs, this function may be overridden
by a board specific one.
For this the parameters needed to be changed. So I intentionally squashed
the PPC4xx stuff using this routine into this patch. Otherwise it would
not be git-bisectable anymore.
The board specific function for the AMCC/APM Ebony eval board is now
included in this patch version.
Tested-by: Detlev Zundel <dzu@denx.de>
Cc: Gerald Van Baren <vanbaren@cideas.com>
This patch fixes a problem in the PPC4xx POST UART driver. This driver
incorrectly used the in/out8() io-accessor functions. This could lead to
problems since these functions don't guarantee execution ordering. This
patch now replaces these functions with the correct ones.
Additionally the driver is converted to using the NS16550 struct instead
of macros for the register offsets.
And some common code is factored out for better maintainability.
