Misaligned warnings are useful to debug faulty drivers.
A misaligned warning is printed also when the driver
is correct - use debug() instead of printf().
CC: Albert Aribaud <albert.u.boot@aribaud.net>
CC: Mike Frysinger <vapier@gentoo.org>
CC: Marek Vasut <marex@denx.de>
Since commit 5c1ad3e6f8ae578bbe30e09652f1531e9bc22031
(net: fec_mxc: allow use with cache enabled) the FEC_MXC
driver uses flush_dcache_range() and invalidate_dcache_range()
functions. This driver is also configured for ARM1136 based
'flea3' and 'mx35pdk' boards which currently do not build
as there are no ARM1136 specific flush_dcache_range() and
invalidate_dcache_range() functions. Add various ARM1136
cache functions to fix building for 'flea3' and 'mx35pdk'.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
On mx6qsabrelite the console is ttymxc1.
Add boot switch setting information into the README
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
disabled by default until drivers are fixed
Currently, board files are setting this field to 0x01
which the manual says is a reserved value. Change to
use the default of 0x02 - 128 cycles.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
Add a README file for mx28evk board.
Split the README into a common part and a m28 specific part.
This will make things easier when adding new README files for other mx28
based boards.
Signed-off-by: Bernhard Walle <walle@corscience.de>
Since kernel should be in a ubifs partition, we need UBIFS.
The greater malloc size is needed for UBIFS.
Squashed two commits (UBIFS enabled and malloc size increased) into one.
Signed-off-by: Thomas Weber <weber@corscience.de>
The reset_net_chip() function has wrong timings for the reset pulse.
This appeared to work until:
0607e2b (ARMV7: OMAP: Write more than 1 byte at a time in i2c_write)
Fix the Ethernet support by introducing right timings.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
With older toolchains we need CONFIG_SPL_LIBGENERIC_SUPPORT in order for
CONFIG_SPL_NAND_SUPPORT to link.
Remove userbutton command and do the detection in board config file using the gpio command
Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com>
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
After removing omap1610inn for not building, move omap1510inn to
orphaned. Also update boards.cfg to note it's part of the 'omap' SoC to
make sure the board is built more often and future breakage noticed
quicker.
* 'marek.vasut@gmail.com' of git://git.denx.de/u-boot-staging:
LMB: Fix undefined lmb_reserve() on non-lmb platforms
MIPS: fix endianess handling
MIPS: fix inconsistency in config option for cache operation mode
MIPS: board.c: fix init of flash data in bd_info
* 'master' of git://git.denx.de/u-boot-net:
net/designware: Change timeout loop implementation
net/designware: Set ANAR to 0x1e1
net/designware: Program phy registers when auto-negotiation is ON
net/designware: Try configuring phy on each dw_eth_init
net/designware: Consecutive writes must have delay
net/designware: Phy address fix
net/designware: Fix the max frame length size
net/designware: Fix to restore hw mac address
microblaze: Wire up LL_TEMAC driver initialization
microblaze: Add faked LL_TEMAC driver configuration
microblaze: Enable several ethernet driver compilation
net: ll_temac: Add LL TEMAC driver to u-boot
Update net subsystem maintainer in doc/git-mailrc
net/eth.c: fix eth_write_hwaddr() to use dev->enetaddr as fall back
mvgbe: remove warning for unused methods
* 'master' of git://git.denx.de/u-boot-onenand:
onenand: samsung: Enable OneNAND support at Samsung's Exynos4210
onenand: Replace ONENAND_IS_MLC() with ONENAND_HAS_4KB()
onenand:samsung OneNAND chip probe functions added for GONI and Exynos4210
onenand:samsung Target dependent OneNAND chip probe function
* 'master' of git://git.denx.de/u-boot-nios:
nios2 - adjust gbl data off to account for bd_info
nios2: implement get_ticks and get_tbclk
nios2: add flush_dcache_range function
* 'master' of git://git.denx.de/u-boot-x86:
x86: Remove dead code in eNET
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Tom Warren <TWarren@nvidia.com>
Cc: Graeme Russ <graeme.russ@gmail.com>
The new implementation changes the timeout loop implementation to avoid 1 ms
delay in each failing test. It also configures the delay to 10usec.
Signed-off-by: Amit Virdi <amit.virdi@st.com>
This patch forces the advertised capabilities during auto
negotiation to always be 10/100 Mbps and half/full as duplexing.
Signed-off-by: Armando Visconti <armando.visconti@st.com>
If AN(auto-negotiation) is ON, speed bit of control register are not
applicable. Also phy registers were not getting programmed as per the
result of AN. This patch sets only AN bit & restart AN bit for AN ON
selection & programs PHY registers as per AN result.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
Phy autonegotiation works only when the ethernet cable is plugged in.
Since the phy was configured only at the init time, a plugged in cable
was necessary to initialize the phy properly.
This patch keeps a flag to check if the phy initialization has
succeeded, and calls configure_phy routine at every init if this flag
reports otherwise.
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
This patch solves a TX/RX problem which happens at 10Mbps, due to the
fact that we are not respecting 4 cyles of the phy_clk (2.5MHz) between
two consecutive writes on the same register.
The code assumes the phy address to be > 0, which is not true, the phy address
can be in the range 0-31.
The max frame length for normal descriptor can be 0x7FF i.e 2047. It was wrongly
specified as 2048. Currently, the max descriptor length is around 1500, so
redefining the mask to 1600
The network controller mac resets hardware address stored in MAC_HI and MAC_LO
registers if mac is resetted. So, hw mac address needs to be restored in case
mac is explicitly resetted from driver.
Enable OneNAND support for Exynos4210 (C210 universal).
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
This replacement causes 4KB page size devices to work properly with u-boot.
The old ONENAND_IS_MLC() behavior has been preserved by explicit
setting of ONENAND_HAS_4KB_PAGE for those devices.
This change makes the onenand_base.c file more resembling the respective
kernel sources.
Test HW:
- Samsung S5PC110 GONI
- Samsung S5PC210 Universal
Initialize ll_temac driver.
Reported-by: Michal Simek <monstr@monstr.eu>
Signed-off-by: Stephan Linz <linz@li-pro.net>
Expand the specific configuration for the microblaze-generic
board in xparameters.h with a faked setup to enable the
LL_TEMAC driver.
Note: From now the microblaze-generic board is no longer a
valid board configuration for a real piece of hardware. Rather
than, we use the file config.mk and xparameters.h as a faked
board configuration to force the compilation of all potential
driver code for Microblaze systems.
U-Boot's multipple network supports enables to use
several ethernet drivers but microblaze-generic
platform config file select only one driver.
Xilinx LocalLink Tri-Mode Ether MAC driver can be
used by Xilinx Microblaze or Xilinx ppc405/440 in
SDMA and FIFO mode. DCR or XPS bus can be used.
The driver uses and requires MII and PHYLIB.
CP: 4 warnings: 'Use of volatile is usually wrong'
I won't fix this, because it depends on the network
driver subsystem.
Separate callback for probing OneNAND memory chip.
Tested at:
Samsung Exynos4210 (S5PC210 Universal)
If no special function is defined, default implementation will be used.
This approach gives more flexibility for OneNAND device probing.
Signed-off-by: Joe Hershberger <joe.hershberger@gmail.com>
Ignore the return value of eth_getenv_enetaddr_by_index(), and if it
fails, fall back to use dev->enetaddr, which could be filled up by
the ethernet device driver:
With the current code, introduced with below commit, eth_write_hwaddr()
will fail immediately if there is no eth<n>addr in the environment variables.
However, e.g. for an overo based product that uses the SMSC911x ethernet
chip (with the MAC address set via EEPROM connected to the SMSC911x chip),
the MAC address is still OK.
On mx28 boards that are depending on the OCOTP bits to set the MAC address
(like the Denx m28 board), the OCOTP bits should be used instead of
failing on the environment variables.
Actually, this was the original behavior, and was later changed by
commit 7616e7850804c7c69e0a22c179dfcba9e8f3f587.
Signed-off-by: Eric Miao <eric.miao@linaro.org>
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
CC: Stefan Roese <sr@denx.de>
CC: Eric Miao <eric.miao@linaro.org>
CC: Wolfgang Denk <wd@denx.de>
CC: Philip Balister <philip@balister.org>
CC: Zach Sadecki <zach@itwatchdogs.com>
Some baords may use the GBE interface but they have no
phy connected to the interface and a direct MAC/MAC interface.
For them we need to get rid of compiler warnings.
Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
Make endianess of target CPU configurable. Use the new config
option for dbau1550_el and pb1000 boards.
Adapt linking of standalone applications to pass through
endianess options to LD.
Build tested with:
- ELDK 4 mips_4KC- and mips4KCle
- Sourcery CodeBench Lite 2011.03-93
With this patch all 26 MIPS boards can be compiled now in one step by
running "MAKEALL -a mips".
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Commit ab2a98b11716364bc5a8c43cdfa7fee176cda1d8 missed to
use the new config option in dcache_enable().
Fix this to avoid inconsistencies if someone wants to disable
and enable D-caches.
Boards with CONFIG_SYS_NO_FLASH should not forced to define
CONFIG_SYS_FLASH_BASE. In this case the flash data in bd_info
should be initialized with 0 like the other archs do.
This avoids a compiler warning about unused variables.
Acked-By: Graeme Russ <graeme.russ@gmail.com>
flush_dcache is not declared in the common.h API,
flush_dcache_range however is
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: Ben Warren <biggerbadderben@gmail.com>
Cc: Thomas Chou <thomas@wytron.com.tw>
Acked-by: Thomas Chou <thomas@wytron.com.tw>
