replace all occurences of CONFIG_PRELOADER with CONFIG_SPL_BUILD
Signed-off-by: Aneesh V <aneesh@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
* Fix: if using md5 command watchdog timed out
* change function call md5(..) to the watchdog-safe variant
md5_wd(..) to support watchdog reset
Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
* Fix: if using sha1 command watchdog timed out
* change function call sha1_csum(..) to the watchdog-safe variant
sha1_csum_wd(..) to support watchdog reset
It might be desirable to have the ability to flush icache/dcache
within u-boot, this patch gives each arch the ability to provide
a flush_dcache/flush_icache function to let u-boot flush caches
from the prompt
Signed-off-by: Matthew McClintock <msm@freescale.com>
Print a message if we do not have the ability to uncompress a gzip
image. Before, u-boot would just assume the routines were available
If we don't want to build support for any partition types we can now
add #undef CONFIG_PARTITIONS in a board config file to keep this from
being compiled in. Otherwise boards assume this is compiled in by
default
In miiphy_register() the new device's name was initialised by passing a
string parameter as the format string to sprintf(). As this would cause
problems if it ever contained a '%' symbol, switch to using strncpy()
instead.
Signed-off-by: Laurence Withers <lwithers@guralp.com>
Cc: Andy Fleming <afleming@freescale.com>
When booting with a ramdisk we bump the amount of memory reserved for
the device tree by FDT_RAMDISK_OVERHEAD. However we did not increase
the actual size in the device tree blob to match.
Its possible on boundary cases that we dont have enough memory according
to the device tree blob and get errors like:
WARNING: could not set linux,initrd-end FDT_ERR_NOSPACE
We can easily fix this by setting the device tree size at the same time
we bump the amount of memory reserved for the device tree.
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
This reverts commit f18714dd61331b48ab9dc0ef717d61f1441a0e17
which cuases compile errors on a number of boards.
* Fix: if using crc32 command watchdog timed out
* change function call crc32(..) to the watchdog-safe variant
crc_32_wd(..) to support watchdog reset
In some cases (e.g. bootm with a elf payload which is already at the right
position) there is a in place copy of data to the same address. Catching this
saves some ms while booting.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
Add support for AHCI controllers that are not PCI based.
The ata id string always needs swapping, not just on BE machines.
This include is needed, if this memory test is used "outside"
from post code, for example booting with nand_spl, and using
this memory test before copying u-boot code to RAM and jumping
to it.
andes_spi is an spi interface developed by Andes Tech.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
Remove an unneeded prototype declaration from the top of main.c,
and use plain inline instead of __inline__ to please checkpatch.
When CONFIG_DW_SEARCH_PHY is disabled, the local phy_addr variable
never gets initialized which causes random behavior at runtime and a
gcc warning. So set it by default to the stored phy address.
Reviewed-by: Vipin Kumar <vipin.kumar@st.com>
Fix commit message.
The ctrl variable is only used when autoneg support is disabled, so only
declare it under those conditions to avoid an unused variable warning.
Rather than having a bunch of random commands handle autostart behavior,
unify the logic in a single place. This also fixes building of these
different commands when bootm is disabled.
Acked-by: Matthew McClintock <msm@freescale.com>
Acked-by: Scott Wood <scottwood@freescale.com>
We need a TLB entry to call get_ram_size(); the common code doesn't create
one until *after* fixed_sdram() has determined the size. So we set up tlbs
for the max possible size and tear them down once we're done with
get_ram_size(); the common 85xx code will then set up a final set of tlb
entries for the *actual* detected size of ddr.
This prevents us from having TLB entries that are larger than DDR sitting
around for very long, which is not a recommended scenario.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
This is useful when we just want to wipe out the TLBs. There's currently
a function that resets the ddr tlbs to a different value; it is changed to
utilize this function. The new function can be used in conjunction with
setup_ddr_tlbs() for a board to temporarily map/unmap the DDR address
range as needed.
The Fman device tree node binding allows for the entire Fman firmware binary
data to be embedded in the device tree. This eliminates the need to have
NOR flash mapped to Linux just so that the Fman driver can see the firmware.
The location of the Fman firmware is taken from the 'fman_ucode' environment
variable.
The ePAPR specification says that phandle properties should be called
"phandle", and not "linux,phandle". To facilitate the migration from
"linux,phandle" to "phandle", we update fdt_qportal() to use the new
function, fdt_create_phandle(). This function abstracts the creation of
phandle properties.
* 'master' of git://git.denx.de/u-boot-mmc:
mmc: rescan fails on empty slot
AT91:mmc:fix multiple read/write error
mmc: Access mode validation for eMMC cards > 2 GiB
mmc: sh_mmcif: add support for Renesas MMCIF
mmc: fix the condition for MMC version 4
MMC: add marvell sdhci driver
MMC: add sdhci generic framework
MMC: add erase function to both mmc and sd
MMC: unify mmc read and write operation
mmc: Tegra2: Enable SD/MMC driver for Seaboard and Harmony
mmc: Tegra2: SD/MMC driver for Seaboard - eMMC on SDMMC4, SDIO on SDMMC3
* 'master' of git://git.denx.de/u-boot-arm:
ARM: MX5: Fix broken leftover TO-2 errata workaround
MX31: Cleanup clock function
scb9328: Add ARM relocation support
am3517evm: change console device from ttyS2 to ttyO2
Remove volatile qualifier in get_ram_size() calls
TI: TNETV107X Fix Build Error
ARM: add missing CONFIG_SKIP_LOWLEVEL_INIT for armv7
arm: add CONFIG_MACH_TYPE setting and documentation
arm: add __ilog2 function
Timer: Fix misuse of ARM *timer_masked() functions outside arch/arm
EfikaMX: Enable EXT2 booting
EfikaMX: Add missing CONFIG_SYS_TEXT_BASE
EfikaMX: Use correct imximage.cfg
MX27: Update to autogenerated asm-offsets.h
MX5: Update to autogenerated asm-offsets.h
imx: Add support for zmx25 board
imx: Make imx25 compatible to mxc_gpio driver and fix in tx25
imx: Add auto generation of asm-offsets.h for imx25
imx: Add support for USB EHCI on imx25
imx: Use correct imx25 reset.c
imx: Add get_tbclk() function for imx25
ARM: Update maintainer of board scb9328
mx27: Make the UART port number explicit
build: Add targets for auto gen of asm-offsets.h and use it in imx35
mx31pdk: cosmetic: Fix line over 80 characters
* 'master' of git://git.denx.de/u-boot-mpc85xx:
powerpc/p2041rdb: Add p2041rdb board support
powerpc/85xx: Fix detection of P1017E
powerpc/mpc8548cds: Remove incorrect DDR_MSYNC_IN erratum define
This check was broken. r3 does not contain the silicon revision anymore, so
we need to reload it. Also, this errata only applies to i.MX51.
Signed-off-by: David Jander <david@protonic.nl>
The patch provide the same API used with other i.MX
processors and get rid of mx31_ functions.
This patch fixes compiler errors due to missing definitions of
CONFIG_SYS_SDRAM_BASE and CONFIG_SYS_INIT_SP_ADDR.
It also does some cleanup: CONFIG_SYS_TEXT_BASE was moved to scb9328.h,
obsolete config.mk was removed. The scb9328 board has 1 DRAM bank, so don't
ask for more banks. CONFIG_NR_DRAM_BANKS will ever be 1.
Signed-off-by: Torsten Koschorrek <koschorrek@synertronixx.de>
the serial device names have been changed from ttySx to ttyOx, so the
console device name should be also changed to support the latest kernel
versions.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
Acked-by: Vaibhav Hiremath<hvaibhav@ti.com>
P2041RDB Specification:
Memory subsystem:
* 4Gbyte unbuffered DDR3 SDRAM SO-DIMM(64bit bus)
* 128 Mbyte NOR flash single-chip memory
* 256 Kbit M24256 I2C EEPROM
* 16 Mbyte SPI memory
* SD connector to interface with the SD memory card
Ethernet:
* dTSEC1: connected to the Vitesse SGMII PHY (VSC8221)
* dTSEC2: connected to the Vitesse SGMII PHY (VSC8221)
* dTSEC3: connected to the Vitesse SGMII PHY (VSC8221)
* dTSEC4: connected to the Vitesse RGMII PHY (VSC8641)
* dTSEC5: connected to the Vitesse RGMII PHY (VSC8641)
PCIe:
* Lanes E, F, G and H of Bank1 are connected to one x4 PCIe SLOT1
* Lanes C and Land D of Bank2 are connected to one x4 PCIe SLOT2
SATA: Lanes C and Land D of Bank2 are connected to two SATA connectors
USB 2.0: connected via a internal UTMI PHY to two TYPE-A interfaces
I2C:
* I2C1: Real time clock, Temperature sensor, Memory module
* I2C2: Vcore Regulator, 256Kbit I2C Bus EEPROM, PCIe slot1/2
UART: supports two UARTs up to 115200 bps for console
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
Had a typo such that P1017E would not be detected correctly.
Checkpatch.pl complains about the volatile qualifier in calls to
get_ram_size(). Remove this qualifier in the prototype and in the
calls where it is useless, and leave it only in the function body
where it is needed.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This patch provides SDRAM base address and initial stack address to fix
build errors.
Signed-off-by: Chan-Taek Park <c-park@ti.com>
cpu_init_crit can be skipped, but the code is still enabled requiring a
platform to supply lowlevel_init.
Cc: Albert ARIBAUD <albert.aribaud@free.fr>
CONFIG_MACH_TYPE is used to set the machine type number in the
common arm code instead of setting it in the board code.
Boards with dynamically discoverable machine types can still set the
machine type number in the board code.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Add a new "fdt_high" enviroment variable. This can be used to control (or prevent) the
relocation of the flattened device tree on boot. It can be used to prevent relocation
of the fdt into highmem. The variable behaves similarly to the existing "initrd_high"
variable.
Signed-off-by: David A. Long <dave.long@linaro.org>
Add __ilog2 function for ARM. Needed for ahci.c
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Fail in 'mmc rescan' if mmc_init() returns error
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
Acked-by: Andy Fleming <afleming@freescale.com>
According to datasheet,set block count before multiple read/write.
Signed-off-by: elen.song <elen.song@atmel.com>
This patch provides handling of the two way handshake when SEND_OP_COND
(CMD1) is send to mmc card. It is necessary to inform eMMC card if the
host can work with high capacity cards (Jedec JESD84-A441, point 7.4.3).
The extra flag MMC_MODE_HC (high capacity) is added to indicate if the
host is capable of handling the high capacity eMMC cards.
Since this change is added to the generic mmc framework, then it requires
other boards to indicate if their mmc controllers can handle high capacity
cards. As it is now - the old behaviour of the framework is preserved.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
