Clean Makefile
Move device specific values to driver for better reading
Microblaze and PowerPC use boot_get_ramdisk for loading
ramdisk to memory with checking return value.
Return 0 means success. Return 1 means failed.
Here is correspond part of code from bootm.c which check
return code.
ret = boot_get_ramdisk (argc, argv, images, IH_ARCH_PPC,
&rd_data_start, &rd_data_end);
if (ret)
goto error;
Redesign uartlite driver to in_be32 and out_be32 macros
Fix missing header in io.h
which happened when rounding the serial port clock divisor
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
caused by missing dcache status/enable/disable functions.
This patch removes some ft_board_setup() functions from some 4xx boards.
This can be done since we now have a default weak implementation for this
in cpu/ppc4xx/fdt.c. Only board in need for a different/custom
implementation like canyonlands need their own version.
Mail to kharris@nexus-tech.net bounces because the user doesn't exist
anymore. You can't be a maintainer without a valid e-mail address, so
move all boards that used to be maintained by Kyle Harris to the
"orphaned" list.
Currently, only PowerPC has a list of orphaned boards, so this patch
creates one for ARM as well.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
On the at91sam9260ep development board there is an EEPROM
connected to the TWI interface (PA23, PA24 Peripheral A
multiplexing), so we cannot use these pins as ETX2, ETX3.
This patch configures PA10, PA11 pins for ETX2, ETX3
instead of PA23, PA24 pins.
Signed-off-by: Manuel Sahm <Manuel.Sahm@feig.de>
The DIU_DIV register is 8 bit not 5 bit. This prevented large DIV values
so it was not possible to set a slow pixel clock and thus prevented
display on small screens.
Signed-off-by: Kenneth Johansson <kenneth@southpole.se>
Acked-by: John Rigby <jrigby@freescale.com>
board/ads5121/iopin.c
Replace bit fields in struct iopin_t with a single
field and intialize it via plain old macros.
This fixes the type pun warnings and makes the code
more readable.
board/ads5121/ads5121.c
Add include iopin.h to ads5121.c for the iopin_initialize
prototype.
Add an extern void ads5121_diu_init(void)
Signed-off-by: John Rigby <jrigby@freescale.com>
Remove all CFG_CSn_RO in cpu/mcf52x2/cpu_init.c. If
CFG_CSn_RO is defined as 0, the chipselect will not
be assigned.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Rename CONFIG_MCFTMR to CONFIG_MCFRTC to include real time
clock module in cpu/<cf arch>/cpu_init.c
Add #define CONFIG_MCFTMR in EB+MCF-EV123.h configuration file
Rename int mii_init(void) to void mii_init(void)
The compiling error was caused by missing a closed parentheses
in speed.c
The timer was assigned to wrong timer memory mapped which
caused udelay() and timer() not working properly.
Signed-off-by: Kurt Mahan <kmahan@freescale.com>
The formula "counter = (u32) (gd->bus_clk / gd->baudrate) / 32"
can generate the wrong divisor due to integer division truncation.
Round the calculated divisor value by adding 1/2 the baudrate
before dividing by the baudrate.
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
This patch now moves common.h to the top of the inlcude list. This
is needed for boards with CONFIG_PHYS_64BIT set (e.g. katmai), so that
the phys_size_t/phys_addr_t are defined to the correct size in this
driver.
Some boards based on AT91SAM926X-EK use smaller DF chips to keep
bootstrap, u-boot and its environment, using NAND or other external
storage for kernel and rootfs. This patch adds support for
small 1024x263 chip.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
This patch fixes a potentially serious issue related to USB which was
discouvered by Martin Krause <martin.krause@tqs.de> and fixed for
ARM920T. Martin wrote:
Turn off USB to prevent the host controller from writing to the
SDRAM while Linux is booting. This could happen, because the HCCA
(Host Controller Communication Area) lies within the SDRAM and the
host controller writes continously to this area (as busmaster!), for
example to increase the HccaFrameNumber variable, which happens
every 1 ms.
This is a slightly modified version of the patch in order to shutdown
USB when booting on all architectures.
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
ADS5121 Rev 3 board is now the default config
config targets are now
ads5121_config
Rev 3 board with
PCI
M41T62 on board RTC
512MB DRAM
ads5121_rev2_config
Rev 2 board with
No PCI
256MB DRAM
Signed-off-by: Martha Marx <mmarx@silicontkx.com>
Consolidate ADS5121 IO Pin configuration to one file
board/ads5121/iopin.c.
Remove pin config from cpu/mpc512x/fec.c
Only print partition for selected device if user supplied the <dev>
arg with the "usb part [dev]" command.
Signed-off-by: Christian Eggers <ceggers@gmx.de>
Acked-by: Markus Klotzbuecher <mk@denx.de>
