Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
and remove the now unused asm/arch-at91/io.h
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
Follow commit 8ae86b76c648d8bef97241c78e2fddb1c4f164d3
which changed the variable name.
Fix this error,
nios2-elf-ld: invalid hex number `-o'
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
Remove the last CONFIG_SYS_NAND_READ_DELAY occurance from nand_boot.c.
I missed this one in patch a9c847cb [nand_spl: nand_boot.c: Remove
CONFIG_SYS_NAND_READ_DELAY].
This fixes a compile breakage on kilauea_nand for example.
Cc: Scott Wood <scottwood@freescale.com>
There are multiple reasons why this define should be removed:
First it saves some space and therefore fixes a problem we have on
the canyonlands_nand and glacier_nand targets right now.
Second, the define was hackish and would most likely not work on all
board using nand_boot.c. Boards not providing a real dev_ready()
function should implement a board specific function instead.
I checked and it seems, that all boards using nand_boot.c right now
already implement a board specific dev_ready() function. So this
patch should not break any boards and will result in smaller
NAND_SPL images.
Cc: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Tested-by: Sughosh Ganu <urwithsughosh@gmail.com>
Patch 65a9db7b [nand_spl: Fix large page nand_command()] broke
nand booting on canyonlands. "options" has to be initialized to
0. If not, boards might have the NAND_BUSWIDTH_16 bit set,
resulting in wrong offset calculation.
Cc: Alex Waterman <awaterman@dawning.com>
The canyonland boards nand_spl size is just under the maximum 4KByte size. This
patch decreases the size of the nand_spl to make a previous commit - commit
65a9db7be0868be91ba81b9b5bf821de82e6d9b0 - fit in the nand_spl.
Signed-off-by: Alex Waterman <awaterman@dawning.com>
This reverts commit bbc6353c740064c8e0741b772376a1a67a1c3f01.
It breaks building on many systems:
.../common/env_embedded.c:28:20: fatal error: config.h: No such file or directory
compilation terminated.
.../common/image.c:27:20: fatal error: common.h: No such file or directory
.../lib/crc32.c:12:20: fatal error: common.h: No such file or directory
.../lib/md5.c:28:22: fatal error: compiler.h: No such file or directory
.../lib/sha1.c:33:20: fatal error: common.h: No such file or directory
Reword "The DIMM max tCKmin is ..." to "The DDR clock is faster than the slowest
DIMM(s) can support". Fixed interger type in printf as well.
Signed-off-by: York Sun <yorksun@freescale.com>
The compatible property for the L2 cache node (on 85xx systems that don't
have a CPC) was using a value for the property length that did not match
the actual length of the property.
calc_hdrcsum two times are checked. checksumi of exthdr is not checked.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Prafulla Wadaskar <prafulla@marvell.com>
Fix some missing declaration in header.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Add missing definitions in header file according to datasheet.
Un-nestted the register structure in ftsmc020.h
Avoid relocation problem by fix global declaration.
Faraday's ftide020_s is an IDE-AHB controller for SoC design.
This patch add the u-boot driver (PIO) of ftide020 ATA (IDE) driver.
IDE commands include read, info, and other functions has been implemented.
Because this IDE controller support AHB interface only which is differ
from other most IDE controller supports PCI interface. Some registers
access is required during CMD/DATA I/O. Hence a configuration
"CONFIG_IDE_AHB" is required to be defined according to the feature in
cmd_ide.c.
When your emulator is connected at reset (or is used to load u-boot)
it is possible to get the relocation address from the gd->relocaddr
since gd is always in r8 (on ARM) it is addressable before the
gdb has remapped symbols.
Document this alternate method in-line with the original method
written by Heiko Schocher.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
CC: Heiko Schocher <hs@denx.de>
CC: Wolfgang Denk <wd@denx.de>
Acked-by: Heiko Schocher <hs@denx.de>
The bdinfo command prints the relocaddr on ARM as it does
on PPC.
Update the debugging instructions for arm relocation to
reflect this fact rather than requiring that the user
rebuild the u-boot image using -DDEBUG.
cmd_bdinfo.c: clean up with 2.6.38 checkpatch.pl
Acked-by: Detlev Zundel <dzu@denx.de>
- remove from boards.cfg
- add to doc/README.scrapyard
Signed-off-by: Eric Bénard <eric@eukrea.com>
Now that we have the documentation, the code should be changed to reflect
it ;)
Asd far as I can see, these are the places where HW_WATCHDOG is used
instead of WATCHDOG:
arch/blackfin/cpu/blackfin/watchdog.c
arch/m68k/cpu/mcf547x_8x/cpu.c
The relevant maintainers are on CC.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Support registers definitions of ftsdmc021 SDRAM controller.
ftahbc020s.h provides basic definitions of this controller
to help a SoC which use this AHB Controller could
do scalable software settings in lowlevel_init.S.
Noticed while building all of mpc8xx. Also
constify usage string in timer.c
Warnings fixed are:
timer.c: In function 'timer':
timer.c:189: warning: format not a string literal and no format arguments
timer.c:258: warning: format not a string literal and no format arguments
atm.c: In function 'atmUnload':
atm.c:99: warning: array subscript is above array bounds
atm.c: In function 'atmLoad':
atm.c:65: warning: array subscript is above array bounds
codec.c: In function 'codsp_write_pop_int':
codec.c:678: warning: array subscript is above array bounds
codec.c: In function 'codsp_write_cop_short':
codec.c:585: warning: array subscript is above array bounds
codec.c: In function 'codsp_write_sop_int':
codec.c:512: warning: array subscript is above array bounds
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of
many comments about CONFIG_SYS_GBL_DATA_SIZE.
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
This patch adds support for the National LM64 temperature
sensor with integrated fan control to lm63.c.
Main difference between LM63 and LM64 is 16°C offset in sensor
readings.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
- don't include config.h when building with host cc,
- HOSTCFLAGS was defined with the wrong name, so wasn't used,
- make sure make finds sources outside of tools/.
Signed-off-by: François Revol <revol@free.fr>
Fix return values for initialize/init/recv/send functions
GNU Makefile have two flavors of variables, recursively expanded that is
defined by using '=', and simply expanded that is defined by using ':='.
The bug is caused by using recursively expanded flavor for BIN and SREC.
As you can see below, they are prepended by $(obj) twice.
We can reproduce this bug with a simplified version of this Makefile:
$ cat >Makefile <<\EOF
obj := /path/to/obj/
ELF := hello_world
BIN_rec = $(addsuffix .bin,$(ELF)) # recursively expanded
BIN_sim := $(addsuffix .bin,$(ELF)) # simply expanded
ELF := $(addprefix $(obj),$(ELF))
BIN_rec := $(addprefix $(obj),$(BIN_rec))
BIN_sim := $(addprefix $(obj),$(BIN_sim))
show:
@echo BIN_rec=$(BIN_rec)
@echo BIN_sim=$(BIN_sim)
.PHONY: show
EOF
$ make show
BIN_rec=/path/to/obj//path/to/obj/hello_world.bin
BIN_sim=/path/to/obj/hello_world.bin
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
This removes the following checkpatch issue:
- ERROR: do not use assignment in if condition
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it>
Cc: Ben Warren <biggerbadderben@gmail.com>
This removes the following checkpatch issues:
- ERROR: switch and case should be at the same indent
- WARNING: suspect code indent for conditional statements
- WARNING: labels should not be indented
- ERROR: return is not a function, parentheses are not required
- ERROR: "foo * bar" should be "foo *bar"
- ERROR: "(foo*)" should be "(foo *)"
