Create more generic names for the symbols exported from the linker script
By reserving space for the Global Data immediately below the stack during
assembly level initialisation, the C declaration of the static global data
can be removed, along with the 'RAM Bootstrap' function. This results in
cleaner code, and the ability to pass boot-up flags from assembler into C
By using another register, reduce code size by one instruction
%ebx will hold low-level boot flags and must be preserved
Using %ebp as a return pointer prevents creating 'load anywhere' images
To allow for 'load anywhere' images, the %ebp return pointer 'hack' must
be removed, so we cannot have two 'calls' to get_mem_size
Progress indication is not relocation friendly so remove it in
preperation for full relocatability support
Change to:
- reparam=3
- no-from-pointer
- no-stack-protector
- preferred-stack-boundary=2
- no-top-level-reorder
These options make the code a little smaller and faster
Perform some basic code cleanups of the x86 files
Linux has C macros and code to load the GTD after switching to Protected
Mode. Using these greatly simplifies the assembler code
Follow the discussion of Charles Manning and Mike Frysinger.
Using gc_sections helps reduce image size.
The header of recent Linux Kernels includes the size of the image, and
therefore is not needed to be passed to zboot. Still process the third
parameter (size of image) in the event that an older kernel is being loaded
Use TEXT_BASE rather than a hard-coded base address on x86 linker scripts.
This will allow any board to define its base link address without having
to modify the linker script
Relocation is not board-specific for the x86 architectrure, so
CONFIG_RELOC_FIXUP_WORKS can be defined globally in the config.h
Commit 55e97429d1e6cf0976711e4e0f29ea924b7e5917 removed the definition
from /arch/i386/include/asm/u-boot.h but not its usage in do_bdinfo()
The GPIO 16 and 19 reconfiguration should be done once USB is initialized.
So moved the reconfiguration to the USB init function.
Signed-off-by: Rupjyoti Sarmah <rsarmah@apm.com>
I accidentally left these hacks in the code while doing the big header
cleanup. Let's remove it now.
This patch changes the PPC4xx POST UART driver to use the common
NS16550 functions for receiving and sending. Additionally the
local function for SoC divisor setup are removed. Instead the
functions from arch/powerpc/cpu/ppc4xx/4xx_uart.c are used. This
removes code duplication.
Also the common CONFIG_SYS_NS16550_COMx defines are now used
to describe the POST UART's.
And a compile breakage is fixed, introduced by a git merge of
the ppc4xx/next branch into master. Now "ppc4xx.h" is moved to
"asm/ppc4xx.h". Fixed as well with this patch.
This patch fixes a bug in fdt_fixup_nor_flash_node() when the reg
property has multiple reg tuples, like:
reg = <0 0x00000000 0x04000000
0 0x04000000 0x04000000>;
In this case this function did not update the reg property correctly.
This patch brings the lwmon5 board support up-to-date. Here a
summary of the changes:
lwmon5 board port related:
- GPIO's changed to control the LSB transmitter
- Reset USB PHY's upon power-up
- Enable CAN upon power-up
- USB init error workaround (errata CHIP_6)
- EBC: Enable burstmode and modify the timings for the GDC memory
- EBC: Speed up NOR flash timings
lwmon5 board POST related:
- Add FPGA memory test
- Add GDC memory test
- DSP POST reworked
- SYSMON POST: Fix handling of negative temperatures
- Add output for sysmon1 POST
- HW-watchdog min. time test reworked
Additionally some coding-style changes were done.
Signed-off-by: Sascha Laue <sascha.laue@liebherr.com>
Add support code for bluestone board wth APM821XX processor based.
This patch includes early board init, misc init, configure EBC,
initializes UIC, MAKEALL, board.cfg and MAINTAINERS file.
Signed-off-by: Tirumala R Marri <tmarri@apm.com
APM821XX is a new line of SoCs which are derivatives of
PPC44X family of processors. This patch adds support of CPU, cache,
tlb, 32k ocm, bootstraps, PLB and AHB bus.
Signed-off-by: Tirumala R Marri <tmarri@apm.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Roderik Wildenburg <roderik.wildenburg@manroland.com>
The OTP code does a little shuffling of arguments that aren't really
necessary, so use a local variable instead to fix build errors now
that the args[] parameter is const.
Building this board for parallel flash fills up the bss section and thus
fails to link, so bump up the monitor size a bit.
Rather than use a hardcoded "7", use the new Blackfin global define.
The current size used (256KiB) is smaller than the LDR created for
the bf548-ezkit, so 'run update' doesn't work correctly. So bump
up the size a bit by making this flexible per-board config.
The board includes:
* ADSP-BF561 rev. 0.5
* 32-bit SDRAM (2 * MT48LC16M16A2TG or MT48LC32M16A2TG)
* Gigabit Ether AX88180 (ASIX) + 88E1111 rev. B2 (Marvell)
* SPI boot flash on PF2 (M25P64 8MB, or M25P128 16 MB)
* FPGA boot flash on PF3 (M25P64 8MB, or M25P128 16 MB)
* Spartan6-LX150 (memory-mapped; both PPIs also connected)
* See http://www.skutek.com/
Signed-off-by: Wojtek Skulski <skulski@pas.rochester.edu>
Since we're no longer extracting the env from the target ELF file (since
upstream wouldn't take that change), we're back to the problem of cpu
defines not properly propagating to the env setup stage. So the embedded
env built by the host compiler doesn't match the one that is linked into
the u-boot env.
Reported-by: Vivi Li <vivi.li@analog.com>
The intention all along was to accept pin names irrelevant of their case.
But I guess I forgot to test/implement support for that.
We need to use the Blackfin BootROM-specific OOB layout when we boot out
of NAND as that is what the on-chip ROM expects.
Also need to increase the monitor size a little to accommodate the extra
NAND code overhead.
We use the lock/unlock options in our default nand code, so enabl
support for the options.
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Let people easily override bootdelay and network settings.
Make the GPIO command usable in a scripting environment by returning
the GPIO value rather than always 0.
Support for the Blackfin System Development Platform (SDP) base module.
The input sub command was missing from the help text, and it didn't show
the actual value currently read on the GPIO. This allows people to read
the value of input pins.
The CONFIG_BFIN_CPU option is largely used in the build system, so move
it out of the board config.h and into the board config.mk. It'd be nice
to keep everything in the config.h, but the patch to extract that value
early was rejected.
