2010-07-16powerpc: Update configs to properly set FSL_ELBCBecky Bruce
Some parts that have an Enhanced Local Bus Controller weren't setting CONFIG_FSL_ELBC. Fix this so we can use this define properly going forward (currently it's only used if PHYS_64BIT is set, which meant not all platforms needed to have it set correctly). Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-1685xx/p1_p2_rdb: enable hwconfigPoonam Aggrwal
Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16Move ICS CLK chip frequency calculation code into a common board libraryKumar Gala
We have several boards that use the same ICS307 CLK chip to drive the System clock and DDR clock. Move the code into a common location so we share it. Convert the P2020DS board as the first to use the new common ICS307 code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Timur Tabi <timur@freescale.com>
2010-07-16ppc/85xx: Add a structure defn for PIXIS registersKumar Gala
The various boards that have PIXIS FPGAs have slightly different register definitions, however there is some common functionality (like reset, ICS307 clk control, etc) that can be shared. The struct definition exists for MPC8536DS, MPC8544DS, MPC8572DS, MPC8610HPCD, and MPC8641HPCN boards. Also fixed ngpixis to be __packed__ instead of aligned. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc/8xxx: Add is_core_disabled to remove disabled cores from dtbKumar Gala
If we explicitly disabled a core remove it from the dtb we pass on to the kernel. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc8xxx: Remove cpu-handles for cpus we deleteKumar Gala
We may have cpu-handles pointing to the cpu nodes we delete. If so we should delete the handles as well. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc/8xxx: Add base support for the SEC4Kim Phillips
Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc/8xxx: Distinguish between incompatible SEC h/w typesKim Phillips
CONFIG_SYS_FSL_SEC_COMPAT is set to 2 for the SEC 2.x and SEC 3.x. Parts with newer SEC h/w versions will increment the number to accomodate incompatible code changes. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16fdt: move fsl specific code from common fdt area to mpc8xxx/fdt.cKim Phillips
2010-07-14Merge branch 'next' of git://git.denx.de/u-boot-niosWolfgang Denk
2010-07-14Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2010-07-14Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2010-07-14Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-07-13Blackfin: bf561-acvilon: drop unused env redund defineMike Frysinger
The SPI env code didn't support redundant environments until recently, but this code was written before that. Since it has never been tested (and currently causes a build failure), simply punt it. If the functionality is actually desired, it can be re-added once it has been tested. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: drop old u-boot.lds clean targetMike Frysinger
The u-boot.lds CPP unification missed the Blackfin-specific clean target. It is no longer needed, so punt it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: bf527-ad7160-eval: new board supportMichael Hennerich
Support the new AD7160 eval board. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: enable IP defrag for ADI boardsMike Frysinger
2010-07-13Blackfin: bfin_mac: remove space from nameMike Frysinger
Some commands (like 'mii') use this name to select devices, but they break when those names contain spaces. So drop the space from the Blackfin EMAC driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: unify default I2C settings for ADI boardsMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2010-07-13Blackfin: bf561: use DMA for Core B L1 regionsMike Frysinger
The L1 regions of Core B are not directly accessible from Core A, so we need to use DMA to get at them. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: cm-bf548: convert to portmux frameworkMike Frysinger
Rather than bang MMRs directly, use the new portmux framework to handle the details. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: bf527-ezkit: convert to portmux frameworkMike Frysinger
2010-07-13Blackfin: bf548-ezkit: convert to portmux frameworkMike Frysinger
2010-07-13Blackfin: bf518f-ezbrd: convert to portmux frameworkMike Frysinger
2010-07-13Blackfin: bf518f-ezbrd: handle different PHYs dynamicallyMike Frysinger
The original BF518F-EZBRD's have a Micrel KSZ8893 DSA on them, but newer ones only have a National PHY (which lack a RX Error interrupt line). So in the board eth init code, dynamically detect what is hooked up to the MAC and handle each accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: bf533-stamp: scrub unused codeMike Frysinger
Much of the local bf533-stamp.h header is unused, and the few bits that are are only needed in one file. So move the few used bits out and punt all the rest. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: blackstamp: convert eth/flash swap logic to gpio frameworkMike Frysinger
2010-07-13Blackfin: bf533-stamp: convert eth/flash swap logic to gpio frameworkMike Frysinger
2010-07-13Blackfin: bfin_spi: support gpios as chip selectsMike Frysinger
Rather than only support the pins dedicated as chip selects, utilize the gpio framework to support any gpio pin. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: bfin_spi: convert to portmux frameworkMike Frysinger
2010-07-13Blackfin: serial: convert to portmux frameworkMike Frysinger
Use the new portmux framework to handle the details when possible. Unfortunately, we cannot yet use this in the standalone initialization logic, so we need to keep around the old portmux writes for now. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: pata_bfin: convert to portmux frameworkMike Frysinger
2010-07-13Blackfin: bfin_sdh: convert to portmux frameworkMike Frysinger
2010-07-13Blackfin: bfin_nand: convert to portmux frameworkMike Frysinger
Rather than bang MMRs directly, use the new portmux framework to handle the details. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Scott Wood <scottwood@freescale.com>
2010-07-13Blackfin: bfin_mac: convert to portmux frameworkMike Frysinger
Rather than bang MMRs directly, use the new portmux framework to handle the details. While we're doing this, let boards declare the exact list of pins they need in case there is one or two they don't actually have hooked up. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12edminiv2: add ethernet supportAlbert Aribaud
Add edminiv2 board support for mv_egiga. Add edminiv2 config to enable mv_egiga. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12mvgbe: add support for orion5x GbE controllerAlbert Aribaud
Add definitions and initialization in orion5x for mvgbe. Add orion5x in mvgbe SoC includes. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12mvgbe: support SoCs other than kirkwoodAlbert Aribaud
Rename all references to kirkwood in mvgbe symbols throughout the whole codebase. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12net: rename: kirkwood_egiga as mvgbeAlbert Aribaud
Rename kirkwood_egiga.* to mvgbe.* and adjust makefile and #include accordingly. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12kirkwood_egiga: CONFIG_SKIP_LOCAL_MAC_RANDOMIZATIONAlbert Aribaud
This configuration option allows SoCs without random generation capability to fill in local MACs with a fixed rather than random value Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12NAND: formatting cleanups from env.oob supportScott Wood
Change if (ok) { bunch of stuff } else { error } to if (error) { get out } proceed with bunch of stuff Plus a few whitespace cleanups. Signed-off-by: Scott Wood <scottwood@freescale.com>
2010-07-12NAND: environment offset in OOB (CONFIG_ENV_OFFSET_OOB)Ben Gardiner
This is a re-submission of the patch by Harald Welte <laforge@openmoko.org> with minor modifications for rebase and changes as suggested by Scott Wood <scottwood@freescale.com> [1] [2]. This patch enables the environment partition to have a run-time dynamic location (offset) in the NAND flash. The reason for this is simply that all NAND flashes have factory-default bad blocks, and a fixed compile time offset would mean that sometimes the environment partition would live inside factory bad blocks. Since the number of factory default blocks can be quite high (easily 1.3MBytes in current standard components), it is not economic to keep that many spare blocks inside the environment partition. With this patch and CONFIG_ENV_OFFSET_OOB enabled, the location of the environment partition is stored in the out-of-band (OOB) data of the first block in flash. Since the first block is where most systems boot from, the vendors guarantee that the first block is not a factory default block. This patch introduces the 'nand env.oob' command, which can be called from the u-boot command line. 'nand env.oob get' reads the address of the environment partition from the OOB data, 'nand env.oob set {offset,partition-name}' allows the setting of the marker by specifying a numeric offset or a partition name. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/43916 [2] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/79195 Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Acked-by: Harald Welte <laforge@gnumonks.org>
2010-07-12nios2: remove EP1C20, EP1S10, EP1S40 boardsThomas Chou
The example configuration files of nios2-generic board can generated binary to run on the EP1C20, EP1S10, and EP1S40 boards. So the three boards can be removed. With nios2-generic approach, the fpga parameter header file can be generated from hardware designs using tools. Porting u-boot for nios2 boards is simplified. Vendors can supply their fpga parameter file or patches to add a new nios2-generic board instance. There is no need to include other boards support for nios2 in the u-boot mainline. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-12nios2: add spi flash support to nios2-generic boardThomas Chou
This patch enables the altera_spi and spi_flash drivers for the nios2-generic board. It allows access to the EPCS/SPI flash on the Altera EP1C20 board. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Tested-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-12gpio_led: add gpio_request to __led_initThomas Chou
This patch adds the gpio usage request. The polarity is changed to positive as suggested by Mike Frysinger. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-12nios2: add gpio_requestThomas Chou
This will be used by nand_plat. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-12nios2: add fdt supportThomas Chou
This patch adds fdt support to boot linux, followed Michal's work on microblaze. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-12nios2: use gc sections to reduce image sizeThomas Chou
Follow the discussion of Charles Manning and Mike Frysinger. Using gc_sections helps reduce image size. Configuring for nios2-generic board... Before, text data bss dec hex filename 123979 3724 22892 150595 24c43 /tmp/u-boot/u-boot After, text data bss dec hex filename 115983 3800 22732 142515 22cb3 /tmp/u-boot/u-boot Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-12cpuat91: unbreak ethernetEric Bénard
* the following problems are met : config was set to use the new driver as a default but - RMII was not enabled for the new driver - the new driver didn't compile with RMII enabled - the new driver initialize a PHY at address O when the PHY of this board is at 1 thus we get "AT91 EMAC RMII: No PHY present" * to fix these problems, this patch : - enable RMII for the new driver - fix the wrong define used in the at91_emac.c - allow the config file to set a default phy address (and use 0 as a default as in the actual at91_emac.c driver) Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12at91_emac: Write MAC address automaticallyEric Bénard
tested on cpuat91. Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
