Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
When generating include/autoconfig.mk, hex numbers would be quoted.
This caused some false positives during automatic testing of the
builds, and is known to cause some real issues for some Blackfin
configurations. Don't use apostophes for decimal and hex numbers (nor
for octal numbers).
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
When planning for more generalization and Makefile cleanup it became
obvious that the introduction of a separate CONFIG_MK_ name space for
config options that were set through scripting in the Makefile was
not a good idea.
Originally the idea was to provide a script-free approach to supply
configuration options - there was no real need for a separate name
space. But when we now convert the existing Makefile entries to make
use of this approach, it would mean that we have to touch a large
number of board config files and add #ifdef / #define sequences to
"convert" from the CONFIG_MK_ to the CONFIG_ name space.
It seems much cleaner to get rid of this somewhat arbitrary _MK
string now for the few boards that actually use it.
There are some boards where it's currently not possible to detect all
board information at runtime, therefore a new column was added to
boards.cfg .
This column can contain multiple options: a board configuration name,
optionally followed by a colon (':') and a list of options, which are
separated by comma (',').
In case of simple options like '256M_U_BOOT', these expand to
"#define CONFIG_MK_256M_U_BOOT 1" in config.h . In case of
assignments like 'RAM=8192', these expand to "#define CONFIG_MK_RAM
8192" in config.h .
Example:
FOO:HAS_BAR,BAZ=64
means:
- the name of the board config file is include/configs/FOO.h
- the generated file include/config.h will contain these
lines:
#define CONFIG_HAS_BAR 1
#define CONFIG_BAZ 64
[wd@denx.de: edited commit message; added code to deal with an
optional board configuration name]
"make clean" after builds of MatrixVision boards would leave stale
files around:
board/matrix_vision/mvblm7/bootscript.img
board/matrix_vision/mvsmr/bootscript.img
Fix this.
commit 6aa3d3bfaa986f1aff5e21a9b9f68d087715b1a9
"83xx: Remove warmboot parameter from PCI init functions" missed
one mpc83xx_pcie_init callsite, causing this build error:
Configuring for MPC837XEMDS_HOST board...
pci.c: In function 'pci_init_board':
pci.c:141: error: too many arguments to function 'mpc83xx_pcie_init'
this patch extends the commit to include that callsite.
Doubled use of DECLARE_GLOBAL_DATA_PTR caused compile warning:
pci.c:71: warning: register used for two global register variables
Cc: Kim Phillips <kim.phillips@freescale.com>
The logodl board has long been unmaintained and left broken.
As obviously nobody is interestedin that code any more, we may as well
remove it.
Cc: August Hoeraendl <august.hoerandl@gmx.at>
Cc: Robert Schwebel <r.schwebel@pengutronix.de>
Cc: Marek Vasut <marek.vasut@gmail.com>
commit 6d014adf dropped support for the forceenv() function, but failed
to remove references to it from board/davinci/schmoogie/schmoogie.c
Replace forceenv() by setenv() and set CONFIG_ENV_OVERWRITE instead in
the board config file to allow overwriting the serial number.
Cc: Sergey Kubushyn <ksi@koi8.net>
Acked-by: Sergey Kubushyn <ksi@koi8.net>
Commit 3b8ac464 "FPGA: add support for downloading Lattice bitstream"
added support for Lattice devices, but failed to add #ifdef's that are
needed when building for non-Lattice devices, which results in build
failures like these:
Configuring for GEN860T board...
drivers/fpga/libfpga.a(fpga.o): In function `fpga_dev_info':
/home/wd/git/u-boot/work/drivers/fpga/fpga.c:145: undefined reference to `lattice_info'
drivers/fpga/libfpga.a(fpga.o): In function `fpga_dump':
/home/wd/git/u-boot/work/drivers/fpga/fpga.c:269: undefined reference to `lattice_dump'
drivers/fpga/libfpga.a(fpga.o): In function `fpga_load':
/home/wd/git/u-boot/work/drivers/fpga/fpga.c:233: undefined reference to `lattice_load'
make: *** [u-boot] Error 1
Add the missing code.
This patch fixes the LINUX_BOOT_PARAM_ADDR define to be based off of
PHYS_SDRAM_1 instead of CONFIG_SYS_MEMTEST_START. On da830 they are the same
thing but on da850 the CONFIG_SYS_MEMSTART define is offset from the
PHYS_SDRAM_1 start.
Without this patch it is not possible to boot linux on da850 -- bootm hangs
at "Uncompressing Linux... done, booting the kernel."
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The current da850evm support in u-boot/master omits any use of
the davinci EMAC. This patch adds basic support for the EMAC using
the MII PHY found on the baseboard of the EVM. The MAC address is
read from the environment variable 'ethadd'. Note that this is
different from the da850evm support in the u-boot omapl1 tree
where the MAC address is read from SPI flash.
CC: Sandeep Paulraj <s-paulraj@ti.com>
CC: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Mike Frysinger <vapier@gentoo.org>
This patch enables also the mtdpart, ubi and ubifs commands when NAND support
is enabled.
Signed-off-by: Ben Gardiner<bengardiner@nanometrics.ca>
To: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
The current da850evm config is missing the pieces for NAND support that can be
found in Sandeep's u-boot-davinci tree [1].
This patch adds NAND support in the spirit of the support in the u-boot-davinci
tree where NAND support for the da850evm can be enabled by putting a single
'#define CONFIG_USE_NAND' at the top of the include/configs/da850evm.h file.
[1] http://arago-project.org/git/people/?p=sandeep/u-boot-davinci.git;a=tree
The default NAND flash timings are very conservative. This patch assigns the
timings reccomended in the recent linux kernel patch [1] from Sekhar Nori. The
speedup, as reported in that patch, is 5.3x for reads.
[1] http://www.spinics.net/lists/arm-kernel/msg100278.html
CC: Sekhar Nori <nsekhar@ti.com>
There is currently no NAND pinmux enabled by the da850evm board setup code.
This is fine when booting from NAND since the early boot code (UBL) will setup
the pinmux; however, when the boot mode is any other setting NAND is unusable
when enabled in the config.
This patch adds a pinmux list for NAND and enables it when NAND is enabled in
the config. Tested by booting from SPI on the da850evm and verifying NAND
was usable.
CC: Nick Thompson <nick.thompson@ge.com>
The ECC calculations were started by writing 1 << 13 to the nand FCR register;
that value is also defined as DAVINCI_NANDFCR_4BIT_CALC_START in emif_defs.h.
This patch substitutes the macro DAVINCI_NANDFCR_4BIT_CALC_START for the
magic number '1 << 13'.
The IGEP module is a low-power, high performance production-ready
system-on-module (SOM) based on TI's OMAP3 family.The IGEP module
solution based upon TI OMAP3 provides a low-power/low-cost platform
for a variety of consumer/industrial/medical devices.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
The IGEP v2 board is a low-cost, fan-less and industrial temperature
range single board computer that unleashes laptop-like performance and
expandability without the bulk, expense, or noise of typical desktop
machines. Its architecture shares much in common with other OMAP3 boards.
Acked-by: Steve Sakoman <steve.sakoman@linaro.org>
Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
Introduce Numonyx DDR timings and provide CONFIG_OMAP3_NUMONYX_DDR
config options to allow for platform files to setup their timings.
This patch fixes the build breakage introduced by the recent relocation
changes for ARMV7
Signed-off-by: Steve Sakoman <steve@sakoman.com>
This patch fixes a typo in the routine to calculate the cs offset
based upon the contents of the SDRC cs_cfg register. This function
mistakenly shifts the CS1STARTLOW field 17 bits right instead of
17 bits left.
This hasn't been an issue to date because all OMAP3 boards currently
are configured to have zeros in this field.
Reported-by: Peter Maydell <peter.maydell@linaro.org>
Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org>
changes for ARMV7
The SDP4430 does not have onboard NAND, it has eMMC on the second
MMC slot. This patch adds support for saving the u-boot environment
to eMMC.
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com>
Tested-by: Steve Sakoman <steve@sakoman.com>
This patch switches from the legacy mmc driver to the new generic mmc driver
OMAP boards currently use a legacy mmc driver. This patch adds a new
mmc driver which will work with the generic mmc driver in u-boot.
This new driver will work with both OMAP3 and OMAP4 boards.
This patch does not remove the old driver. It should remain in the
tree until all boards that use it switch to the new driver.
The current mmc driver returns erroneous capacity information for
eMMC. The capacity of eMMC devices is available only in the ext-CSD
register. This patch add code to read the ext-CDSD register and
correctly calculate eMMC capacity.
Acked-by: Steve Sakoman <steve@sakoman.com>
TI hasn't reserved a USB Product ID for gadgets, so use the default
vendor and product ID to avoid confusion.
We cannot rely on the syscontrol rom func to program PLL_DIV with anomaly
05000440 is in effect, so manually program the MMR when necessary.
Signed-off-by: Loic Minier <loic.minier@linaro.org>
CC: stefano babic <sbabic@denx.de>
The env change its implementation after this log, while env mmc
didn't change it immediately, which cause issue. Follow to the
new style to fix it.
commit ea882baf9c17cd142c99e3ff640d3ab01daa5cec
Author: Wolfgang Denk <wd@denx.de>
Date: Sun Jun 20 23:33:59 2010 +0200
New implementation for internal handling of environment variables.
Signed-off-by: Lei Wen <leiwen@marvell.com>
Call watchdog_reset() upon newline. This is done here in putc
since the environment code uses a single puts() to print the complete
envrironment upon "printenv". So we can't put this watchdog call
in puts().
This is needed for boards with a very short watchdog timeout, like the
lwmon5 with a 100ms timeout. Without this patch this board resets in the
commands with long outputs, like "printenv" or "fdt print".
Note that the image size is not increased with this patch when
CONFIG_HW_WATCHDOG or CONFIG_WATCHDOG are not defined since the compiler
optimizes this additional code away.
Fix typo in comment.
The crash was occuring in env_relocate because it was being called prior
to mmc_initialize. This patch moves the MMC initialization earlier in
the init process.
This patch also cleans up the env_relocate_spec code in env_mmc.c
Only a few PPC boards actually use the common BAT manipulation
functions, so only compile it for them.
Originally the Makefile defines CONFIG_ADS5121_REV2 when configuring
for board mpc5121ads_rev2. The config in include/configs/mpc5121ads.h
expects a define CONFIG_MPC5121ADS_REV2 for this.
Therefore there are two defines used but only 1 is defined.
This patch renames references to CONFIG_ADS5121_REV2 to CONFIG_MPC5121ADS_REV2
to have one common define.
This patch fixes faulty mem size detection caused by wrong config in
Signed-off-by: Mark Vels <mark.vels@team-embedded.nl>
Fix build error introduced in beca5a5f5bf0d88125580e5e9c1730469cd50ab8
common/libcommon.a(fdt_support.o): In function `fdt_add_edid':
/local/hudson/jobs/mirrors-u-boot.git/workspace/common/fdt_support.c:1205: undefined reference to `fdt_increase_size'
Signed-off-by: Matthew McClintock <msm@freescale.com>
The patch adds the EHCI controller for the i.MX31 Soc.
The patch adds a utility function and defines
to set the pad as it is done in linux.
