- add capability to "fastboot flash" with sparse format images
Signed-off-by: Steve Rae <srae@broadcom.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
- update static function
- additional debugging statements
- update "fastboot command" information
- add missing include file
- update spelling
- implement 'fastboot flash' for eMMC devices
- add support for 'fastboot flash' command for eMMC devices
Enable the Extend address to support SPI flash more than 16MB.
Signed-off-by: Hou Zhiqiang <B48286@freescale.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Cc: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
Tested-by: Luka Perkov <luka@openwrt.org>
Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
This patch introduces the clrsetbits_le32() accessor functions in the
kirkwood SPI driver. Note that it also includes a fix:
- writel(~KWSPI_CSN_ACT | KWSPI_SMEMRDY, &spireg->ctrl);
+ writel(KWSPI_SMEMRDY, &spireg->ctrl);
Here the bit KWSPI_CSN_ACT (0x1) should have been cleared. Instead
0xfffffffe is written into this control register. This is the main
reason to use the clrsetbits() functions now. As they make clearing
bits much less error prone.
Additionally KWSPI_IRQUNMASK is not used in spi_cs_activate() and
spi_cs_deactivate() any more. Its the wrong macro but has the same
value as the correct one (KWSPI_CSN_ACT).
This is in preparation for use of this driver on the Marvell Armada XP
platform as well.
Add ID for this Numonix / STMicro chip.
Tested on Marvell DB-78460-BP board.
Currently, CONFIG_SPL_SPI_* #defines are used for controlling SPI boot in
SPL. These #defines do not allow the user to select SPI mode for the SPI flash
(there's no CONFIG_SPL_SPI_MODE, so the SPI mode is hardcoded in
spi_spl_load.c), and duplicate information already provided by
CONFIG_SF_DEFAULT_* #defines.
Kill CONFIG_SPL_SPI_*, and use CONFIG_SF_DEFAULT_* instead.
Cc: Tom Rini <trini@ti.com>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Lars Poeschel <poeschel@lemonage.de>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Hannes Petermaier <hannes.petermaier@br-automation.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
MXC SPI driver has a feature whereas a GPIO line can be used to force CS high
across multiple transactions. This is set up by embedding the GPIO information
in the CS value:
cs = (cs | gpio << 8)
This merge of cs and gpio data into one value breaks the sf probe command:
if the use of gpio is required, invoking "sf probe <cs>" will not work, because
the CS argument doesn't have the GPIO information in it. Instead, the user must
use "sf probe <cs | gpio << 8>". For example, if bank 2 gpio 30 is used to force
cs high on cs 0, bus 0, then instead of typing "sf probe 0" the user now must
type "sf probe 15872".
This is inconsistent with the description of the sf probe command, and forces
the user to be aware of implementaiton details.
Fix this by introducing a new board function: board_spi_cs_gpio(), which will
accept a naked CS value, and provide the driver with the relevant GPIO, if one
is necessary.
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Eric Benard <eric@eukrea.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Add support for M25PE16 and M25PX16
Since dev->req_seq value is initialized from "reg" property of fdt node,
there is posibility, that address value contained in fdt is greater than
INT_MAX, and then value in dev->req_seq is negative which led to probe()
fail.
This patch fix this problem by ensuring that req_seq is positive, unless
it's one of errno codes.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
Allow serial_find_console_or_panic() to work without a device tree.
The sequence number support in driver model requires device tree control.
It should be skipped if CONFIG_OF_CONTROL is not defined, and should not
require functions from fdtdec.
The list is supposed to be terminated with a NULL name, but is not. If a
board probes a chip which does not appear in the table, U-Boot will crash
(at least on sandbox).
A merge error ended up repeating a similar sentence twice. Fix it.
The get_maintainers script is a useful default, but sometimes is copies
too many people, or takes a long time to run.
Add an option to disable it and update the README.
This check should now be done whatever mode buildman is running in, since
we may be displaying information while building.
- Use _defconfig instead of _config, but still _config is working.
- Corrected README.sandbox path in ./README
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@gmail.com>
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Disable subpage write when using PMECC to prevent buggy partial page write.
This fix has been taken from linux sources (see commit
90445ff6241e2a13445310803e2efa606c61f276)
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Acked-by: Josh Wu <josh.wu@atmel.com>
If the SoC has pcr, we use pcr (peripheral control register)
to enable or disable clock.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Using CPU_HAS_PCR micro to present the SoC has pcr
(peripheral control register).
When use pcr (peripheral control register), then we won't need
to care about the peripheral ID.
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Add NOR flash hardware init function, including SMC and PIO
configuration.
We defined the macro pmecc_readl(b)/pmecc_writel for pmecc register access.
But in the driver we also use the readl(b)/writel.
To keep consistent, this patch make all use pmecc_readl(b)/pmecc_writel.
This patch adds boot script support to am335x_evm
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
and 'loadbootenv' as already done for 'loadimage' and 'loaduimage'.
This patch uses generic 'load' command instead of 'fatload' for 'loadbootscript' and 'loadbootenv' as already done for 'loadimage' and 'loaduimage' for OMAP4 boards.
This allows to use EXT partition instead of FAT, while keeping FAT compatibility.
This patch implements a workaround to fix DDR3 memory issue.
The code for workaround detects PGSR0 errors and then preps for
and executes a software-controlled hard reset.In board_early_init,
where logic has been added to identify whether or not the previous
reset was a PORz. PLL initialization is skipped in the case of a
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Keegan Garcia <kgarcia@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
Commit f219e01311b2 (tools: Import Kconfiglib)
added SPDX GPL-2.0+ to this library by mistake.
It should be ISC.
Cc: Ulf Magnusson <ulfalizer@gmail.com>
At the high level, the problem is that we set gd multiple times (and
still do, even after the commit we're reverting). We set important
parts of gd to the copy which is not above stack but rather in the data
section. For the release, we're going to revert this change and for the
next release we shall correct things to only, really, set gd once to an
appropriate location and ensure that comments about it are correct too.
This reverts commit f0c3a6c4ad09210d5d4aeafe87685ee75e5683d6.
Acked-by: Albert Aribaud <albert.u.boot@aribaud.net>
We do not have to distinguish CONFIG_TARGET_VEXPRESS_AEMV8A_SEMI
from CONFIG_TARGET_VEXPRESS_AEMV8A. Rename the former to the latter.
Reviewed-by: Steve Rae <srae@broadcom.com>
Cc: David Feng <fenghua@phytium.com.cn>
When a DNS query is sent out, the ethernet packet can get directed to
the MAC address of a server that was communicated to before. This is
wrong when the previously stored MAC address corresponds to a different
server's IP address, i.e. when the IP address of the previous and the
current communication are different.
The error can get reproduced by running a sequence of e.g. a TFTP
download and a DNS query, where the TFTP and DNS servers reside on
individual machines.
The fix is to clear the server's MAC address that might be left from a
previous operation, and to fetch the peer's MAC address in a new ARP
lookup, before the DNS query is sent. This is the approach taken in
other network services, like 8e52533d1095 ("net: tftpsrv: Get correct
client MAC address").
Reported-by: Dirk Zimoch <dirk.zimoch@psi.ch>
Signed-off-by: Gerhard Sittig <gsi@denx.de>
For the SPL configuration, "make <dir>/<target>" is used.
Here,
<dir> is either "spl" or "tpl"
<target> is one of "config", "menuconfig", "xconfig", etc.
This commit adds two checks:
[1] If <dir> is given an unsupported subimage, the configuration
should error out like this:
$ make qpl/menuconfig
*** "make qpl/menuconfig" is not supported.
[2] Make sure that "CONFIG_SPL" is enabled in the ".config" before
running "make spl/menuconfig. Otherwise, the SPL image
is not built at all. Having "spl/.config" makes no sense.
In such a case, the configuration should exit with a message:
$ make spl/menuconfig
*** Create ".config" with "CONFIG_SPL" enabled
*** before "make spl/menuconfig".
Suggested-by: Simon Glass <sjg@chromium.org>
This driver was upstreamed without an SMSC copyright, even thought it seems
that SMSC was the original author.
See the kernel version for a code comparison:
http://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=2f7ca802bdae2ca41022618391c70c2876d92190
It's not clear who actually moved this code, or whether the kernel was the
original source, or somewhere else, but it probably should still have the
SMSC copyright.
This patch fixes the build error for CONFIG_CMD_MTDPARTS_SPREAD
Signed-off-by: Maxin B. John <maxin.john@enea.com>
After mtd was synced with Linux 3.14
(ff94bc40af3481d47546595ba73c136de6af6929)
the number of parameters for write_page function of nand_chip was
changed. The additional two var were needed for subpage write.
As keystone has no supbage write they are not needed. So correct
only function definition by upgrading it's parameter list.
That helps to get ritd of compilation warning.
gd->fdt_blob is used for FDT control of U-Boot.
If CONFIG_OF_CONTROL is not defined, it is useless.
