2009-06-12afeb9260: fix macb device initJean-Christophe PLAGNIOL-VILLARD
uses PA10, PA11 for ETX2 and ETX3. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12ppc4xx: Remove PCI async bootup message if PCI is not usedStefan Roese
2009-06-12TQM834x: use buffered writes to accelerate writing to flashWolfgang Denk
Also enable display of 'E'mpty sectors in "flinfo" output. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-12TQM834x: add FDT supportWolfgang Denk
2009-06-12TQM834x: fix environment size; add redundant env.Wolfgang Denk
Also reserve more space for U-Boot as it will probably grow soon. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-12ARM DaVinci: Reset with watchdog enabledThomas Lange
Once the Davinci watchdog has been enabled, the timeout value cannot be changed. If the timeout in use is long, it can take a long time for card to reset. By writing an invalid service key, we can trigger an immediate reset. Signed-off-by: Thomas Lange <thomas@corelatus.se>
2009-06-12video: Add an option to skip video initializationWolfgang Denk
This patch adds an option to skip the video initialization on for all video drivers. This is needed for the CPCI750 which can be built as CPCI host and adapter/target board. And the adapter board can't access the video cards located on the CompactPCI bus. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Rebased against simplifying patch. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12drv_video_init(): simplify logicWolfgang Denk
Simplify nesting of drv_video_init() and use a consistent way of indicating failure / success. Before, it took me some time to realize which of the returns was due to an error condition and which of them indicated success. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Anatolij Gustschin <agust@denx.de>
2009-06-12at91: regroup IP hw init in one file per socJean-Christophe PLAGNIOL-VILLARD
2009-06-12dm355 evm supportDavid Brownell
Initial U-Boot support for the DaVinci DM355 EVM. This is a board from Spectrum Digital. Board docs include schematic and firmware for its microcontroller: http://c6000.spectrumdigital.com/evmdm355/revd/ Most of the DM355 chip is fully documented by TI, the most notable exception being the MPEG/JPEG coprocessor (programmable using codecs available at no cost from TI), which is omitted from its DM335 sibling: http://focus.ti.com/docs/prod/folders/print/tms320dm355.html This version can boot from the on-board DM9000 Ethernet chip, after being loaded (from NAND, MMC/SD, or UART). In the near future, NAND and USB support could be added ... NAND support is being held back until the support for the 4-bit ECC hardware is ready. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12OMAP3EVM: Set default bootfileSanjeev Premi
The current configuration doesn't define default bootfile; leading to this warning at execution: OMAP3_EVM # dhcp ... ... DHCP client bound to address 192.168.1.11 *** Warning: no boot file name; using 'AC18BE16.img' TFTP from server 0.0.0.0; our IP address is 192.168.1.11; sending through gateway 192.168.1.1 Filename 'AC18BE16.img'. Load address: 0x82000000 Loading: * TFTP error: 'File not found' (1) Signed-off-by: Sanjeev Premi <premi@ti.com>
2009-06-12ARM DaVinci: Minor Updates to base addressess-paulraj@ti.com
Patch adds base addresses for DaVinci DM365. Updated patches for DM365 will be posted soon. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-06-12ZOOM2 Add support for debug board detection.Tom Rix
The logicpd web site is a good source for general information on this board. Please start looking here if the below links are broken. http://www.logicpd.com This is a pdf of the product http://www.logicpd.com/sites/default/files/1012659A_Zoom_OMAP34x-II_MDP_Brief.pdf This is a pdf of the product quick start guide. The debug board is described here. http://support.logicpd.com/downloads/1165/ This is a wiki showing the debug board in use https://omapzoom.org/gf/project/omapzoom/wiki/?pagename=GettingStartedWithZoomII_AKA_OMAP34XII_MDP The zoom2 has an auxillary board that contains the serial, net, jtag and battery simulator. This change supports a runtime check if the debug board is connected. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12OMAP3 Port kernel omap gpio interface.Tom Rix
Port version 2.6.27 of the linux kernel's omap gpio interface to u-boot. The orignal source is in linux/arch/arm/plat-omap/gpio.c See doc/README.omap3 for instructions on use. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12ZOOM2 Add initial support for Zoom2Tom Rix
Zoom2 is a new board from Texas Instruments and LogicPD The logicpd web site is a good source for general information on this board. Please start looking here if the below links are broken. http://www.logicpd.com This is a pdf of the product http://www.logicpd.com/sites/default/files/1012659A_Zoom_OMAP34x-II_MDP_Brief.pdf This is the product description web page http://www.logicpd.com/products/development-kits/texas-instruments-zoom%E2%84%A2-omap34x-ii-mdp This patch provides a zoom2 base target by copying zoom1 and by making some obvious changes. To configure, run make omap3_zoom2_config Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12ARM DaVinci:Consolidate common u-boot.ldsSandeep Paulraj
The u-boot.lds is common for all DaVinci boards. The patch removes multiple instances and moves the u-boot.lds to /cpu/arm926ejs/davinci folder. This addresses one of the comments i received while submitting patches for DM3xx Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-06-12OMAP Consolidate common u-boot.lds to cpu layer.Tom Rix
The u-boot.lds file is common for all omap boards. Move a cleaned up version to the cpu layer and add makefile logic to use it. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12arm/dcc: add xscale supportJean-Christophe PLAGNIOL-VILLARD
2009-06-12arm/dcc: use static support to allow to use it at anytimeJean-Christophe PLAGNIOL-VILLARD
the dcc can be used at the start of the cpu Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12ARM: Update mach-typesJean-Christophe PLAGNIOL-VILLARD
update against linux v2.6.29 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12arm920/926/926: remove non needed headerJean-Christophe PLAGNIOL-VILLARD
2009-06-12davinci dm6446evm NAND updateDavid Brownell
This updates the optional (non-default!) NAND support for the DaVinci DM6446 EVM: - include MTD partitioning, defaulting to what Linux uses - use a flash-based BBT, which among other things speeds bootup This matches code that's now queued for mainline Linux, and might even merge in an upcoming 2.6.30-rc; and the MTIDS are set up so that the U-Boot $mtdparts environment variable can be passed as-is on the kernel command line as a cmdlinepart override. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12davinci: display correct clock infoDavid Brownell
Move the clock-rate dumping code into the cpu/.../davinci area where it should have been, enabled by CONFIG_DISPLAY_CPUINFO, updating the format and showing the DSP clock (where relevant). Switch boards to use the cpuinfo() hook for this stuff. Remove a few now-obsolete PLL #defines. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12ZOOM1 Remove more legacy NAND defines.Tom Rix
These legacy NAND defines are no longer needed by this target. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12LED Add documentation describing the status_led and colour led API.Tom Rix
This document describes the u-boot status LED API. This allows common u-boot commands to use a board's leds to provide status for activities like booting and downloading files. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12ARM Add blue colour LED to status_led.Tom Rix
There is exiting support for red,yellow,green but no blue. The main LED on the zoom2 is a blue LED. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12arm: timer and interrupt init reworkJean-Christophe PLAGNIOL-VILLARD
actually the timer init use the interrupt_init as init callback which make the interrupt and timer implementation difficult to follow so now rename it as int timer_init(void) and use interrupt_init for interrupt btw also remane the corresponding file to the functionnality implemented as ixp arch implement two timer - one based on interrupt - so all the timer related code is moved to timer.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12OMAP3: Reorganize Makefile styleJean-Christophe PLAGNIOL-VILLARD
Reformat COBJS handling. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-06-12OMAP3: Remove dublicated interrupt codeJean-Christophe PLAGNIOL-VILLARD
Remove duplicated interrupt code. Original, identical code can be found in lib_arm/interrupts.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-06-12at91rm9200: move reset code to reset.cJean-Christophe PLAGNIOL-VILLARD
2009-06-12ixp/interrupts: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2009-06-12arm: cleanup remaining CONFIG_INIT_CRITICALJean-Christophe PLAGNIOL-VILLARD
2009-06-12arm946es: remove non used timerJean-Christophe PLAGNIOL-VILLARD
2009-06-12davinci: add basic dm355/dm350/dm335 supportDavid Brownell
Add some basic declarations for DaVinci DM355/DM350/DM335 support, keyed on CONFIG_SOC_DM355. (DM35X isn't quite right because the DM357 is very different; while the DM355 is like a DM355 without the MPEG/JPEG coprocessor). These have different peripherals than the DM6446, and some of the peripherals are at different addresses. Notably for U-Boot, there's no EMAC, and the NAND controller address is different Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12davinci: fix dm644x bugletsDavid Brownell
Fix two buglets in the dm644x support: don't set two must-be-zero bits in the UART management register; and only include the I2C hooks if the I2C driver is being included. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12davinci: split out some dm644x-specific bits from pscDavid Brownell
Split out DaVinci DM6446-specific bits from more generic bits: - Add a CONFIG_SOC_DM644X. All current boards use DM6446 chips; DM6443 and DM6441 chips differ in available peripherals. - Move most DM644X-specific bits from psc.c to a new dm644x.c file, which is conditionally built. It provides device-specific setup. Plus minor coding style and comment updates with respect to the PSC. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12davinci: cpu-specific build uses conditional make syntaxDavid Brownell
Update cpu/arm926ejs/davinci/Makefile to use COBJ-y type syntax. Add the first conditional: for EMAC driver support. Not all chips have an EMAC; and boards might not use it, anyway. This doesn't touch PHY configuration; that should eventually become conditional too. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12davinci: move psc support board-->cpuDavid Brownell
Move DaVinci PSC support from board/* to cpu/* where it belongs. The PSC module manages clocks and resets for all DaVinci-family SoCs, and isn't at all board-specific. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12DaVinci now respects SKIP_LOWLEVEL_INITDavid Brownell
Don't needlessly include lowlevel init code; that's only really needed with boot-from NOR (not boot-from-NAND). The 2nd stage loader (UBL) handles that before it loads U-Boot. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12DaVinci Ethernet cleanupDavid Brownell
Chips without the EMAC controller won't need the utilities it uses to read an Ethernet address from EEPROM; so don't include them needlessly. Use is_valid_ether() to validate the address from EEPROM. All-zero addresses aren't the only invalid addresses. A fully erased EEPROM returns all-ones, also invalid... Switch those Ethernet utilities to use "%pM" for printing MAC addresses; and not say ROM when they mean EEPROM. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12lib_arch/board.c: Move malloc initialization before flash_init()Stefan Roese
This patch moves the malloc initialization before calling flash_init(). Upcoming changes to the NOR FLASH common CFI driver with optional MTD infrastructure and MTD concatenation support will call malloc(). And nothing really speaks against enabling malloc just a little earlier in the boot stage. Some architectures already enable malloc before calling flash_init() so they don't need any changes here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Scott McNutt <smcnutt@psyent.com> Cc: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: John Rigby <jcrigby@gmail.com>
2009-06-12ppc4xx: Add Sequoia RAM-booting targetStefan Roese
This patch adds another build target for the AMCC Sequoia PPC440EPx eval board. This RAM-booting version is targeted for boards without NOR FLASH (NAND booting) which need a possibility to initially program their NAND FLASH. Using a JTAG debugger (e.g. BDI2000/3000) configured to setup the SDRAM, this debugger can load this RAM- booting image to the target address in SDRAM (in this case 0x1000000) and start it there. Then U-Boot's standard NAND commands can be used to program the NAND FLASH (e.g. "nand write ..."). Here the commands to load and start this image from the BDI2000: 440EPX>reset halt 440EPX>load 0x1000000 /tftpboot/sequoia/u-boot.bin 440EPX>go 0x1000000 Please note that this image automatically scans for an already initialized SDRAM TLB (detected by EPN=0). This TLB will not be cleared. This TLB doesn't need to be TLB #0, this RAM-booting version will detect it and preserve it. So booting via BDI2000 will work and booting with a complete different TLB init via U-Boot works as well. Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12tools/envcrc: add --binary option to export embedded envMike Frysinger
The --binary option to envcrc can be used to export the embedded env as a binary blob so that it can be manipulated/examined/whatever externally. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12Enable CONFIG_NET_MULTI on all remaining PPC4xx boardsBen Warren
All in-tree PPC4xx boards now use CONFIG_NET_MULTI Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-124xx: Add support for DP405 hardware variantsMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-124xx: Remove binary cpld bitstream from DP405 boardMatthias Fuchs
This patch removes the cpld binary bitstream that is used by esd's cpld command on DP405 boards. Because u-boot with an external cpld bitstream may not take more space in flash than before the u-boot binary is shrinked a little bit. Some unused featues have been removed therefore. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-124xx: Remove binary cpld bitstream from VOM405 boardMatthias Fuchs
This patch removes the cpld binary bitstream that is used by esd's cpld command on VOM405 boards. Because u-boot with an external cpld bitstream may not take more space in flash than before the u-boot binary is shrinked a little bit. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-124xx: Remove binary cpld bitstream from PMC405 boardMatthias Fuchs
This patch removes the cpld binary bitstream that is used by esd's cpld command on PMC405 boards. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-124xx: Remove binary cpld bitstream from CMS700 boardMatthias Fuchs
This patch removes the cpld binary bitstream that is used by esd's cpld command on CMS700 boards. Because u-boot with an external cpld bitstream may not take more space in flash than before the u-boot binary is shrinked a little bit. Some unused featues have been removed therefore. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12esd/common: extend cpld command with address parameterMatthias Fuchs
This patch adds support for an address parameter to esd's cpld command. This is in preparation to remove compiled-in binary cpld (xsvf) bitstreams. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
