2008-09-10nvedit: rename error comment to CONFIG_ENV_IS_IN_Jean-Christophe PLAGNIOL-VILLARD
2008-09-10cmd_mem: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10move cmd_get_data_size to command.cJean-Christophe PLAGNIOL-VILLARD
add CMD_DATA_SIZE macro to enable it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-10env_flash: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-10env_nowhere: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-10env_sf: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_SPI_FLASH in CONFIG_ENV_IS_IN_SPI_FLASHJean-Christophe PLAGNIOL-VILLARD
2008-09-10env_onenand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_ONENAND in CONFIG_ENV_IS_IN_ONENANDJean-Christophe PLAGNIOL-VILLARD
2008-09-10env_nvram: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-09-10env_nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NAND in CONFIG_ENV_IS_IN_NANDJean-Christophe PLAGNIOL-VILLARD
2008-09-10env_dataflash: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_DATAFLASH in CONFIG_ENV_IS_IN_DATAFLASHJean-Christophe PLAGNIOL-VILLARD
2008-09-10cmd_eeprom: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10env_eeprom: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10cmd_mac: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
finish remaning CFG_ID_EEPROM in CONFIG_ID_EEPROM start in commit ad8f8687b78c3e917b173f038926695383c55555 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-10cmd_fdc: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10common/Makefile: add core command sectionJean-Christophe PLAGNIOL-VILLARD
2008-09-10cmd_vfd: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10muas3001: update BR4 settingsHeiko Schocher
Also set up the port pins for using I2C. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-09-10autoscr: Fix one-character lines and non-newline terminated scriptsPetri Lehtinen
When not using hush, the autoscr command now executes lines that are only one character long. It also runs the last line of scripts even if it does not end in a newline. Signed-off-by: Petri Lehtinen <petri.lehtinen@inoi.fi>
2008-09-10ppc4xx: Allow DTT_I2C_DEV_CODE configured by CFG_I2C_DTT_ADDRVictor Gallardo
On AMCC Arches board DTT_I2C_DEV_CODE is different then canyonlands and glacier. Signed-off-by: Victor Gallardo <vgallardo@amcc.com>
2008-09-10Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2008-09-10muas3001: added support for the LM75 sensor.Heiko Schocher
2008-09-10muas3001: activate WDT for the muas3001 board.Heiko Schocher
2008-09-10muas3001: added 64MB SDRAM autodetection.Heiko Schocher
2008-09-09Fix printf errors under -DDEBUGAndrew Klossner
Fix printf format-string/arg mismatches under -DDEBUG. These warnings occur with DEBUG defined for a platform using cpu/mpc85xx. Users of other architectures can unearth similar problems by adding the line "CFLAGS += -DDEBUG=1" in config.mk right after "CFLAGS += $(call cc-option,-fno-stack-protector)". Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-09-09Merge branch 'master' of ssh://10.10.0.7/home/wd/git/u-boot/masterWolfgang Denk
2008-09-09Update CHANGELOG, prepare 2008-10-rc1 releasev2008.10-rc1Wolfgang Denk
2008-09-0985xx: Ensure timebase is zero on secondary coresKumar Gala
The e500um says the timebase is volatile out of reset. To ensure TB sync works we need to make sure its zero. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-09bootm_load_os: fix load_end debug messageJean-Christophe PLAGNIOL-VILLARD
print load_end value not pointer Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-09bootm: enable fdt support only on ppc, m68k and sparcJean-Christophe PLAGNIOL-VILLARD
...as done in image.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-09common/cmd_mem.c: remove nested #if defined(CONFIG_CMD_MEMORY)Markus Heidelberg
Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de>
2008-09-09gitignore: add tags files and Vim swap fileMarkus Heidelberg
2008-09-09add board_eth_init() for sh7785lcr boardYoshihiro Shimoda
Fix the problem that cannot work RTL8169 on sh7785lcr board. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
2008-09-09Merge branch 'denx'Andy Fleming
2008-09-09mtd: SPI Flash: Support the STMicro FlashTsiChung Liew
Add MTD SPI Flash support for M25P16, M25P20, M25P32, M25P40, M25P64, M25P80, M25P128. Signed-off-by: Jason McMullan <mcmullan@netapp.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-09-09trab: fix build problem after change to use do_div()Wolfgang Denk
We must link with libgeneric now. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-09Correct drv_usb_kbd_init functionRyan CHEN
The patch is that check if usb_get_dev_index() function return valid pointer. If valid, continue. Otherwise return -1. Signed-off-by: Ryan Chen <ryan.chen@st.com> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-09-09Make usb-stop() safe to call multiple times in a row.Remy Bohmer
A recent commit (936897d4d1365452bbbdf8430db5e7769ef08d38) enabled the usb_stop() command in common/cmd_bootm.c which was not enabled for some time, because no board did actually set the CFG_CMD_USB flag. So, now the usb_stop() is executed before loading the linux kernel. However, the usb_ohci driver hangs up (at least on AT91SAM) if the driver is stopped twice (e.g. the peripheral clock is stopped on AT91). If some other piece of code calls usb_stop() before the bootm command, this command will hangup the system during boot. (usb start and stop is typically used while booting from usb memory stick) But, stopping the usb stack twice is useless anyway, and a flag already existed that kept track on the usb_init()/usb_stop() calls. So, we now check if the usb stack is really started before we stop it. This problem is now fixed in both the upper as low-level layer. Signed-off-by: Remy Bohmer <linux@bohmer.net> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-09-09Makefile: fix bug introduced by commit 47ffd6c2Wolfgang Denk
2008-09-09ppc4xx: ppc440-generic-ALL: Fix out of tree build v2Ricardo Ribalda Delgado
This patch solves the problems compiling ml507, v5fx30teval and ppc440-generic out of tree. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
2008-09-09Fix dev_print when called from usb_stor_info (usb storage command)NĂ­colas Carneiro Lebedenco
Fix output of the usb storage command. It was printing "Device 0: not available" because IF_TYPE_USB was not included into the switch statement. Signed-off-by: Nicolas Lebedenco <nicolas.lebedenco@tasksistemas.com.br>
