2008-09-09Update CHANGELOG, prepare 2008-10-rc1 releasev2008.10-rc1Wolfgang Denk
2008-09-09bootm_load_os: fix load_end debug messageJean-Christophe PLAGNIOL-VILLARD
print load_end value not pointer Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-09bootm: enable fdt support only on ppc, m68k and sparcJean-Christophe PLAGNIOL-VILLARD
...as done in image.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-09common/cmd_mem.c: remove nested #if defined(CONFIG_CMD_MEMORY)Markus Heidelberg
Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de>
2008-09-09gitignore: add tags files and Vim swap fileMarkus Heidelberg
2008-09-09add board_eth_init() for sh7785lcr boardYoshihiro Shimoda
Fix the problem that cannot work RTL8169 on sh7785lcr board. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
2008-09-09mtd: SPI Flash: Support the STMicro FlashTsiChung Liew
Add MTD SPI Flash support for M25P16, M25P20, M25P32, M25P40, M25P64, M25P80, M25P128. Signed-off-by: Jason McMullan <mcmullan@netapp.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-09-09Correct drv_usb_kbd_init functionRyan CHEN
The patch is that check if usb_get_dev_index() function return valid pointer. If valid, continue. Otherwise return -1. Signed-off-by: Ryan Chen <ryan.chen@st.com> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-09-09Make usb-stop() safe to call multiple times in a row.Remy Bohmer
A recent commit (936897d4d1365452bbbdf8430db5e7769ef08d38) enabled the usb_stop() command in common/cmd_bootm.c which was not enabled for some time, because no board did actually set the CFG_CMD_USB flag. So, now the usb_stop() is executed before loading the linux kernel. However, the usb_ohci driver hangs up (at least on AT91SAM) if the driver is stopped twice (e.g. the peripheral clock is stopped on AT91). If some other piece of code calls usb_stop() before the bootm command, this command will hangup the system during boot. (usb start and stop is typically used while booting from usb memory stick) But, stopping the usb stack twice is useless anyway, and a flag already existed that kept track on the usb_init()/usb_stop() calls. So, we now check if the usb stack is really started before we stop it. This problem is now fixed in both the upper as low-level layer. Signed-off-by: Remy Bohmer <linux@bohmer.net> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-09-09Makefile: fix bug introduced by commit 47ffd6c2Wolfgang Denk
2008-09-09ppc4xx: ppc440-generic-ALL: Fix out of tree build v2Ricardo Ribalda Delgado
This patch solves the problems compiling ml507, v5fx30teval and ppc440-generic out of tree. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
2008-09-09Fix dev_print when called from usb_stor_info (usb storage command)Nícolas Carneiro Lebedenco
Fix output of the usb storage command. It was printing "Device 0: not available" because IF_TYPE_USB was not included into the switch statement. Signed-off-by: Nicolas Lebedenco <nicolas.lebedenco@tasksistemas.com.br>
2008-09-09FIT: make iminfo check hashes of all images in FIT, return 1 on failed checkBartlomiej Sieka
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-09-09FIT: add ability to check hashes of all images in FIT, improve outputBartlomiej Sieka
- add function fit_all_image_check_hashes() that verifies if all hashes of all images in the FIT are valid - improve output of fit_image_check_hashes() when the hash check fails Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-09-09qemu_mips: Update linux bootm to support dynamic cmdlineJean-Christophe PLAGNIOL-VILLARD
2008-09-09Add support for booting of INTEGRITY operating system uImagesPeter Tyser
2008-09-09mips/bootm: Fix typo in commit c4f9419c, "initrd_start" replaced by ↵Jean-Christophe PLAGNIOL-VILLARD
"images->rd_start" Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-09Remove support for booting ARTOS imagesKumar Gala
Pantelis Antoniou stated: AFAIK, it is still used but the products using PPC are long gone. Nuke it plz (from orbit). So remove it since it cleans up a usage of env_get_char outside of the environment code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-09Makefile: compile and link each module just onceWolfgang Denk
Several source files need to be compiled and linked when one or more config options are selected. To allow for easy selection in the Makefiles yet to avoild multiple compilation (which costs build time) and especially multiple linking (which causes errors), we use "COBJS = $(sort COBJS-y)" which eliminates duplicates. By courtesy of Detlev Zundel who suggested this approach. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-09Moved conditional compile into MakefileAndreas Engel
Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2008-09-09Merged serial_pl010.c and serial_pl011.c.Andreas Engel
They only differ in the init function. This also adds the missing watchdog support for the PL011. Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2008-09-09Remove gap fill in srec object v2Ricardo Ribalda Delgado
SREC files do not need gap fill: The load address is specified in the file. On the other hand, it can't be avoided in a .bin object. It has no information about memory location. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
2008-09-09README: fix missing subdirectory in the documentationMarkus Heidelberg
2008-09-09Update i386 code (sc520_cdp)Graeme Russ
Attempt to bring i386 / sc520 inline with master Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-09-09fw_env: add NAND supportGuennadi Liakhovetski
Add support for environment in NAND with automatic NOR / NAND recognition, including unaligned environment, bad-block skipping, redundant environment copy. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-09-09ppc4xx: Fix out-of-tree building of CPCI405 variantsMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Acked-by: Stefan Roese <sr@denx.de>
2008-09-09Removed hardcoded MxMR loop value from upmconfig() for MPC85xx.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2008-09-0985xx: socrates: Enable Lime support.Anatolij Gustschin
This patch adds Lime GDC support together with support for the PWM backlight control through the w83782d chip. The reset pin of the latter is attached to GPIO, so we need to reset it in early_board_init_r. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-0985xx: Socrates: Major code update.Detlev Zundel
- Update the local bus ranges in the FDT for Linux for the various devices connected to the local bus via chip-select. - Set the LCRR_DBYP bit in the LCRR for local bus frequencies lower than 66 MHz and uses I/O accessor functions consequently. - UPM data update. - Update of default environment and configuration. Use I2C multibus as we do have two I2C buses. Also enable sdram and ext2 commands. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-09-09Update Freescale 85xx boards to sys_eeprom.cTimur Tabi
The new sys_eeprom.c supports both the old CCID EEPROM format and the new NXID format, and so it obsoletes board/freescale/common/cds_eeprom.c. Freescale 86xx boards already use sys_eeprom.c, so this patch migrates the remaining Freescale 85xx boards to use it as well. cds_eeprom.c is deleted. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-09-09lib_ppc/interrupts.c: make board_show_activity() a weak functionWolfgang Denk
This allows to use show_activity() without having to define an empty board_show_activity() function. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-09stxxtc: remove empty CONFIG_SHOW_ACTIVITY functionsWolfgang Denk
2008-09-09NETTA2: remove empty CONFIG_SHOW_ACTIVITY functionsWolfgang Denk
2008-09-09Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
Conflicts: Makefile Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-09disk-on-chip: remove duplicate doc_probe declarationJean-Christophe PLAGNIOL-VILLARD
2008-09-09onenand_uboot: fix warning: 'struct mtd_oob_ops' declared inside parameter listJean-Christophe PLAGNIOL-VILLARD
2008-09-09rs5c372: fix rtc_set prototypeJean-Christophe PLAGNIOL-VILLARD
2008-09-09ARM: fix warning: target CPU does not support interworkingSergei Poselenov
This patch fixes warnings like this: start.S:0: warning: target CPU does not support interworking which come from some ARM cross compilers and are caused by hard-coded (with "--with-cpu=arm9" configuration option) ARM targets (which support ARM Thumb instructions), while the ARM target selected from the command line (with "-march=armv4") doesn't support Thumb instructions. This warning is issued by the compiler regardless of the real use of the Thumb instructions in code. To fix this problem, we use options according to compiler version being used. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-09ARM: Use do_div() instead of division for "long long".Sergei Poselenov
2008-09-08lib_arm/bootm.c: fix compile warningsWolfgang Denk
bootm.c:128: warning: label 'error' defined but not used bootm.c:65: warning: unused variable 'ret' Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-08ml507: fix out of tree build problemWolfgang Denk
2008-09-08common/cmd_bootm.c: fix printf() format warningsWolfgang Denk
2008-09-08BMW, PCIPPC2, PCIPPC6, RBC82: fix compile warningsWolfgang Denk
missing doc_probe() prototype. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-08mk48t59: fix compile problem introduced by commit d1e23194Wolfgang Denk
2008-09-08ppc4xx: Move ppc4xx specific prototypes to ppc4xx headerStefan Roese
This patch moves some 4xx specific prototypes out of include common.h to a ppc4xx specific header. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-08Merge branch 'master' of /home/stefan/git/u-boot/u-bootStefan Roese
2008-09-08ppc4xx: Update CPCI405(AB) configurationMatthias Fuchs
This patch add FDT support and command line editing capabilities for CPCI405 and CPCI405AB boards. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-08ppc4xx: Cleanup CPCI405 linker scriptMatthias Fuchs
2008-09-08ppc4xx: Update CPCI405 variants handlingMatthias Fuchs
This patch replaces the BOARD_REVISION variable in include/config.mk by a using a temporary include file in the platform directory. The former way does not work anymore and the latter is also used by some other boards. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-08ppc4xx: Remove CONFIG_CS8952_PHY defineStefan Roese
Since this define is only used on one board that was never really in production, removing this compile time option doesn't hurt and makes the code more readable. Signed-off-by: Stefan Roese <sr@denx.de>
