Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
introduced by 53677ef18 "Big white-space cleanup."
Reuse the existing DIU driver in board/freescale/common.
Signed-off-by: York Sun <yorksun@freescale.com>
Add DIU and cfb console support to FSL 5121ADS board.
Use #define CONFIG_VIDEO in config file to enable fb console.
Remove DPRINTF macro and replace it with generic debug macro.
The clock divider has different format in 5121 and 8610. This patch moves it to
board specific code.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
with the GD_FLG_LOGINIT flag in gd->flags.
This way we become able to utilize the full post_log_word for POST
activities (overwise, POST ECC, which has 0x8000 ID, could be
erroneously treated as started in post_output_backlog() even if there
was actually no POST ECC run (because of OCM POST failure, for
example).
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Don't run futher tests in case of a test fails that is marked as
POST_STOP.
Switch the OCM testid with the codec one. The reason is that current
implementation requires the POST_ROM testid to fit into lower 16
bits, and the codec test will never run with POST_ROM hopefully.
Added OCM test to POST layer. This version runs before all other tests
but doesn't yet interrupt post sequence on failure.
Signed off by: Gururaja Hebbar <gururajakr@sanyo.co.in>
Change LCRR clock ratio from 2 to 4 to commodate VSC7385.
Correct TSEC1 vs TSEC2 assignment.
Define ETHADDR and ETH1ADDR always.
Update CHANGELOG for release.
When SATA is selected (via jumper J6) we need to disable the first PCIe
node in the device tree, so that Linux doesn't initialize it. Otherwise
the Linux SATA driver will fail to detect the devices.
The same goes the other way around too. So if PCIe is selected we need
to disable the SATA node in the device tree.
This is because PCIe port 0 and SATA on 460EX share the same pins
(multiplexed) and we have to configure in U-Boot which peripheral is
enabled.
flash.c:593: warning: dereferencing type-punned pointer will break strict-aliasing rules
flash.c:398: error: label at end of compound statement
...and add to MAKEALL script
env_get_char is not a function, but a pointer to one.
Several board/<...>/config.mk files include dynamically built (by
the Makefile) config files but used the wrong file name of
$(TOPDIR)/board/$(BOARDDIR)/config.tmp
instead if the correct
$(OBJTREE)/board/$(BOARDDIR)/config.tmp
The bug is nasty because the build result is correct for the (normal)
in-tree builds, and because 'sinclude' is used no errors get raised
even for out-of-tree build tests. But out-of-tree builds use an
incomplete and thus usually incorrect configuration...
This patch fixes the canyonlands config.mk file to enable correct
out-of-tree builds. Thanks to Wolfgang Denk for spotting this.
Canyonlands has a file ddr2_fixed.c which needs special treatment when
building in separate directory. It has to be linked to build directory
otherwise it is not seen.
This reverts commit 55774b512fdf63c0516d441cc5da7c54bbffb7f2
which broke many PowerPC boards.
This reverts commit 1b5605ca57fbb364f4d78eeee28b974ed875e888
which breaks building on all PPC boards that don't use a log buffer.
Calculation of tail was incorrect when size % 4 == 0.
New code removes the conditional and does the same thing but with arithmetic
Signed-off-by: Nick Spence <nick.spence@freescale.com>
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93
which is known to break booting from dataflash and NAND.
When using dhcp/bootp the "netmask" environment variable is not set
because CONFIG_BOOTP_SUBNETMASK is not defined. But usually this is
desireable, so the following patch adds this this option to the board
config.
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
