This patch fixes a problem introdiced with patch
bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by
initdram()].
The boards affected are:
- PCI405
- PPChameleonEVB
- quad100hd
- taihu
- zeus
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
This patch prevents linker error on AT91RM9200 boards, if
CONFIG_CMD_I2_TREE is set.
It implements i2c_set_bus_speed and i2c_get_bus_speed as a dummy function.
Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
ARM DaVinci: Remove duplicate code in cpu/arm926ejs/davinci/dp83848.c
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
__ARM__ is given by arm_config.mk automatically.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
This patch changes get_timer() for i.MX to return the time since
'base' instead of the time since the counter was at zero.
Symptom seen is flash timeout errors when erasing or programming a
sector using the common cfi flash code.
Signed-off-by: Andrew Dyer <adyer@righthandtech.com>
1) Change the i.MX serial driver to use the baud rate set in the
u-boot environment
2) don't assume a 16MHz value for PERCLK1 in baud rate calculations
3) don't write a 1 to the RDR bit in the USR2 reg. (bit is not "write
one to clear" like other status bits in the reg.)
Code in cpu/arm920t/start.S will die with a compilation error if
CONFIG_STACKSIZE + CFG_MALLOC_LEN works out to an invalid constant for
the ARM sub instruction. Change the code so that each is subtracted
independently to avoid the error.
omap730.h
- Correct Invalid #define of MPUTIM_PTV_MASK for
omap1510 & omap730 register definition
MPUTIM_PTV_MASK is defined as
#define MPUTIM_PTV_MASK (0x7<<PTV_BIT)
while it should have been
#define MPUTIM_PTV_MASK (0x7<<MPUTIM_PTV_BIT)
- Below Patch corrects the same
Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
Signed-off-by: Adrian Filipi <adrian.filipi@eurotech.com>
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
The i.MX31 has three SPI buses and each bus has several chip selects
and the MC13783 chip can be connected to any of these. The current
RTC driver for MC13783 is hardcoded for CSPI2/SS2.
This patch makes make MC13783 SPI bus and chip select configurable
via CONFIG_MC13783_SPI_BUS and CONFIG_MC13783_SPI_CS.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
This patch adds the reset_timer() function (needed by nand_base.c) and
modifies the get_timer_masked() to work in the same way as the omap24xx
function.
add CMD_DATA_SIZE macro to enable it
- #if CFG_ENV_IS_IN_FLASH
- #if (CFG_ENV_IS_IN_FLASH == 1)
- #define CFG_ENV_IS_IN_FLASH 0
finish remaning CFG_ID_EEPROM in CONFIG_ID_EEPROM
start in commit ad8f8687b78c3e917b173f038926695383c55555
This is part of the switch to newer upstream MTD code.
Based on original patch by Bernard Blackham <bernard@largestprime.net>
U-boot's HW ECC support for large page NAND on Davinci is completely
broken. Some kernels, such as the 2.6.10 one supported by
MontaVista for DaVinci, rely upon this broken behaviour as they
share the same code for ECCs. In the existing scheme, error
detection *might* work on large page, but error correction
definitely does not. Small page ECC correction works, but the
format is not compatible with the mainline git kernel.
This patch adds ECC code that matches what is currently in the
Davinci git repository (since NAND support was added in 2.6.24).
This makes the ECC and OOB layout written by u-boot compatible with
Linux for both small page and large page devices and fixes ECC
correction for large page devices.
The old behaviour can be restored by defining the macro
CFG_DAVINCI_BROKEN_ECC, which is undefined by default.
Acked-by: Sergey Kubushyn <ksi@koi8.net>
