2015-06-18omap_gpmc: move prefetch out of CONFIG_NAND_OMAP_ELMJeroen Hofstee
The prefech mode is a feature of the gpmc, not the ELM. An am3517 does not have an elm, but can do prefeches, so move the code out of the CONFIG_NAND_OMAP_ELM ifdef. Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@konsulko.com> Cc: Daniel Mack <zonque@gmail.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-17MSI_Primo81_defconfig: enable USB OTG port and keyboard supportKarsten Merker
The MSI Primo 81 is an Allwinner A31s-based tablet on which the OTG port is the only accessible USB interface. The existing defconfig had VGA console on the LCD enabled, but was missing keyboard support because the prerequisites for that (sunxi MUSB support and AXP221 GPIO support) had not been available before. All previously missing dependencies are available now, so this patch enables keyboard support and its prerequisites in the defconfig. Signed-off-by: Karsten Merker <merker@debian.org> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-06-17sun6i: cpu_reset: Do not return from cpu_reset()Hans de Goede
Currently on sun6i after a "reset" the prompt returns and the user can even type stuff until the watchdog triggers and does the actual reset. This is somewhat unexpected behavior for the "reset" command, this commit adds an endless loop to wait for the watchdog to trigger so that we do not return to the prompt. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-06-17sunxi: musb: Remove unused sunxi_musb_exit methodHans de Goede
Remove the unused sunxi_musb_exit method, there is no code in u-boot calling the exit method, and our implementation was broken as it did not disable the clocks and asserted reset. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-06-17sunxi: musb: Do not fully reset the controler from sunxi_musb_disableHans de Goede
Fully resetting the controller is a too big hammer, and the musb_core will then afterwards fail to communicate with any endpoints other then 0 as too much state was cleared. Instead report vbus low for 200ms which will effectively end the current session without needing to do a full reset. This fixes usb mass-storage devices no longer working after a "usb reset" Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-06-15Merge git://git.denx.de/u-boot-usbTom Rini
2015-06-15Merge git://git.denx.de/u-boot-marvellTom Rini
2015-06-15omap5: Exclude more environment from SPL buildsTom Rini
In the cases where we make use of environment in SPL we do not need these defaults compiled in and available. These are taking up space that in some cases now prevent linking, so drop. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-15board: add support for Vision System's Baltos Industrial PCYegor Yefremov
Vision Systems's Baltos is based on AM335x SoC from Texas Instruments. This patch adds support such Industrial PCs in mainline u-boot. [ balbi@ti.com: updated original patch to current u-boot ] Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-06-15ARM: DRA7: emif: Fix DDR init sequence during warm resetLokesh Vutla
Unlike OMAP5, EMIF PHY used in DRA7 will be left in unknown state after warm reset, emif needs to be configured to bring it back to a known state. So configure EMIF during warm reset. Reported-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-06-15avr32: move CONFIG_SYS_GENERIC_BOARD to KconfigMasahiro Yamada
Now all the AVR32 boards have been converted into Generic Board. Select it in Kconfig and clean up defines in header files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-06-15ARM: AM43x: Fix MAX_RAM_BANK_SIZELokesh Vutla
On AM437x-GP Evm there is 2GB of DDR3 memory available as stated in AM437x GP EVM HardwareUser's guide http://www.ti.com/lit/ug/spruhw7/spruhw7.pdf. But MAX_RAM_BANK_SIZE is defined as 1GB. Fixing MAX_RAM_BANK_SIZE to 2GB on AM43xx. Reported-by: Shivasharan Nagalikar <shivasharan.nagalikar@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-15am33xx: Re-enable SW levelling for DDR2Tom Rini
The recent changes for hw leveling on am33xx were not intended for DDR2 boards, only DDR3. Update emif_sdram_type to take a sdram_config value to check against. This lets us pass in the value we would use to configure, when we have not yet configured the board yet. In other cases update the call to be as functional as before and check an already programmed value in. Tested-by: Yan Liu <yan-liu@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-06-15ARM: BeagleBoard-x15: Enable i2c5 clocksLokesh Vutla
On AM57xx evm I2C5 is used to detect the LCD board by reading the EEPROM present on the bus. Enable i2c5 clocks to help that. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-15am43xx_evm: Enable NAND bootTom Rini
Enable booting from NAND on the am437xx-evm. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-15am335x_evm: nand: Fix boot from NANDRoger Quadros
Use the correct partition names from with the Device Tree blob and the kernel is picked up. Also use partition name instead of number for the root filesystem in the kernel boot arguments. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-15am335x_evm: am44xx_evm: dra7xx_evm: nand: Fix file-system partition nameRoger Quadros
We almost always use UBIFS for user accessible NAND file systems and the UBIFS file system might contain more than one volume within the single NAND partition. The last NAND partition is therefore more appropriately named as "NAND.file-system" instead of "NAND.rootfs" The Linux kernel (as of v3.16) also uses "NAND.file-system" to name the last NAND partition. This patch makes the partition name consistent between u-boot and the kernel. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-15configs: am43xx_evm: Enable NANDRoger Quadros
AM43xx EVMs have NAND so enable it. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-15highbank: add custom ahci_link_up functionMark Langsdorf
The Calxeda highbank SOC needs a custom sequence to bring up SATA links, so override ahci_link_up with custom function to handle combophy setup. Signed-off-by: Mark Langsdorf <mark.langsdorf@gmail.com> Signed-off-by: Richard Gibbs Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Andre Przywara <osp@andrep.de>
2015-06-14tools/kwboot: Add parameters to set delay and timeout via cmdlineStefan Roese
To support the Armada 38x, new values for the request-delay and the response-timeout are needed. As the values already implemented in this tool (for Kirkwood and Armada XP) don't seem to work here. To make this more flexible, lets add make those 2 parameters configurable via the cmdline. Here the new parameters: -q <req-delay>: use specific request-delay -s <resp-timeo>: use specific response-timeout For the Marvell DB-88F6820 these values are known to work: One board: -q 2 -s 1 2nd board: -q 5 -s 5 So this seems to be even board specific. But with this patch now those values can be specified and tested via the cmdline. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Kevin Smith <kevin.smith@elecsyscorp.com> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-06-14arm: mvebu: Update CBAR with SOC regs baseKevin Smith
SMP-enabled Linux kernels read the CBAR register in CP15 to find the address of the SCU registers. After remapping internal registers, also update the CBAR so the kernel can find them. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Acked-by: Stefan Roese <sr@denx.de>
2015-06-14arm: mvebu: Disable L2 cache before enabling d-cacheStefan Roese
L2 cache may still be enabled by the BootROM. We need to first disable it before enabling d-cache support. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com>
2015-06-14tools/kwbimage.c: Correct header size for SPI bootKevin Smith
If defined, the macro CONFIG_SYS_SPI_U_BOOT_OFFS allows a board to specify the offset of the payload image into the kwb image file. This value was being used to locate the image, but was not used in the "header size" field of the main header. Move the use of this macro into the function that returns the header size so that the same value is used in all places. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Stefan Roese <sr@denx.de>
2015-06-12ahci: extend data io wait to 10sMark Langsdorf
The AHCI driver currently waits 5s before timing out when sending a data command to a drive. Some drives take upwards of 8s to respond to the initial data command while they're spinning up. Increase the data io timeout to 10s so that those drives can be found on initial scsi scan. Signed-off-by: Mark Langsdorf <mark.langsdorf@gmail.com> Signed-off-by: Andre Przywara <osp@andrep.de>
2015-06-12ahci: support LBA48 data reads for 2+TB drivesMark Langsdorf
Enable full 48-bit LBA48 data reads by passing the upper word of the LBA block pointer in bytes 9 and 10 of the FIS. This allows uboot to load data from any arbitrary sector on a drive with 2 or more TB of available data connected to an AHCI controller. Signed-off-by: Mark Langsdorf <mark.langsdorf@gmail.com> Signed-off-by: Andre Przywara <osp@andrep.de> [trini: Make use of CONFIG_SYS_64BIT_LBA in a few places to drop warnings on platforms that don't enable that feature ] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-12cmd_scsi: use lbaint_t for LBA values instead of u32Mark Langsdorf
2015-06-12ARM: highbank: add reset support for Calxeda Midway machineMark Langsdorf
The Calxeda Midway part has A15 cores, which do not have the Highbank A9's SCU used there for resetting the chip. Add code to distinguish between the A9 and the A15 and invoke the appropriate register writes to support the newer part. Andre: rework detection of Highbank vs. Midway Rob: fix Andre's reworked detection Signed-off-by: Mark Langsdorf <mark.langsdorf@gmail.com> Signed-off-by: Andre Przywara <osp@andrep.de> Signed-off-by: Rob Herring <robh@kernel.org>
2015-06-12ARM: highbank: add missing SCU register setup for resetRob Herring
Andre: assign names to the magic values Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Andre Przywara <osp@andrep.de>
2015-06-12ARM: BeagleBoard-x15: Add mux dataLokesh Vutla
Adding the mux data, manual and virtual mode settings for BeagleBoard-X15. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Roger Quadros <rogerq@ti.com>
2015-06-12ARM: BeagleBoard-x15: Enable IO delay recalibration sequenceLokesh Vutla
Enable IO delay recalibration sequence. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: CPSW: Remove IO delay hackLokesh Vutla
Now all manual mode configurations are done as part of IO delay recalibration sequence, remove the hack done for CPSW. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-06-12ARM: DRA7-evm: Add mux dataNishanth Menon
Adding the mux data, manual and virtual mode settings for DRA7-evm. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Vishal Mahaveer <vishalm@ti.com>
2015-06-12ARM: DRA7-evm: Enable IO delay recalibration sequenceLokesh Vutla
Enabling IO delay recalibration sequence for DRA7 EVM. UART and I2C are configured before IO delay recalibration sequence as these are used earlier and safe to use. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: Add support for manual mode configurationLokesh Vutla
In addition to the regular mux configuration, certain pins of DRA7 require to have "manual mode" also programmed, when predefined delay characteristics cannot be used for the interface. struct iodelay_cfg_entry is introduced for populating manual mode IO timings. For configuring manual mode, along with the normal pad configuration do the following steps: - Select MODESELECT field of each assocaited PAD. CTRL_CORE_PAD_XXX[8]:MODESELECT = 1(Enable MANUAL_MODE macro along with mux) - Populate A_DELAY, G_DELAY values that are specified in DATA MANUAL. And pass the offset of the CFG_XXX register in iodelay_cfg_entry. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: Add support for IO delay configurationLokesh Vutla
On DRA7, in addition to the regular muxing of pins, an additional hardware module called IODelay which is also expected to be configured. This "IODelay" module has it's own register space that is independent of the control module. It is advocated strongly in TI's official documentation considering the existing design of the DRA7 family of processors during mux or IODelay recalibration, there is a potential for a significant glitch which may cause functional impairment to certain hardware. It is hence recommended to do muxing as part of IOdelay recalibration. IODELAY recalibration sequence: - Complete AVS voltage change on VDD_CORE_L - Unlock IODLAY config registers. - Perform IO delay calibration with predefined values. - Isolate all the IOs - Update the delay mechanism for each IO with new calibrated values. - Configure PAD configuration registers - De-isolate all the IOs. - Relock IODELAY config registers. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: Add support for virtual mode configurationLokesh Vutla
In addition to the regular mux configuration, certain pins of DRA7 require to have "virtual mode" also programmed. This allows for predefined delay characteristics to be used by the SoC to meet timing characterstics needed for the interface. Provide easy to use macro to do the same. For configuring virtual mode, along with normal pad configuration add the following two steps: - Select MODESELECT field of each assocaited PAD. CTRL_CORE_PAD_XXX[8]:MODESELECT = 1 - DELAYMODE filed should be configured with value given in DATA Manual. CTRL_CORE_PAD_XXX[7:4]:DELAYMODE =[0-15] (as given in DATA manual). Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: Add pinctrl register definitionsLokesh Vutla
Adopting the pinctrl register definitions from Linux kernel to be consistent. Old definitions will be removed once all the pinctrl data is adapted to new definitions. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7: Make do_set_mux32() genericLokesh Vutla
do_set_mux32() is redefined in dra7xx and beagle_x15 boards. IO delay recalibration sequence also needs this. Making it generic to avoid duplication. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7xx: EMIF: Fix DLL_CALIB_CTRL registerLokesh Vutla
When DLL_CALIB_INTERVAL is set, an extra delay is added which is not required and it consumes EMIF bandwidth. So making the DLL_CALIB_CTRL[8:0]DLL_CALIB_INTERVAL bits to 0. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-06-12ARM: DRA7: Update DDR IO registersLokesh Vutla
Update DDR IO register values. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA7: Update DDR IO configurationLokesh Vutla
DDRIO_2 and LPDDR2CH1_1 registers are not present for DRA7. So not configuring these registers for DRA7xx Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA7: Add is_dra72x cpu check definitionLokesh Vutla
A generic is_dra72x cpu check is useful for grouping all the revisions under that. This is used in the subsequent patches. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA72-evm: Enable HW levelingLokesh Vutla
Updating EMIF registers to enable HW leveling on DRA72-evm. Also updating the timing registers. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA7-evm: Enable HW levelingLokesh Vutla
Updating EMIF registers to enable HW leveling on DRA7-evm. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: BeagleBoard-X15: Enable HW levelingLokesh Vutla
Updating EMIF registers to enable HW leveling on BeagleBoard-X15. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA7: DDR3: Add support for HW levelingLokesh Vutla
DRA7 EMIF supports Full leveling for DDR3. Adding support for the Full leveling sequence. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12kconfiglib: sync with the latest in Kconfiglib projectMasahiro Yamada
This commit imports some updates of kconfiglib.py from https://github.com/ulfalizer/Kconfiglib - Warn about and ignore the "allnoconfig_y" Kconfig option - Statements in choices inherit menu/if deps - Add Symbol.is_allnoconfig_y() - Hint that modules are still supported despite warnings. - Add warning related to get_defconfig_filename(). - Fix typo in docs. - Allow digits in $-references to symbols. Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com> Signed-off-by: Philip Craig <philipjcraig@gmail.com> Signed-off-by: Jakub Sitnicki <jsitnicki@gmail.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-12Nokia RX-51: Fix calculating return address in save_boot_paramsPali Rohár
Commit e11c6c279d823dc0d2f470c5c2e3c0a9854a640f broke calculating lr register in function save_boot_params() and caused U-Boot to crash at early boot time on Nokia N900 board. This patch fix calculating return address in lr register and make Nokia N900 board bootable again. Patch was tested in qemu and also on real N900 HW. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
2015-06-11Merge git://git.denx.de/u-boot-dmTom Rini
2015-06-11common/cmd_bdinfo: show gd->board_typeHannes Schmelzer
sometimes it is usefull to know if board-detection has written the correct value into gd->board_type. For this we add some output to the bdinfo command. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
