When applying the AT91CAP9 patches upstream, something transformed
the '@' character into the ' <at> ' sequence.
The patch below restores the original form in all the places where
it has been modified (the AT91CAP9 files, the AT91SAM9260 files which
were copied from AT91CAP9, and a couple of other files where the
' <at> ' sequence was present).
Signed-off-by: Stelian Pop <stelian@popies.net>
When doing the AT91CAP9/AT91SAM9 port, a number of header files were
copied from the Linux kernel sources. This patch explicitly specifies
this origin for all the copied headers, and for those missing copyright
information, adds it.
Additionaly, the header file 'at91sam926x_mc.h' has been superceeded
in the latest kernel sources by 'at91sam9_smc.h'.
The copyright information has been confirmed by the AT91 Linux kernel
maintainer, Andrew Victor <avictor.za@gmail.com>.
When Ulf did the dataflash.c cleanup, he didn't add his copyright on
the new created files. This patch fixes the problem.
According to schematics and to RedBoot sources, the MX31ADS uses a 32768Hz
oscillator as a SKIL source. Fix previously wrongly assumed 32000Hz value.
Also fix a typo when verifying a jumper configuration. While at it, make
two needlessly global functions static.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Add logbuffer to reserved LMB areas to prevent initrd allocation
from overlaping with it.
Make sure to use correct logbuffer base address.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Removed duplicated effective memory size calculation code.
Recent modifcations to LOGBUFFER handling code were incorrecly
introduced to fit_check_kernel() routine during
"Merge branch 'new-image' of git://www.denx.de/git/u-boot-testing",
commit 27f33e9f45ef7f9685cbdc65066a1828e85dde4f.
This patch cleans up this merge issue.
Changed implementation such that fw_printenv returns failure status
when one or more specified variables do not exist or when incorrect
command syntax is used.
This aids scripting fw_printenv such that the script can key of the
return status rather than relying on standard error "scraping".
Signed-off-by: Grant Erickson <gerickson@nuovations.com>
In the current top-of-tree, 1.3.3.-rc2, the optional tool
'tools/env/fw_printenv' fails to compile for two reasons:
1) The header watchdog.h cannot be found.
2) The header zlib.h is picked up from the tool chain rather than the
project causing a prototype conflict for crc32.
This patch addresses both of these issues.
Platforms Tested On:
- AMCC "Kilauea"
When CONFIG_CMDLINE_EDITING is enabled, readline_into_buffer() doesn't
work before relocating to RAM because command history is written into
a global array that is not writable before relocation. This patch
defers to the no-editing and no-history code in readline_into_buffer()
if it is called before relocation.
Signed-off-by: James Yang <James.Yang@freescale.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: Vlad Lungu <vlad.lungu@windrvier.com>
Removed the second include, with all the #ifdef around as suggested by Wolfgang.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
This patch fixes three typos.
The first is a repetition of CONFIG_CMD_BSP.
The second makes the #endif comment match its #if.
The third is a spelling error.
Signed-off-by: Adrian Filipi <adrian.filipi@eurotech.com>
Add support for the recognition of 'powerpc' as an alias for the PowerPC
architecture type since Linux is already trending in that direction,
preferring 'powerpc' to 'ppc'.
The 7610 and related parts have an L2IP bit in the L2CR that is
monitored to signal when the L2 cache invalidate is complete whereas the
7450 and related parts utilize L2I for this purpose. However, the
current code does not account for this difference. Additionally the 86xx
L2 cache invalidate code used an "andi" instruction where an "andis"
instruction should have been used.
This patch addresses both of these bugs.
Signed-off-by: Travis Wheatley <travis.wheatley@freescale.com>
Acked-By: Jon Loeliger <jdl@freescale.com>
Fix a bogus circular dependency that caused an infinite loop of
"Generating include/autoconf.mk" again and again.
This patch adds fdt (flattened device tree) support to all remaining AMCC
eval boards. Most newer boards already support device tree. With this patch,
all AMCC boards now enable device tree passing from U-Boot to Linux
arch/powerpc kernels.
This patch adds a default ft_board_setup() routine to the 4xx fdt code.
This routine is defined as weak and can be overwritten by a board specific
one if needed.
This patch adds fdt (flattened device tree) support to the AMCC
Acadia eval board. This increases the image size and it doesn't
fit anymore into 256kByte. Since we didn't want to remove features
from the configuration, we decided to increase the U-Boot image size
(add one flash sector).
Also changed the default environment definition to make it
independent of such changes.
Add support for booting with a device tree blob. This is needed to boot
ARCH=powerpc kernels. Also add support for setting the eth0 mac address
via the ethaddr variable.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
Corrected two typos in the 460GT/EX FBDV array.
Signed-off-by: Dave Mitchell <dmitchell@amcc.com>
Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
These same settings are used on MPC8349ITX, and
improve performance on MPC8349EMDS.
Signed-off-by: Lee Nipper <lee.nipper@freescale.com>
Some old GNU assemblers, such as v2.14 (ELDK 3.1.1), v2.16 (ELDK 4.1.0),
warns illegal global symbol references by bal (and jal also) instruction.
This does not happen with the latest binutils v2.18.
Here's an example on gth2_config:
mips_4KC-gcc -D__ASSEMBLY__ -g -Os -D__KERNEL__ -DTEXT_BASE=0x90000000 -I/home/skuribay/devel/u-boot.git/include -fno-builtin -ffreestanding -nostdinc -isy
stem /opt/eldk311/usr/bin/../lib/gcc-lib/mips-linux/3.3.3/include -pipe -DCONFIG_MIPS -D__MIPS__ -G 0 -mabicalls -fpic -pipe -msoft-float -march=4kc -mtune=4k
c -EB -c -o cache.o cache.S
cache.S: Assembler messages:
cache.S:243: Warning: Pretending global symbol used as branch target is local.
cache.S:250: Warning: Pretending global symbol used as branch target is local.
In principle, gas might be sensitive to global symbol references in PIC
code because they should be processed through GOT (global offset table).
But if `bal' instruction is used, it results in PC-based offset jump.
This is the cause of this warning.
In practice, we know it doesn't matter whether PC-based reference or GOT-
based. As for this case, both will work before/after relocation. But let's
fix the code.
This patch explicitly sets up a target address, then jump there.
Here's an example of disassembled code with/without this patch.
90000668: 1485ffef bne a0,a1,90000628 <mips_cache_reset+0x20>
9000066c: ac80fffc sw zero,-4(a0)
90000670: 01402821 move a1,t2
-90000674: 0411ffba bal 90000560 <mips_init_icache>
-90000678: 01803021 move a2,t4
-9000067c: 01602821 move a1,t3
-90000680: 0411ffcc bal 900005b4 <mips_init_dcache>
-90000684: 01a03021 move a2,t5
-90000688: 03000008 jr t8
-9000068c: 00000000 nop
+90000674: 01803021 move a2,t4
+90000678: 8f8f83ec lw t7,-31764(gp)
+9000067c: 01e0f809 jalr t7
+90000680: 00000000 nop
+90000684: 01602821 move a1,t3
+90000688: 01a03021 move a2,t5
+9000068c: 8f8f81e0 lw t7,-32288(gp)
+90000690: 01e0f809 jalr t7
+90000694: 00000000 nop
+90000698: 03000008 jr t8
+9000069c: 00000000 nop
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
.gpword works only with local symbols on certain binutils versions
Update ChNAGELOG, minor white space cleanup.
Some systems are dumb and do not implement the -n flag to echo (like OS X).
Convert the Makefile to use printf as this should work everywhere.
If you enable environment in the flash, but disable the embedded
option, and you disable the saveenv command, then the #if nested
logic will trigger a compile failure:
env_flash.c: In function 'env_relocate_spec':
env_flash.c:399: error: 'flash_addr' undeclared (first use in this function)
The fix is to add CMD_SAVEENV ifdef protection like everywhere else.
Fix incorrect mask to enable all 64MB of onboard flash.
Previously U-Boot incorrectly mapped only 8MB of flash, this
patch correctly maps all the available flash.
Signed-off-by: Jeremy McNicoll <jeremy.mcnicoll@windriver.com>
The mmap() related code is full of inconsistent casts/constants when
it comes to error checking, and may break when building on some
systems (like ones that do not implicitly define the caddr_t type).
Let's just avoid the whole mess by writing the code nice and clean in
the first place.
- warning: 'srom' defined but not used
- warning: implicit declaration of function ‘serial_initialize’
