global define.
Include immap.h and timer.h. Moved dtimer interrupt setup to dtimer_intr_setup() from cpu/mcf532x/interrupts.c. Changed (CFG_CLK /1000000) -1 << 8 to CFG_TIMER_PRESCALER
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Include immap.h and renamed mcfrtc.h to rtc.h
Added mcffec_initialize() in eth_initialize()
Include immap.h
Seperated from mcfuart.h
Seperated from mcftimer.h
Since it is already in m68k folder, un-necessary to pad mcf. Replaced immap_5329.h and m5329.h to immap.h
Renamed mcfserial.c to mcfuart.c. Modified Makefile for mcfuart.o from mcfserial.o. Replace immap_5329.h and m5329.h to immap.h
Replaced immap_5329.h and m5329.h with immap.h. Included cache_invalid.
interrupt_init() and dtimer_intr_setup() are placed in interrupts.c. Added interrupts.o to Makefile
Replaced immap_5329.h and m5329.h with immap.h. Removed whitespaces.
Replaced immap_5329.h and m5329.h with immap.h. Enabled icache_enable() in cpu_init_r().
Replace immap_5329.h and m5329.h with immap.h. Removed interrupt_init() and placed it in interrupts.c
Removed flash.o and added mii.o
The removed MII routines will be placed in mii.c.
There is a Common Flash Interface Driver existed. To use the CFI driver, define CFG_FLASH_CFI in configuration file.
Removed new uart structure and defines to uart.h
New timer structure and defines will move to new timer.h
Removed whitespace
Replaced whitespace with tabs
to new header file.
Create new header file to include immap_5xxx.h and m5xxx.h and to share among drivers without update in driver file each processor is added. Moved peripherals base address and defines from configs file to immap.h.
Changed MAKEALL file mode to executable, removed executable file mode from Makefile
Added board/freescale/m5329evb, cpu/mcf532x, drivers/net,
drivers/serial, immap_5329.h, m5329.h, mcfrtc.h,
include/configs/M5329EVB.h, lib_m68k/interrupts.c, and
rtc/mcfrtc.c
Modified CREDITS, MAKEFILE, Makefile, README, common/cmd_bdinfo.c,
common/cmd_mii.c, include/asm-m68k/byteorder.h, include/asm-m68k/fec.h,
include/asm-m68k/io.h, include/asm-m68k/mcftimer.h,
include/asm-m68k/mcfuart.h, include/asm-m68k/ptrace.h,
include/asm-m68k/u-boot.h, lib_m68k/Makefile, lib_m68k/board.c,
lib_m68k/time.c, net/eth.c and rtc/Makefile
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Most prominently this changes 'erase' to be non-repeatable.
Signed-off-by: Detlev Zundel <dzu@denx.de>
This patch adds NAND booting support for the AMCC Acadia eval board.
Please make sure to configure jumper J7 to position 2-3 when booting
from NOR, and to position 1-2 when booting for NAND.
I also added a board command to configure the I2C bootstrap EEPROM
values. Right now only 267MHz is support for booting either via NOR
or NAND FLASH. Here the usage:
=> bootstrap 267 nor ;to configure the board for 267MHz NOR booting
=> bootstrap 267 nand ;to configure the board for 267MHz NNAND booting
e600 does not have a bootpg restriction.
Move the version string to beginning of image at fff00000.
Resetvec.S is not needed.
Update flash copy instructions.
Add tftpflash env variable
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
The attached patch is mainly cosmetic, allowing u-boot to
display the correct bootstrap option letter according to the
datasheets.
The original patch was extended with 405EZ support by Stefan
Roese.
Signed-off-by: Benoit Monin <bmonin@adeneo.eu>
This patch undoes the patch by Jeff Mann with commit-id ada4697d. As
suggested by AMCC it is not recommended to dynamically change the EBC
speed after bootup. So we undo this change to be on the safe side.
This patch adds NAND booting support for the AMCC Bamboo eval board.
Since the NAND-SPL boot image is limited to 4kbytes, this version
only supports the onboard 64MBytes of DDR. The DIMM modules can't be
supported, since the setup code for I2C DIMM autodetection and
configuration is too big for this NAND bootloader.
The U-Boot NAND booting support is now extended to support ECC
upon loading of the NAND U-Boot image.
Tested on AMCC Sequoia (440EPx) and Bamboo (440EP).
This patch updates the "normal" Bamboo NOR booting port, so
that it is compatible with the coming soon NAND booting
Bamboo port.
It also enables the 2nd NAND flash on the Bamboo.
This patch adds hardware ECC support to the NDFC driver. It also
changes the register access from using the "simple" in32/out32
functions to the in_be32/out_be32 functions, which make sure
that the access is correctly synced. This is the only recommended
access to SoC registers in the current Linux kernel.
This patch updates the nand_ecc code to the latest Linux version.
The main reason for this is the more compact code. This makes
it possible to include the ECC code into the NAND bootloader
image (NAND_SPL) for PPC4xx.
With the updated 44x DDR2 driver the Luan board now supports
ECC generation and checking.
Add config option for 180 degree advance clock control as needed
for the AMCC Luan eval board.
