Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
During NAND_SPL boot, base address and different register are programmed
default by corresponding NAND controllers(eLBC/IFC). These settings are
sufficient enough for NAND SPL.
Avoid updating these register.They will be programmed during NAND RAMBOOT.
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Freescale's e500v1 and e500v2 cores (used in mpc85xx chips) have some
restrictions on external debugging (JTAG).
So define CONFIG_SYS_PPC_E500_DEBUG_TLB to enable a temporary TLB entry to be
used during boot to work around the limitations.
Please refer doc/README.mpc85xx for more information
Signed-off-by: Radu Lazarescu <radu.lazarescu@freescale.com>
Update NAND code base to ovecome e500 and e500v2's second limitation i.e. IVPR
+ IVOR15 should be valid fetchable OP code address.
As NAND SPL does not compile vector table so making sure IVOR + IVOR15 points to
any fetchable valid data
Signed-off-by: Marius Grigoras <marius.grigoras@freescale.com>
Debugging of e500 and e500v1 processer requires debug exception vecter (IVPR +
IVOR15) to have valid and fetchable OP code.
1) While executing in translated space (AS=1), whenever a debug exception is
generated, the MSR[DS/IS] gets cleared i.e. AS=0 and the processor tries to
fetch an instruction from the debug exception vector (IVPR + IVOR15); since now
we are in AS=0, the application needs to ensure the proper TLB configuration to
have (IVOR + IVOR15) accessible from AS=0 also.
Create a temporary TLB in AS0 to make sure debug exception verctor is
accessible on debug exception.
2) Just after relocation in DDR, Make sure IVPR + IVOR15 points to valid opcode
Debugging of e500 and e500v1 processer requires MSR[DE] bit to be set always.
Where MSR = Machine State register
Make sure of MSR[DE] bit is set uniformaly across the different execution
address space i.e. AS0 and AS1.
Signed-off-by: Catalin Udma <catalin.udma@freescale.com>
This describes requirement of e500 and e500v2 processor to support external
debugger.
It also provide an insight of the configuration switch required and their
description.
On p1010rdb some signals are muxed for tdm/can/uart/flash.
If we don't set fsl_p1010mux:tdm_can to "can" or "tdm" explicitly,
defaultly we keep spi chip selection to spi-flash instead of to
tdm/slic and disable uart1 when not using flexcan, as well disable sdhc.
BSC9131RDB is a Freescale reference design board for BSC9131 SoC. BSC9131 SOC
is an integrated device that targets Femto base station market. It combines
Power Architecture e500v2 and DSP StarCore SC3850 core technologies with
MAPLE-B2F baseband acceleration processing elements
BSC9131RDB Overview
-1Gbyte DDR3 (on board DDR)
-128Mbyte 2K page size NAND Flash
-256 Kbit M24256 I2C EEPROM
-128 Mbit SPI Flash memory
-USB-ULPI
-eTSEC1: Connected to RGMII PHY
-eTSEC2: Connected to RGMII PHY
-DUART interface: supports one UARTs up to 115200 bps for console display
Apart from the above it also consists various peripherals to support DSP
functionalities.
This patch adds support for mainly Power side functionalities and peripherals
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Akhil Goyal <Akhil.Goyal@freescale.com>
Signed-off-by: Rajan Srivastava <rajan.srivastava@freescale.com>
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
- BSC9131 is integrated device that targets Femto base station market.
It combines Power Architecture e500v2 and DSP StarCore SC3850 core
technologies with MAPLE-B2F baseband acceleration processing elements.
- BSC9130 is exactly same as BSC9131 except that the max e500v2
core and DSP core frequencies are 800M(these are 1G in case of 9131).
- BSC9231 is similar to BSC9131 except no MAPLE
The BSC9131 SoC includes the following function and features:
. Power Architecture subsystem including a e500 processor with 256-Kbyte shared
L2 cache
. StarCore SC3850 DSP subsystem with a 512-Kbyte private L2 cache
. The Multi Accelerator Platform Engine for Femto BaseStation Baseband
Processing (MAPLE-B2F)
. A multi-standard baseband algorithm accelerator for Channel Decoding/Encoding,
Fourier Transforms, UMTS chip rate processing, LTE UP/DL Channel processing,
and CRC algorithms
. Consists of accelerators for Convolution, Filtering, Turbo Encoding,
Turbo Decoding, Viterbi decoding, Chiprate processing, and Matrix Inversion
operations
. DDR3/3L memory interface with 32-bit data width without ECC and 16-bit with
ECC, up to 400-MHz clock/800 MHz data rate
. Dedicated security engine featuring trusted boot
. DMA controller
. OCNDMA with four bidirectional channels
. Interfaces
. Two triple-speed Gigabit Ethernet controllers featuring network acceleration
including IEEE 1588. v2 hardware support and virtualization (eTSEC)
. eTSEC 1 supports RGMII/RMII
. eTSEC 2 supports RGMII
. High-speed USB 2.0 host and device controller with ULPI interface
. Enhanced secure digital (SD/MMC) host controller (eSDHC)
. Antenna interface controller (AIC), supporting three industry standard
JESD207/three custom ADI RF interfaces (two dual port and one single port)
and three MAXIM's MaxPHY serial interfaces
. ADI lanes support both full duplex FDD support and half duplex TDD support
. Universal Subscriber Identity Module (USIM) interface that facilitates
communication to SIM cards or Eurochip pre-paid phone cards
. TDM with one TDM port
. Two DUART, four eSPI, and two I2C controllers
. Integrated Flash memory controller (IFC)
. TDM with 256 channels
. GPIO
. Sixteen 32-bit timers
The DSP portion of the SoC consists of DSP core (SC3850) and various
accelerators pertaining to DSP operations.
This patch takes care of code pertaining to power side functionality only.
Add USB device-tree fixup for following platforms:
MPC8536DS, P1022DS, P1023RDS, P2020COME, P2020DS, P2041RDB, P3060QDS
Use the POSIX variant of basename due to BSD systems (e.g. OS X) do not provide
GNU version of basename(3). It is save to use the POSIX variant here cause we do
never use argv[0] later on which may be modified by the basename(3) POSIX
variant.
On systems providing GNU variant the GNU variant should be used since string.h
is included before libgen.h. Therefore let the _GNU_SOURCE as is.
This patch fixes following warning (on OS X):
---8<---
mkenvimage.c: In function ‘main’:
mkenvimage.c:105: warning: implicit declaration of function ‘basename’
mkenvimage.c:105: warning: assignment makes pointer from integer without a cast
--->8---
cc: Keith Mok <ek9852@gmail.com>
The value of ET0_ERXD6 and GPSR1_INIT was wrong.
This fixes them.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
This patch dramatically drops the amount of time u-boot needs to read a
file from an ext2 partition. On a typical 2 to 5 MB file (kernels and
initrds) it goes from tens of seconds to a couple seconds.
All we are doing here is grouping contiguous blocks into one read.
Boot tested on Globalscale Technologies Dreamplug (Kirkwood ARM SoC)
with three different files. sha1sums were calculated in Linux
userspace, and then confirmed after ext2load.
Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
Tested-by: Eric Nelson <eric.nelson@boundarydevices.com>
Tested-by: Thierry Reding <thierry.reding@avionic-design.de>
Add a new command "sysboot" which parses syslinux menu files and boots
using kernel and initrd specified by menu files. The operation is similar
to "pxe boot" except local files on ext2 or fat filesystem are parsed.
For syslinux, the initrd can be set in the append string as
"initrd=<file>", so try to find it there if we haven't already set the
initrd.
If the file path starts with a '/', then don't pre-pend the bootfile path.
This fixes a problem with running 'pxe boot' multiple times where the
bootfile path gets pre-pended to itself each time.
Kernels can be specified using "linux" or "kernel" entry. The difference
is kernel is supposed to detect the type of file, but for u-boot both are
treated the same.
Use a menu string if present, otherwise use the kernel string.
Include files outside of a menu were not getting included and parsed.
Make the menu timeout apply only when prompt flag is set and after the
menu is displayed. This allows auto boot to work no matter whether prompt
is set or cleared. Use the default selection if the menu times out.
This also fixes the timeout value given to readline_into_buffer to be
seconds instead of 10th of seconds.
Old behavior:
if prompt
display menu and wait for choice
else
wait for timeout
if key pressed
else
exit command
New behavior:
if prompt
display menu
if key pressed
wait for choice
else
boot default entry on timeout
else
boot default entry
This tests for a bad habits of mine like this:
return 0 ;
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
This driver is unused and obsolete.
Cc: unsik Kim <donari75@gmail.com>
Signed-off-by: Loïc Minier <lool@debian.org>
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
patman shouts when it couldn't find a $(HOME)/.patman file.
Handle it in a sane way by creating a new one for the user.
It looks for a user.name and user.email in the global .gitconfig
file, waits for the user input if it can't find there. Update the
same in the README
Signed-off-by: Vikram Narayanan <vikram186@gmail.com>
Move the config file from ~/.config/patman to ~/.patman as it is
more appropriate to have it there. Update the same in the README.
Compressing the logos with lzma rather than gzip saves ~9kb with the
Blackfin 24bit images and ~3kb with the 16bit images.
Add a new -l option to easylogo so people can pick lzma as their
decompression routine.
Simplify the code slightly by using a for() loop since this is
basically what we're already doing -- incrementing "ngood" to
the value in "count".
Not only does the source code get simpler, but it also shrinks the
compiled object code too.
While we're here, tweak the summary message to avoid the plural
issue. It isn't that big of a deal, and it's currently wrong
anyways in the single (1 byte) case:
Total of 1 byte were the same
Grammar wise, that should be "was" rather than "were". The new
output people should be able to easily figure out:
Total of 1 byte(s) were the same
Total of 10 byte(s) were the same
* 'master' of git://git.denx.de/u-boot-mpc83xx:
km/common: check test_bank and testpin for testboot
powerpc/83xx/km: readout dip_switch on kmcoge5ne
powerpc/83xx: configure CONFIG_POST for kmcoge5ne
powerpc/83xx/km: added missing enable of application buffer
km/common: increase bootlimit to 3
km/common: fixed error in ethaddr (1-byte-shift)
MAINTAINERS: cleanup for keymile boards
powerpc/83xx: add kmcoge5ne board support
km/common: add support for second flash
powerpc83xx/km: remove unneeded CONFIG_PCI for kmeter1
powerpc83xx/km: lock the window size to 2GiB befor fixing sdram size
powerpc/83xx/km: use tuxx1.h for kmsupx5 target
powerpc/83xx: increment malloc heap size for the MPC832x MDS boards
If the testpin is asserted, first check if a test_bank
variable is defined before trying to boot this
test_bank.
Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
On kmcoge5ne we have a dip switch present. If this switch
was switched on the actual_bank is set to 0 and this SW
will be booted.
kmcoge5ne starts the post tests if the testpin on
the board was enabled. Currently it does simply a memory
test.
Enabled application buffers in uboot to allow application chipselect
access in uboot.
Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com>
Increase bootlimit to 3 to be more tolerant during the
boot process before switching to the backup application.
The MAC address begins at offset 1.
cc: Kim Phillips <kim.phillips@freescale.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Gerlando Falauto <gerlando.falauto@keymile.com>
cc: Heiko Schocher <hs@denx.de>
This board is a MPC8360 board. Two flashes are present
a NOR flash were u-boot and the u-boot environment is stored
and a NAND flash for the application code. This board has 512MB
SDRAM.
Additionaly we introduce a common km8360.h file and convert kmeter1 to
use this.
Signed-off-by: Christian Herzig <christian.herzig@keymile.com>
Add support for a second flash.
By default, a single flash chip is set up:
- called 'boot'
- mtd name for ubi 'ubi0'
MTDIDS and MTDPARTS may be overwritten to add a second flash.
The 'ubiattach' command is featured in two versions:
- if CONFIG_KM_UBI_PARTITION_NAME_APP is not defined:
this is the version as up to now
- if CONFIG_KM_UBI_PARTITION_NAME_APP is defined:
a check on 'actual_bank' will be done to determine the flash to boot
from.
Use CONFIG_KM_UBI_PARTITION_NAME_BOOT and
CONFIG_KM_UBI_PARTITION_NAME_APP to define where to put the bootloader
and the applications.
Example:
In the board config do:
... snip ...
"boot:" \
"768k(u-boot)," \
"128k(env)," \
"128k(envred)," \
"-(" CONFIG_KM_UBI_PARTITION_NAME_BOOT ");" \
"app:" \
"-(" CONFIG_KM_UBI_PARTITION_NAME_APP ");"
... snap ...
You may also need to enable the second flash:
... snip ...
/* additional featured for COGE5 */
... snap ...
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
We don't use PCI on kmeter1 and never will be, so remove some
unneeded code.
If the ram size isn't locked to 2GiB, the get_ram_size() may hang up.
This additional header is unneeded, we can use the tuxx1.h for this
target.
The malloc buffer is not large enough to hold a flash sector (0x20000 bytes)
in addition to whatever else it normally holds, so double its size. This
fixes a failure trying to save the environment:
=> save
Saving Environment to Flash...
Unable to save the rest of sector (122880)
. done
Protected 1 sectors
This problem probably surfaced from some other change that significantly
increased the normal memory usage, thereby not leaving enough room for
the saveenv command.
Commit 418396e212b59bf907dbccad997ff50f7eb61b16 introduced a
bug that causes nand read and nand write to crash in strcmp
due to a null pointer.
Root cause is that strchr(cmd, '.') returns a null pointer when
the input string does not contain a '.'
The strcmp function does not check for null pointers, resulting
in a crash.
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Scott Wood <scott@tyr.buserror.net>
* 'master' of git://git.denx.de/u-boot-video:
video: atmel/lcd: add LCD driver for new Atmel SoC
video: cfb_console: flush dcache for frame buffer in DRAM
cfb_console: Ignore bell character
cfb_console: Add console_clear_line function
cfb_console: Fix function console_back
omap3_dss: cosmetic changes
omap3_dss: add optional framebuffer
mx53loco: Add LCD support
mx5: Rename mx51_fb_init()
mx53: Allow IPUv3 driver to also work on mx53
mx51evk: Add LCD support
EXYNOS: display 32bpp bitmap TIZEN logo
create lib/tizen directory
LCD: display 32bpp decompressed bitmap image
common/lcd.c: reduce one CONFIG_LCD_LOGO ifdef
common/lcd.c: reduce some CONFIG_LCD_*_LOGO ifdefs
common/lcd.c: use ARRAY_SIZE
cmd_bmp.c: make bmp_display() usable by drivers or board code
LCD: support another s6e8ax0 panel type
LCD: change s6e8ax0 panel gamma value
include/video.h: drop unused video_printf()
* 'master' of git://git.denx.de/u-boot-avr32:
avr32:board.c: fix compile warning
avr32:grasshopper: fix PHY initialisation
