2017-03-09tools: Remove CONFIG_SYS_TEXT_BASE in MakefilePatrick Delaunay
This define is not used in tools sources and can be removed to avoid unnecessary link between tools and defconfig Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-09kbuild: turn of dtc unit address warnings by defaultMasahiro Yamada
DTC 1.4.2 or later checks DT unit-address without reg property and vice-versa, and generates lots of warnings. Fixing DT files will take for a while. Until then, let's turn off the check unless building with W=*. Introduce a new helper dtc-option to check if the option is supported in order to suppress warnings on older versions. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2017-03-08Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2017-03-08Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2017-03-08omap3_logic: Move SPL Stack into SDRAMAdam Ford
A previous patch broke the board. This patch will add missing part from the previous patch and also move the SPL Stack into SDRAM at 0x82000000. Tested with GCC 4.8.2 and GCC 6.2 Fixes: 0959649dc6d9 ("omap3_logic: Switch to simple malloco in SPL") Signed-off-by: Adam Ford <aford173@gmail.com> Changes in V2: - Keep CONFIG_SPL_SYS_MALLOC_SIMPLE - Add CONFIG_SYS_MALLOC_F_LEN=0x2000 (8 MB)
2017-03-07video: cfb_console: fix 32-bit display on 64-bit architecturesAndre Przywara
"unsigned long" is a lousy data type when it comes to match peripheral hardware registers with a fixed size. Just do the obvious and match a 32-bit display format with an "u32" data type for casting. This fixes the logo display on 64-bit architectures, which produced a black line on the right side of the logo with non-black backgrounds. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2017-03-07net: zynq_gem: Fix masking of supported phydev featuresNathan Rossi
When the zynq_gem driver initializes the phy it sets the supported features that the phy can support and advertise. However instead of masking the supported features such that it limits the available features it sets the phy to have the exact supported features of the zynq_gem. This is problematic as it will enable features that a phy does not have or cannot advertise. Specifically this appears as an issue when using a phy that is only capable of 10/100, but the zynq_gem driver will override this and try to enable and advertise 10/100/1000. Reported-by: Arno Steffens <star@gmx.li> Fixes: 80243528ef ("net: gem: Fix gem driver on 1Gbps LAN") Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Tested-by: Arno Steffens <star@gmx.li> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2017-03-01net: macb: Fix ETH not found when clock not supportWenyou Yang
For the boards such as smartweb on which the clock driver isn't supported, the ethernet fail to be found when booting up with the below log. ---8<--- Net: No ethernet found. --->8--- Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-03-01armv8: spl: Call spl_relocate_stack_gd for ARMv8Philipp Tomsich
As part of the startup process for boards using the SPL, we need to call spl_relocate_stack_gd. This is needed to set up malloc with its DRAM buffer. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-01armv5te: make 'ret lr' produce iinterworking 'bx lr'Albert ARIBAUD
Current ARM assembler helper for the 'return to caller' pseudo-instruction turns 'ret lr' into 'mov pc, lr' for ARMv5TE. This causes the core to remain in its current ARM state even when the routine doing the 'ret' was called from Thumb-1 state, triggering an undefined instruction exception. This causes early run-time failures in all boards compiled using the Thumb-1 instruction set (for instance the Open-RD family). ARMv5TE supports 'bx lr' which properly implements interworking and thus correctly returns to Thumb-1 state from ARM state. This change makes 'ret lr' turn into 'bx lr' for ARMv5TE. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2017-02-27Prepare v2017-rc3Tom Rini
2017-02-27arm: mach-omap2: Flush cache after FIT post-processing imageAndrew F. Davis
After we authenticate/decrypt an image we need to flush the caches as they may still contain bits of the encrypted image. This will cause failures if we attempt to jump to this image. Reported-by: Yogesh Siraswar<yogeshs@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-02-27drivers/net/Kconfig: Correct use of apostropheTom Rini
2017-02-27Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-02-27rockchip: video: fix 83500000 clock mistake in rockchip HDMINickey Yang Nickey Yang
There is one "0" too many in 83500000 mpixelclock in rockchip_mpll_cfg[]. fix it. Signed-off-by: Nickey Yang <nickey.yang@rock-chips.com>
2017-02-27splash: Prevent splash_load_fs from writing to 0x0Jonathan Golder
Passing NULL to fs_read() for actread value results in hanging U-Boot at least on our ARM plattform (TI AM335x). Since fs_read() and following functions do not catch nullpointers, writing to 0x0 occurs. Passing a local dummy var instead of NULL solves this issue. Signed-off-by: Jonathan Golder <jonathan.golder@kurz-elektronik.de> Cc: Anatolij Gustschin <agust@denx.de>
2017-02-26travis-ci: Temporarily disable using a newer device tree compilerTom Rini
For a long while dtc has warned about various constructs. This is now leading to log file size being exceeded in travis, and as the majority of these errors need to be fixed in the kernel, switch to using the stock device-tree-compiler package. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-26Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2017-02-26usb: gadget: f_dfu: set serial number if serial# is validFelipe Balbi
With this patch, USB Command Verifier is happy with our DFU implementation on Chapter 9 tests. Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
2017-02-26usb: gadget: g_dnl: fix g_dnl_set_serialnumber()Felipe Balbi
instead of only copying if strlen(s) is less than 32 characters, let's just copy at most 31 characters regardless of the size of serial#. This will guarantee that we always have a serial number if serial# environment variable is set to anything. Note that without a proper serial number, USB Command Verifier fails our test of Device Descriptor since we will claim to have a serial number without really providing one when requested. Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
2017-02-26usb: gadget: f_dfu: write req->actual bytesFelipe Balbi
If last packet is short, we shouldn't write req->length bytes to non-volatile media, we should write only what's available to us, which is held in req->actual. Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-02-26usb: gadget: dfu: add result for handle_getstatus()Patrick Delaunay
harmonize result with other handle_XXX() functions: return int for size remove the define RET_STAT_LEN : no more necessary Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2017-02-26usb: gadget: dfu: correct size for USB_REQ_DFU_GETSTATE resultPatrick Delaunay
return the correct size for DFU_GETSTATE result (1 byte in DFU 1.1 spec) to avoid issue in USB protocol and the variable "value" is propagated to req->lenght as all the in the other request with answer - DFU_GETSTATUS - DFU_DNLOAD - DFU_UPLOAD Then the buffer is correctly treated in USB driver NB: it was the only request witch directly change "req->actual" Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2017-02-26usb: gadget: dfu: add functional descriptor in descriptor setPatrick Delaunay
The "DFU descriptor set" must contain the "DFU functional descriptor" but it is missing today in U-Boot code (cf: DFU spec 1.1, chapter 4.2 DFU Mode Descriptor Set) This patch only allocate buffer and copy DFU functional descriptor after interfaces. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2017-02-26usb: dwc3: gadget: Remove unused header inclusionVincent Tinelli
Remove sys_proto.h inclusion which is not used by the driver. Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-02-23Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
- Fix regressions caused by the previous reworks - Add pin configuration support - Re-work SPL code - Update DRAM and PLL setup code - Enable needed configs, disable unneeded configs
2017-02-23ARM: uniphier: set up charge pump current for MPLL of LD11 SoCMasahiro Yamada
2017-02-23ARM: uniphier: add simple eMMC load APIs instead of ROM APIMasahiro Yamada
Re-use of routines embedded in the Boot ROM requires a function pointer table for each SoC. This is not nice in terms of the maintainability in a long run. Implement simple eMMC load APIs that are commonly used for LD11, LD20, and hopefully future SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: enable CONFIG_CMD_CONFIGMasahiro Yamada
This command is useful to see which config options are enabled on the running U-Boot image. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: enable CONFIG_CMD_GPTMasahiro Yamada
Enable CONFIG_CMD_GPT, keeping CONFIG_SPL_EFI_PARTITION because the SPL for UniPhier platform does not recognize any partitions. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: disable CONFIG_SPL_DOS_PARTITIONMasahiro Yamada
The SPL for UniPhier platform does not recognize any partitions. Do not compile unneeded features. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: deassert RST_n of eMMC device for LD11/LD20Masahiro Yamada
For LD11 and LD20 SoCs, the RST_n pin is asserted by default. If the EXT_CSD[162], bit[1:0] (RST_n_ENABLE) is fused, the eMMC device would stay in the reset state until its RST_n pin is deasserted by software. Currently, this is cared by an ad-hoc way because the eMMC hardware reset provider is not supported in U-Boot for now. This code should be re-written once the "mmc-pwrseq-emmc" binding is supported. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: add DRAM PHY clock duty adjustment for LD20 SoCKotaro Hayashi
If the DRAM clock duty does not meet the allowable tolerance, it is marked in an efuse register. If the register is fused, the boot code should compensate for the DRAM clock duty error. Signed-off-by: Kotaro Hayashi <hayashi.kotaro@socionext.com> [masahiro: simplify code, add git-log] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: remove dram_nr_ch from board parametersMasahiro Yamada
This parameter is redundant because we can know the number of channels by checking if dram_ch[2].size is zero. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: rework spl_boot_device() and related codeMasahiro Yamada
The current implementation has ugly switch statements here and there, and duplicates similar code. Rework it using table lookups for SoC data and reduce code duplication. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: move spl_boot_mode() to a separate fileMasahiro Yamada
The spl_boot_mode() is unrelated to the other code in this file. Besides, this function is only called from common/spl/spl_mmc.c, so it is reasonable to guard with CONFIG_SPL_MMC_SUPPORT. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: move MMC code to a separate fileMasahiro Yamada
Currently, arch/arm/mach-uniphier/boot-mode/boot-mode.c is messed up with unrelated code; there is no reason why the "mmcsetn" command must be placed in this file. Split out the MMC code into arch/arm/mach-uniphier/mmc-first-dev.c. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: disable CONFIG_MTD_NOR_FLASHMasahiro Yamada
This feature is seldom used these days on UniPhier boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: dts: uniphier: drop u-boot, dm-pre-reloc from system-bus pinctrl nodeMasahiro Yamada
Since commit 26b09c022ab6 ("ARM: uniphier: move SBC and Support Card init code to U-Boot proper"), SPL does not need pin-mux settings for the System Bus. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: rename second stage loader nameMasahiro Yamada
For the memory footprint reason, the Boot ROM can not load the ARM Trusted Firmware BL1 directly when Trusted Board Boot is enabled. The second stage loader is Socionext's own firmware, so rename it for clarification. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23pinctrl: uniphier: support pin configurationMasahiro Yamada
Support the following DT properties: "bias-disable" "bias-pull-up" "bias-pull-down" "bias-pull-pin-default" "input-enable" "input-disable" My main motivation is to support pull up/down biasing. For Pro5 and later SoCs, the pupdctrl register number is the same as the pinmux number, so this feature can be supported without having big pin tables. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: enable generic EHCI driver for uniphier_v8_defconfigMasahiro Yamada
The LD11 SoC is equipped with USB EHCI controllers. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: remove DRAM base address from board parametersMasahiro Yamada
The base address of each DRAM channel can be calculated from other parameters, so does not need hard-coding. What we need is the size of each DRAM channel and DRAM_SPARSE flag to decide the start address of DRAM channel 1. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: update README.uniphier for latest build instructionMasahiro Yamada
Since commit c0efc3140e75 ("ARM: uniphier: change CONFIG_SPL_PAD_TO to 128KB"), the u-boot.bin should be burned at the offset 0x20000. I missed to update README.uniphier in that commit. Now updating. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: print Support Card info very lateMasahiro Yamada
Since commit 26b09c022ab6 ("ARM: uniphier: move SBC and Support Card init code to U-Boot proper"), the System Bus is initialized by board_init(). The show_board_info() is called from board_init_f() by default, so the revision register of the Micro Support Card may not be accessed at this point. Show its revision after the System Bus is initialized. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: skip memreserve of unused DRAM bank of LD20Masahiro Yamada
Now the "for" loop here iterates on the detected memory banks. It must skip unused DRAM banks. Fixes: c995f3a3c526 ("ARM: uniphier: use gd->bd->bi_dram for memory reserve on LD20 SoC") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: correct spelling of "invalid"Masahiro Yamada
2017-02-23ARM: uniphier: skip MEMCONF ch2 parsing if CH2_DISABLE bit is setMasahiro Yamada
If SG_MEMCONF_CH2_DISABLE bit is set, the DRAM channel 2 is unused. The register settings for the ch2 should be ignored. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: revive accidentally removed dcache_disable()Masahiro Yamada
Commit a8e6300d483d ("ARM: uniphier: refactor spl_init_board()") accidentally dropped dcache_disable() call. Since then, the SPL of LD11 and LD20 failed to load U-Boot proper. Fixes: a8e6300d483d ("ARM: uniphier: refactor spl_init_board()") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
