Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Changed the wording to properly describe the shadowing
of the environment from ROM to RAM
Signed-off-by: Bruce Adler <bruce.adler@acm.org>
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Signed-off-by: Vlad Lungu <vlad@comsys.ro>
The scan code of the key 'z' is 0x1d, which should be handled.
The change has be tested on NOVATEK USB keyboard and ULI PCI OHCI
controller.
Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
The configuration file has already enabled USB, but it
missed definition of CFG_OHCI_SWAP_REG_ACCESS, the USB
on MPC8641HPCN can not work because of the wrong USB
register endian.
And add the USB command to U-Boot commands list.
usb_cpu_init() configures GPS USB pins, clocks, etc. and
is required for proper operation of kernel USB subsystem.
This setup was previously done in the kernel by the fixup
code which is being removed, thus low level init must be
done by U-boot now.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
An obvious typo. Originally fixed in linkstation u-boot port.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Since December 2003 the timer_interrupt_cpu() function in
cpu/mpc824x/interrupts.c contains what seems to be a superfluous
parameter. Remove it.
Add ft_cpu_setup(..)-function to adapt it for use with libfdt
based on code from mpc5xxx
Sigend-off-by: Sergej Stepanov <Sergej.Stepanov@ids.de>
To get the IDS8247 board working following are done:
- FCC2 is deactivated
- FCC1 is activated
- I2C is activated
- CFI driver is activated
- Adapted for use with LIBFDT
Signed-off-by: Sergej Stepanov <Sergej.Stepanov@ids.de>
Wolfgang is right: It's not a good idea to set up default initial
ethernet addresses for a board, even though they belong to the local
range.
This will change the failure mode from "IT manager screams at you for
using duplicate ethernet addresses" to a nice error message explaining
that the ethernet address hasn't been set properly.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
This is a multi-part message in MIME format.
commit e6e505eae94ed721e123e177489291fc4544b7b8
Author: Justin Flammia <jflammia@savantav.com>
Date: Mon Oct 29 17:19:03 2007 -0400
Found a bug in the way the DHCP Request packet is built, where the IP address
that is offered by the server is bound to prematurely. This patch is a fix of
that bug where the IP address offered by the DHCP server is not used until
after the DHCP ACK from the server is received.
Signed-off-by: Justin Flammia <jflammia@savantav.com>
Signed-off-by: Ben Warren <bwarren@qstreams.com>
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
With this patch PSC3 is configured as UART. This is done, because if
the pins of PSC3 are not configured at all (-> all pins are GPI),
due to crosstalk, spurious characters may be send over the RX232_2_TXD
signal line.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
grafic controller
Some commands for the STK52xx base board try to access the SM501 grafic
controller. But the TQM5200S has no grafic controller (only the TQM5200
and the TQM5200B have). This patch deactivates the commands accessing
the SM501 for the TQM5200S.
signal line.
grafic controller
Patch 16e23c3f removed PCSRBAR allocation. But passing zero windows
to pciauto_setup_device has the side effect of not getting
COMMAND_MEMORY set.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
The pxa255_idp being an old unmaintained board showed several issues:
1. CONFIG_INIT_CRITICAL was still defined.
2. Neither CONFIG_MAC_PARTITION nor CONFIG_DOS_PARTITION was defined.
3. Symbol flash_addr was undeclared.
4. The boards lowlevel_init function was still called memsetup.
5. The TEXT_BASE was still 0xa3000000 rather than 0xa3080000.
6. Using -march=armv5 instead of -march=armv5te resulted in lots of
'target CPU does not support interworking' warnings on recent compilers.
7. The PXA's serial driver redefined FFUART, BTUART and STUART used as
indexes rather than the register definitions from the pxa-regs header
file. Renamed them to FFUART_INDEX, BTUART_INDEX and STUART_INDEX to
avoid any ambiguities.
8. There were several redefinition warnings concerning ICMR, OSMR3,
OSCR, OWER, OIER, RCSR and CCCR in the PXA's assembly start file.
9. The board configuration file was rather outdated.
10. The part header file defined the vendor, product and revision arrays
as unsigned chars instead of just chars in the block_dev_desc_t
structure.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Fix MPC8266 command line definition so it won't break when new commands
are added to u-boot.
Signed-off-by Rune Torgersen <runet@innovsys.com>
New board has faster oscillator and a different Flash chip. This affects:
- CFG_MPC5XXX_CLKIN
- SDRAM timings
- Flash CS configuration (timings)
- Flash sector size, and thus MTD partition layout
- malloc() arena size (due to bigger Flash sectors)
- smaller memory test range (due to bigger malloc() arena)
This patch also enables more extensive memory testing via "mtest".
Per AN3221 (MPC5200B SDRAM Initialization and Configuration), the SDelay
register must be written a value of 0x00000004 as the first step of the
SDRAM contorller configuration.
PHYSADDR is for physical address, KSEG1ADDR is for uncached.
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
