2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-25mpc5121ads: fix breakage introduced when reordering elpida_mddrc_config[]Wolfgang Denk
2009-09-25mucmc52, uc101: delete ata@3a00 node, if no CF card is detectedHeiko Schocher
U-Boot can detect if an IDE device is present or not. If not, and this new config option is activated, U-Boot removes the ATA node from the DTS before booting Linux, so the Linux IDE driver does not probe the device and crash. This is needed for buggy hardware (uc101) where no pull down resistor is connected to the signal IDE5V_DD7. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-09-25mpc5200, mucmc52, uc101: config cleanupHeiko Schocher
- As these boards are similiar, collect common config options in manroland/common.h and manroland/mpc52xx-common.h for mpc5200 specific common options for this manufacturer. - add OF support - update default environment Signed-off-by: Heiko Schocher <hs@denx.de> Minor edit of commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-25Fix "ppc/85xx: Clean up use of LAWAR defines" breakageWolfgang Denk
Commit 002741ae86 modified include/asm-ppc/mmu.h such that the LAWAR_ defines were only enabled for the 83xx platform, but they are also needed on MPC512x system. Enabling these for E300 systems seems thus more appropriate. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-25Add Elpida Memory Configuration to mpc5121ads BoardsMartha M Stan
Signed-off-by: Martha M Stan <mmarx@silicontkx.com> Minor coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-25mpc512x: Streamlined fixed_sdram() init sequence.Martha M Stan
Signed-off-by: Martha M Stan <mmarx@silicontkx.com> Minor cleanup: Re-ordered default_mddrc_config[] to have matching indices. This allows to use the same index "N" for source and target fields; before, we had code like this out_be32(&im->mddrc.ddr_time_config2, mddrc_config[3]); which always looked like a copy & paste error because 2 != 3. Also, use NULL when meaning a null pointer. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-24Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2009-09-24ppc/p4080: Determine various chip frequencies on CoreNet platformsKumar Gala
The means to determine the core, bus, and DDR frequencies are completely new on CoreNet style platforms. Additionally on p4080 we can have different frequencies for FMAN and PME IP blocks. We need to keep track of the FMAN & PME frequencies since they are used for time stamping capabilities inside each block. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/p4080: Handle timebase enabling and frequency reportingKumar Gala
On CoreNet style platforms the timebase frequency is the bus frequency defined by 16 (on PQ3 it is divide by 8). Also on the CoreNet platforms the core not longer controls the enabling of the timebase. We now need to enable the boot core's timebase via CCSR register writes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/p4080: Add various p4080 related defines (and p4040)Kumar Gala
There are various locations that we have chip specific info: * Makefile for which ddr code to build * Added p4080 & p4040 to cpu_type_list and SVR list * Added number of LAWs for p4080 * Set CONFIG_MAX_CPUS to 8 for p4080 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/p4080: CoreNet platfrom style secondary core releaseKumar Gala
The CoreNet platform style of bringing secondary cores out of reset is a bit different that the PQ3 style. Mostly the registers that we use to setup boot translation, enable time bases, and boot release the cores have moved around. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/p4080: CoreNet platfrom style CCSRBAR settingKumar Gala
On CoreNet based platforms the CCSRBAR address is split between an high & low register and we no longer shift the address. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-09-24ppc/p4080: Add support for CoreNet style platform LAWsKumar Gala
On CoreNet based platforms the LAW address is split between an high & low register and we no longer shift the address. Also, the target IDs on CoreNet platforms have been completely re-assigned. Additionally, added a new find_law() API to which LAW an address hits in. This is need for the CoreNet style boot release code since it will need to determine what the target ID should be set to for boot window translation. Finally, enamed LAWAR_EN to LAW_EN and moved to header so we can use it elsewhere. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/p4080: Add p4080 platform immap definitionsKumar Gala
The p4080 SoC has a significant amount of commonality with the 85xx/PQ3 platform. We reuse the 85xx immap and just add new definitions for local access and global utils. The global utils is now broken into global utils, clocking and run control/power management. The offsets from CCSR for a number of blocks have also changed. We introduce the CONFIG_FSL_CORENET define to distinquish the PQ3 style of platform from the new p4080 platform. We don't use QoirQ as there are products (like p2020) that are PQ3 based platforms but have the QoirQ name. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Fix enabling of L2 cacheKumar Gala
We need to flash invalidate the locks in addition to the cache before we enable. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-2485xx-fdt: Fixed l2-ctlr's compatible prop for QorIQVivek Mahajan
The code assumed names where just numbers and always prefixed 'mpc'. However newer QorIQ don't follow the mpc naming scheme. Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: add cpu init config file for boot from NANDMingkai Hu
When boot from NAND, the NAND flash must be connected to br/or0. Also init RAM(L2 SRAM or DDR SDRAM) for load the second image to it. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24immap_85xx: add porpllsr's plat ratio definitionMingkai Hu
2009-09-24ppc/85xx: add ld script file for boot from NANDMingkai Hu
The first stage 4K image uses a seperate ld script file to generate 4K image. This patch moves it to the cpu/mpc85xx/* to make it avaliable for 85xx platform. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24mpc8610hpcd: Use common 86xx fdt fixup codePeter Tyser
Using the common 86xx fdt fixups removes some board-specific code and should make the mpc8610hpcd easier to maintain in the long run. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc85x0: tidy up Makefile to use new configuration script.Paul Gortmaker
Commit 804d83a5 allows us to move all the configuration variation tweaks out of the top level Makefile and down into the boards config header. This takes advantage of that for the sbc8540/sbc8560 boards. There were a couple of cheezy comments pointing at incorrect files, or files that don't exist, so I've cleaned those up too. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: allow enabling PCI via a make config optionPaul Gortmaker
Prior to this commit, to enable PCI, you had to go manually edit the board config header, and if you had 33MHz PCI, you had to manually change CONFIG_SYS_NS16550_CLK too, which was not real user friendly, This adds the typical PCI and clock speed make targets to the toplevel Makefile in accordance with what is being done with other boards (i.e. using the "-t" to mkconfig). Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: update PCI/PCI-e support codePaul Gortmaker
The PCI/PCI-e support for the sbc8548 was based on an earlier version of what the MPC8548CDS board was using, and in its current state it won't even compile. This re-syncs it to match the latest codebase and makes use of the new shared PCI functions to reduce board duplication. It borrows from the MPC8568MDS, in that it pulls the PCI-e I/O back to 0xe280_0000 (where PCI2 would be on MPC8548CDS), and similarly it coalesces the PCI and PCI-e mem into one single TLB. Both PCI-x and PCI-e have been tested with intel e1000 cards under linux (with an accompanying dts change in place) Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24fsl_pci: create a SET_STD_PCI_INFO() helper wrapperPaul Gortmaker
Recycle the recently added PCI-e wrapper used to reduce board duplication of code by creating a similar version for plain PCI. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: correct local bus SDRAM size from 64M to 128MPaul Gortmaker
The size of the LB SDRAM on this board is 128MB, spanning CS3 and CS4. It was previously only being configured for 64MB on CS3, since that was what the original codebase of the MPC8548CDS had. In addition to setting up BR4/OR4, this also adds the TLB entry for the second half of the SDRAM. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: use I/O accessorsPaul Gortmaker
Sweep throught the board specific file and replace the various register proddings with the equivalent I/O accessors. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: remove eTSEC3/4 voltage hackPaul Gortmaker
With only eTSEC1 and 2 being brought out to RJ-45 connectors, we aren't interested in the eTSEC3/4 voltage hack on this board Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: enable access to second bank of flashPaul Gortmaker
The sbc8548 has a 64MB SODIMM flash module off of CS6 that previously wasn't enumerated by u-boot. There were already BR6/OR6 settings for it [used by cpu_init_f()] but there was no TLB entry and it wasn't in the list of flash banks reported to u-boot. The location of the 64MB flash is "pulled back" 8MB from a 64MB boundary, in order to allow address space for the 8MB boot flash that is at the end of 32 bit address space. This means creating two 4MB TLB entries for the 8MB chunk, and then expanding the original boot flash entry to 64MB in order to cover the 8MB boot flash and the remainder (56MB) of the user flash. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: cosmetic line re-wrapPaul Gortmaker
Fix the extra long lines to be consistent with u-boot coding style. No functional change here. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2009-09-24sbc8548: get_clock_freq is not valid for this boardPaul Gortmaker
The get_clock_freq() comes from freescale/common/cadmus.c and is only valid for the CDS based 85xx reference platforms. It would be nice if we could read the 33 vs. 66MHz status somehow, but in the meantime, tie it to CONFIG_SYS_CLK_FREQ like all the other non-CDS boards do. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: delete unused MPC8548CDS info carried over from portPaul Gortmaker
There are a couple defines and PCI bridge quirks related to the PCI backplane of the MPC8548CDS that have no meaning in the context of the port to the sbc8548 board, so delete them. Also, the form factor of the sbc8548 is a standalone board with a single PCI-X and a single PCI-e slot. That pretty much guarantees that it will never be a PCI agent itself, so the host/agent and root complex/end node distinctions have been removed. Similarly, since there is no physical connector mapping to PCI2, so all references of PCI2 in the board support files have been removed as well. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: enable use of PCI network cardsPaul Gortmaker
Create a board_eth_init to allow a place to hook in the PCI ethernet init after all the eTSEC are up and configured. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: 32bit DDR changes for P1020/P1011Poonam Aggrwal
The P1020/P1011 SOCs support max 32bit DDR width as opposed to P2020/P2010 where max DDR data width supported is 64bit. As a next step the DDR data width initialization would be made more dynamic with more flexibility from the board perspective and user choice. Going forward we would also remove the hardcodings for platforms with onboard memories and try to use the FSL SPD code for DDR initialization. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: replace README with completely new documentPaul Gortmaker
The previous README.sbc8548 was pretty much content-free. Replace it with something that actually gives the end user some relevant hardware details, and also lists the u-boot configuration choices. Also in the cosmetic department, fix the bogus line in the Makefile that was carried over from the SBC8560 Makefile, and the typo in the sbc8548.c copyright. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Clean up use of LAWAR definesKumar Gala
On 85xx platforms we shouldn't be using any LAWAR_* defines but using the LAW_* ones provided by fsl-law.h. Rename any such uses and limit the LAWAR_ to the 83xx platform as the only user so we will get compile errors in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Clean up mpc8572DS PCI setup codeKumar Gala
Use new fsl_pci_init_port() that reduces amount of duplicated code in the board ports, use IO accessors and clean up printing of status info. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Clean up p2020ds PCI setup codeKumar Gala
2009-09-24ppc/85xx: Clean up p1_p2_rdb PCI setupKumar Gala
General code cleanup to use in/out IO accessors as well as making the code that prints out info sane between board and generic fsl pci code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Simplify the top makefile for P1_P2_RDB boardsKumar Gala
2009-09-24ppc/85xx: Simplify the top makefile for 36-bit config for P2020DSKumar Gala
2009-09-24ppc/85xx: Simplify the top makefile for 36-bit config for MPC8572DSKumar Gala
2009-09-24ppc/85xx: simplify the top makefile for 36-bit config for mpc8536dsMingkai Hu
2009-09-24ppc/85xx: Fix LCRR_CLKDIV definesKumar Gala
For some reason the CLKDIV field varies between SoC in how it interprets the bit values. All 83xx and early (e500v1) PQ3 devices support: clk/2: CLKDIV = 2 clk/4: CLKDIV = 4 clk/8: CLKDIV = 8 Newer PQ3 (e500v2) and MPC86xx support: clk/4: CLKDIV = 2 clk/8: CLKDIV = 4 clk/16: CLKDIV = 8 Ensure that the MPC86xx and MPC85xx still get the same behavior and make the defines reflect their logical view (not the value of the field). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-24MAKEALL: Use POSIX mathPeter Tyser
2009-09-24MAKEALL: Add summary informationPeter Tyser
This change adds some basic summary information to the MAKEALL script. The summary information includes how many boards were compiled, how many boards had compile warnings or errors, and which specific boards had compile warnings or errors. This information is useful when doing compile testing to quickly determine which boards are broken. As a side benefit, no empty $BOARD.ERR files are generated by MAKEALL. Previously, each board had a corresponding $BOARD.ERR file, even if the board compiled cleanly. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-24galaxy5200: enable version environment variableEric Millbrandt
Add version environment variable configuration to the galaxy5200 board header file. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-24digsy_mtc: Add TCR register value for RTC (DS1339)Werner Pfister
Signed-off-by: Werner Pfister <werner.pfister@intercontrol.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-09-24rtc/ds1337.c: Allow to set TCR registerWerner Pfister
This is needed to correctly start the charging of an attached capacitor or battery. Signed-off-by: Werner Pfister <werner.pfister@intercontrol.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
