2005-12-16 | Merge with /home/sr/git/u-bootv1.1.4U-Boot-1_1_4 | Wolfgang Denk | |
2005-12-16 | MPC5200: Set PCI retry counter to 0 = infinite retry; | Wolfgang Denk | |
The default of 255 is too short for slow devices. Patch by Martin Nykodym, 12 Dec 2005 | |||
2005-12-15 | Changes to Yellowstone & Yosemite 440EP/GR eval boards: | Stefan Roese | |
- Changed GPIO setup to enable another address line in order to address 64M of FLASH. - Added function sdram_tr1_set to auto calculate the tr1 value for the DDR. Patch by Steven Blakeslee, 12 Dec 2005 | |||
2005-12-14 | Merge with /home/m8/git/u-boot | Wolfgang Denk | |
2005-12-12 | (no commit message) | Wolfgang Denk | |
2005-12-06 | Change port configuration for O2DNT (CODEC1 on PSC1) | Marian Balakowicz | |
2005-12-06 | Fix DPRAM offset/size for MPC8541/8555. | Wolfgang Denk | |
Simplify TQM85xx Makefile handling. | |||
2005-12-04 | Fix data overflow (typo?) in rtc/ds1302.c | Wolfgang Denk | |
2005-12-04 | Code cleanup, especially MIPS for GCC 4.x | Wolfgang Denk | |
2005-12-01 | Fix U-Boot compilation for MIPS boards using ELDK 4.0 | Wolfgang Denk | |
2005-12-01 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-12-01 | Adjust TQM834x PHY addresses for latest hardware revision. | Wolfgang Denk | |
2005-12-01 | Increase malloc arena on TQM5200 board to 256 kB. | Wolfgang Denk | |
With 64 kb uniform flash sector size the old value of 128 kB was too small. | |||
2005-11-30 | Fix miiphy global data initialization (problem on 4xx boards when no | Marian Balakowicz | |
ethaddr is assigned). Initialization moved from miiphy_register() to eth_initialize(). Based on initial patch for 4xx platform by Matthias Fuchs. | |||
2005-11-30 | Add support for TQM8541/8555 boards, TQM85xx support reworked: | Stefan Roese | |
- Support for TQM8541/8555 boards added. - Complete rework of TQM8540/8560 support. - Common TQM85xx code now supports all current TQM85xx platforms (TQM8540/8541/8555/8560). - DDR SDRAM size detection added. - CAS latency default values can be overwritten by setting "serial#" to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used. If problems are detected with this non default CAS latency, the defualt values will be used instead. - FLASH size detection added. - Moved FCC ethernet driver initialization behind TSEC driver init -> TSEC is first device. Patch by Stefan Roese, 30 Nov 2005 | |||
2005-11-29 | Compile warning fixed | Stefan Roese | |
Patch by Stefan Roese, 29 Nov 2005 | |||
2005-11-29 | Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board. | Stefan Roese | |
Patch by John Otken, 23 Nov 2005 | |||
2005-11-29 | Minor AMCC 4xx board cleanups | Stefan Roese | |
Patch by Stefan Roese, 27 Nov 2005 | |||
2005-11-27 | Increase IPB and PCI clocks for O2DNT board. | Marian Balakowicz | |
2005-11-27 | Changed PPC44x startup message (cpu info, speed...) to common style: | Stefan Roese | |
On PPC44x platforms, the startup message generated in "cpu.c" only comprised the ppc type and revision but not additional informations like speed etc. Those speed infos where printed in the board specific code. This new implementation now prints all CPU infos in the common cpu specific code. No board specific code is needed anymore and therefore removed from all current 44x implementations. Patch by Stefan Roese, 27 Nov 2005 | |||
2005-11-25 | Remove unnnecessary #include <linux/types.h> from include/asm-*/u-boot.h | Wolfgang Denk | |
2005-11-25 | Allow use of include/image.h and include/asm-*/u-boot.h in proprietary code. | Wolfgang Denk | |
The COPYING file was extended to make clear that these files can be used in non-GPL code, too. | |||
2005-11-22 | Add support for Prodrive P3P440 board: | Stefan Roese | |
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c - CFG_FLASH_QUIET_TEST added to use the common CFI driver for bank autodetection Patch by Stefan Roese, 22 Nov 2005 | |||
2005-11-20 | Change all '$(...)' variable references into '${...}' | Wolfgang Denk | |
which makes the environment compatible with the hush shell. WARNING: Support for the old '$(...)' syntax will be discontinued in a later version. | |||
2005-11-17 | Minor changes to init flags in TQM834x PCI. | Rafal Jaworowski | |
2005-11-15 | Add CHANGELOG entry | Stefan Roese | |
Patch by Stefan Roese, 15 Nov 2005 | |||
2005-11-15 | Merge with /server/home/stefan/git/u-boot/bamboo-sdram | Stefan Roese | |
2005-11-15 | Fix Bamboo DDR SDRAM initialization (problem with onboard SDRAM) | Stefan Roese | |
2005-11-15 | New PPC 405EP board added: CMS700 | Stefan Roese | |
Added CONFIG_NET_MULTI for VOM405 board. Added reset_phy() for VOM405 board. Patch by Matthias Fuchs, 09 Nov 2005 | |||
2005-11-10 | Add explanation for CDP checksum algorithm | Wolfgang Denk | |
2005-11-08 | Updated PCI mapping for esd CPCI2DP board. | Stefan Roese | |
Add support for error LED. Patch by Matthias Fuchs, 07 Nov 2005 | |||
2005-11-07 | Fix MPC85xx PCI support (pci_register_hose() before pci config access) | Stefan Roese | |
Patch by Stefan Roese, 07 Nov 2005 | |||
2005-11-07 | Correct PPC Timebase register definitions (SPRN_TBRL...) | Stefan Roese | |
2005-11-05 | Adjust bd->bi_flashstart on Yellowstone & Yosemite to correct size | Stefan Roese | |
Patch by Stefan Roese, 05 Nov 2005 | |||
2005-11-03 | Adjust TQM85x PHY addresses for latest hardware revision. | Wolfgang Denk | |
2005-11-03 | Additional fix for external IRQ config on Yellowstone & Yosemite | Stefan Roese | |
Patch by Stefan Roese, 03 Nov 2005 | |||
2005-11-01 | Add support for Ocotea pass 3 with 440GX Rev. F | Stefan Roese | |
Patch by Stefan Roese, 01 Nov 2005 | |||
2005-11-01 | Merge with /git/u-boot.git | Stefan Roese | |
2005-10-29 | More verbose CHANGELOG entry.DENX-2005-10-29-2350 | Wolfgang Denk | |
2005-10-29 | Merge with /home/m8/git/u-boot | Wolfgang Denk | |
2005-10-29 | Add missing CHANGELOG entries. | Marian Balakowicz | |
2005-10-28 | Add support for multiple PHYs. | Marian Balakowicz | |
2005-10-28 | Correct includes for flat tree builder. | Marian Balakowicz | |
2005-10-28 | Fix conflicting types (flash_write()) in trab auto_update.c | Marian Balakowicz | |
2005-10-28 | Fix external IRQ configuration on Yellowstone & Yosemite | Stefan Roese | |
The multiplexed signals Ext IRQ0...3 have to be configured as IRQ, because they default to GPIOx (440EP/GR). Patch by Stefan Roese, 28 Oct 2005 | |||
2005-10-21 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2005-10-20 | Add missing 4xx board to MAKEALL | Stefan Roese | |
Patch by Stefan Roese, 20 Oct 2005 | |||
2005-10-20 | Fix conflicting types (flash_write()) in esd auto_update.c | Stefan Roese | |
2005-10-20 | Fix problem with sleep in NetConsole (use get_timer()) | Stefan Roese | |
2005-10-20 | Add NetConsole Support for AMCC eval boards | Stefan Roese | |
