We use CONFIG_OF_LIBFDT and CONFIG_OF_BOARD_SETUP on all our powerpc
targets, so there is no need to check these defines within our C code.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
We use the same settings for open firmware defines on all our powerpc
targets, so move them from the CPU specific headers to the common
powerpc header.
128kByte and 3,986MB may be in the future too little for kernel the fdt
blob respectively the kernel image. So increase the reserved areas here,
we have the space for this.
On mgcoge3ne we also want to start the test application if the testpin
is asserted. But we don't have a full POST test support yet. So simply
add a function to read the testpin value.
The get_pin and set_pin funciton was only used for pins on Port D and
therefore the value was hard coded in the function. Enhance this with a
parameter, that we are able to use this functions for other ports too.
This board is similar to TUXX1, but it has differend FPGAs.
Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com>
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
develop mode
Search for the kernel and DTBs in a folder named PRODUCTNAME (found in the IVM)
at the TFTP server instead of the u-boot boardname.
Signed-off-by: Tobias Müller <Tobias.Mueller@keymile.com>
When loading the dtb file via tftp we should load the one which matches
boardId and hwKey and not a common one for the boardname. We have boards
were different hwKeys are used and then we may load an incorrect dtb
file. If no fdt_bid_kwkey.dtb file is not a fallback to boardname.dtb is used.
If a DTB is found with cramfsls, the bootscript continues as expected.
If none is found, the cramfsloadfdt and boot subbootcmds are updated to
not load the DTB from cramfs and not pass it to the kernel. The kernel
thus must have an appended DTB otherwise the boot will fail.
This is required for the km_kirkwood boards that must support .esw where
the DTB sometimes is appended (for backwards compatibility) and sometimes
is passed correctly (as we do now for all newer boards).
To prevent u-boot to stop accidently e.g. due to line noise on the
serial line, we now use the option CONFIG_AUTOBOOT_KEYED. We choose the
<SPACE> key for this.
There was a small typo for KM_COGE5UN that resulted in the dip switch
not to behave as expected.
Similar to kmcoge5un we need to check the dip switch at startup
connected to the kirkwood at MPP43. If it's set we need to set the
actual_bank to zero to boot from SW bank zero. Additional to kmcoge5un
we need to check also the pin in misc_init to decide wether we wait for
the ne to start or not. If the dip_switch is set we don't wait and
continue immediately.
Configure PHY LED register for Marvell 88E1118R PHY used on PIGGY3 to
match with printed descriptions on PCB
[trini: Fix typo, CRTL_PAGE -> CTRL_PAGE]
KM_ENV_BUS was used for nothing else than an direct assignment to
CONFIG_I2C_ENV_EEPROM_BUS. To avoid this, directly use
CONFIG_I2C_ENV_EEPROM_BUS instead.
Patchwork: http://patchwork.ozlabs.org/patch/399411/
SeeedStudio BeagleBone Green (BBG) is clone of the BeagleBone Black (BBB) minus
the HDMI port and addition of two Grove connectors (i2c2 and usart2).
This board can be identified by the 1A value after A335BNLT (BBB) in the at24 eeprom:
1A: [aa 55 33 ee 41 33 33 35 42 4e 4c 54 1a 00 00 00 |.U3.A335BNLT....|]
http://beagleboard.org/green
http://www.seeedstudio.com/wiki/Beaglebone_green
In Mainline Kernel as of:
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=79a4e64c679d8a0b1037da174e4aea578c80c4e6
Patch tested on BeagleBone Black (rev C) and BeagleBone Green (production model)
Signed-off-by: Robert Nelson <robertcnelson@gmail.com>
CC: Tom Rini <trini@konsulko.com>
CC: Jason Kridner <jkridner@gmail.com>
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
This updates git-mailrc to add me as a maintainer of x86.
CM-T3517 has several HW revisions.
Add board specific get_board_rev() callback to retrieve revision number.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
Reviewed-by: Igor Grinberg <grinberg@compulab.co.il>
Currently the mmc device that SPL looks at is always mmc0, regardless
of the BOOT_DEVICE_MMCx value. This forces some boards to
implement hacks in order to boot from other mmc devices.
Make SPL take into account the correct mmc device.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Use spl alternate boot device feature to define fallback to
the main boot device as it is defined by hardware.
Cc: Igor Grinberg <grinberg@compulab.co.il>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Now that we support alternative boot devices, it can sometimes be
unclear which boot devices was actually used. Provide a function to
announce which boot devices are attempted during boot.
Introduce spl_boot_list array, which defines a list of boot devices
that SPL will try before hanging. By default this list will consist
of only spl_boot_device(), but board_boot_order() can be overridden
by board code to populate the array with custom values.
Refactor spl image load code out of board_init_r and into its own
function. This is a preparation for supporting alternative boot
devices.
Make spl_*_load_image() functions return a value instead of
hanging if a problem is encountered. This enables main spl code
to make the decision whether to hang or not, thus preparing
it to support alternative boot devices.
Some boot devices (namely nand and spi) do not hang on error.
Instead, they return normally and SPL proceeds to boot the
contents of the load address. This is considered a bug and
is rectified by hanging on error for these devices as well.
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Hans De Goede <hdegoede@redhat.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Jagan Teki <jteki@openedev.com>
Get rid of emmc boot code duplication in spl_mmc_load_image() using a switch
case fallthrough into MMCSD_MODE_RAW. Since the #ifdef CONFIG_SUPPORT_EMMC_BOOT
check is not really necessary, remove it in the process.
No functional changes.
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Move the code that handles fs boot out of spl_mmc_load_image() and into its
own function to reduce the #ifdef complexity of spl_mmc_load_image().
Implement defaults for the raw partition image loading so that the #ifdef
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION in spl_mmc_load_image() will no
longer be necessary.
This change makes it possible for mmc_load_image_raw_partition() and
mmc_load_image_raw_sector() to coexist.
Implement default versions of falcon mode functions to make the
CONFIG_SPL_OS_BOOT check in spl_mmc_load_image() unnecessary, thus reducing
its #ifdef complexity.
Cc: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Suriyan Ramasami <suriyan.r@gmail.com>
Simplify spl_mmc_load_image() code by moving the part that finds the mmc device
into its own function spl_mmc_find_device(), available in two flavors: DM and
non-DM.
This refactor fixes a bug in which an error in the device location sequence
does not necessarily aborts the rest of the code. With this refactor, we fail
the moment there is an error.
The original intention of the mmc load_image() function was to try multiple
boot modes before failing. This is evident by the lack of break statements
in the switch, and the following line in the default case:
puts("spl: mmc: no boot mode left to try\n");
This implementation is problematic because:
- The availability of alternative boot modes is very arbitrary since it
depends on the specific order of the switch cases. If your boot mode happens to
be the first case, then you'll have a bunch of other boot modes as alternatives.
If it happens to be the last case, then you have none.
- Opting in/out is tied to config options, so the only way for you to prevent an
alternative boot mode from being attempted is to give up on the feature completely.
- This implementation makes the code more complicated and difficult to
understand.
Address these issues by inserting a break statements between the cases to make the
function try only one boot mode.
Remove code duplication in spl_nand_load_image().
Cc: Scott Wood <scottwood@freescale.com>
Acked-by: Scott Wood <scottwood@freescale.com>
[trini: Add back cast to unsigned long of spl_image.load_addr]
Sometimes it can be useful to link the fw_ tools instead
of having the fw_setenv/fw_printenv installed.
Patch exports the tool as library and allowes to link it
with own programs.
BeagleBoard X15 (http://beagleboard.org/x15) support in u-boot does
actually support two different platform configuration offered by
TI. In addition to BeagleBoard X15, it also supports the TMDXEVM5728
(or more commonly known as AM5728-evm).
Information about the TI AM57xx EVM can be found here
http://www.ti.com/tool/tmdxevm5728
The EVM configuration is 1-1 compatible with BeagleBoard X15 with the
additional support for mPCIe, mSATA, LCD, touchscreen, Camera, push
button and TI's wlink8 offering.
Hence, we rename the beagle_x15 directory to am57xx to support TI
EVMs that use the AM57xx processor. By doing this we have common code
reuse. This sets the stage to have a common u-boot image solution for
multiple TI EVMs such as that already done for am335x and am437x. This
sets the stage for upcoming multiple TI EVMs that share the same code
base.
NOTE: Commit eae7ae185335 ("am437x: Add am57xx_evm_defconfig using
CONFIG_DM") introduced DT support for beagle_x15 under am57xx_evm
platform name. However, this ignored the potential confusion arising for
users as a result. To prevent this, existing beagle_x15_defconfig is
renamed as am57xx_evm_nodt_defconfig to denote that this is the "non
device tree" configuration for the same platform. We still retain
am57xx-beagle-x15.dts at this point, since we just require the common
minimum dts.
As a result of this change, users should expect changes in build
procedures('make am57xx_evm_nodt_defconfig' instead of 'make
beagle_x15_defconfig'). Hopefully, this would be a one-time change.
Signed-off-by: Steve Kipisz <s-kipisz2@ti.com>
Signed-off-by: Schuyler Patton <spatton@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
When for example generating/manipulating SD card/eMMC images which
contain U-Boot and its environment(s), it is handy to use a given
configuration file instead of the compiled-in default one.
And since the default configuration file is expected under /etc
it's hard for an usual linux user account without special permissions
to use fw_printenv/fw_setenv for this purpose.
So allow to pass an optional filename via a new '-c' command
line argument.
Example:
$ ln -s fw_printenv tools/env/fw_setenv
$ cat fw_env.config
test.img 0x20000 0x20000
test.img 0x40000 0x20000
$ tools/env/fw_printenv -c ./fw_env.config fdt_file
fdt_file=imx28-duckbill.dtb
$ tools/env/fw_setenv -c ./fw_env.config fdt_file imx28-duckbill-spi.dtb
fdt_file=imx28-duckbill-spi.dtb
Signed-off-by: Michael Heimpold <mhei@heimpold.de>
Zap ioremap(), as it is replaced by map_physmem(,,MAP_NOCACHE).
Change ioremap() to map_physmem(), as it is more used in u-boot.
These options were already defined in mv-common.h file.
Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
It is already defined in included mv-common.h file.
The CONFIG_CMD_ENV is enabled by default so we can safely remove it.
Avoid double typing in the shell and build u-boot.kwb when running "make" only.
