With the migration to python3 for all of our tests, we need to install
pyelftools via pip now rather than the system tools as they will
otherwise not be present in our virtualenv.
Changes in v2: Switch to pip
https://gitlab.denx.de/u-boot/custodians/u-boot-dm
binman support for FIT
new UCLASS_SOC
patman switch 'test' command
minor fdt fixes
patman usability improvements
- R8A774A1 / Beacon EmbeddedWorks RZG2M Dev Kit support
- Convert dc2114x driver to DM.
- Assorted environment fixes.
- Enhance environment in MMC and controlled via OF_CONTROL
- Allow for environment in FAT to use the same device we boot from
rather than be hard-coded.
With the change to absolute imports the concurrent tests feature
unfortunately broke. Fix it.
We cannot easy add a warning, since the output messes up tests which check
the output.
At present testPackX86RomMeNoDesc removes the contents of the
descriptor.bin file and testPackX86RomMeMissingDesc removes the file
completely.
If a test that relies on this file happens to run after it is removed, it
will not work. Since we have no control over the selecting of tests that
run in parallel and series, we must avoid changing the files.
Update this tests to use separate files instead.
Manage 2 copy at the end of the partition selected by config
"u-boot,mmc-env-partition" to save the U-Boot environment,
with CONFIG_ENV_SIZE and 2*CONFIG_ENV_SIZE offset.
This patch allows to support redundancy (CONFIG_ENV_OFFSET_REDUND).
The output of the function mmc_offset_try_partition must be a
byte offset in mmc and not a multiple of blksz.
This function is used in mmc_offset(), called by mmc_get_env_addr()
and the offset is used in write_env(), erase_env() and read_env().
In these function, blk_start = offset / mmc->read_bl_len
or /write_bl_len so this offset is not a multiple of blksz.
Use the weak function mmc_get_env_dev in mmc_offset_try_partition
function to allow dynamic selection of mmc device to use
and no more use directly the define CONFIG_SYS_MMC_ENV_DEV.
Add a pytest for testing the env info sub-command:
test_env_info: test command with several option that
can be executed on real hardware device without assumption
test_env_info_sandbox: test the result on sandbox
with a known ENV configuration: ready & default & persistent
The quiet option '-q' is used for support in shell test;
for example:
if env info -p -d -q; then env save; fi
Enable support for sub command 'env info' in sandbox
with CONFIG_CMD_NVEDIT_INFO. This is aimed primarily
at adding unit test.
Check the current ENV location, dynamically provided by the weak
function env_get_location to be sure that the environment can be
persistent.
The compilation flag ENV_IS_IN_DEVICE is not enough when the board
dynamically select the available storage location (according boot
device for example).
This patch solves issue for stm32mp1 platform, when the boot device
is USB.
The "env info" can be use for test with -d and -p parameter,
in scripting case the output of the command is not needed.
This patch allows to deactivate this output with a new option "-q".
For example, we can save the environment if default
environment is used and persistent storage is managed with:
Without the quiet option, I have the unnecessary traces
First boot:
Default environment is used
Environment can be persisted
Saving Environment to EXT4... File System is consistent
Next boot:
Environment was loaded from persistent storage
Add trace in env save to indicate any errors to end user and avoid
silent output when the command 'env save' is not executed.
Correct the overflow check of the bit-field env_has_init with
the max value of env_location= ENVL_COUNT and no more with the
size of env_locations.
This bit-field is indexed by this enumerate and not by the position in
the env_locations (only used in env_get_location) and the
2 values are different, depending of thea ctivated CONFIG_ENV_IS_ options.
I don't want to have to specify the device; only the partition.
This allows me to use the same image on internal eMMC or SD card for
Banana Pi R2, and it finds its own environment either way.
[trini: Add #if/#else/#endif logic around CONFIG_SYS_MMC_ENV_DEV usage,
whitespace changes]
When you enable CONFIG_OF_LIVE, you will end up with a lot of
conversions.
To generate this commit, I used coccinelle excluding drivers/core/,
include/dm/, and test/
The semantic patch that makes this change is as follows:
<smpl>
expression dev;
-devfdt_get_addr(dev)
+dev_read_addr(dev)
</smpl>
This cast is unneeded.
Use the _ptr suffixed variant instead of casting. Also, convert it to
dev_read_addr_ptr(), which is safe to CONFIG_OF_LIVE.
One curious part is an error check like follows in
drivers/watchdog/omap_wdt.c:
priv->regs = (struct wd_timer *)devfdt_get_addr(dev);
if (!priv->regs)
return -EINVAL;
devfdt_get_addr() returns FDT_ADDR_T_NONE (i.e. -1) on error.
So, this code does not catch any error in DT parsing.
dev_read_addr_ptr() returns NULL on error, so this error check
will work.
I generated this commit by the following command:
$ find . -name .git -prune -o -name '*.[ch]' -type f -print | \
xargs sed -i -e 's/([^*)]*\*)devfdt_get_addr(/dev_read_addr_ptr(/'
I manually fixed drivers/usb/host/ehci-mx6.c
Currently, fdt_fixup_mtdparts() only checks the compatible property.
It is pointless to fix up the disabled node.
Skip the node if it has the property:
status = "disabled"
Platform code can call fdt_fixup_mtdparts() in order to hand U-Boot's
MTD partitions over to the Linux device tree.
Currently, fdt_fixup_mtdparts() calls mtdparts_init() in its entry.
If no target MTD device is found, an error message like follows is
displayed:
Device nand0 not found!
This occurs when the same code (e.g. arch/arm/mach-uniphier/fdt-fixup.c)
is shared among several boards, but not all of them support an MTD device.
Parse the DT first, then call mtdparts_init() only when the target MTD
node is found.
Yet, you still need to call mtdparts_init() before device_find().
Running 'ut dm' on the sandbox without -D or -d results in segmentation
faults due to NULL pointer dereferences.
Check that device pointers are non-NULL before using them.
Use ut_assertnonnull() for pointers instead of ut_assert().
Tested-by: Philippe Reynes <philippe.reynes@softathome.com>
Make use of UCLASS_SOC to find device family and revision for
print_cpuinfo.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Enable CONFIG_SOC_DEVICE and CONFIG_SOC_DEVICE_TI_K3 so the TI K3 SoC
driver can be used for SoC detection.
Introduce a chipid node to provide a UCLASS_SOC driver to identify TI K3
SoCs.
SoCs.
Introduce an soc_ti_k3_driver that allows identification and selection
of SoC specific data based on the JTAG ID register for device
identification, as described for AM65x[0] and J721E[1] devices.
[0] http://www.ti.com/lit/ug/spruid7e/spruid7e.pdf
[1] http://www.ti.com/lit/ug/spruil1a/spruil1a.pdf
Add a sandbox SOC driver, and some tests for the SOC uclass.
Introduce UCLASS_SOC to be used for SOC identification and attribute
matching based on the SoC ID info. This allows drivers to be provided
for SoCs to retrieve SoC identifying information and also for matching
device attributes for selecting SoC specific data.
This is useful for other device drivers that may need different
parameters or quirks enabled depending on the specific device variant in
use.
Add a new documentation file for UCLASS_SOC and its usage to describe
the SoC Device ID framework that allows SoC identification and device
data matching.
This function is only called from fdt_fixup_mtdpart() in the same file.
The user can either count the number of patches, or provide a
tracking branch.
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Setting sendemail.suppresscc to all or cccmd leads to --cc-cmd
parameter being ignored, and emails going either nowhere, or
just to the To: line maintainer.
This reverts commit 3ebe09d09a407f93022d945a205c5318239eb3f6.
There is no user of this split function that's why remove it.
This reverts commit 118f4d4559a4386fa87a1e2509e84a1986b24a34.
The commit 361377dbdbc9 ("ARM: rmobile: Merge prior-stage firmware DT
fragment into U-Boot DT on Gen3") reverted changes introduced by commit
175f5027345c ("ARM: renesas: Configure DRAM size from ATF DT fragment")
that's why there is no reason to use functions with _fdt() suffix because
parameter is gd->fdt_blob as is already for functions without _fdt()
suffix.
The unsupported Commit-xxx option are silently skipped
and removed as 're_remove=Commit-\w*', this patch adds
warning message in this case to detect misspelled issue
for the 2 supported options:
Commit-notes:
Commit-changes:
For example: the final 's' is missing (Commit-note:)
NB: no issue for Series-xxx option as only the supported
options are accepted (see valid_series in series.py)
The function fdt_find_regions look in the exclude list for each
property, even if the name is NULL. It could happen if the fit
image is corrupted. On sandbox, it generates a segfault.
To avoid this issue, if the name of a property is NULL, we report
an error and avoid looking in the exclude list.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
Detect unexpected 'END' line when a section is not detected.
This patch detect issue when tag name for section start is misspelled,
for example 'Commit-note:' for 'Commit-notes:'
Commit-note:
END
Then 'Commit-note:' is removed silently by re_remove = "Commit-\w*:"
but 'END' is kept in commit message.
These functions should not modify the device. Convert them to const so
that callers don't need to cast if they have a const udevice *.
FIT (Flat Image Tree) is the main image format used by U-Boot. In some
cases scripts are used to create FITs within the U-Boot build system. This
is not ideal for various reasons:
- Each architecture has its own slightly different script
- There are no tests
- Some are written in shell, some in Python
To help address this, add support for FIT generation to binman. This works
by putting the FIT source directly in the binman definition, with the
ability to adjust parameters, etc. The contents of each FIT image come
from sub-entries of the image, as is normal with binman.
Add a method for adding a property containing arbitrary bytes. Make sure
that the tree can expand as needed in this case.
Normally the FIT timestamp is created the first time mkimage is run on a
FIT, when converting the source .its to the binary .fit file. This
corresponds to using the -f flag. But if the original input to mkimage is
a binary file (already compiled) then the timestamp is assumed to have
been set previously.
Add a -t flag to allow setting the timestamp in this case.
Some binary blobs unfortunately obtain their position in the image from
other binary blobs, such as Intel's 'descriptor'. In this case we cannot
rely on packing to work. It is not possible to produce a valid image in
any case, due to the missing blobs.
Allow zero-length overlaps so that this does not cause any problems.
Update the Intel blob entries to support missing binaries.
When external blobs are missing, show a message indicating that the images
are not functional.
When warnings and errors are produced by tools they should be written to
stderr. Update the tout implementation to handle this.
Sometimes it is useful to build an image even though external binaries are
not present. This allows the build system to continue to function without
these files, albeit not producing valid images.
U-Boot does with with ATF (ARM Trusted Firmware) today.
Add a new flag to binman to request this behaviour.
