Synchronise device trees with linux v5.19-rc5.
As a preparatory step rename the included SoC dtsi from vf.dtsi to
vf610.dtsi as this is how it is named in Linux upstream.
Synchronise device tree with linux-next next-20220708.
Please note that this also means that instead of the previous "generic"
U-Boot specific carrier board agnostic device trees we are now using the
regular ones for the Colibri Evaluation (carrier) board V3 (e.g.
imx7d-colibri-eval-v3.dtb rather than the previous
imx7-colibri-rawnand.dtb and imx7d-colibri-emmc-eval-v3.dtb rather than
the previous imx7-colibri-emmc.dtb).
Please further note that the PMIC node name got changed from rn5t567@33
to pmic@33 which required adjustment in resp. board file
board/toradex/colibri_imx7/colibri_imx7.c.
As a preparatory step remove the epdc reference which does not exist in
the Linux upstream device tree and rename the qspi1 reference to qspi as
this is how it is named in the Linux upstream device tree.
This avoids the following error once synchronised:
+Error: arch/arm/dts/.imx7d-sdb-qspi.dtb.pre.tmp:10.1-6 Label or path
epdc not found
+Error: arch/arm/dts/.imx7d-sdb-qspi.dtb.pre.tmp:29.1-7 Label or path
qspi1 not found
+Error: arch/arm/dts/imx7d-sdb-qspi-u-boot.dtsi:6.1-7 Label or path
qspi1 not found
As a preparatory step rename the qspi1 reference to qspi as this is how
+Error: arch/arm/dts/.imx7-cm.dtb.pre.tmp:96.1-7 Label or path qspi1 not
found
Synchronise device tree with linux v5.19-rc5.
imx6ull-colibri-eval-v3.dtb rather than the previous imx6ull-colibri.dtb
and imx6ull-colibri-emmc-eval-v3.dtb rather than the previous
imx6ull-colibri-emmc.dtb).
As a preparatory step remove the qspi node with its flash0 label as this
is already in the Linux upstream device tree.
+arch/arm/dts/imx6ul-14x14-evk.dtb: ERROR (duplicate_label):
/soc/bus@2100000/spi@21e0000/n25q256a@0: Duplicate label 'flash0' on
/soc/bus@2100000/spi@21e0000/n25q256a@0 and
/soc/bus@2100000/spi@21e0000/flash@0
U-Boot specific carrier board agnostic device tree we are now using the
regular one for the Colibri Evaluation (carrier) board V3 (e.g.
imx6dl-colibri-eval-v3.dtb rather than the previous imx6-colibri.dtb).
Synchronise device tree with linux-next 20220706.
regular one for the Apalis Evaluation (carrier) board (e.g.
imx6q-apalis-eval.dtb rather than the previous imx6-apalis.dtb).
Synchronise device trees with linux-next next-20220708.
As a preparatory step make sure to refer to absolute node paths where
labels were removed in Linux upstream.
+Error: arch/arm/dts/imx6q-tbs2910-u-boot.dtsi:3.1-7 Label or path aips1
not found
+Error: arch/arm/dts/imx6q-tbs2910-u-boot.dtsi:11.1-5 Label or path soc
not found
Fix the following build-time pwms property warnings:
w+arch/arm/dts/imx6dl-aristainetos2c_7.dtb: Warning (pwms_property):
/backlight:pwms: property size (12) too small for cell size 3
w+arch/arm/dts/imx6dl-aristainetos2c_cslb_7.dtb: Warning (pwms_property):
Fix the following build-time pwms property warning:
w+arch/arm/dts/imx6dl-brppt2.dtb: Warning (pwms_property):
Add product id print in show_board_info(), with an increasing number of
Toradex SKUs available with small differences it makes sense to print it.
Move serial number print to a dedicated line, this prevents the previous
line with the product name to overflow the 80 columns with any
reasonable product name length.
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
Up to now in the code we named Toradex SKUs in a slightly different way
compared to the official product name, start using the official names
from now on to avoid misunderstanding.
This has also the nice benefit of the string being shorter, allowing
to fit nicely in 80 columns even adding the product ID when printing
the hardware information.
Fix checkpatch warn, use `IS_ENABLED(CONFIG_TDX_CFG_BLOCK_2ND_ETHADDR)`
instead of `#ifdef CONFIG_TDX_CFG_BLOCK_2ND_ETHADDR`.
Remove stale show_boot_logo() declaration, not used anywhere.
Fixes: e6fd30dd9eef ("toradex: drop legacy show_boot_logo function and use splashscreen")
Simplify interactive config block creation code, instead of having a
a long list of questions and a complex tree of preprocessor directive to
guess the exact SKU, just ask the user to select it from a list.
The modules list is filtered out to include only SKUs that are supported
by the specific u-boot binary in execution.
Use generally available ARRAY_SIZE macro, instead of hand-coding it
every time is needed.
Remove comment "not currently on sale" on specific SKUs, this
information does not belong to the code and will never be accurate.
Add new i.MX 8M Mini SKU to ConfigBlock handling.
0068: Verdin iMX8M Mini Quad 2GB WB IT No CAN
This SKU is identical to 0055 but without CAN. Mention this in the name
so those modules can be distinguished.
Reviewed-by: Francesco Dolcini <francesco.dolcini@toradex.com>
Sync imx8mm.dtsi device tree with linux-next 20220711.
The main motivation for doing this sync is the sha256 regression
reported by Andrey Zhizhikin [1].
The linux-next kernel has the following commit, which disables
the job ring 0 and fixes the problem:
https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/commit/?h=next-20220715&id=dc9c1ceb555ff661e6fc1081434600771f29657c
[1] https://lore.kernel.org/u-boot/AM6PR06MB46912207D9460CD9924F35DAA68B9@AM6PR06MB4691.eurprd06.prod.outlook.com/T/#t
Signed-off-by: Fabio Estevam <festevam@denx.de>
Add instructions to build and boot from QSPI Flash
Signed-off-by: Mamta Shukla <mamta.shukla@leica-geosystems.com>
Signed-off-by: Thomas Haemmerle <thomas.haemmerle@leica-geosystems.com>
Tested-by: Adam Ford <aford173@gmail.com>
Reviewed-by: Fabio Estevam <festevam@denx.de>
Add entry for imx8mm_evk_fspi_defconfig in
board/freescale/imx8mm_evk/MAINTAINERS
The macro `CONFIG_SYS_UBOOT_BASE` is used by SPL loaders `"NOR"` and
`"XIP"` to determine the base address of u-boot.
For `"NOR"` on i.MX8MM it is the base address of QSPI0 plus the offset
of the flattened image tree blob.
Although `QSPI0_AMBA_BASE` is used to define CONFIG_SYS_UBOOT_BASE in
multiple board header files for i.MX8MM, it is not specified.
Specify offset of flattened image tree blob (needs to be set to same
value as specified in 'binman' node), base address of QSPI0 and size of
FlexSPI configuration block.
Reviewed-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
Add QSPI Boot option in u-boot-spl for i.MX8m EVK.
Add imx8mm_evk_fspi_defconfig to build QSPI boot image.
This config is based on imx8mm_evk_defconfig with addtional config options to
define FSPI Header parameters required to generate QSPI Header.
Update SPL offset to include header size and overwrite IMX_CONFIG to use
lpddr.cfg for FSPI.
Add definition for FSPI configuration block and subsequently new offsets for
u-boot-spl and u-boot-itb for CONFIG_FSPI_HEADER option.
Add struct with Flex SPI Configuration Block and enable generating
fspi header using mkimage.
Refer i.MX 8M Mini Application Processor Reference Manual for
detailed information about parameters for FlexSPI Configuration block.
Since fe8acf556c3 ("imx: HAB: Validate IVT before authenticating image")
the U-Boot HAB implementation is checking whether reserved1 field in IVT
is zero or not. In case the field is not zero, IVT validation fails. Stop
setting IVT reserved1 field to non-zero in mkimage imx8m plugin, otherwise
the validation cannot ever work.
Note that this only affects legacy boards which do not use binman.
Cc: Fabio Estevam <festevam@denx.de>
Cc: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Simplify the use of the ROM API by using the wrappers that take care
of saving/restoring gd and computing the xor value. This makes the
generated code smaller and the C code easier to read.
The ROM API is thoroughly undocumented, but apparently passing the xor
of the real arguments as an extra argument is required [1]. Also, we
need to do the "save gd/restore gd" dance. These are both error-prone,
and lead to a lot of code duplication.
Since both imx8m[np] and imx8ulp SOCs have this, add a separate
translation unit which is included precisely when the new
CONFIG_IMX8_ROMAPI symbol is set, which provide convenience wrappers
that take care of computing the xor value as well as doing the gd
dance, and that thus have a more intuitive API. Subsequent patches
will make use of these to reduce boilerplate.
[1] One wonders, for example, if the check is only applied to the
lower 32 bits, or if we're implicitly relying on all 64-bit pointer
values we're passing effectively have 0 in the upper 32 bits.
This exposes the struct rom_api, the g_rom_api variable declaration
and the associated #defines to slightly fewer boards: namely, those
IMX8M which are not IMX8MN or IMX8MP. But the latter two are the only
IMX8M* ones where the g_rom_api variable is defined (in imx8m/soc.c),
so that should be fine.
In order not to repeat the IMX8MN || IMX8MP || IMX8ULP logic in
multiple places where we need to know if the SOC exposes the ROM API,
add a "def_bool y" Kconfig symbol.
ft_board_setup relies on the board_type() function to optimize which phy
nodes need to be enabled for Linux.
Add calls to setup and release the board-detect GPIOs.
Also fix the switch-case statement to only enable phy address 4 for
Cubox and unknown devices.
Fixes: 741ce308 ("mx6cuboxi: fixup dtb ethernet phy nodes before booting an OS")
Signed-off-by: Josua Mayer <josua@solid-run.com>
The TI DP83867 phy has been replaced with the MaxLinear GPY111 phy
due to part availability. Add support for it:
- increase post-reset time to 300ms per datasheet
- leave tx-delay/rx-delay undefined in dt defaulting to 2.0ns
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
The imx6q arm2 board support has been removed from U-Boot
as it did not get converted to DM.
Remove the MX6Q_ARM2 related ifdefery in the driver.
https://source.denx.de/u-boot/custodians/u-boot-nand-flash
In preparation of re-sync of mtd stack, we opt to move the current stack
slowly in order to have a more easy sync and test. We would like to
prepare uboot to support no-jedec and no-onfi compliant nand so we need
to clean up a bit the code we have now and upstream some of the support.
In this series we expect no functional change
Tested on:
- imx6ull Micron MT29F2G08ABAGAH4
- imx8mn Macronix MX30LF4G18AC
https://source.denx.de/u-boot/custodians/u-boot-efi
Pull request for efi-2022-10-rc1-2
Documentation:
* doc: add package uuid-dev to build dependencies
UEFI:
* remove support for CONFIG_LCD
* fix authenticated capsules tests
Others:
* pxe: simplify label_boot()
* cli: support bracketed paste
- octeontx_wdt: Add MIPS Octeon support (Stefan)
- watchdog: add amlogic watchdog support (Philippe)
- watchdog: add pulse support to gpio watchdog driver (Paul)
Upstream linux commit f7025a43a9da26.
The MTD subsystem has its own small museum of ancient NANDs in a form of
the CONFIG_MTD_NAND_MUSEUM_IDS configuration option. The museum contains
stone age NANDs with 256 bytes pages, as well as iron age NANDs with 512
bytes per page and up to 8MiB page size.
It is with great sorrow that I inform you that the museum is being
decommissioned. The MTD subsystem is out of budget for Kconfig options and
already has too many of them, and there is a general kernel trend to
simplify the configuration menu.
We remove the stone age exhibits along with closing the museum
REMARK Don't apply this part from upstream:
Some of the iron age ones are transferred to the regular NAND depot.
Namely, only those which have unique device IDs are transferred, and the
ones which have conflicting device IDs are removed.
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Dario Binacchi <dario.binacchi@amarulasolutions.com>
Upstream linux commit fb3bff5b407e58.
This patch enables support to read the ECC strength and size from the
NAND flash using Toshiba Memory SLC NAND extended-ID. This patch is
based on the information of the 6th ID byte of the Toshiba Memory SLC
NAND.
Upstream linux commit 3b5206f4be9b65.
Move Macronix specific initialization logic into nand_macronix.c. This
is part of the "separate vendor specific code from core" cleanup
process.
Upstream linux commit 229204da53b31d.
Move AMD/Spansion specific initialization/detection logic into
nand_amd.c. This is part of the "separate vendor specific code from
core" cleanup process.
Upstream linux commit 10d4e75c36f6c1.
Move Micron specific initialization logic into nand_micron.c. This is
part of the "separate vendor specific code from core" cleanup process.
Upstream linux commit 9b2d61f80b060c.
Move Toshiba specific initialization and detection logic into
nand_toshiba.c. This is part of the "separate vendor specific code from
