Fix:
i2c.c: In function 'i2c_init':
i2c.c:23:15: warning: variable 'actualFreq' set but not used
[-Wunused-but-set-variable]
Cc: Eran Man <eran@nbase.co.il>
Acked-by: Heiko Schocher <hs@denx.de>
Make checkpatch-clean
Fix:
sym53c8xx.c: In function 'scsi_write_dsp':
sym53c8xx.c:456:16: warning: variable 'val' set but not used
Fix:
sata_sil3114.c: In function 'scan_sata':
sata_sil3114.c:793:7: warning: array subscript is above array bounds [-Warray-bounds]
sata_sil3114.c:794:7: warning: array subscript is above array bounds [-Warray-bounds]
sata_sil3114.c:795:39: warning: array subscript is above array bounds [-Warray-bounds]
sata_sil3114.c:795:7: warning: array subscript is above array bounds [-Warray-bounds]
sata_sil3114.c:797:7: warning: array subscript is above array bounds [-Warray-bounds]
sata_sil3114.c:800:7: warning: array subscript is above array bounds [-Warray-bounds]
sata_sil3114.c:801:7: warning: array subscript is above array bounds [-Warray-bounds]
sata_sil3114.c:802:39: warning: array subscript is above array bounds [-Warray-bounds]
sata_sil3114.c:802:7: warning: array subscript is above array bounds [-Warray-bounds]
sata_sil3114.c:804:7: warning: array subscript is above array bounds [-Warray-bounds]
Fix:
x86emu/ops.c: In function 'x86emuOp_int3':
x86emu/ops.c:3521:9: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
x86emu/ops.c: In function 'x86emuOp_int_IMM':
x86emu/ops.c:3549:9: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
x86emu/ops.c: In function 'x86emuOp_into':
x86emu/ops.c:3579:9: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
x86emu/ops.c: In function 'x86emuOp_aad':
x86emu/ops.c:3993:8: warning: variable 'a' set but not used [-Wunused-but-set-variable]
Fix:
ahci.c: In function 'ata_scsiop_read10':
ahci.c:564:6: warning: variable 'lba' set but not used [-Wunused-but-set-variable]
Fix:
davinci_mmc.c: In function 'dmmc_wait_fifo_status':
davinci_mmc.c:72:7: warning: variable 'mmcstatus1' set but not used [-Wunused-but-set-variable]
davinci_mmc.c: In function 'dmmc_busy_wait':
davinci_mmc.c:89:7: warning: variable 'mmcstatus1' set but not used [-Wunused-but-set-variable]
Delete the unused variable.
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Fix:
ivm_core.c: In function 'ispVMLCOUNT':
ivm_core.c:2105:16: warning: unused variable 'usByte'
CC: Wolfgang Denk <wd@denx.de>
* 'master' of /home/wd/git/u-boot/custodians:
api: export LCD device to external apps
font: split font data from video_font.h
tools: logo: split bmp arrays from bmp_logo.h
lcd: add clear and draw bitmap declaration
VIDEO: mx3fb: GCC4.6 fix build warnings
Powerpc/DIU: Fixed the 800x600 and 1024x768 resolution bug
* 'master' of git://git.denx.de/u-boot-video:
arm, davinci: add DAVINCI_MMC_CLKID
arm, davinci_emac: fix driver bug if more then 3 PHYs are detected
arm, davinci: da850/dm365 lowlevel cleanup
omap5: Add omap5_evm board build support.
omap4/5: Add support for booting with CH.
omap5: emif: Add emif/ddr configurations required for omap5 evm
omap5: clocks: Add clocks support for omap5 platform.
omap5: Add minimal support for omap5430.
omap: Checkpatch fixes
omap4: make omap4 code common for future reuse
GCC4.6: Squash warnings in onenand_base.c
GCC4.6: Fix common/usb.c on xscale
OneNAND: Add simple OneNAND SPL
PXA: vpac270: Enable the new generic MMC driver
PXA: Cleanup serial_pxa
PXA: Drop csb226 and innokom boards (unmaintained)
m28evk: Fix comment about the number of RAM banks
mx31: Fix checkpatch warnings in generic.c
mx31: Use proper IO accessor for GPR register
mx31: Remove duplicate definition for GPR register
qong: Use generic function for configuring GPR register
M28EVK: Enable USB HOST support
iMX28: Add USB HOST driver
iMX28: Add USB and USB PHY register definitions
M28: Add memory detection into SPL
iMX28: Fix ARM vector handling
M28: Add doc/README.m28 documentation
M28: Add MMC SPL
iMX28: Add support for DENX M28EVK board
iMX28: Add u-boot.sb target to Makefile
iMX28: Add image header generator tool
iMX28: Add driver for internal RTC
iMX28: Add GPMI NAND driver
iMX28: Add APBH DMA driver
iMX28: Add SPI driver
iMX28: Add GPIO control
iMX28: Add I2C bus driver
iMX28: Add PINMUX control
FEC: Add support for iMX28 quirks
iMX28: Add SSP MMC driver
iMX28: Initial support for iMX28 CPU
MX25: zmx25: GCC4.6 fix build warnings
da850: add new config file for AM18xx
BeagleBoard: config: Switch to ttyO2
OMAP3: Change omap3_evm maintainer
devkit8000: Fix NAND SPL on boards with 256MB NAND
integrator: enable Vpp and disable flash protection
integrator: add system controller header
integrator: make flash writeable on boot
integrator: use io-accessors for board init
integrator: move text offset to config
integrator: pass configs for core modules
ARM: remove superfluous setting of arch_number in board specific code.
SPL: Allow ARM926EJS to avoid compiling in the CPU support code
integrator: do not test first part of the memory
arm: a320: fix broken timer
ARM: define CONFIG_MACH_TYPE for all ronetix boards
dm646x: pass board revision info to kernel
dm646x: add new configuration for dm6467T
arm, davinci: Fix setting of the SDRAM configuration register
arm, davinci: Remove the duplication of LPSC functions
arm, davinci: Rename AM1808 lowlevel functions to DA850
da8xxevm: fix build error
ARM: re-add MACH_TYPE_XXXXXX for VCMA9 board and add CONFIG_MACH_TYPE
* 'master' of git://git.denx.de/u-boot-arm:
M28: Add MMC SPL
Fix constness of the fdt void pointer in fdt_getprop_u32_default
Add some missing endian conversions in fdt_support.c
* 'master' of git://git.denx.de/u-boot-fdt:
powerpc/85xx: Fix builds of P1020/P2020RDB-PC_36BIT_NAND
arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c: Fix GCC 4.6 build warning
arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c: Fix GCC 4.6 build warning
arch/powerpc/cpu/mpc8xxx/ddr/options.c: Fix GCC 4.6 build warning
drivers/qe/uec.c: Fix GCC 4.6 build warning
drivers/usb/host/ehci-fsl.c: Fix GCC 4.6 build warning
drivers/net/fm/fm.c: Fix GCC 4.6 build warning
board/sbc8560/sbc8560.c: Fix GCC 4.6 build warning
board/sbc8548/sbc8548.c: Fix GCC 4.6 build warning
board/freescale/mpc8569mds/mpc8569mds.c: Fix GCC 4.6 build warning
board/freescale/mpc8568mds/mpc8568mds.c: Fix GCC 4.6 build warning
board/freescale/mpc8548cds/mpc8548cds.c: Fix GCC 4.6 build warning
board/freescale/common/pixis.c: Fix GCC 4.6 build warning
board/freescale/common/cds_pci_ft.c: Fix GCC 4.6 build warning
arch/powerpc/cpu/mpc8xxx/fsl_lbc.c: Fix GCC 4.6 build warning
arch/powerpc/cpu/mpc85xx/tlb.c: Fix GCC 4.6 build warning
arch/powerpc/cpu/mpc85xx/cpu_init.c: Fix GCC 4.6 build warning
phylib: Enable AR8021 phy support
powerpc/85xx: Set max alloc length to 10MB on P1022DS
powerpc/mpc85xx: Set SYSCLK to the required frequency
powerpc/85xx: Fix NAND SPL support
powerpc/85xx: Fix MPC8572DS NAND build
fsl_ifc: Fixed a bug in the erratum handling code for IFC_A003399
powerpc/85xx: Add support for Book-E MMU Arch v2.0
powerpc/85xx: Make inclusion of USB device fixup conditional
powerpc/85xx: Fix warning for USB device-fixup
powerpc/85xx: resize the boot page TLB before relocating CCSR
powerpc/85xx: verify the current address of CCSR before relocating it
powerpc/85xx: add some missing sync instructions in the CCSR relocation code
powerpc/85xx: fix some comments in the CCSR relocation code
powerpc/85xx: fix definition of MAS register macros
powerpc/mpc8548cds: Fix network initialization
powerpc/mpc8548: Add workaround for erratum NMG_eTSEC129
powerpc/QorIQ: fix network frame manager TBI PHY address settings
* 'master' of git://git.denx.de/u-boot-mpc85xx:
adp-ag101p: add product into MAINTAINERS list
adp-ag101p: Add SoC and board support of ag101p
nds32: fix data section of linker script
dwcddr21mctl: Synopsys DWC DDR2/1 Memory Controller
andes_pcu.h: header file of andes_pcu power control unit
* 'master' of git://git.denx.de/u-boot-nds32:
fsl_i2c: Fix compile warning
* 'master' of git://git.denx.de/u-boot-i2c:
Tegra2: mmc: Factor out mmc_wait_inhibit functionality
Tegra2: mmc: Add data transfer completion timeout
Tegra2: mmc: Support DMA restarts at buffer boundaries
Tegra2: mmc: define register field values in tegra2_mmc.h
MMC: PL180: Fix infinite loop with VExpress extended fifo implementation
This patch exports LCD info-query and bitmap-rendering functions to
external apps.
This patch is tested on a Seaboard. Because the LCD driver is not yet
upstreamed, the test was done in a local downstream repo.
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
While video_font.h is useful even without referencing the font data, it
is not possible to be included multiple times because it defines font
data array right in the header.
This patch splits the font data array into video_font_data.h and so now
video_font.h can be included multiple times. This at least solves the
code duplication in board/mcc200/lcd.c.
The generated header bmp_logo.h is useful even outside common/lcd.c for
the logo dimension. However, the problem is, the generated bmp_logo.h
cannot be included multiple times because bmp_logo_palette[] and
bmp_logo_bitmap[] are defined in the bmp_logo.h.
This patch fixes this by defining these arrays in another header
bmp_logo_data.h and in bmp_logo.h only declaring these arrays.
The functions for clearing and drawing bitmaps on the screen were not
exposed publicly and are made public in this patch in preparation for
implementing the display interface of api_public.h.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
since commits:
davinci: emac: add support for more than 1 PHYs
062fe7d332c28ede25626f448681e43d76bb312e
davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM
fb1d6332b5430b90a8fa8ebab709f33a60e9f816
I get following warning on the enbw_cmc board:
Err: serial
Net: 5 ETH PHY detected
miiphy_register: non unique device name 'KSZ8873 @ 0x01'
DaVinci-EMAC
Hit any key to stop autoboot: 0
Also I see some debug printfs:
=> run load
+ emac_close
+ emac_ch_teardown
- emac_ch_teardown
+ emac_ch_teardown
- emac_ch_teardown
- emac_close
+ emac_open
- emac_open
Using DaVinci-EMAC device
reason is 062fe7d332c28ede25626f448681e43d76bb312e new define MAX_PHY.
This is set to 3! I get on this board 5 active phys, so
this leads in wrong memory writes ...
so I changed:
- define CONFIG_SYS_DAVINCI_EMAC_PHY_COUNT to set
the MAX_PHY value, add a description in README
for the new CONFIG_SYS option.
- print an error message if more then MAX_PHYs are
detected.
- fill the active_phy_addr array in a for loop with
0xff
- changed printf() in debug_emac()
Cc: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Prabhakar Lad <prabhakar.csengg@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Tom Rini <tom.rini@gmail.com>
- Cleanup a lot of fix values, and use defines instead.
- Also make some values configurable through the board config
file.
- delete the NAND_SPL code for da850, as it is not used actually
- remove the asm code
Cc: Wolfgang Denk <hs@denx.de>
Cc: Christian Riesch <christian.riesch@omicron.at>
This patch adds the build support for the
omap5_evm board.
Signed-off-by: sricharan <r.sricharan@ti.com>
Configuration header(CH) is 512 byte header attached to an OMAP
boot image that will help ROM code to initialize clocks, SDRAM
etc and copy U-Boot directly into SDRAM. CH can help us in
by-passing SPL and directly boot U-boot, hence it's an alternative
for SPL. However, we intend to support both CH and SPL for OMAP4/5.
Initialization done through CH is limited and is not equivalent
to that done by SPL. So U-Boot has to distinguish between the
two cases and handle them accordingly. This patch takes care
of doing this.
Add the emif configurations required for omap5 soc.Add the
correct ddr part configurations required for omap5 evm board.
EDB8164B3PH from ELPIDA is the part used on the board.
Also changes are done to retain some part of the code
common for OMAP4/5 and keep only the remaining in the Soc
specific directories.
Adding the correct configurations required for
dplls, clocks, for omap5 Soc.
Also changes are done to retain some part of the code common
for OMAP4/5 and move only the remaining to the Soc specific
directories.
This patch adds the minimal support for OMAP5. The platform and machine
specific headers and sources updated for OMAP5430.
OMAP5430 is Texas Instrument's SOC based on ARM Cortex-A15 SMP architecture.
It's a dual core SOC with GIC used for interrupt handling and SCU for cache
coherency.
Also moved some part of code from the basic platform support that can be made
common for OMAP4/5. Rest is kept out seperately. The same approach is followed
for clocks and emif support in the subsequent patches.
Fixing them here so that when the files are reused in
subsequent patches for omap5, avoids new checkpatch
warnings.
Much of omap4 soc support code can be reused for omap5.
Move them to the omap-common directory to facilitate
this.
onenand_base.c: In function ‘onenand_do_lock_cmd’:
onenand_base.c:1946:6: warning: variable ‘wp_status_mask’ set but not used
onenand_base.c: In function ‘onenand_check_maf’:
onenand_base.c:2229:8: warning: variable ‘name’ set but not used
onenand_base.c: In function ‘flexonenand_get_boundary’:
onenand_base.c:2258:6: warning: variable ‘ret’ set but not used
Cc: Scott Wood <scottwood@freescale.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
The problem was that the code, when the function was compiled with -Os, was
misgenerated. As in the function description, this is likely another
manifestation of the bug in GCC.
Cc: Remy Bohmer <linux@bohmer.net>
This introduces small OneNAND loader, fitting into 1kB of space (smallest
possible OneNAND RAM size). Some devices equipped with such crappy chips will
use this.
V2: Introduce spl_onenand_load_image() to load data from OneNAND in SPL
V3: Cleanup, align with nand_spl. Skip whole blocks.
* Cleanup register definitions by introducing new regs-uart.h, compliant with
rest of U-Boot.
* Remove old register definitions from pxa-regs.h
* Convert serial_pxa to new regs-uart.h
* Cleanup serial_pxa
Cc: Robert Schwebel <robert@schwebel.de>
The function fdt_getprop_u32_default doesn't modify the fdt, so it can use a
const void * for its fdt argument.
Signed-off-by: Gabe Black <gabeblack@chromium.org>
Some functions in fdt_support.c use fdt_getprop to read 32 bit values out of
the device tree, but then use them directly without doing any endian
conversion. Because they check for a value that doesn't actually appear in
practice, the functions continued to work even though they're incorrect.
This change adds the missing conversions.
This is a well encapsulated section of mmc_send_cmd, by moving
it to it's own function it increases the readability of mmc_send_cmd.
Signed-off-by: Anton Staaf <robotboy@chromium.org>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Currently when no expected completion condition occures in the
mmc_send_cmd while loop that is waiting for a data transfer to
complete the MMC driver just hangs.
This patch adds an arbitrary 2 second timeout. If nothing we
recognize occures within 2 seconds some diagnostic information
is printed and we fail out.
Currently if a DMA buffer straddles a buffer alignment boundary
(512KiB) then the DMA engine will pause and generate a DMA
interrupt. Since the DMA interrupt is not enabled it will hang
the MMC driver.
This patch adds support for restarting the DMA transfer. The
SYSTEM_ADDRESS register contains the next address that would have
been read/written when a boundary is hit. So we can read that
and write it back. The write triggers the resumption of the
transfer.
This moves the magic numbers sprinkled about the MMC driver
to a single location in the header file and gives them
meaningful names.
Size grew a bit so nand-spl didn't fit in 4k, reduce done by removing
LAW entries not needed during SPL phase.
Fix:
ctrl_regs.c: In function 'set_ddr_sdram_cfg_2':
ctrl_regs.c:641:15: warning: variable 'rcw_en' set but not used [-Wunused-but-set-variable]
ctrl_regs.c: In function 'compute_fsl_memctl_config_regs':
ctrl_regs.c:951:31: warning: array subscript is above array bounds [-Warray-bounds]
ctrl_regs.c:752:34: warning: array subscript is above array bounds [-Warray-bounds]
Fix:
fsl_corenet_serdes.c: In function 'fsl_serdes_init':
fsl_corenet_serdes.c:511:8: warning: variable 'buf' set but not used [-Wunused-but-set-variable]
fsl_corenet_serdes.c:498:18: warning: variable 'lane_prtcl' set but not used [-Wunused-but-set-variable]
