All flush_cache() calls in microblaze code are supposed to flush the
entire instruction and data caches, so introduce flush_cache_all()
helper to handle this.
Also, provide implementations for flush_dcache_all() and
invalidate_icache_all() so that icache and dcache u-boot commands can
work.
Signed-off-by: Ovidiu Panait <ovpanait@gmail.com>
Link: https://lore.kernel.org/r/20220531181435.3473549-9-ovpanait@gmail.com
Signed-off-by: Michal Simek <michal.simek@amd.com>
Replace XILINX_DCACHE_BYTE_SIZE macro with two Kconfig symbols for
instruction and data caches sizes, respectively:
CONFIG_XILINX_MICROBLAZE0_ICACHE_SIZE
CONFIG_XILINX_MICROBLAZE0_DCACHE_SIZE
Also, get rid of the hardcoded value in icache_disable().
Link: https://lore.kernel.org/r/20220531181435.3473549-8-ovpanait@gmail.com
Signed-off-by: Michal Simek <michal.simek@amd.com> (s/bralid/brlid/g)
Factor out icache/dcache components from flush_cache() function. Call the
newly added __flush_icache()/__flush_dcache() functions inside
icache_disable() and dcache_disable(), respectively. There is no need to
flush both caches when disabling a particular cache type.
Link: https://lore.kernel.org/r/20220531181435.3473549-7-ovpanait@gmail.com
Replace CONFIG_ICACHE with a Kconfig option more limited in scope -
XILINX_MICROBLAZE0_USE_WIC. It should be enabled if the processor supports
the "wic" (Write to Instruction Cache) instruction. It will be used to
guard "wic" invocations in microblaze cache code.
Link: https://lore.kernel.org/r/20220531181435.3473549-6-ovpanait@gmail.com
Replace CONFIG_DCACHE with a Kconfig option more limited in scope -
XILINX_MICROBLAZE0_USE_WDC. It should be enabled if the processor supports
the "wdc" (Write to Data Cache) instruction. It will be used to guard
"wdc" invocations in microblaze cache code.
Also, drop all ifdefs around flush_cache() calls and only keep one
CONFIG_IS_ENABLED() guard within flush_cache() itself.
Link: https://lore.kernel.org/r/20220531181435.3473549-5-ovpanait@gmail.com
XILINX_USE_DCACHE macro was removed in 7556fa09e0e ("microblaze: Simplify
cache handling"), but it was still used in a couple of places.
Replace those occurences with CONFIG_DCACHE.
Link: https://lore.kernel.org/r/20220531181435.3473549-4-ovpanait@gmail.com
in16/out16 routines seem to not be used anywhere in microblaze code, so
remove them.
Link: https://lore.kernel.org/r/20220531181435.3473549-3-ovpanait@gmail.com
Relocate cpu_ops pointers when CONFIG_NEEDS_MANUAL_RELOC is enabled.
The (gd->flags & GD_FLG_RELOC) check was added to make sure the reloc_done
logic works for drivers that use DM_FLAG_PRE_RELOC.
Link: https://lore.kernel.org/r/20220531181435.3473549-2-ovpanait@gmail.com
Migrate cpu command to use U_BOOT_CMD_WITH_SUBCMDS() helper macro, to
reduce duplicated code. This also fixes the cpu command on boards that
enable CONFIG_NEEDS_MANUAL_RELOC.
Link: https://lore.kernel.org/r/20220531181435.3473549-1-ovpanait@gmail.com
Microblaze is using NEEDS_MANUAL_RELOC from the beginnging. This is causing
issues with function pointer arrays which need to be updated manually after
relocation. Building code with -fPIC and linking with -pic will remove this
limitation and there is no longer need to run manual update.
By default still old option is enabled but by disabling NEEDS_MANUAL_RELOC
code will be compiled for full relocation.
The patch does couple of things which are connected to each other.
- Define STATIC_RELA dependency to call relocate-rela to fill sections.
- REMAKE_ELF was already enabled but u-boot file can't be used because
sections are empty. relocate-rela will fill them and output file is
u-boot.elf which should be used.
- Add support for full relocation (u-boot.elf)
- Add support for early relocation when u-boot.bin is loaded to different
address then CONFIG_SYS_TEXT_BASE
- Add rela.dyn and dynsym sections
Disabling NEEDS_MANUAL_RELOC U-Boot size increased by 10% of it's original
size (550kB to 608kB).
Link: https://lore.kernel.org/r/a845670b34925859b2e321875f7588a29f6655f9.1655299267.git.michal.simek@amd.com
Microblaze is 32bit that's why it is using elf32 format. Relocation code
requires to get information about rela and dynsym senctions and also text
base which was used for compilation.
Code build with -fPIC and linked with -pic generates 4 relocation types.
R_MICROBLAZE_NONE is the easiest one which doesn't require any action.
R_MICROBLAZE_REL only requires write addend to r_offset address.
R_MICROBLAZE_32/R_MICROBLAZE_GLOB_DAT are the most complicated. There is a
need to find out symbol value with adding symbol value and write it to
address pointed by r_offset. Calculation with addend is also added but
only 0 addend values are generated now.
Link: https://lore.kernel.org/r/9912c3d76933bdf75e1ebb6aab43726cd32cafb5.1655299267.git.michal.simek@amd.com
Add support for 32bit ELF format which is used by Microblaze. Also check
that code runs only for Microblaze.
Function finds information about rela.dyn and dynsym which will be used
later for relocation.
Link: https://lore.kernel.org/r/7491cc72fe04cbd48db014f1492ce463e91dfb42.1655299267.git.michal.simek@amd.com
Relocation support is only for EM_AARCH64 that's why check machine type to
make sure that the code will never run on any unsupported one.
Link: https://lore.kernel.org/r/36f26c8752335239344b265e5ddedad10e9cac8b.1655299267.git.michal.simek@amd.com
Adding support for new type requires to change code layout that's why move
elf64 code to own function for easier maintenance.
It also solves the problem with not calling fclose in case of error.
Return value from rela_elf64 is saved to variable that's why fclose() is
called all the time.
Link: https://lore.kernel.org/r/21763b80527521c85ca7d4ac64ad6ff4885409c8.1655299267.git.michal.simek@amd.com
Symbol handling depends on compilation flags. Right now manual relocation
is used that's why symbols can be referenced just by name and there is no
need to find them out. But when position independent code (PIC) is used
symbols need to be described differently. That's why having one macro
change is easier than changing the whole code.
Link: https://lore.kernel.org/r/d704e9a267c8b536452fb999111dbfbc9d652be5.1655299267.git.michal.simek@amd.com
Better to add comment to explain why reset vector points all the time to
origin U-Boot location.
If reset happens U-Boot should start from it's origin location.
Link: https://lore.kernel.org/r/5ca6341b7487708247fe2948d7e496ea6f7c2e02.1655299267.git.michal.simek@amd.com
Right now U-Boot runs all the time from the same address where it is loaded
but going to full relocation code starting address doesn't need to be fixed
and can be simply discovered from reading PC register. That's why use r20
to get PC address and subtract offset from the beginning to get starting
address.
Link: https://lore.kernel.org/r/044b727c33dfbe662f68512d0da0775a4805f360.1655299267.git.michal.simek@amd.com
r20 is not used that's why remove logic around it.
Link: https://lore.kernel.org/r/1b32bab5c050d099b2f6d49bc4896322ed03d788.1655299267.git.michal.simek@amd.com
There are additional operations which can be done simpler that's why
improve logic around relocation address r7 handling and _start symbol.
Link: https://lore.kernel.org/r/c8b60f72f1605c2ba6b4b7be1893d7e6ec3d8597.1655299267.git.michal.simek@amd.com
SLR low address is still setup to 0 that's why only high limit should be
updated. STACK_SIZE macro is present and could be possible used for
low address alignment but it is not done by this patch.
Link: https://lore.kernel.org/r/c00cb843df848703b760a65934ed3ce31fafcf19.1655299267.git.michal.simek@amd.com
Follow up patch will convert symbol handling that's why it is necessary to
separate logic around symbols to special instruction. It adds 4B for new
instruction but it is worth to do it to have code ready for for full
relocation.
Link: https://lore.kernel.org/r/030863fa9a9c1ca0a9b082fe498522da09189fbc.1655299267.git.michal.simek@amd.com
Enable u-boot.elf recreation from u-boot.bin to prepare for removing manul
relocation. Enable option for big endian configuration but it is not used
too much that's why it is completely untested.
By supporting this system there is a need to define LITTLE/BIG endian
Kconfig options to pass -EL/-EB flags.
Full command line for u-boot.elf recreation looks like this:
microblazeel-xilinx-linux-gnu-objcopy -I binary -B microblaze \
-O elf32-microblazeel u-boot.bin u-boot-elf.o
Link: https://lore.kernel.org/r/7e242a519fcd1c693b9103c5599b515af555ca43.1655299267.git.michal.simek@amd.com
This option will be used by Microblaze that's why move it to generic
location to be able to use it.
Link: https://lore.kernel.org/r/ceb39fa615cb5657b66a7b77bab99e86ca7a3346.1655299267.git.michal.simek@amd.com
Trivial fix.
Link: https://lore.kernel.org/r/c4ede6dc738c5bd7c518f3bb2c9410b15c102e20.1655299267.git.michal.simek@amd.com
Use symbol instead macro to find where U-Boot starts.
Link: https://lore.kernel.org/r/d5d4c201bee6171e85b47783d916387d84db0456.1655299267.git.michal.simek@amd.com
CONFIG_SYS_INIT_SP_OFFSET macro place stack to TEXT_BASE - SYS_MALLOC_F_LEN
but there is no reason to do it now because board_init_f_alloc_reserve()
returns exact location where stack should be. That's why stack location is
calculated at run time and there is no need to hardcode it via macro. This
change will help with placing U-Boot to any address.
Link: https://lore.kernel.org/r/e9aee69646e022fd8a96cbee2d2a07ab81fb6e05.1655299267.git.michal.simek@amd.com
When U-Boot starts stack protection can be already enabled that's why setup
the lowest possible SLR value which is address 0. And the highest possible
stack in front of U-Boot. That's why you should never load U-Boot to the
beginning of DDR. There must be some space reserved. Code is using this
location for early malloc space, early global data and stack.
Link: https://lore.kernel.org/r/86b9748bad12142659804d6381bc6bbf20be44f1.1655299267.git.michal.simek@amd.com
There is no reason to use absolute branches and use just relative. This
change helps with moving binary to different location and start it from
there.
Link: https://lore.kernel.org/r/83a5103b85c1c2220cd3ab4d5365169c6660e40a.1655299267.git.michal.simek@amd.com
There is no need to pass section information via parameters.
Let's read text base and rela start/end directly from elf.
It will help with reading other information from ELF for others
architecture. Input to relocate-rela is u-boot binary and u-boot ELF.
Link: https://lore.kernel.org/r/ab7ae14a6e058722e8c608089729e98edf20a08d.1655299267.git.michal.simek@amd.com
Declare rela_start/end and text_base as global variables. It will help with
using these variables for ELF decoding.
Link: https://lore.kernel.org/r/7485b163e92f8f3f754c35f7c88c3314f2212efd.1655299267.git.michal.simek@amd.com
Numbers in comment are shifter which is visible from command which calls
them. Also relocate-rela usage is describing them.
"Usage: %s <bin file> <text base> <rela start> <rela end>"
Link: https://lore.kernel.org/r/bb0287b9071eb33eea0cf914a7128c2603684377.1655299267.git.michal.simek@amd.com
There is no value to open u-boot binary file so early. Better to check all
values first and then open binary file.
Link: https://lore.kernel.org/r/9c2b4ebadbe83497db28af02f6af2623793ffdb6.1655299267.git.michal.simek@amd.com
u3007 is removed in zynqmp-m-a2197-02-revA board and on
zynqmp-m-a2197-03-revA it was renamed to v3022 at address 0x18.
Link: https://lore.kernel.org/r/f477796bcca6fce09168699a0498d792f4a54acf.1655287013.git.michal.simek@amd.com
TI manual (https://www.ti.com/lit/gpn/TPS53681) is saying that i2c address
is 7bit where c0h is 1100000 which is 0x60.
This will fix issues reported by make dtbs that 0xc0 is above 7bit regular
i2c address range.
Link: https://lore.kernel.org/r/2f50c1cd258f6b05deb2a6a9af7fa92952f3f8cb.1655287013.git.michal.simek@amd.com
si570 is normally at 0x5d address and address is not aligned with address
in node.
8T49N240 can't be at 0xd8 that's why it is shifter by one bit.
Link: https://lore.kernel.org/r/4fa86fffa9cb8abe633fbc5a9c55bea249b5edfb.1655287013.git.michal.simek@amd.com
Add support to handle 'output-enable' and 'bias-high-impedance'
configurations. DT property output-enable brings out the pins from
tri-state, whereas bias-high-impedance changes the pins state to
tri-state.
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
Link: https://lore.kernel.org/r/1a02cd41d183d397ebce23c497178281c7286692.1655286745.git.michal.simek@amd.com
DP is enabled for revB and should be enabled for kv260-revA too. Changes in
other boards were done by commit 8b82a3a7feb0 ("arm64: zynqmp: Enable DP
driver for SOMs").
Link: https://lore.kernel.org/r/4e273bce3a8acf4495b67b702b1704acec8d9ccb.1654779436.git.michal.simek@amd.com
Do not use 0 as address for memory because of the special meaning for
pointers (null pointer). Change the spl bss start address to the second
page.
Signed-off-by: Stefan Herbrechtsmeier <stefan.herbrechtsmeier@weidmueller.com>
Link: https://lore.kernel.org/r/20220607074314.27125-1-stefan.herbrechtsmeier-oss@weidmueller.com
Board is using kv260 design for couple of parts defined by spec like i2c
eeproms, ina260, uart, etc.
Board has 4 gems. One gem connected via PS SGMII(GT), another PS RGMII(MIO)
and 2 via EMIO. First two shares the same MIO lines for PHYs. PL based one
have separate EMIO lines via PL.
Also two USB 3.0 with usb hubs are present. USB phys and USB hubs should
have separate reset line. The first usb0 hub also has USB-SD controller
(usb2244) connected to port 0.
To test compatibility with k26 you can run:
fdtoverlay -o /tmp/output.dtb -i arch/arm/dts/zynqmp-sm-k26-revA.dtb \
arch/arm/dts/zynqmp-sck-kr-g-revA.dtbo
Also add support for kr260-revB board. Based on FRU it is revision B
but schematics can be label as revA03.
Changes in revB are:
- SFP light
- GEM2/3 TX_CLK fixes
- PMOD/RPI connector fixes
- Replace si5332 with oscilators
Link: https://lore.kernel.org/r/dac2ee1826e73b89c8cc1e430354eb43d291f675.1652870941.git.michal.simek@amd.com
Setup default values for debug console, base address and frequency.
Link: https://lore.kernel.org/r/ce93efd3ed67aa6390810ce0b79e0d00e7c36b4b.1652871485.git.michal.simek@amd.com
It is useful to get information about BL type and entry address that's why
add some debug messages.
Link: https://lore.kernel.org/r/fb023b618a009009a0b564c24223cadc10ced5b3.1652871741.git.michal.simek@amd.com
Add support to switch to EL1 and load an EL1 app from U-Boot which is
executing at EL2 or EL3 in aarch64 mode.
Link: https://lore.kernel.org/r/20220506055345.1921-1-ashok.reddy.soma@xilinx.com
Enable CONFIG_DM_ETH_PHY to utilize shared MDIO bus support on all xilinx
platforms.
Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com>
Acked-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
Link: https://lore.kernel.org/r/965981eb324d13a98aad8bd88eb8b50bc5147a7e.1652181968.git.michal.simek@amd.com
CONFIG_DM_ETH_PHY enables support to utilize generic ethernet phy
framework. Though if ethernet PHY node is in other ethernet node, it
will use shared MDIO to access the PHY of other ethernet. Move ethernet
print info statement from plat function to probe function, as phyaddr is
not enumerated when CONFIG_DM_ETH_PHY is enabled.
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
Link: https://lore.kernel.org/r/93e11ccca56b6e52b2dcc283d08d5042537f828f.1652181968.git.michal.simek@amd.com
Link: https://lore.kernel.org/r/ecfec78234233fefdc172c141c207b2d78ef70c5.1652181968.git.michal.simek@amd.com
This test was written to match up with the list of compatibles in
drivers/i2c/tegra_i2c.c so adding another one requires the test to be
updated to match.
Fixes: 0d2105ae5e32 ("arm: tegra: Update some DT compatibles")
Use device tree to set MAC address of the Ethernet chip.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Some of the DT compatibles have changed upstream so add new DT compatibles
to ensure things continue to keep working if the device trees are
updated.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Add new lines to make errorr messages easier to read.
