2016-02-06video: test: Adjust order of file closureSimon Glass
Close the file earlier to hopefully fix a Coverity error. Reported-by: Coverity (CID: 134901) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-06video: Use 'int' for loop variables instead of shortSimon Glass
Using short doesn't save anything and is confusing when the width and height variables are ulong. This may fix Coverity CID134902 but I doubt it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-06cmd: Fix control bmp_display()Simon Glass
All paths should share the same return. Reported-by: Coverity (CID:134903) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-06microblaze: Correct build error in eth-uclass.cSimon Glass
This fixes the following error when building microblaze-generic: net/eth-uclass.c: In function 'eth_post_probe': net/eth-uclass.c:466:18: error: 'gd' undeclared (first use in this function) ops->start += gd->reloc_off; Fixes: db9391e1 ("net: Move driver-model code into its own file") Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-02-04Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2016-02-04Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2016-02-04Revert "arm: socfpga: set the fpga global bit to disable HPS to FPGA signals"Dinh Nguyen
Apparently, the logic for the FPGA global bit is not universal between Gen5 and Gen10 devices is not the same. Disabling this bit, while applicable to Gen10 devices, will break FPGA programming on Gen5 devices. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2016-02-04usb: gadget: dwc2_udc_otg: modified the check condition for max packet size ↵Frank Wang
of ep_in in high speed In current high speed fastboot, fs_ep_in.wMaxPacketSize is configured 64 bytes as default, as a result, it failed to match the size at initialization stage in usb controller. Actually, hardware can support less than or equal to 512 bytes in high speed mode, so I changed the condition from '!=' to '>' to fix this issue. Signed-off-by: Frank Wang <frank.wang@rock-chips.com> Tested-by: Steve Rae <srae@broadcom.com>
2016-02-04imx: mx6: implement board_mmc_get_env_devPeng Fan
Implement board_mmc_get_env_dev for the boards. Following is examples: SD1/SD2/SD3: return devno; SD2/SD3: return devno - 1; SD2/SD4: if (devno == 2), return dev - 2; return dev - 1; Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-02-04imx: mx6: implement mmc_get_env_devPeng Fan
Implement mmc_get_env_dev, devno can be got from smbr1 of SRC. Introduce a weak function board_mmc_get_env_dev, different boards can implement it according to different sdhc controllers that used by the board. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-02-04imx: mx7dsabresd: move mmc_get_env_devno to soc codePeng Fan
Move mmc_get_env_devno to soc.c and rename to mmc_get_env_dev to match the one in common/env_mmc.c. Introduce a weak function board_mmc_get_env_dev. Different boards can implement this according to sdhc controller which is used by the board. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-02-02dm: vybrid_gpio: Drop legacy codeBhuvanchandra DV
All boards using this driver are with device tree support, hence drop the legacy code in driver to have a pure DT solution. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-02dm: lpuart: Drop the legacy codeBhuvanchandra DV
2016-02-02arm: vybrid: Drop enabling GPIO, SPI and UART in legacy modeBhuvanchandra DV
Remove the legacy way of enabling GPIO, SPI and UART on Vybrid based boards since these driver's now only supports DT mode. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-02arm: vybrid: Update defconfig'sBhuvanchandra DV
Let's go with pure DT solution for board's based on NXP/Freescale Vybrid platform. - Merge the DT defconfig with non-DT defconfig for Toradex Colibri VF50/VF61 and drop the non-DT defconfig. - Update the legacy defconfigs for NXP/Freescale VF610 Tower Board with DT. - Update the legacy defconfigs for Phytec phyCORE-vybrid Board with DT. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-02arm: pcm052: Add device tree file'sBhuvanchandra DV
- Add device tree files for Phytec phyCORE-Vybrid Board. - Enable lpuart support for Phytec phyCORE-Vybrid Board. - Use UART1 for stdout. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-02arm: vf610-twr: Add device tree file'sBhuvanchandra DV
- Add device tree files for NXP/Freescale VF610 Tower Board. - Enable lpuart support on NXP/Freescale VF610 Tower Board. - Use UART1 as stdout. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-02arm: colibri-vf: Enable serial supportBhuvanchandra DV
- Enable lpuart support on Toradex Colibri VF50/VF61 - Use UART0 for stdout. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-02arm: vybrid: Update the license stringBhuvanchandra DV
Since SPDX license is already there, drop the full one. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-02arm: vybrid: Enable lpuart supportBhuvanchandra DV
Add device tree node's for lpuart on Vybrid platform Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-02imx: mx6sxsabresd: Add MCIMX28LCD display supportYe Li
The i.MX6SX SABRESD board supports MCIMX28LCD (800x480x24) at LCDIF1 port, enable this display feature by adding relevant BSP codes and configurations. Signed-off-by: Ye Li <ye.li@nxp.com>
2016-02-02imx: mx6ul/sx: Fix issue in LCDIF clock dividers calculationYe Li
The checking with max frequency supported is not correct, because the temp is calculated by max pre and post dividers. We can decrease any divider to meet the max frequency limitation. Actually, the calculation below the codes is doing this way to find best pre and post dividers. Signed-off-by: Ye Li <ye.li@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-02-02imx: mx6sx: Fix issue in LCDIF clock enablementYe Li
Wrong checking for the base_addr paramter with LCDIF1 and LCDIF2. Always enter the -EINVAL return. Signed-off-by: Ye Li <ye.li@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-02-02mx6slevk: Remove CONFIG_ETHPRIME optionFabio Estevam
As mx6slevk has only one Ethernet port, we don't need to declare CONFIG_ETHPRIME, so just remove it. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-02imx: MX6DQ{P}/DL:SABRESD Fix bmode eMMC failureYe Li
The BOOTCFG value used by bmode for SABRESD eMMC boot are actually for SD card. Fixed the value to correct one. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-02tqma6_wru4: Fix the reset delay for the the LAN8720 PHYFabio Estevam
According to the LAN8720 datasheet tpurstd (time that reset line should stay asserted) is 25ms. So do as suggested by the LAN8720 datasheet. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-02mx6slevk: Fix the reset delay for the the LAN8720 PHYFabio Estevam
Since commit 59370f3fcd1350 ("net: phy: delay only if reset handler is registered") Ethernet is no longer functional. This commit does not have an issue in itself, but it revelead a problem with the Ethernet initialization. According to the LAN8720 datasheet tpurstd (time that reset line should stay asserted) is 25ms. So do as suggested in order to have Ethernet working again. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-02imx: mx6sxsabreauto: Add support for mx6sx SABREAUTO boardYe Li
Initial version for mx6sx SABREAUTO board support with features: PMIC, QSPI, NAND flash, SD/MMC, USB, Ethernet, I2C, IO Expander. Signed-off-by: Ye Li <ye.li@nxp.com>
2016-02-02mx6: soc: Add ENET2 mac address supportYe Li
The i.MX6SX and i.MX6UL has two ENET controllers, add support for reading MAC address from fuse for ENET2. Signed-off-by: Ye Li <ye.li@nxp.com>
2016-02-02tools: mxsboot: Use more portable cpu_to_le32()Bin Meng
Currently when building mxsboot on certain machines it reports: HOSTCC tools/mxsboot tools/mxsboot.c: In function 'mx28_create_sd_image': tools/mxsboot.c:560: warning: implicit declaration of function 'htole32' /tmp/cchLIV6q.o: In function 'main': mxsboot.c:(.text+0x6d8): undefined reference to 'htole32' mxsboot.c:(.text+0x6e7): undefined reference to 'htole32' mxsboot.c:(.text+0x6f6): undefined reference to 'htole32' mxsboot.c:(.text+0x705): undefined reference to 'htole32' mxsboot.c:(.text+0x711): undefined reference to 'htole32' /tmp/cchLIV6q.o:mxsboot.c:(.text+0x71d): more undefined references to 'htole32' follow collect2: ld returned 1 exit status make[1]: *** [tools/mxsboot] Error 1 make: *** [tools] Error 2 The solution is to use cpu_to_le32() instead which is more portable, just like other U-Boot tools [1] do. [1] http://lists.denx.de/pipermail/u-boot/2014-October/192919.html Suggested-by: Marek Vasut <marex@denx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2016-02-02wandboard: fix variable name so PXE boot worksPeter Robinson
All boards that support PXE booting use the pxefile_addr_r variable. Standardise wandboard with this variable as pxe_addr_r isn't used anywhere else so it's a typo. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-02-02arm: imx6: Enable DDR calibration on NovenaMarek Vasut
Enable the DDR calibration functionality on Novena to deal with the memory SoDIMM on this board. Moreover, tweak the initial DDR DRAM parameters so the calibration works properly. Signed-off-by: Marek Vasut <marex@denx.de>
2016-02-02arm: imx6: Add DDR3 calibration code for MX6 Q/D/DLMarek Vasut
Add DDR3 calibration code for i.MX6Q, i.MX6D and i.MX6DL. This code fine-tunes the behavior of the MMDC controller in order to improve the signal integrity and memory stability. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2016-02-02Prepare v2016.03-rc1v2016.03-rc1Tom Rini
2016-02-02Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2016-02-02Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-02-02board: atmel: sama5d2_xplained: add SPL supportWenyou Yang
The sama5d2 Xplained SPL supports the boot medias: spi flash and SD Card. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-02arm: at91/spl: mpddrc: use IP version to check configurationWenyou Yang
To remove the unnecessary #ifdef-endif, use the mpddrc IP version to check whether or not the interleaved decoding type is supported. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-02arm: at91/spl: mpddrc: add mpddrc DDR3-SDRAM initializationWenyou Yang
The DDR3-SDRAM initialization sequence is implemented in accordance with the DDR3-SRAM/DDR3L-SDRAM initialization section described in the SAMA5D2 datasheet. Add registers and definitions of mpddrc controller, which is used to support DDR3 devices. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-02arm: at91/spl: mpddrc: add struct atmel_mpddrc_configWenyou Yang
Add struct atmel_mpddrc_config to accommodate the mpddrc register configurations, not using the mpddrc register map structure, struct atmel_mpddrc, in order to increase readability and reduce run-time memory use. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-02atmel_nand: Add 32 bit ecc support for sama5d2 chipJosh Wu
Also if minimum ecc requirment is bigger then what we support, then just use our maxium pmecc support. But it is not safe, so we'll output a warning about this. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-02atmel_nand_ecc: update pmecc registers according to sama5d2 chipJosh Wu
1. add the pmecc register mapping for sama5d2. 2. add the pmecc error location register mapping for sama5d2. 3. add some new field that is different from old ip. 4. add sama5d2 pmecc ip version number. Signed-off-by: Josh Wu <josh.wu@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-01Makefile: Drop unnecessary -dtb suffixesSimon Glass
When OF_CONTROL is enabled, u-boot-dtb.* files are the same as u-boot.* files. So we can use the latter for simplicity. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01Makefile: Make u-boot.img the same as u-boot-dtb.imgSimon Glass
Create u-boot.img even when OF_CONTROL is enabled, so that this file can be used in both cases. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01socfpga: Simplify Makefile filenamesSimon Glass
We don't need the -dtb suffix anymore, so drop it. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01tegra: Always build a boot image with the same filenameSimon Glass
Adjust the Makefile to build u-boot-tegra.bin which contains a device tree if OF_SEPARATE is enabled, and does not if not. This mirrors U-Boot's new approach of using u-boot.bin to handle both cases. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01fdt: Build an SPL binary without device treeSimon Glass
At present u-boot-spl.bin holds the plain SPL binary without the device tree. This is somewhat annoying since you need either u-boot-spl.bin or u-boot-spl-dtb.bin depending on whether device tree is used. Adjust the build such that u-boot-spl.bin includes a device tree (if enabled), and the plain binary is in u-boot-spl-nodtb.bin. For now u-boot-spl-dtb.bin remains the same. Tested-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01fdt: Build a U-Boot binary without device treeSimon Glass
At present u-boot.bin holds the plain U-Boot binary without the device tree. This is somewhat annoying since you need either u-boot.bin or u-boot-dtb.bin depending on whether device tree is used. Adjust the build such that u-boot.bin includes a device tree (if enabled), and the plain binary is in u-boot-nodtb.bin. For now u-boot-dtb.bin remains the same. This should be acceptable since: - without OF_CONTROL, u-boot.bin still does not include a device tree - with OF_CONTROL, u-boot-dtb.bin does not change The main impact is build systems which are set up to use u-boot.bin as the output file and then add a device tree. These will have to change to use u-boot-nodtb.bin instead. Adjust tegra rules so it continues to produce the correct files. Tested-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01tegra: Clarify generation of -nodtb file with OF_CONTROLSimon Glass
Fix the ALL-y logic in the Makefile so that is clear that we always want the -nodtb file. Tested-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
