Add support for storing configuration for Apalis iMX8X SoM
in Toradex config block.
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Synchronise with latest linux-next kernel pin func header file.
- 2 FAT fixes.
- MediaTek ethernet support improvement.
- Initial Cortina Access CAxxxx family support.
- Correct return value of do_gpio() and so gpio shell command.
Add basic Presidio G3 engineering board support
Signed-off-by: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
Add serial UART driver support for all Cortina Access
CAxxxx family of SoCs.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Jason Li <jason.li@cortina-access.com>
Add support for hardware watchdog timer on all Cortina Access
DM_GPIO based GPIO controller driver for CAxxxx SoCs.
This driver support multiple CPU architectures and
Cortina Access SoC platforms.
The Cortina CAxxxx GPIO driver maintains DM_GPIO support
across different CPU ISA in the CAxxxx Soc Family; Not just ARM.
Therefore, it is not desirable to split out and maintain separete
gpio header file for each CPU architecture.
Assign Alex Nemirovsky as custodian for all
Cortina Access (CA) for ARM and MIPS based SoCs.
Currently Cortina Access CAxxxx family of SoCs support both
ARM and MIPS ISA. Drivers have cross platform support for
both architectures.
To match the other PowerPC platforms the function show_regs() must not
be marked static but instead be an exposed global function.
Cc: Christophe Leroy <christophe.leroy@c-s.fr>
Acked-by: Christophe Leroy <christophe.leroy@c-s.fr>
Based on reading the text of the license comment this appears to be
the BSD-2-Clause license but with an imperfect word match as
BSD-2-Clause was not (as far as I recall) a common license choice at the
time the code was written.
This patch enable mt7622 ethernet support in its defconfig
Signed-off-by: MarkLee <Mark-MC.Lee@mediatek.com>
building mtk ethernet driver for aarch64 (mt7622) results
in warnings/errors
"error: cast from pointer to integer of different size"
Fixes: 23f17164d9 ("ethernet: MediaTek: add ethernet driver for MediaTek ARM-based SoCs")
Signed-off-by: Frank Wunderlich <frank-w@public-files.de>
This patch add eth and sgmii dts node for mt7622 to support ethernet
This patch add mt7622 support in mediatek eth driver
This patch add sgmii init part for the mediatek SoC that
support sgmii mode. It is a must for mt7622.
The code for handing file overwrite incorrectly calculated the amount of
data to write when writing to the last non-cluster aligned chunk. Fix
this by ensuring that no more data than the 'filesize' is written to disk.
While touching min()-based calculations, change it to type-safe min_t()
function.
This patch finally fixes the issue revealed by the test script from the
previous patch. The correctness of the change has been also verified by
the following additional test scripts:
--->8-fat_test2.sh---
#!/bin/bash
make sandbox_defconfig
make
dd if=/dev/zero of=/tmp/10M.img bs=1024 count=10k
mkfs.vfat -v /tmp/10M.img
cat >/tmp/cmds <<EOF
x
host bind 0 /tmp/10M.img
fatls host 0
mw 0x1000000 0x0a434241 0x1000 # "ABC\n"
mw 0x1100000 0x0a464544 0x8000 # "DEF\n"
fatwrite host 0 0x1000000 file0001.raw 0x1000
fatwrite host 0 0x1000000 file0002.raw 0x1000
fatwrite host 0 0x1000000 file0003.raw 0x1000
fatwrite host 0 0x1000000 file0004.raw 0x1000
fatwrite host 0 0x1000000 file0005.raw 0x1000
fatrm host 0 file0002.raw
fatrm host 0 file0004.raw
fatls host 0
fatwrite host 0 0x1100000 file0007.raw 0x2000
fatwrite host 0 0x1100000 file0007.raw 0x1f00
reset
EOF
./u-boot </tmp/cmds
#verify
rm -r /tmp/result /tmp/model
mkdir /tmp/result
mkdir /tmp/model
yes ABC | head -c 4096 >/tmp/model/file0001.raw
yes ABC | head -c 4096 >/tmp/model/file0003.raw
yes ABC | head -c 4096 >/tmp/model/file0005.raw
yes DEF | head -c 7936 >/tmp/model/file0007.raw
mcopy -n -i /tmp/10M.img ::file0001.raw /tmp/result
mcopy -n -i /tmp/10M.img ::file0003.raw /tmp/result
mcopy -n -i /tmp/10M.img ::file0005.raw /tmp/result
mcopy -n -i /tmp/10M.img ::file0007.raw /tmp/result
hd /tmp/10M.img
if diff -urq /tmp/model /tmp/result
then
echo Test okay
else
echo Test fail
fi
--->8-fat_test3.sh---
#!/bin/bash
make
x
fatls host 0
fatls host 0
fatwrite host 0 0x1100000 file0007.raw 0x2100
reset
EOF
./u-boot </tmp/cmds
#verify
mkdir /tmp/result
mkdir /tmp/model
yes DEF | head -c 8448 >/tmp/model/file0007.raw
hd /tmp/10M.img
then
echo Test okay
else
echo Test fail
fi
--->8-fat_test4.sh---
#!/bin/bash
make
x
fatls host 0
mw 0x1200000 0x0a494847 0x8000 # "GHI\n"
fatls host 0
fatwrite host 0 0x1100000 file0007.raw 0x900
fatwrite host 0 0x1200000 file0007.raw 0x900 0x900
fatwrite host 0 0x1100000 file0007.raw 0x900 0x1200
fatwrite host 0 0x1200000 file0007.raw 0x900 0x1b00
reset
EOF
./u-boot </tmp/cmds
#verify
mkdir /tmp/result
mkdir /tmp/model
yes DEF | head -c 2304 >/tmp/model/file0007.raw
yes GHI | head -c 2304 >>/tmp/model/file0007.raw
yes DEF | head -c 2304 >>/tmp/model/file0007.raw
hd /tmp/10M.img
then
echo Test okay
else
echo Test fail
fi
--->8---
Feel free to prepare a proper sandbox/py_test based tests based on
the provided test scripts.
The code for handing file overwrite incorrectly assumed that the file on
disk is always contiguous. This resulted in corrupting disk structure
every time when write to existing fragmented file happened. Fix this
by adding proper check for cluster discontinuity and adjust chunk size
on each partial write.
This patch partially fixes the issue revealed by the following test
script:
--->8-fat_test1.sh---
#!/bin/bash
make
x
fatls host 0
fatls host 0
fatwrite host 0 0x1100000 file0007.raw 0x4000
reset
EOF
./u-boot </tmp/cmds
#verify
mkdir /tmp/result
mkdir /tmp/model
yes DEF | head -c 16384 >/tmp/model/file0007.raw
hd /tmp/10M.img
then
echo Test okay
else
echo Test fail
fi
--->8---
Overwritting a discontiguous test file (file0007.raw) no longer causes
corruption to file0003.raw, which's data lies between the chunks of the
test file. The amount of data written to disk is still incorrect, what
causes damage to the file (file0005.raw), which's data lies next to the
test file. This will be fixed by the next patch.
Feel free to prepare a proper sandbox/py_test based tests based on the
Use the correct return value in function do_gpio() and update
commands documentation with the return values from command_ret_t enum.
CMD_RET_SUCCESS is returned on command success and CMD_RET_FAILURE is
returned on command failure.
The command was returning the pin value, which caused confusion when
debugging (#define DEBUG).
Signed-off-by: Luka Kovacic <luka.kovacic@sartura.hr>
Tested-by: Robert Marko <robert.marko@sartura.hr>
Update to a newer Docker image that contains SDL2 libraries as required
by recent Sandbox changes.
Use the same logic from 24df1b14f3ab to use our own GRUB binaries in
Azure pipelines as well.
Up to now we have been relying on openSUSE repositories for GRUB on arm and
arm64 though we have included GRUB in our Docker image.
Use the GRUB included in our Docker image.
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-04-rc2
Fix pylint issues in Python based tests.
- Gen 5 and Watchdog fixes
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
- Bug fixes on ls1012a, ls1021a, ls1028ardb platforms Integrate fspi for
ls1028a, add DM-I2C support, update secure boot header offset
https://gitlab.denx.de/u-boot/custodians/u-boot-raspberrypi
- DFU support file operations lager then the default max size
- add dfu support to dwc2 for bcm2835
- enable DFU for RPi4
- Fix RPi4 memory map to include the genet device
- add driver for the genet ethernet device
- enable network support in RPi4 config
Fix pylint warnings:
* add missing module and function documentation
* correct indentation
Fix warnings issued by pylint:
* naming of variables
* usage of commas and semicolons
* indentation
* placement of module description
Add DDR2 support to Gen5 DRAM driver. As the DDR2 macro names generated
by Quartus are named differently than the DDR3 ones, use anon unions to
store them in the same structures, without growing their size.
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Add optional support for fetching watchdog clock rate from DT
and ungating reset via reset framework. This is optional as not
all platforms using DW WDT support the clock and reset frameworks
yet.
Cc: Chin Liang See <chin.liang.see@intel.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Philipp Tomisch <philipp.tomisch@theobroma-systems.com>
Cc: Tien Fong Chee <tien.fong.chee@intel.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # roc-rk3399-pc
Convert the designware watchdog timer driver to DM and add DT probing
support. Perform minor coding style clean up, like drop superfluous
braces. These ought to be no functional change.
- Various minor fixes for x86
- Switch to ACPI mode on Intel edison
- Support run-time configuration for NS16550 driver
- Update coreboot and slimbootloader serial drivers to use NS16550
- ICH SPI driver fixes to hardware sequencing erase case
- Move ITSS from Apollo Lake to a more generic location
- Intel GPIO driver bug fixes
- Move to vs2017-win2016 platform build host for Azure pipelines
https://gitlab.denx.de/u-boot/custodians/u-boot-ti
- DFU boot support for J721e
- I2C support for J721e
- GPIO support for J721e
- Android boot image updates on AM57XX
- OMAP watchdog fixes
Inside Kconfig we must not use the CONFIG_ prefix with the imply statement.
Fixes: 28e3c39e535b ("board: freescale: ls1012a2g5rdb: enable network
support on ls1012a2g5rdb")
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Updates the secure boot headers offsets of Kernel and other
firmware images for SD and NOR boot sources used by
esbc_validate command.
Signed-off-by: Priyanka Singh <priyanka.singh@nxp.com>
firmware images for SD and QSPI boot sources used by
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
firmware images for SD and XSPI boot sources used by
firmware images used by esbc_validate command.
The default reserved memory for CMA is high memory. If LPAE is enabled,
highmem pages are non-remapped and can not be used with
dma_alloc_coherent. This patch will reserve low memory for CMA and fix
the issue on LS1021A.
Signed-off-by: Peng Ma <peng.ma@nxp.com>
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Signed-off-by: Alison Wang <alison.wang@nxp.com>
This supports i2c DM and enables CONFIG_DM_I2C
for SoC LS1021A
Signed-off-by: Biwen Li <biwen.li@nxp.com>
for SoC LS1012A
The default value of CONFIG_SYS_MALLOC_F_LEN (0x400)
leaves U-Boot with not enough memory to load i2c driver
before relocate, causing it to hang.
Change the default value of CONFIG_SYS_MALLOC_F_LEN
for below SoCs,
- LS1012A
- LS1021A
- LS1043A
- LS1046A
This adds DM_FLAG_PRE_RELOC flag to probe i2c driver
before relocation
Fix below SPL build error when DM_I2C is enabled,
- arch/arm/cpu/armv8/built-in.o: In function `board_init_f:
arch/arm/cpu/armv8/fsl-layerscape/spl.c:74: undefined reference to `i2c_init_all'
arch/arm/cpu/armv8/fsl-layerscape/spl.c:74:(.text.board_init_f+0x30):
relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol
`i2c_init_all'
make[2]: *** [spl/u-boot-spl] Error 1
make[1]: *** [spl/u-boot-spl] Error 2
make: *** [sub-make] Error 2
arch/arm/cpu/armv8/fsl-layerscape/spl.c: In function 'board_init_f':
arch/arm/cpu/armv8/fsl-layerscape/spl.c:74:2: warning: implicit
declaration of function 'i2c_init_all'; did you mean 'misc_init_r'?
[-Wimplicit-function-declaration]`
Add support of driver model of pcf8563
Enable FSPI controller support. So, flash environment can now be used
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
Align flexspi node properties with linux device-tree properties
Tested on LX2160A-RDB
