For some CPUs, having malloc() available very early is useful. There is no
reason to delay this since early malloc is allocated before board_init_f()
is called.
Move early malloc() init nearer to the start of the init sequence.
This warning appears even though it seems that the compiler could work it
out. Fix it.
Return the saved TSC frequency in get_tbclk_mhz().
Use the same way that Linux does for quick TSC calibration via PIT
when calibration via MSR fails.
Using MSR_PLATFORM_INFO (0xCE) to calibrate TSR will cause #GP on
processors which do not have this MSR. Instead only doing the MSR
calibration for known/supported CPUs.
The CPU identification happens in x86_cpu_init_f() and corresponding
fields are saved in the global data for later use.
The built in self test value is available in register eax on start-up. Save
it so that it can be accessed later. Unfortunately we must wait until the
global_data is available before we can do this, so there is a little bit of
shuffling to keep it around.
Some functions are missing prototypes. Fix those that are specific to x86.
Instead of an x86-specific cpu_init_f() function, use the normal U-Boot one
for this purpose. Also remove a useless/misleading comment.
Instead of having an x86-specific DRAM init function, adjust things so we
can use the normal one.
This code is a little muddled, so tidy it up. Make sure that we put the
GDT in the right place and set it up properly.
We should invalidate the TLB right at the start to ensure that we don't get
false address translations even though paging is disabled.
This allows a board to do very early init, but no boards need to do this.
We may as well drop this feature.
This was missed when the real mode support was dropped. Remove it.
When an MPC5200 based board is used with SPL support, the main
U-Boot needs to clear the GD (global data) struct again.
Otherwise the generic board init code in board_init_f (when
CONFIG_SYS_GENERIC_BOARD is defined) will not initialize all
GD variables correctly. Resulting in a hangup on the a4m2k
board.
a3m071 and a4m2k share one config header. So adding the generic board defines
in this one file is enough to convert both boards.
The gdsys hrcon board is based on a Freescale MPC8308 SOC.
It boots from NOR-Flash, kernel and rootfs are stored on
SD-Card.
On board peripherals include:
- 1x GbE (optional)
- Lattice ECP3 FPGA connected via eLBC and PCIe
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Wolfgang Denk found this issue using cppcheck:
(error) Uninitialized variable: fpga_features
Addressing was completely broken for cmd_fpgad.
The device id makes u-boot think that this chip needs
cfi_reverse_geometry(), which is not the case.
Add it to jedec_flash, so it is handled properly.
Tune dlvision configuration similar to other gdsys boards to reduce memory
footprint.
The UBI layer will disable much of its error reporting when it is
compiled into the linux kernel to avoid stopping boot. We want this
error reporting in U-Boot since we don't initialize the UBI layer until
it is used and want the error reporting.
We force this by telling the UBI layer we are building as a module.
Signed-off-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
Cc: Kyungmin Park <kmpark@infradead.org>
ff94bc40af3481d47546595ba73c136de6af6929 "mtd, ubi, ubifs: resync with Linux-3.14"
introduced the writebufsize field in struct mtd_info, which
is not initialized in the cfi_flash driver, which leads in
not working ubi on cfi flashes. Fix it
Reported-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
Acked-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
The code for this board supports following features:
- Boot media support: NAND flash/SD card/SPI flash
- Support LCD display (optional, disabled by default)
- Support ethernet
- Support USB mass storage
Signed-off-by: Bo Shen <voice.shen@atmel.com>
- Support ethernet
The User Register in GMAC IP is used to select interface type.
When with GE feature, it is used to select interface between
RGMII and GMII. If without GE feature, it is used to select
interface between MII and RMII.
As in SAMA5D4 SoC, the gf table in ROM code can not be seen.
So, when we try to use PMECC, we need to build it when do
initialization.
Add a macro NO_GALOIS_TABLE_IN_ROM in soc header file. If it
is defined we will build gf table runtime.
The PMECC use the BCH algorithm, so based on the build_gf_tables()
function in lib/bch.c, we can build the Galois Field lookup table.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
replaces the at91bootstrap code with SPL code.
make the spl image with:
./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin
this writes the length of the spl image into the 6th
execption vector. This is needed from the ROM bootloader.
Reviewed-by: Bo Shen <voice.shen@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
add support for using spl code on at91sam9260 and at91sam9g45
based boards.
[adopt Bo's change in spl.c]
device ready pin is signalling that the device is ready on state 1
not on 0. Simmiliar as it is in drivers/mtd/nand/nand_spl_simple.c
Acked-by: Scott Wood <scottwood@freescale.com>
erase one nand block in spl code. keep it simple, as size matters
This is used on the upcoming taurus spl support.
using this driver in SPL code with CONFIG_SPL_NAND_ECC
configured leads in an compileerror. Fix this.
[fix subject]
enable to boot only a raw u-boot.bin image from nand with the
CONFIG_SPL_NAND_RAW_ONLY define. This option saves space on
boards where spl space is low.
- compile mpddrc ram init code also for AT91SAM9M10G45
based boards.
- in CONFIG_SAMA5D3 case, look for the ATMEL_MPDDRC_CR_DECOD_INTERLEAVED
in the cr configuration
use the configure value for computing the ba_off value
not the value from the cr register. This leaded in a
wrong ram configuration on the upcoming corvus spl board
support.
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
move CONFIG_SYS_SPI_WRITE_TOUT into drivers/spi/atmel_spi.h
and define a default value. Delete this define in the board
config files, where it is possible (all boards use currently
the same value).
generate the boot.bin file for all atmel SoC (arm920, arm926, armv7)
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
[fix subject]
The clock source for master clock can be slow clock, main clock,
plla clock or upll clock. So, make the clock source selection
field in mckr can be configured.
We need to make sure the main clock ready field in MCFR is set
after switch to main crystal oscillator.
When boot up without mac address setting, it will give the warning
message like: "Warning: failed to set MAC address", however when
execute network related command, it still execute them without any
warning information.
With this patch, it will exit directly with following information:
"gmac0: mac address is not valid"
It also solve the problem after bootup then set mac address and the
mac address won't set to net device issue.
Tested-by: Boris Brezillon <boris.brezillon@free-electrons.com>
