The problem here is that uboot can't mount ext4 filesystem with
commit "50ce4c07df1" applied. We use hard-coded "SECTOR_SIZE"(512)
before this commit, now we introduce (block_dev_desc_t *)->log2blksz
to replace this macro. And after we calling do_ls()->fs_set_blk_dev(),
the variable log2blksz is not initialized, which it's not correct.
And this patch try to solve the problem by caculating the value of
log2blksz from variable blksz.
Fix reading ext4_extent_header struture on BE machines. Some 16 bit
fields where converted to 32 bit fields, due to the byte swap on BE
machines the containing value was corrupted. Therefore reading ext4
filesystems on BE machines where broken before.
Signed-off-by: Rommel Custodio <sessyargc+uboot@gmail.com>
[sent via git-send-email; rework commit message]
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
As both the DDR SDRAM and NAND flash connect to EBI on at91sam9n12
and share the lower 8 bits data line. If use low drive of the data
line, it will cause DDR data access corrupt in lower address, so
change the data line to high drive mode
This will fix the Linux kernel boot issue when use Lower address
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
The old value of 0x000e0030 will cause ethernet
timeout issues on the sabrelite and possibly other
boards using the KSZ9021.
I have no explanation as to why.
But this is a correct change, the TRM will be updated
to show that 00b is the only valid setting for bits
19-18 of DRAM_RESET.
My thanks go to Liu Hui(Jason) for this information.
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Commit de1d786e (add support for Xilinx 1000BASE-X phy (GTX)) introduced the
checking for ESTATUS_1000_XHALF, but it incorrectly sets the
SUPPORTED_1000baseX_Full flag in this case.
Set the SUPPORTED_1000baseX_Half flag instead.
Acked-by: Charles Coldwell <coldwell@gmail.com>
Reviewed-By: Sascha Silbe <t-uboot@infra-silbe.de>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
de1d786 [add support for Xilinx 1000BASE-X phy (GTX)] introduced a
check for the extended status register in order to support
1Gbps-capable PHYs that don't have the 1000BASE-T registers. Since
Extended Status only indicates what the PHY (i.e. the local side) is
capable of, this broke communication with non-1Gbps peers.
Only check the extended status if the 1000BASE-T registers are
actually missing so we don't end up setting speed to 1Gbps even though
the previous test (for the combination of local and peer support for
1Gbps) already indicated we can't do 1Gbps with the current peer.
Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
The value of this config variable is not available to image.h on the host,
since the board config is not actually included. Bring this in so that
mkimage will be built with image-signing support for sandbox at least.
Missing space for loaddtb command has been added. When missing, ext4load
fails with wrong number of passed parameters.
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Before the bootm refactor, fixup_silent_linux() was done only in the
monolithic bootm case, not in the subcommand case. With the refactor, it
is done always, which is good. Unfortunately it is done too late, since it
is the PREP or CMDLINE stages that set up the command line for Linux.
Move fixup_silent_linux() into the LOADOS stage, which is where we find
out the OS being used, and can thus decide whether to perform this step.
commit 54965b61360 (README: mxs: Introduce README.mxs) should have changed the
file name to README.mxs, as it covers both mx23 and mx28 now.
Dealing with the sys ctrl register should touch only the
relevant bits and not accidently the whole register. On i.MX6,
the sys control register contains bits which shouldn't be reset to
0, e.g. SYS_CTRL[3-0] and IPP_RST_N (SYS_CTRL[23]).
Do this by read/modify/write instead of just a 32bit write.
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
1. No contents of "asm/arch/clk.h" is used within "dw_mmc.c".
2. If arch doesn't have "asm/arch/clk.h" driver won't build.
Without mentioned inclusion dw_mmc driver could be built for arches
other than ARM. For ARM driver still builds without it.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Mischa Jonker <mjonker@synopsys.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Cc: Amar <amarendra.xt@samsung.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Fill the right command type when using CMD12 to stop data transfer.
Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com>
CC: Fleming Andrew-AFLEMING <AFLEMING@freescale.com>
CC: Scott Wood <scottwood@freescale.com>
CONFIG_SPL_BUILD creates debug TLB entry, so disable it before init_tlbs.
CONFIG_SPL_INIT_MINIMAL never creates any debug TLB entry, so no need
of disable_tlb().
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
The gdsys ControlCenter Digital board is based on a Freescale P1022 QorIQ SOC.
It boots from SPI-Flash but can be configured to boot from SD-card for
factory programming and testing.
On board peripherals include:
- 2x GbE
- Lattice ECP3 FPGA connected via PCIe
- mSATA RAID1
- USB host
- DisplayPort video output
- Atmel TPM
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc>
MAKEALL is fine for ppc4xx and mpc85xx.
Run checks were done on our controlcenterd hardware.
Add support for Atmel TPM devices with two wire interface.
if alen is 0: no longer start a write cycle before reading data.
Acked-by: Heiko Schocher <hs@denx.de>
Extend the tpm library with support for single authorized (AUTH1) commands
as specified in the TCG Main Specification 1.2. (The internally used helper
functions are implemented in a way that they could also be used for double
authorized commands if someone needs it.)
Provide enums with the return codes from the TCG Main specification.
For now only a single OIAP session is supported.
OIAP authorized version of the commands TPM_LoadKey2 and TPM_GetPubKey are
provided. Both features are available using the 'tpm' command, too.
Authorized commands are enabled with CONFIG_TPM_AUTH_SESSIONS. (Note that
this also requires CONFIG_SHA1 to be enabled.)
Acked-by: Che-Liang Chiou <clchiou@chromium.org>
Before setting: mipi_lcd_device.reverse_panel = 1, the Trats's LCD panel
was flipped by 180 degrees.
The flip was caused by following change:
Exynos: Change get_timer() to work correctly
SHA1: 3d00c0cb96ff93a929700b80d89cb905e5ab5315
This commit fixed udelay(), which is necessary (due to HW LCD controller
oddity) for mipi-dsi correct operation. As a result the display orientation
has been switched.
As a follow up, the hwrevision() function has been removed, since it was
used only in this particular place.
Test HW: Trats Exynos4210 rev 0.
Provide proper setting for the APLL fout frequency calculation for
Exynos4 based targets (especially Exynos4210 - Trats board).
Fix:
mpc8323erdb.c: In function 'mac_read_from_eeprom':
mpc8323erdb.c:198:3: warning: dereferencing type-punned pointer will
break strict-aliasing rules [-Wstrict-aliasing]
cc: Timur Tabi <timur@tabi.org>
cc: Kim Phillips <kim.phillips@freescale.com>
With CONFIG_SYS_64BIT_LBA, lbaint_t gets defined as a 64-bit type,
which is required to represent block numbers for storage devices that
exceed 2TiB (the block size usually is 512B), e.g. recent hard drives
We now use lbaint_t for partition offset to reflect the lbaint_t change,
and access partitions beyond or crossing the 2.1TiB limit.
This required changes to signature of ext4fs_devread(), and type of all
variables relatives to block sector.
ext2/ext4 fs uses logical block represented by a 32 bit value. Logical
block is a multiple of device block sector. To avoid overflow problem
when calling ext4fs_devread(), we need to cast the sector parameter.
Signed-off-by: Frédéric Leroy <fredo@starox.org>
Some ARM compilers may emit code that makes unaligned accesses when
faced with constructs such as:
char name[12] = "bootmenu_";
same fix as commit: 064d55f8bc8d7d205ed0be6abb6717e92eeb7cad
data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<3ff4b60c>] lr : [<3ff4b7b0>]
sp : 3f346a58 ip : 3ff9c8e6 fp : 02000060
r10: 00000000 r9 : 3df47fc0 r8 : 3f347f40
r7 : 00000000 r6 : 00000000 r5 : 00000003 r4 : 3f759140
r3 : 000003f0 r2 : 00000000 r1 : 000003f1 r0 : 00000000
Flags: nzCv IRQs on FIQs off Mode SVC_32
Resetting CPU ...
Signed-off-by: Lan Yixun (dlan) <dennis.yxun@gmail.com>
"cramfsload uImage_1" succeeds even though the actual file is named
"uImage".
Fix file name comparison when one name is the prefix of the other.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Wolfgang Denk <wd@denx.de>
cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
adjust instructions for the invocation of Patman's self test: the -t
flag appears to have a different meaning now, refer to the --test option
for the builtin unit test; adjust a directory location and make sure to
run the file which resides in the source directory
Signed-off-by: Gerhard Sittig <gsi@denx.de>
The block device expects to see lbaint_t for the blknr parameter. Change
the SCSI read/write functions to suit.
This fixes the following build warnings for coreboot:
cmd_scsi.c: In function ‘scsi_scan’:
cmd_scsi.c:119:30: error: assignment from incompatible pointer type [-Werror]
cmd_scsi.c:120:32: error: assignment from incompatible pointer type [-Werror]
The files board/qi/qi_lb60/qi_lb60.c and include/configs/qi_lb60.h were
licensed under the GPL v3 or later, and not v2 or later. As this is
incompatible with the project, revert this board support until the
responsible parties are available to re-license (if so desired) under
GPL v2.
A recent bootm fix left the error path incomplete. If CONFIG_TRACE is
set it may still not be a supported command, so cover that with the
unsupported subcommand print. Once we handle BOOTM_STATE_OS_GO, we can
just move into the error handler itself, no need for a goto there.
[trini: Update slightly based on Simon's changes to also cover
CONFIG_TRACE/BOOTM_STATE_FAKE_OS_GO]
The driver triggered a BUG() in nand_base.c:3214/nand_scan_tail()
because the ecc.strength was not set in NAND_ECC_HW_SYNDROME ECC
mode.
Cc: Benoit Thebaudeau <benoit.thebaudeau@advansee.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
A FIT image with a ramdisk that sets the entry or load points to 0x0
must be treated as meaning "leave in place" and NOT "relocate to 0x0".
This regression was introduced in a51ec63.
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and
serial.
The arguments were out of place since commit 983c72f, since this file was
missed and not tested. Correct this.
If a specific configuraion is selected by the bootm command, e.g. with
'bootm 84000000#recoveryconf' we must honour this for not just the kernel,
but also the ramdisk and FDT.
In the conversion to using a common fit_image_load() function for loading
images from FITs (commits a51ec63 and 53f375f) this feature was lost.
Reinstate it by passing the selected configuration back from
fit_image_load() to boot_get_kernel(), then use this configuration
(which is stored in images->fit_uname_cfg) in both boot_get_ramdisk()
and boot_get_fdt().
The OS function is now always called with the PREP stage. Adjust the
remaining bootm OS functions to deal with this correctly.
This is not needed as we already print 'OK' later in all cases.
With ELDK4.2 we were getting a warning that load_end may be used
uninitialized in calling lmb_reserve. This could not be the case,
however. If we re-order the checks (and make them slightly clearer as
well) the warning goes away. bootm_load_os may only return 0 on
success, BOOTM_ERR_OVERLAP in a non-fatal overlap (already covered in
comments) or a fatal BOOTM_ERR that is covered in the error handler.
OpenEmbedded has change partitioning layout of generated image so it
does not raise warnings during the boot regarding unkown partition
being used for U-Boot.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Jason Liu <r64343@freescale.com>
The MX28 multi-layer AHB bus can be too slow and trigger the
FEC DMA too early, before all the data hit the DRAM. This patch
ensures the data are written in the RAM before the DMA starts.
Please see the comment in the patch for full details.
This patch was produced with an amazing help from Albert Aribaud,
who pointed out it can possibly be such a bus synchronisation
issue.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Tested-by: Alexandre Pereira da Silva <aletes.xgr@gmail.com>
Remove incorrectly called and duplicate flush_dcache_range() call
from fec_mxc driver. The call is not needed, since the caches are
already flushed in fec_tbd_init(), moreover the second argument should
be the ending address, not size.
Reported-by: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
