The board uses lane 1 of SERDES for USB. Set the mux
accordingly.
The USB controller and EVM supports super-speed for USB0
on the Type-C port. However, the SERDES has a limitation
that upto 2 protocols can be used at a time. The SERDES is
wired for PCIe, eDP and USB super-speed. It has been
chosen to use PCIe and eDP as default. So restrict
USB0 to high-speed mode.
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Signed-off-by: Ravi Gunasekaran <r-gunasekaran@ti.com>
Configure first lane to PCIe, the second lane to USB and the last two lanes
to eDP. Also, add sub-nodes to SERDES0 DT node to represent SERDES0 is
connected to PCIe.
Add dt node for the single instance of WIZ (SERDES wrapper) and
SERDES module shared by PCIe, eDP and USB.
Add support for single instance of USB 3.0 controller in J721S2 SoC.
Add support for j721s2-wiz-10g device to use clock-names interface
instead of explicitly defining clock nodes within device tree node.
Reviewed-by: Roger Quadros <rogerq@kernel.org>
During refactor this seemed to have been missed.
Fixes: 3e85631db7c5 ("include: environment: ti: Use .env for environment variables")
Signed-off-by: Manorit Chawdhry <m-chawdhry@ti.com>
Enable DMA and CPSW options we now support for the am62ax SoC family
Signed-off-by: Bryan Brattlof <bb@ti.com>
Enable CPSW3G MAC Port 1 at U-Boot stage.
Since the MDIO driver is not DM enabled, add the MDIO pinctrl in the
cpsw3g device-tree node as a HACK.
Signed-off-by: Siddharth Vadapalli <s-vadapalli@ti.com>
Add CPSW device-tree nodes to support Ethernet at U-Boot stage.
In preparation for enabling ethernet for the am62ax family of SoCs,
introduce the initial DMA channel settings for the am62ax
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
[bb@ti.com: expanded on commit message]
J721E and J7200 have same file j721e_init.c which had the firewall
configs for J721E being applied on J7200 causing the warnings. Split the
firewalls for both the boards to remove those warnings.
commit 77df85c48537faade5648b314baeff2259787ee8 upstream
Currently, name_fdt is not set for J7200, fix this so right DTB is
picked during boot.
Signed-off-by: Neha Malcom Francis <n-francis@ti.com>
This reverts commit 07e8de1a2cd2f4e341ebc53fc8bdacc3f9954f22.
Unfortunately this commit breaks the jump to ATF for the GP variant of
the am62x family of SoCs.
Signed-off-by: Praneeth Bajjuri <praneeth@ti.com>
On K3 HS-SE devices all the firewalls are locked by default
until sysfw comes up. Rom configures some of the firewall for its usage
along with the SRAM for R5 but the PSRAM region is still locked.
The K3 MCU Scratchpad for j784s4 was set to a PSRAM region triggering the
firewall exception before sysfw came up. The exception started happening
after adding multi dtb support that accesses the scratchpad for reading
EEPROM contents.
Old map:
┌─────────────────────────────────────┐ 0x41c00000
│ SPL │
├─────────────────────────────────────┤ 0x41c61f20 (approx)
│ STACK │
├─────────────────────────────────────┤ 0x41c65f20
│ Global data │
│ sizeof(struct global_data) = 0xd8 │
├─────────────────────────────────────┤ gd->malloc_base = 0x41c66000
│ HEAP │
│ CONFIG_SYS_MALLOC_F_LEN = 0x10000 │
├─────────────────────────────────────┤ CONFIG_SPL_BSS_START_ADDR
│ SPL BSS │ (0x41c76000)
│ CONFIG_SPL_BSS_MAX_SIZE = 0xA000 │
├─────────────────────────────────────┤ (0x41c80000)
│ DM DATA │
├─────────────────────────────────────┤ (0x41c84130) (approx)
│ EMPTY │
└─────────────────────────────────────┘ CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX
(0x41cffbfc)
New map:
│ SPL │
│ STACK │
│ Global data │
│ HEAP │
│ DM DATA │
│ EMPTY │
├─────────────────────────────────────┤ SYS_K3_MCU_SCRATCHPAD_BASE
│ SCRATCHPAD │ (0x41cff9fc)
│ SYS_K3_MCU_SCRATCHPAD_SIZE = 0x200 │
(0x41cffbfc)
Fixes: a7341dea7087 ("configs: j784s4_evm_r5: Enable support for building multiple dtbs into FIT")
Reviewed-by: Kamlesh Gurudasani <kamlesh@ti.com>
Some firewalls enabled by ROM are still left on. So some
address space is inaccessible to the bootloader. For example,
in OSPI boot mode we get an exception and the system hangs.
Therefore, disable all the firewalls left on by the ROM.
( hopefully this will be covered by andrew's series so wouldn't be
required during merge )
include the common files and remove the redundant variables. run_fit
wasn't working so the refactor for the env was required.
Add J784S4 High Security EVM defconfig.
These configs are same as for the non-secure part, except for:
CONFIG_TI_SECURE_DEVICE option set to 'y'
CONFIG_FIT_SIGNATURE option set to 'y'
CONFIG_BOOTCOMMAND option is changed to use fitImage
'# CONFIG_CMD_SETEXPR is not set' is removed to allow fit booting
Non-HS devices will continue to boot due to runtime device type detection.
If TI_SECURE_DEV_PKG is not set the build will emit warnings, for non-HS
devices these can be ignored.
Now that the default flow is moving towards FIT_SIGNATURE, make the
default of FIT_IMAGE_POST_PROCESS depend on it.
Fedora/Redhat and Arch are somewhat standardized on their dtb directory
structure. Our TI Arago distro will now follow that standard. Add the
directory dtbs/ to the DTB search path.
Signed-off-by: Andrew Davis <afd@ti.com>
In Linux the ARM64 DTSs are stored in vendor directories to help organize
the files and prevent naming collisions. The deployed DTBs will mirror
this and so the vendor prefix should be added to the variable used to
locate these files.
Suggested-by: Ryan Eatmon <reatmon@ti.com>
When OE is packaging a dtb file into the FIT image it names the node based
on the dtb filename. Node names can't have "/" so it is turned into "_".
We select our FIT config using the "fdtfile" env var so we don't duplicate
the board_name to fdt logic. Result is fdtfile needs mangled when used to
select a config node from OE made FIT image. Do this here.
[ upstream commit 1e00e9be62e54e87673ad03b77fb5ebe4ac270b1 ]
For setting up the master firewalls present in the K3 SoCs, the arm64
clusters need to be powered on.
Re-locates the code for atf/optee authentication.
[ upstream commit 65f3afc6b92a4c1cb4fa0dc47d810db9a4dad5e9 ]
Configuring master firewalls require the power of the cluster to be
enabled before configuring them, change the load of rproc to configure
the gtc clocks and start the cluster along with configuring the boot
vector.
The start of rproc will only start the core.
[ upstream commit 53f02be32e1fd387a37ef9a10a55cbeed425f599 ]
adds a53 cluster to control from the rproc driver
[ upstream commit 9a36735b0f62efc892d3b0eb2c020487c72359f9 ]
[ upstream commit 3922cf6295c772e703d8c1f1044f2ead22ef02c7 ]
[ upstream commit 7fe7920c5e8316e112f66cf2213e3e9df6e35fc2 ]
[ upstream commit dcdcbde2bbbc770573c0a8da19a937e0d8ee6d80 ]
adds a72 cluster to control from the rproc driver
[ upstream commit bdbd6688534cd998edc7dc057b67a70c5a5eeccb ]
[ upstream commit ab3df39ffa981043302bac6300a6cebbbf550a5b ]
[ upstream commit d363013e87a94daf375fb60723f4d8e08b592fc3 ]
Lore Link: https://lore.kernel.org/u-boot/20230411-upstream-firewalling-v2-0-b6c705d50099@ti.com/
commit 45981a9a3759eae8375c85927fb213e4cc14353d upstream
If rev is equal to the array size, we'll access the array
one-past-the-end.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Reviewed-by: Bryan Brattlof <bb@ti.com>
commit 677a1e23da1b97d91a0f69f5a956fbdb11d41524 upstream
The K3 JTAG and SoC ID information is already stored in the K3 arch
hardware file, include that and use its definitions here.
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
[bb@ti.com: rebased to ti-v2023.04]
The jtag id information has moved into the hardware.h file upstream.
Move the j784s4's id information to the correct location to align with
what we're doing upstream.
commit ca0973741d62e7c67270b723a6c25c8e855fb87c upstream
This belongs in the J721e specific file as it is the only place
this is used. Any board level users should use the SOC driver.
While here, move the J721e and J7200 SoC IDs out of sys_proto.h
and into hardware.h. Use a macro borrowed from Rockchip and add
the rest of the SoC IDs for completeness and later use.
This is required for UART boot flow where u-boot.img needs to be
downloaded via YMODEM.
commit 2e43ba78052825c62e3078e308d681da44ccdc8f upstream.
Signed-off-by: Jayesh Choudhary <j-choudhary@ti.com>
Reviewed-by: Andrew Davis <afd@ti.com>
Reviewed-by: Manorit Chawdhry <m-chawdhry@ti.com>
commit db58dc5438ec674cad438a606edc155d06914adc upstream.
in spi_mem_dtr_supports_op we have a check for allowing only even number
of bytes to be r/w. Odd bytes writing can be a concern while writing
data to a flash for example because 8 DTR mode doesn't support it.
However, reading ODD Bytes even though may not be physically possible
we can still allow for it because it will not have serious implications
on any critical registers being overwritten since they are just reads.
Cc: Vaishnav Achath <vaishnav.a@ti.com>
Cc: Pratyush Yadav <pratyush@kernel.org>
Cc: Vignesh Raghavendra <vigneshr@ti.com>
Tested-by: Nikhil M Jain <n-jain1@ti.com>
Signed-off-by: Dhruva Gole <d-gole@ti.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
commit 963b5da339a2ac8ad1451c9b84e746a2e26fd0d4 upstream.
This should have been op->data.buswidth instead as we check for octal
bus width for the data related ops
Also add explanation for why there is checks for 8D even data bytes
Reviewed-by: Pratyush Yadav <ptyadav@amazon.de>
commit 08b3098eadc7f826c3e6fb9d184cf6d82f5028fe upstream.
If one leaves the CQSPI_REG_CMDCTRL in an unclean state this may cause
issues in future command reads. This issue came to light when some flash
reads in STIG mode were coming back dirty.
Co-developed-by: Apurva Nandan <a-nandan@ti.com>
Signed-off-by: Apurva Nandan <a-nandan@ti.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
commit 8077d296adff235e13c1478f92ef42c08e17ec33 upstream.
OSPI controller supports all types of op variants in STIG mode,
only limitation being that the data payload should be less than
8 bytes when not using memory banks.
STIG mode is more stable for operations that send small data
payload and is more efficient than using DMA for few bytes of
memory accesses. It overcomes the limitation of minimum 4 bytes
read from flash into RAM seen in DAC mode.
Use STIG mode for all read and write operations that require
data input/output of less than 8 bytes from the flash, and thereby
support all four phases, cmd/address/dummy/data, through OSPI STIG.
Also, remove the reorder address chunk in apb_command_write since we now
setup ADDR BIT field that does the same job in a cleaner way.
commit 44e2de0480a8a5a5780b6b200935a96b961b94e7 upstream.
buswidth and dtr fields in spi_mem_op are only valid when the
corresponding spi_mem_op phase has a non-zero length. For example,
SPI NAND core doesn't set buswidth when using SPI_MEM_OP_NO_ADDR
phase.
Fix the dtr checks in set_protocol() to ignore empty spi_mem_op
phases, as checking for dtr field in empty phase will result in
false negatives.
commit 28e5e95bf8e75efc8ed49e2dc3c260ab998d59fb upstream
Enable Quality of Service (QoS) blocks for Display SubSystem (DSS), by
servicing the DSS - DDR traffic from the Real-Time (RT) queue. This is
done by setting the DSS DMA orderID to 8.
The C7x and VPAC have been overwhelming the DSS's access to the DDR
(when it was accessing via the Non Real-Time (NRT) Queue), primarily
because their functional frequencies, and hence DDR accesses, were
significantly higher than that of DSS. This led the display to flicker
when certain edgeAI models were being run.
With the DSS traffic serviced from the RT queue, the flickering issue
has been found to be mitigated.
The am62a qos files are auto generated from the k3 resource partitioning
tool.
Section-3.1.12, "QoS Programming Guide", in the AM62A TRM[1], provides
more information about the QoS, and section-14.1, "System Interconnect
Registers", provides the register descriptions.
[1] AM62A Tech Ref Manual: https://www.ti.com/lit/pdf/spruj16
Signed-off-by: Aradhya Bhatia <a-bhatia1@ti.com>
This patch deletes tifs DT node as part of fixup.
TISCI API reported msmc_size, does not include
64KB reserved size for tifs aka MSMC comms memory.
As part of fixup, original code uses TISCI API
reported msmc_size as size for sram DT node.
tifs node is similar to l3-cache, which should
hold address above msms_size, and should be deleted
before passing control to OS.
Documentation
https://software-dl.ti.com/tisci/esd/latest/2_tisci_msgs/general/core.html?highlight=msmc#tisci-msg-query-msmc
Signed-off-by: Udit Kumar <u-kumar1@ti.com>
Add erratum i2327 work around for initialization for RTC
interrupt where interrupt is stuck for ever at startup. Unfortunately,
this workaround needs to be applied under 1 second of boot.
Signed-off-by: Nishanth Menon <nm@ti.com>
[bb@ti.com: rebased from 2021.01]
The K3 MCU Scratchpad for j721s2 was set to a PSRAM region triggering the
EEPROM contents.
Old map:
│ SPL │
│ STACK │
│ Global data │
│ HEAP │
│ DM DATA │
│ EMPTY │
(0x41cffbfc)
New map:
│ SPL │
│ STACK │
│ Global data │
│ HEAP │
│ DM DATA │
│ EMPTY │
(0x41cffbfc)
Allow non fitImage bootflow on Field Securable (HS-FS) devices in
addition to GP, force fitImage boot only on Security enforced (HS-SE)
devices where signed images are necessary to maintain chain of trust.
Enable MCU CPSW2G at U-Boot stage.
Since the MDIO driver is not DM enabled and the CPSW driver is
responsible for configuring the pins corresponding to MDIO as well,
add the MDIO pinctrl in the mcu_cpsw device-tree node as a HACK in
the k3-j784s4-evm-u-boot.dtsi file.
Add device tree nodes to enable MCU CPSW with J784S4 EVM.
Linux kernel device tree patch for the same is at:
https://git.kernel.org/ti/linux/c/6cd4b7cfbcca
