Many boards use a minimal .cfg file in the SPL case.
Introduce spl_sd.cfg so that we can reuse it.
mx6sabresd_spl.cfg configures CCM registers, GPR registers and CCM_CCOSR.
Move the configuration to the spl code.
CCM_CCOSR setting is no longer required to get audio functionality in the
kernel, so remove such setting.
Commit 3ff46cc4 fixed exception vectors setting in
the general ARM case, by either copying the exception
and indirect vector tables to normal (0x00000000) or
high (0xFFFF0000) vectors address, or setting VBAR to
U-Boot's base if applicable.
i.MX27 SoC is ARM926E-JS, thus has only normal and
high options, but does not provide RAM at 0xFFFF0000
and has only ROM at 0x00000000; it is therefore not
possible to move or change its exception vectors.
Besides, i.MX27 ROM code does provide an indirect
vectors table but at a non-standard address and with
the reset and reserved vectors missing.
Turn the current vector relocation code into a weak
routine called after relocate_code from crt0, and add
strong version for i.MX27.
Series-Cc: Heiko Schocher <hs@denx.de>
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Tested-by: Stefano Babic <sbabic@denx.de>
Tested-by: Philippe Reynes <tremyfr@gmail.com>
Tested-by: Philippe Reynes <tremyfr@yahoo.fr>
Since USDHC1 and USDHC3 added, the dev index for USDHC2 changed to
1. So modify the default mmcdev in environment variables to dev 1.
Signed-off-by: Ye.Li <B37916@freescale.com>
The PFUZ probe failed with the following msg:
" wait_for_sr_state: failed sr=81 cr=a0 state=2020
i2c_init_transfer: failed for chip 0x8 retry=0
i2c_init_transfer: failed for chip 0x8 retry=1
i2c_init_transfer: failed for chip 0x8 retry=2
i2c_init_transfer: give up i2c_regs=021a0000
Can't find PMIC:PFUZE100 "
board_early_init_f is too early to call i2c related setting, because
init_func_i2c is called after board_early_init_f being invoked. Thus
move setup_i2c into board_init.
Also PFUZ is connected to I2C bus 0, so change "1" -> "0".
Using this patch PFUZ can be correctly probed:
"PMIC: PFUZE100 ID=0x11"
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
mkimage -T mxs now support new flag in config file:
DISPLAYPROGRESS - makes boot process print HTLLC characters for each BootROM
instruction.
Signed-off-by: Alexey Ignatov <lexszero@gmail.com>
The code for this board supports following features:
- Boot media support: NAND flash/SD card/SPI flash
- Support LCD display (optional, disabled by default)
- Support ethernet
- Support USB mass storage
Signed-off-by: Bo Shen <voice.shen@atmel.com>
- Support ethernet
The User Register in GMAC IP is used to select interface type.
When with GE feature, it is used to select interface between
RGMII and GMII. If without GE feature, it is used to select
interface between MII and RMII.
As in SAMA5D4 SoC, the gf table in ROM code can not be seen.
So, when we try to use PMECC, we need to build it when do
initialization.
Add a macro NO_GALOIS_TABLE_IN_ROM in soc header file. If it
is defined we will build gf table runtime.
The PMECC use the BCH algorithm, so based on the build_gf_tables()
function in lib/bch.c, we can build the Galois Field lookup table.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
replaces the at91bootstrap code with SPL code.
make the spl image with:
./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin
this writes the length of the spl image into the 6th
execption vector. This is needed from the ROM bootloader.
Reviewed-by: Bo Shen <voice.shen@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
add support for using spl code on at91sam9260 and at91sam9g45
based boards.
[adopt Bo's change in spl.c]
device ready pin is signalling that the device is ready on state 1
not on 0. Simmiliar as it is in drivers/mtd/nand/nand_spl_simple.c
Acked-by: Scott Wood <scottwood@freescale.com>
erase one nand block in spl code. keep it simple, as size matters
This is used on the upcoming taurus spl support.
using this driver in SPL code with CONFIG_SPL_NAND_ECC
configured leads in an compileerror. Fix this.
[fix subject]
enable to boot only a raw u-boot.bin image from nand with the
CONFIG_SPL_NAND_RAW_ONLY define. This option saves space on
boards where spl space is low.
- compile mpddrc ram init code also for AT91SAM9M10G45
based boards.
- in CONFIG_SAMA5D3 case, look for the ATMEL_MPDDRC_CR_DECOD_INTERLEAVED
in the cr configuration
use the configure value for computing the ba_off value
not the value from the cr register. This leaded in a
wrong ram configuration on the upcoming corvus spl board
support.
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
move CONFIG_SYS_SPI_WRITE_TOUT into drivers/spi/atmel_spi.h
and define a default value. Delete this define in the board
config files, where it is possible (all boards use currently
the same value).
generate the boot.bin file for all atmel SoC (arm920, arm926, armv7)
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
[fix subject]
The clock source for master clock can be slow clock, main clock,
plla clock or upll clock. So, make the clock source selection
field in mckr can be configured.
We need to make sure the main clock ready field in MCFR is set
after switch to main crystal oscillator.
When boot up without mac address setting, it will give the warning
message like: "Warning: failed to set MAC address", however when
execute network related command, it still execute them without any
warning information.
With this patch, it will exit directly with following information:
"gmac0: mac address is not valid"
It also solve the problem after bootup then set mac address and the
mac address won't set to net device issue.
Tested-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Common part of config for lager, koelsch, alt and gose board will be able to
replace rcar-gen2-common.h.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
The lager, koelsch, alt, gose board supported in rmobile is
distinguished as the R-Car Gen2 series and has much common setting.
This collect up the common part of config as rcar-gen2-common.h.
Gose board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of
dram_init_banksize instead.
Lager board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of
Koesch board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of
Alt board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of
This moves SH_32BIT to Kconfig, and removes SH_32BIT from config
files.
Enable these boards mtdparts for nor flash:
p1020rdb-pd, p1021rdb-pc, p1022ds, p1025twr, and p2020rdb-pc.
Signed-off-by: Xie Xiaobo <X.Xie@freescale.com>
Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
This converts all the Keymile powerpc boards to the generic board
initialization.
This includes the 3 Keymile powerpc subsystems: km82xx, km83xx,
and kmp204x.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Reviewed-by: York Sun <yorksun@freescale.com>
The argument boot_flags of board_init_f() is not used at all in the
powerpc specific board.c init sequence. Now with the generic init
sequence, this boot_flags arg is used by board_init_f().
This patch sets the r3 register that is used to pass the boot_flags
argument from the start.S board_init_f() call to 0 prior to the function
call to avoid unknown content to end up in gd->flags.
* fdt_fixup_mtdparts is called from ft_board_setup
* Run "mtdparts default" to create NAND partition on uboot
* Use mtdparts to create partitions dynamically rather
than using static partitions in device tree
Signed-off-by: Ashish Kumar <Ashish.Kumar@freescale.com>
* run "mtdparts default" to create NAND, NOR partition on uboot
IFC registers can be of type Little Endian or big Endian depending upon
Freescale SoC. Here SoC defines the register type of IFC IP.
So use IFC acessor functions instead of in_be32().
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
-A_007662 states that for x1 link width, PCIe2 controller trains in
Gen1 speed while configured for Gen2 speed.
Workaround:Set the width to x1 and speed to Gen2 by writing to
CCSR registers in PBI phase
-A_008007 states that PVR register may show random value.
Workaround: Reset PVR register using DCSR space in PBI phase
Add PBI based software workaround for A_007662 and A_008007
in t104x_pbi.cfg. This is required for SPL-based bootloaders
like NAND-boot, SD-boot, SPI-boot
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
This support of CPLD includes
- Files and register definitions
- Command to switch alternate bank
- Command to switch default bank
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
LIODN entry for B4860/B4420 mentions USB controller as "mph"
insread of "dr". This results in PAMU not permitting bus
transactions for USB DR controller on B4860 resulting in
USB function failure. Replacing "fsl-usb2-mph" with
"fsl-usb2-dr" allows USB DR controller bus transactions
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
Reviewed-by: Sethi Varun-B16395 <Varun.Sethi@freescale.com>
Reviewed-by: Sun Yusong-R58495 <yorksun@freescale.com>
