The SDHC1_DAT4 signal could be routes to SDHC1_VS or SDHC1
adapter slot for SDHC1 usage. When SDHC1 is selected in RCW,
do not force to route it to SDHC1 adapter slot if find it
has already been configued for SDHC1_VS.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
The pci-host-ecam-generic code assumes that the ECAM is the first PCI
bus in the system to be probed. Therefore, the system-wide bus number
allocated by U-Boot in sequence for it is going to be zero, which
corresponds to the memory-mapped config spaces found within it.
Reuse the logic from other PCI bus drivers, and assume that U-Boot will
allocate bus numbers in sequence for all buses within the current ECAM.
So the base number of the bus needs to be subtracted when indexing the
correct config space.
Fixes: 3675cb044e68 ("PCI: Add driver for a 'pci-host-ecam-generic' host controller")
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Reviewed-by: Alex Marginean <alexandru.marginean@nxp.com>
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
The old load address of itb will overwrite uboots reserved memory
on ls1012afrwy with 512 MiB ram
Signed-off-by: Biwen Li <biwen.li@nxp.com>
The correct setting for the RGMII ports on LS1046ARDB is to
enable delay on both Rx and Tx so the interface mode used must
be PHY_INTERFACE_MODE_RGMII_ID. There is a pull-up that turns
on Rx internal delay by default and the u-boot does not
override that (yet) so in u-boot the interface is functional.
In Linux the PHY driver is clearing the Rx delay for the
"rgmii-txid" mode and the reception does not work.
Changing the RGMII mode to internal delay here ensures that
device tree fix-ups for the PHY connection type turn on both
Tx and Rx internal delay in Linux.
Fixes: cc1aa218f510 ("armv8/ls1046a: RGMII PHY requires internal
delay on Tx")
Signed-off-by: Madalin Bucur <madalin.bucur@oss.nxp.com>
The correct setting for the RGMII ports on LS1043ARDB is to
Fixes: 5a78a472f666 ("armv8/ls1043a: RGMII PHY requires internal
delay on Tx")
The RGMII modes that include internal delay were not all
properly treated in the memac code. Add support for all
RGMII delay modes.
Fixes: 111fd19e3b9e ("fm/mEMAC: add mEMAC frame work")
Add dhcp in supported boot_targets for lx2160.
Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com>
Add DHCP boot target device to enable command bootcmd_dhcp.
Signed-off-by: Yuantian Tang <andy.tang@nxp.com>
Select BOARD_LATE_INIT config so that many board works can be done
in late init stage.
Set VID to 800 mV for Rev1 and set VID as per switch settings
for Rev2.
Update the secure boot headers offsets of Kernel and other
firmware images for SD and XSPI boot sources used by
esbc_validate command.
Signed-off-by: Priyanka Singh <priyanka.singh@nxp.com>
Add emmc in supported boot_targets and
Add bootcmd environment variable for emmc boot.
Setting fdt_high and initrd_high to 0xffffffffffffffff leads to
various difficulty to resolve bugs.
Remove them and use bootm_size instead to safely contain a kernel,
device tree and initrd for relocation.
Reserve DDR memory region used for GIC LPI configuration table.
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
Enable GIC_V3_ITS config to program GIC LPI
Program GIC LPI configuration table:
1. Redistributor PROCBASER configuration table (which
is common for all redistributors)
2. Redistributor pending table (PENDBASER), for all the
available redistributors.
Signed-off-by: Manish Tomar <manish.tomar@nxp.com>
Update "board_fix_fdt" with correct counter value "i".
This will fix the issue while fetching the "reg_names"
resource from fdt after fixup.
Signed-off-by: Vikas Singh <vikas.singh@nxp.com>
This patch sets CONFIG_SYS_BOOTMAPSZ to the amount of memory available
to safely contain a kernel, device tree and initrd for relocation. The
way to set fdt_high as 0xffffffff to disable device tree relocation is
removed.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
- Update a few MAINTAINERS entries
- cache alignment fix in ext4 code
- Two small test fixes
%s/decopmression/decompression/
Signed-off-by: Marek Behún <marek.behun@nic.cz>
We need to align the cache buffer to ARCH_DMA_MINALIGN in order to avoid
access errors like
CACHE: Misaligned operation at range [be0231e0, be0235e0]
seen on the MCIMX7SABRE.
Fixes: d5aee659f217 ("fs: ext4: cache extent data")
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
Add usb.h file into the USB list.
Commit 41e30dcf8796 ("cmd: mmc: Make Mode: printout consistent") fixed
the layout of `mmc info` output. Reflect this change in the respective
testcase.
Also fix a typo in the documentation.
Fixes: 41e30dcf8796 ("cmd: mmc: Make Mode: printout consistent")
Signed-off-by: Harald Seiler <hws@denx.de>
Currently this causes failures of the platform when running the EFI
loader tests, so disable it for now.
This reverts commit af827140e5965e5bb2bcad1c53ca8419b428ff6d.
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- Fixed for rv1108 and elgin-rv1108 board
- Fix the keyboard from USB instead of CrOS EC
Depending on the SoC, a header of four characters is prepended to the
image. There is already a macro defining the number of characters:
RK_SPL_HDR_SIZE, so use it instead of hardcoding "4".
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Since commit 79030a486128 ("rockchip: Add Single boot image
(with binman, pad_cat)") the following boot regression is seen:
U-Boot 2020.04-rc3-00050-gd16e18ca6c-dirty (Mar 09 2020 - 11:40:07 -0300)
Model: Elgin RV1108 R1 board
DRAM: 128 MiB
initcall sequence 67fd12a0 failed at call 6000b927 (err=-22)
This happens because the above commit missed to include the
"rockchip-u-boot.dtsi" for rv1108, so include this file
like it done for other Rockchip SoC dtsi's.
Fixes: 79030a486128 ("rockchip: Add Single boot image (with binman, pad_cat)")
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Currently the following error message is seen during boot:
U-Boot 2020.01-08751-g55759ae141 (Mar 09 2020 - 14:44:52 -0300)
DRAM: 128 MiB
APLL: 600000000 DPLL:1200000000 GPLL:1188000000
ACLK_BUS: 148500000 ACLK_PERI:148500000 HCLK_PERI:148500000 PCLK_PERI:74250000
MMC: dwmmc@30110000: 0
Loading Environment from MMC... OK
In: serial@10210000
Out: serial@10210000
Err: serial@10210000
rockchip_dnl_key_pressed: adc_channel_single_shot fail!
Since the elgin-rv1108 does not use ADC to read the download
key status, select CONFIG_ROCKCHIP_BOOT_MODE_REG=0 to avoid
such error.
Since commit 8e9a8d0d0c8c ("rockchip: elgin-rv1108: use board_early_init_f
for per-boar init") the function that configure the board GPIOs is no
longer called since CONFIG_BOARD_EARLY_INIT_F=y is not selected.
These GPIOs do not need to be configured in such early stagem, so change it
to rk_board_late_init() and also select CONFIG_BOARD_LATE_INIT=y
to fix the regression.
Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br>
In order to make the console pins more robust to noise, activate
the pullups and increase its drive strength.
These boards aren't ChromeOS devices so won't have a cros-ec-keyb
input as it's the keyboard available via the ChromeOS Embedded
Controller. Update them to use a USB keyboard which would actually
be available. Also enable the usb keyboard option for those devices
that don't have it enabled already.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com>
Use syscon API to get grf base instead of get from dts.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
EFI was disabled in f95b8a4b5f64f because of the missing DTB file,
and indeed, the DTB file is required to load recent versions of GRUB
(2.04) correctly.
Signed-off-by: Kristian Amlie <kristian.amlie@northern.tech>
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-04-rc4 (5)
This series contains bug fixes for the UEFI sub-system:
* report correct variable length in GetNextVariable()
* correct copying direction if freestanding memmove()
* remove const for parameter of GetNextVariableName()
* correct function descriptions
Unit tests are added and adjusted.
'vendor' is both an input and an output parameter. So it cannot be
constant.
Fixes: 0bda81bfdc5c ("efi_loader: use const efi_guid_t * for variable services")
Provide unit tests for CalculateCrc32(), CopyMem(), SetMem().
For EFI binaries we have to provide an implementation of memmove() in
efi_freestanding.c.
Before this patch the memmove() function was copying in the wrong
direction.
Correct the description of function efi_convert_pointer().
To check if a variable is non-zero there is no need for '!= 0'.
GetNextVariableName should report the length of the variable including the
final 0x0000 in bytes.
Check this in the unit test.
Increase the buffer size for variable names. 40 bytes is too short.
The runtime service GetNextVariable() returns the length of the next
variable including the closing 0x0000. This length should be in bytes.
Comparing the output of EDK2 and U-Boot shows that this is currently not
correctly implemented:
EDK2:
OsIndicationsSupported: 46
PlatformLang: 26
PlatformLangCodes: 36
U-Boot:
OsIndicationsSupported: 23
PlatformLang: 13
PlatformLangCodes: 18
Provide correct length in GetNextVariable().
Fixes: d99a87f84b75 ("efi_loader: implement GetNextVariableName()")
Use Sphinx style for function descriptions.
Correct the file description.
- Revert "sunxi: psci: avoid error address-of-packed-member"
Pull request for UEFI sub-system for efi-2020-04-rc4 (4)
This series fixes several bugs:
* consider the /reserved-memory node in the device tree
* consider memory reservations created in ft_board_setup()
* correct output of 'efidebug memmap' on the sandbox
* correct the definition of efi_capsule_header()
Furthermore some definitions needed for future patches are added to
header files.
- Fix sbi_remote_sfence_vma{,_asid}.
- Avoid calling sbi_clear_ipi().
- Add new SBI v0.2 extensions support.
Using memcpy() for some MMIO access is generally frowned upon and might
break things on some platforms. Allwinner H3, which fails to boot, being
an example here.
Moreover, fields being accessed are naturally aligned and warnings
produced by GCC have been quiesced for some time already by:
53dc8ae ("gcc-9: silence 'address-of-packed-member' warning")
That said, it should be okay to revert this commit.
This reverts commit 9bd34a69a453d409792e08c00953ce8862145e65.
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
Signed-off-by: Tomasz Duszynski <tduszyns@gmail.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
