Lds files cleened to remove multiple defined section and modified to
be compliant with --gc-sections added for ColdFire platform in a
previous patch.
Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com>
There is a rather subtle build problem where the build time stamp is not
updated for out-of-tree builds if there exists an in-tree build which
has a valid timestamp file. So if you do an in-tree build, then an
out-of-tree build your timestamp will not change.
The correct timestamp_autogenerated.h lives in the object tree, but it
is not always found there. The source still lives in the source tree and
when compiling version.h, it includes timestamp_autogenerated.h. Since
the current directory is always searched first, this will come from the
source tree rather than the object tree if it exists there. This affects
dependency generation also, which means that common/cmd_version.o will not
even be rebuilt if you have ever done an in-tree build.
A similar problem exists with the version file.
This change moves both files into the 'generated' subdir, which is already
used for asm-offsets.h. Then timestamp.h and version.h are updated to
include the files from there.
There are other places where these generated files are included, but I
cannot see why these don't just use the timestamp.h and version.h headers.
So this change also tidies that up.
I have tested this with in- and out-of-tree builds, but not SPL. I have
looked at various other options for fixing this, including sed on the dep
files, -I- and -include flags to gcc, but I don't think they can be made
to work. Comments welcome.
At this point U-Boot will build and run on x86 under Linux.
The idea is to define a new architecture called 'sandbox', alongside ARM
and x86. This runs natively on Linux to suit the host machine. All
hardware access is either omitted or emulated.
The purpose of this system is to test the bulk of the non-hardware-specific
U-Boot code. We can mock the SPI flash, GPIOs, UART and keyboard, then test
that U-Boot behaves as we wish.
Since we want want to have a standard GPIO interface, this adds a definition
for this into include/asm-generic/gpio.h.
The dependency rules are currently done in a shell 'for' loop. This does not
permit Makefile variables to adjust preprocessor flags as is done with normal
compile flags, using the CFLAGS_path/file.o syntax.
This change moves the dependency generation into the Makefile itself, and
permits a CPPFLAGS_path/file.o to adjust preprocessor flags on a file or
directory basis.
The CPPFLAGS_... variable is also folded into CFLAGS during the build.
This fixes a problems when building on some 64-bit machines.
This basic provides required features along with a basic command set.
This uart simply writes to stdout and reads from stdin. We might imagine
instead buffering the data so that a test interface can check output and
inject input.
Add a main program so that we can run U-Boot.
We want to keep all OS-dependent code in once place, with a simple interface
to U-Boot. For now, this is that place.
By default sections are 16-byte aligned on some architectures, but the
command name structure (struct cmd_tbl_s) does not have padding to
16 bytes. This reduces the alignment to 4-bytes so that the command
table can be accessed correctly on any architecture.
(Note: this needs doing properly)
This is not useful on the sandbox architecture since we can simply link all
our code with U-Boot.
We prefer to U-Boot's malloc but for now it is easier to use the C library's
version.
This adds sandbox architecture support to bootm, although it is probably
not useful to load sandbox code into the address space and execute it.
This change at least make the file build correctly on 64-bit machines.
This is required for the bdinfo command to work.
Fix syntax error.
This adds basic files for the sandbox board. The lds file is very simple
since we can rely mostly on the linker defaults.
These files are taken from the ARM board implementation and then reduced
to remove unneeded cruft.
Ideally we would work towards unifying arch/xxx/lib files, particularly
board.c.
This is an initial implementation with all functions defined but not working.
The lds file is very simple since we can mostly rely on the linker defaults.
This sets __WORDSIZE to 8 correctly on 64-bit machines.
We won't actually load an image with this architecture, but we still need to
define it.
It is better to use %p in this case.
This adds required header files for the sandbox architecture, and a basic
description of what sandbox is (README.sandbox).
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
Cc: Matt Waddel <matt.waddel@linaro.org>
These options are required to be present in RFC 4578 compliant DHCP
requests. They give more information to DHCP servers to allow serving
different DHCP responses to different systems based on client
architecture, client capabilities, UUID, or vendor.
Add pxe command, which is intended to mimic PXELINUX functionality.
'pxe get' uses tftp to retrieve a file based on UUID, MAC address or IP
address. 'pxe boot' interprets the contents of PXELINUX config like file
to boot using a specific initrd, kernel and kernel command line.
This patch also adds a README.pxe file - see it for more details on the
pxe command.
With these documented, we can start pushing towards standardizing their
use across boards.
Cc: Mike Frysinger <vapier@gentoo.org>
These are various places I found that checked for conditions equivalent
to isblank.
This prevents a checkpatch warning in the patch to use isblank
Existing ctype checks are implemented using a 256 byte lookup table,
allowing each character to be in any of 8 character classes. Since there
are 8 existing character classes without the blank class, I implemented
isblank without using the lookup table. Since there are only two blank
characters - tab and space - this is a more reasonable approach than
doubling the size of the lookup table to accommodate one more class.
This will be used first by the pxe code, but is intended to be
generic and reusable for other jobs in U-boot.
commit a45dde2293c816138e53c26eca6fd0322583f9a6 changed the dm9000
direct register access to standard IO. This should work
on the ColdFire platform as there are corresponding macros for
the LE devices. But the hardware settings on some ColdFire boards had
swapped the byte order which make the original macros such as out_le16
cannot work. To avoid changing the common io access code on ColdFire
platform, the DM9000_BYTE_SWAPPED define was added to make the dm9000 use
__raw* IO access on some ColdFire boards.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
The function kw_gpio_is_valid returns zero on success, so
adapt the error check accordingly.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Dieter Kiermaier <dk-arm-linux@gmx.de>
The new debug() changes pointed out debug code that rotted a little.
Common U-Boot API wants this define, so import asm/cache.h from Linux
to provide suitable defines.
Acked-by: Anton Staaf <robotboy@chromium.org>
mx3fb.c was based on CONFIG_LCD and is moved by this patch to
CONFIG_VIDEO, which has greater freedom in selecting videomodes
even at runtime.
This renders the accumulating list of display defines
(CONFIG_DISPLAY_VBEST..., CONFIG_DISPLAY_C057...) obsolete as
these may be setup through env variables:
uboot> setenv mydisplay 'video=ctfb:x:240,y:320,depth:16,mode:0,pclk:185925,
le:9,ri:17,up:7,lo:10,hs:1,vs:1,sync:100663296,vmode:0'
uboot> setenv videomode ${mydisplay}
This commit also fixes the board config files for qong and
imx31_phycore boards as needed. The videomode settings of
previously supported displays are added to CONFIG_EXTRA_ENV_SETTINGS
now. CONFIG_SYS_MALLOC_LEN for imx31_phycore board is increased
to make the frame buffer allocation working with the changed
driver.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
This additionally updates mx31/generic.c by
- replacing __REG() macro accesses with readl() and writel()
- providing macros for PDR0 and PLL bit accesses
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Tested-by: Stefano Babic <sbabic@denx.de>
Pixel format defines must be available for boards to set up
the right display. Move them and export in a new file.
CC: Anatolij Gustschin <agust@denx.de>
CC: Marek Vasut <marek.vasut@gmail.com>
The framebuffer driver for MX5 is based on CONFIG_LCD.
In the current implementation, there is a serious bug
because the required memory is allocated before
relocation, but the driver knows only later which is
the resolution of the display. The patch switches the driver
to CONFIG_VIDEO and the memory is allocated by the driver itself.
We also need to switch the vision2 board code and config file
in the same commit so that this commit will be bisectable.
Update the Freescale DIU video driver (fsl_diu_fb.c) to use linux/fb.h.
Some data structures from this header file were just copied into
fsl_diu_fb.c.
In the recent dropping of !NET_MULTI code (commit e2a53458a7ab37523304),
I misread the logic in include/net.h. Some of it was used by NET_MULTI
code as glue between the multi/non-multi worlds for cpm2 boards.
Rather than restore the block of code, push the logic to the board config
headers where it all belongs.
If compressed data is located in sectors at the end of the flash and
it's offset + input stream size > 0xFFFFFFFF, the uncompressing time
is very long, since processing of the stream is done bytewise (and
not blockwise) due to overflow in inflate_fast() while calculation
and checking for enough input available.
Check for this overflow condition and limit the available stream
input size to the actually max. possible input size. This fixes
the problem.
The issue is easily reproduceable by placing a gziped bitmap in flash,
e.g. at FFF80000, and running 'bmp' commands like 'bmp info FFF80000'
or 'bmp display FFF80000'. The uncompressing can take up to 3 sec.
whereas it should normaly take a fraction of a second. If the
'splashimage' environment variable points to this address, the
booting time also increases significantly.
No code defines or calls this, so drop the prototype.
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
The command auto-completion does not work on architectures relying
on CONFIG_NEEDS_MANUAL_RELOC like MIPS. Cause is the missing function
pointer fixup for cmd_tbl_t::complete function in fixup_cmdtable().
This patch adds the missing pointer fixup in case of CONFIG_AUTO_COMPLETE
is defined.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
