This patch adds gpio support of Altera PIO component to the
nios2-generic board. Though it drives only gpio_led at the
moment, it supports bidirectional port to control bit-banging
I2C, NAND flash busy status or button switches, etc.
Tested-by: Ian Abbott <abbotti@mev.co.uk>
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
This patch adds a status led driver followed the GPIO access
conventions of Linux. The led mask is used to specify the gpio pin.
This patch adds driver for a trivial gpio core, which is described
in http://nioswiki.com/GPIO. It is used for gpio led and nand flash
interface in u-boot.
When CONFIG_SYS_GPIO_BASE is not defined, board may provide
its own driver.
Compiling tools subdirectory on Mac OS X 10.6 (Snow Leopard) complains about
wrong syntax in system includes.
In file included from /usr/include/stdio.h:444,
from ../source/u-boot/include/compiler.h:26,
from ../source/u-boot/lib/crc32.c:15:
/usr/include/secure/_stdio.h:46: error: syntax error in macro parameter list
This can be fixed by reverting the workaround for prior OS X releases in
config.mk conditionally for OS X 10.6+.
Match style we use almost everywhere else
For CONFIG_SYS_BOOTCOUNT_SINGLEWORD the code had an endianness problem.
Signed-off-by: Michael Weiss <michael.weiss@ifm.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
Use readX() / writeX() accessors instead of inX() / outX().
Suggested-by: Mike Frysinger <vapier@gentoo.org>
Fix the following compiler problems:
arch/arm/cpu/arm920t/a320/liba320.a(timer.o): In function `udelay':
/home/wd/git/u-boot/work/arch/arm/cpu/arm920t/a320/timer.c:160: multiple definition of `udelay'
lib/libgeneric.a(time.o):/home/wd/git/u-boot/work/lib/time.c:34: first defined here
lib/libgeneric.a(time.o): In function `udelay':
time.c:(.text+0x1c): undefined reference to `__udelay'
call to reset PHY chip.
Current PHY Software Reset operation in guruplug does not
poll reset bit in control register to go to 0(auto clearing)
for making sure reset was successful.This patch uses standard
miiphy call miiphy_reset to make sure proper PHY reset operation.
Signed-off-by: Mahavir Jain <mjain@marvell.com>
commit c7190f028fa950d4d36b6d0b4bb3fc72602ec54c "mpc83xx:
retain POR values of non-configured ACR, SPCR, SCCR, and LCRR
bitfields" incorrectly shifted <register>_<bitfield> (e.g.
ACR_PIPE_DEP) values that were preshifted by their
definition in mpc83xx.h.
this patch removes the unnecessary shifting for the newly
utilized mask values in cpu_init.c, and prevents seemingly
unrelated symptoms such as an mpc8379erdb board from
locking up whilst performing a networking operation,
e.g. a tftp.
Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
"down_write_trylock" needs to return 1 instead of 0 for success.
Otherwise copying a block with a read error (e.g. bit-flip on read)
won't work correctly.
The current U-Boot UBI implementation is copied from Linux. In this
porting the UBI background thread was not handled correctly. Upon write
operations ubi_wl_flush() makes sure, that all queued operations, like
page-erase, are completed. But this is missing for read operations.
This patch now makes sure that such operations (like scrubbing upon
bit-flip errors) are not queued, but executed directly.
The patch adds setup to connect a CASIO COM57H5M10XRC
(640x480 TFT display) to the QONG module.
Commit 15351855 "fsl-diu: Using I/O accessor to CCSR space" caused a
number of "passing argument 2 of 'out_be32' makes integer from pointer
without a cast" warnings; fix these.
Cc: Dave Liu <daveliu@freescale.com>
Cc: Jerry Huang <Chang-Ming.Huang@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Modification of print_size to avoid use of divides and especially
long long divides. Keep the binary scale factor in terms of bit
shifts instead. This should be faster, since the previous code
gave the compiler no clues that the divides where always powers
of two, preventing optimisation.
Signed-off-by: Nick Thompson <nick.thompson@ge.com>
Acked-by: Timur Tabi <timur@freescale.com>
Signed-off-by: Serge Ziryukin <ftrvxmtrx@gmail.com>
This patch sets the SICRL_LBC bits in SICRL to change the function of the
associated pins to GPIO functionality.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
commit 167cdad1372917bc11c636c359aad02625291fa9 "SERIAL: Enable
port-mapped access" inadvertently broke 83xx nand boards by
converting NS16550_init to use io accessors, which expanded
the size of the generated code.
this patch fixes the problem by removing icache functions from
the nand builds, which somewhat follows commit
1a2e203b31d33fb720f2cf1033b241ad36ab405a "mpc83xx: turn on icache
in core initialization to improve u-boot boot time"
This patch removes the checkboard function from the build of
the 4k bootstrap section for the SIMPC8313 as it is not needed
in the spl build. This will allow > 100 bytes of extra room
for other uses.
Due to some overlapping sections it's time to update TEXT_BASE
for this board.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Fix MVBLM7 and MVSMR Makefiles for correct out-of-tree building
(create "bootscript.img" in build directory instead of source
directory) and cleanup (remove "bootscript.img" when cleaning up).
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
Tested-by: Thomas Weber <weber@corscience.de>
Commit 77c1458d caused the following compiler warnings:
fsl_esdhc.c: In function 'esdhc_pio_read_write':
fsl_esdhc.c:142: warning: assignment discards qualifiers from pointer target type
fsl_esdhc.c: In function 'esdhc_setup_data':
fsl_esdhc.c:169: warning: unused variable 'wml_value'
fsl_esdhc.c:164: warning: control reaches end of non-void function
Fix these.
Cc: Dipen Dudhat <dipen.dudhat@freescale.com>
Cc: Andy Fleming <afleming@freescale.com>
SPD has minor change from Rev 1.2 to 1.3. This patch enables Rev 1.3.
The difference has ben examined and the code is compatible.
Speed bins is not verified on hardware for CL7 at this moment.
This patch also enables SPD Rev 1.x where x is up to "F". According to SPD
spec, the lower nibble is optionally used to determine which additinal bytes
or attribute bits have been defined. Software can safely use defaults. However,
the upper nibble should always be checked.
Signed-off-by: York Sun <yorksun@freescale.com>
On the MPC85xx platform if we have SATA its connected on SERDES.
Determing if SATA is enabled via sata_initialize should not be board
specific and thus we move it out of the MPC8536DS board code.
Additionally, now that we have is_serdes_configured() we can determine
if the given SATA port is enabled and error out if its not in the
driver.
The new is_serdes_configured covers a broader range of devices than the
PCI specific code. Use it instead as we convert away from the
is_fsl_pci_cfg() code.
Additionally move to setting LAWs for PCI based on if its configured.
Also updated PCI FDT fixup code to remove PCI controllers from dtb if
they are configured.
Add the ability to determine if a given IP block connected on SERDES is
configured. This is useful for things like PCIe and SRIO since they are
only ever connected on SERDES.
Using PPC I/O accessor to DIU I/O space instead of directly
read/write. It will prevent the dozen of compiler order issue
and PPC hardware order issue for accessing I/O space.
Using the toolchain(tc-fsl-x86lnx-e500-dp-4.3.74-2.i386.rpm)
can show up the order issue of DIU driver.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Add USB commands.
Rename autoscript to bootscript.
Add automatic bootscript image generation to makefile.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Added UPM array table, upmconfig, and Local Bus configuration support for SIMPC8313
Only one file apparently defines this function, and it merely stubs
it out. So if no one is defining/calling it, punt it.
With the cpu include paths moved, the gitignore paths need updating.
Tested-by: Tom Rix <tom@bumblecow.com>
When we changed ARCH from ppc to powerpc we need to treat HOSTARCH the
same way. We use HOSTARCH == ARCH to determine if a build is native.
This patch consolidates bootcount_{store|load} for PowerPC by
implementing a common version in arch/powerpc/lib/bootcount.c. This
code is now used by all PowerPC variants that currently have these
functions implemented.
The functions now use the proper IO-accessor functions to read/write the
values.
This code also supports two different bootcount versions:
a) Use 2 separate words (2 * 32bit) to store the bootcounter
b) Use only 1 word (2 * 16bit) to store the bootcounter
Version b) was already used by MPC5xxx.
Acked-by: Detlev Zundel <dzu@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
for 83xx parts
Cc: Michael Zaidman <michael.zaidman@gmail.com>
Cc: Kim Phillips <kim.phillips@freescale.com>
Fix conditional compile rule for twl4030.c and videomodes.c.
Signed-off-by: Ender.Dai <ender.dai@gmail.com>
