Modifications to support console multiplexing. This is controlled using
CONFIG_SYS_CONSOLE_MUX in the board configuration file.
This allows a user to specify multiple console devices in the environment
with a command like this: setenv stdin serial,nc. As a result, the user can
enter text on both the serial and netconsole interfaces.
All devices - stdin, stdout and stderr - can be set in this manner.
1) common/iomux.c and include/iomux.h contain the environment setting
implementation.
2) doc/README.iomux contains a somewhat more detailed description.
3) The implementation in (1) is called from common/cmd_nvedit.c to
handle setenv and from common/console.c to handle initialization of
input/output devices at boot time.
4) common/console.c also contains the code needed to poll multiple console
devices for input and send output to all devices registered for output.
5) include/common.h includes iomux.h and common/Makefile generates iomux.o
when CONFIG_SYS_CONSOLE_MUX is set.
Signed-off-by: Gary Jennejohn <garyj@denx.de>
When running `strings` on really long strings, the stack tends to get
smashed due to printf(). Switch to puts() instead since we're only passing
the data through.
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
- fix size too small by one in sprintf
- changed old (pre 2004) device name ibmEmac to emac
- boot device may be overriden in board config
- servername may be defined in board config
- additional parameters may be defined in board config
- fixed some line wrappings
- replaced redundant MAX define by max
remove unneeded version.h from lcd.c
Use the GNU 'date' command to auto-generate a new U-Boot
timestamp on every compile.
Commit 6b59e03e0237a40a2305ea385defdfd92000978b
lcd: Let the board code show board-specific info
introduced some bugs which prevent U-Boot building
for lwmon board if CONFIG_LCD_INFO_BELOW_LOGO will
be defined in the board configuration.
Also "LCD enabled" building for TQM823L doesn't work
since this commit.
This patch fixes above-mentioned issues.
When using gdb, history files will often get generated. So ignore them.
This code contains some non-ascii characters in comment lines and code.
Most editors do not display those characters properly and editing those
files results always in diffs at these places which are usually not required
to be changed at all. This is error prone.
So, remove those weird characters and replace them by normal C-style
equivalents for which the proper defines were already in the header.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
The default DDR freq is 400MHz or 800M data rate,
the old settings is pure wrong for the default case.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
Moved up the initialization of GD so C code like set_tlb() can use
gd->flags to determine if we've relocated or not in the future.
If the virtual address for CCSRBAR is the same after relocation but
the physical address is changing we'd end up having two TLB entries with
the same VA. Instead we new us the new CCSRBAR virt address + 4k as a
temp virt address to access the old CCSRBAR to relocate it.
The BR_PHYS_ADDR macro is useful on all machines that have local bus
which is pretty much all 83xx/85xx/86xx chips.
Additionally most 85xx & 86xx will need it if they want to support
36-bit physical addresses.
Add define used to determine if PCI1 interface is in PCI or PCIX mode.
Convert users of the old PORDEVSR_PCI constant to use MPC85xx_PORDEVSR_PCI1
Signed-off-by: Andy Fleming <afleming@freescale.com>
The current code will cause the creation of a 4GB window
starting at 0 if we have more than 4GB of RAM installed,
which overlaps with PCI_MEM space and causes pci_bus_to_phys()
to return erroneous information. Limit the size to 4GB - 1;
which causes the code to create one 2GB and one 1GB window
instead.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Prevent further viral propogation of the unused
symbol CONFIG_L1_INIT_RAM by just removing it.
Removed while(1) hang if memctl_intlv_ctl is set wrong.
Remove embedded tabs from strings.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
since commit be0bd8234b9777ecd63c4c686f72af070d886517
tlb entry for socrates DDR SDRAM will be reconfigured
by setup_ddr_tlbs() from initdram() causing an
inconsistency with previously configured DDR SDRAM tlb
entry from tlb_table:
socrates>l2cam 7 9
IDX PID EPN SIZE V TS RPN U0-U3 WIMGE UUUSSS
7 : 00 00000000 256MB V 0 -> 0_00000000 0000 -I-G- ---RWX
8 : 00 00000000 256MB V 0 -> 0_00000000 0000 ----- ---RWX
9 : 00 10000000 256MB V 0 -> 0_10000000 0000 ----- ---RWX
This patch makes the presence of the DDR SDRAM tlb entry in
the tlb_table dependent on CONFIG_SPD_EEPROM to avoid this
inconsistency.
All mpc8548-based boards should implement the suggested workaround
to CPU 2 errata. Without the workaround, its possible for the
8548's core to hang while executing a msync or mbar 0 instruction
and a snoopable transaction from an I/O master tagged to make
quick forward progress is present.
we need TLB entry for DDR at !SPD case.
The DDR controller of 8548/8544/8568/8572/8536 processors
have the ECC data init feature, and the new DDR code is
using the feature, and we don't need the way with DMA to
init memory any more.
This patch fix the problem that only the [NB_DATAFLASH_AREA - 1] dataflash
partition can be defined to use the area to the end of dataflash size.
Now it is possible to have only one dataflash partition from 0 to the end
of of dataflash size.
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
This patch fix some coding style violations.
Without this patch "saveenv" crashes when MTD partitions are enabled (e.g.
for use in UBI) via CONFIG_MTD_PARTITIONS.
I made some updates to the code that didn't make it into the
README - fix this
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Introducing 64-bit (36-bit) support for the MPC8641HPCN
failed to accomodate the other two 86xx boards.
Introduce definitions for CONFIG_SYS_CCSRBAR_PHYS_{LOW,HIGH}
CONFIG_SYS_CCSR_DEFAULT_DBAT{U,L} and CONFIG_SYS_CCSR_DEFAULT_IBAT{U,L}
with nominal 32-bit values.
Acked-by: Becky Bruce <becky.bruce@freescale.com>
Remove USB obsolete commmand
Signed-off-by: Michael Trimarchi <trimarchi@gandalf.sssup.it>
Signed-off-by: Remy Böhmer <linux@bohmer.net>
USB Code style patch
This caused the operation to be needlessly repeated if there were
no bad blocks and no errors.
Signed-off-by: Valeriy Glushkov <gvv@lstec.com>
This BSP should be outside u-boot source tree.
The second reason is that xilinx ppc405 was moved to generic platform.
This patch disables some unused features from the PCI405 configuration
to keep U-Boot image size below 192k.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
