This patch enable CAAM support for i.MX8M platforms.
Signed-off-by: Aymen Sghaier <aymen.sghaier@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Franck LENORMAND <franck.lenormand@nxp.com>
U-Boot can instantiate CAAM RNG if needed by crypto operations.
Call sec_init() prior running a blob operation to ensure
RNG is correctly instantiated.
Make sure CAAM clock is enabled and check if a job ring is
available for that operation.
Signed-off-by: Breno Lima <breno.lima@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
In order to build CMD_BLOB on i.MX CAAM supported devices it's
necessary to select IMX_HAB. Add IMX_HAB and CAAM supported
SoCs as dependency.
Since commit 8891410c729b ("MLK-19848 mx6dq: Fix chip version issue for
rev1.3") it's not possible to call the HAB API functions on i.MX6DQ
SoC Rev 1.3:
Authenticate image from DDR location 0x12000000...
undefined instruction
pc : [<412c00dc>] lr : [<8ff560bc>]
reloc pc : [<c8b6d0dc>] lr : [<178030bc>]
sp : 8ef444a8 ip : 126e8068 fp : 8ff59aa8
r10: 8ffd51e4 r9 : 8ef50eb0 r8 : 006e8000
r7 : 00000000 r6 : 126ea01f r5 : 0000002b r4 : 126e8000
r3 : 412c00dd r2 : 00000001 r1 : 00000001 r0 : 00000063
Flags: nzCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
The hab.h code is defining the HAB API base address according to the
old SoC revision number, thus failing when calling the HAB API
authenticate_image() function.
Fix this issue by using mx6dq rev 1.3 instead of mx6dq rev 1.5.
Since cmd_dek is using CAAM JR, so enable the CMD_DEK only when
HAS_CAAM is set
Signed-off-by: Ye Li <ye.li@nxp.com>
Add some SOC level codes and build configurations to use HAB lib for
CONFIG_IMX_HAB (secure boot), like adding the SEC_CONFIG fuse, enable
fuse driver, CAAM clock function, and add CAAM secure RAM to MMU table.
The FSL_CAAM is temporally not enabled for iMX8M when CONFIG_IMX_HAB is set,
because we don't need the CAAM driver for SPL.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
The blob command is not working on i.MX7D, i.MX8MQ and i.MX8MM
devices.
Due to different cache management it's necessary to flush dcache
range for destination address so data can be available in memory.
Add necessary operations in blob_encap() and blob_decap() functions.
The imx8mm has changed the address of rvt_hab, use new address for imx8mm.
The authentication procedure is same as imx8mq. In u-boot, the authentication
uses SIP call to trap ATF to run HAB authenticate.
Users need to add CONFIG_SECURE_BOOT=y to defconfig to enable the feature.
Acked-by: Peng Fan <peng.fan@nxp.com>
When building 32-bit targets with CONFIG_SECURE_BOOT and DEBUG enabled
the following warnings are displayed:
arch/arm/mach-imx/hab.c:840:41: warning: format '%lx' expects argument \
of type 'long unsigned int', but argument 3 has type 'uint32_t \
{aka unsigned int}' [-Wformat=]
printf("HAB check target 0x%08x-0x%08lx fail\n",
%08x
ddr_start, ddr_start + bytes);
arch/arm/mach-imx/hab.c:845:45: warning: format '%x' expects argument \
of type 'unsigned int', but argument 3 has type 'ulong \
{aka long unsigned int}' [-Wformat=]
printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", ivt_offset, ivt_addr);
%lx
Fix warnings by providing the correct data type.
When booting in low power or dual boot modes the M4 binary is
authenticated by the M4 ROM code.
Add an option in hab_status command so users can retrieve M4 HAB
failure and warning events.
=> hab_status m4
Secure boot disabled
HAB Configuration: 0xf0, HAB State: 0x66
No HAB Events Found!
Add command documentation in mx6_mx7_secure_boot.txt guide.
As HAB M4 API cannot be called from A7 core the code is parsing
the M4 HAB persistent memory region. The HAB persistent memory
stores HAB events, public keys and others HAB related information.
The HAB persistent memory region addresses and sizes can be found
in AN12263 "HABv4 RVT Guidelines and Recommendations".
Reviewed-by: Utkarsh Gupta <utkarsh.gupta@nxp.com>
The HABv4 implementation in ROM checks if HAB major version
in IVT header is 4.x.
The current implementation in hab.c code is only validating
HAB v4.0 and HAB v4.1 and may be incompatible with newer
HABv4 versions.
Modify verify_ivt_header() function to align with HABv4
implementation in ROM code.
Add ability for hab_status command to show All HAB events and not just
HAB failure events
Signed-off-by: Utkarsh Gupta <utkarsh.gupta@nxp.com>
Currently it's not possible to authenticate additional boot images in HAB
open configuration.
The hab.c code is checking if the SEC_CONFIG[1] fuse is programmed prior
to calling the hab_authenticate_image() API function. Users cannot check
if their additional boot images has been correctly signed prior to closing
their device.
Enable hab.c to authenticate additional boot images in open mode so HAB
events can be retrieved through get_hab_status() function.
Modify to use hab_rvt_failsafe function for failsafe ROM API, not
directly call its ROM address. This function will wrap the sip call for iMX8M
platforms.
Calling csf_is_valid() with an un-signed image may lead to data abort
as the CSF pointer could be pointing to a garbage address when accessed
in HAB_HDR_LEN(*(const struct hab_hdr *)(ulong)ivt_initial->csf).
Authenticate image from DDR location 0x80800000...
Check CSF for Write Data command before authenticating image
data abort
pc : [<fff5494c>] lr : [<fff54910>]
reloc pc : [<8780294c>] lr : [<87802910>]
sp : fdf45dc8 ip : 00000214 fp : 00000000
r10: fffb6170 r9 : fdf4fec0 r8 : 00722020
r7 : 80f20000 r6 : 80800000 r5 : 80800000 r4 : 00720000
r3 : 17a5aca3 r2 : 00000000 r1 : 80f2201f r0 : 00000019
Flags: NzcV IRQs off FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
To avoid such errors during authentication process, validate IVT structure
by calling validate_ivt function which checks the following values in an IVT:
IVT_HEADER = 0x4X2000D1
ENTRY != 0x0
RES1 = 0x0
DCD = 0x0 /* Recommended */
SELF != 0x0 /* Absoulute address of IVT */
CSF != 0x0
RES2 = 0x0
This commit also checks if Image's start address is 4 byte aligned.
commit "0088d127 MLK-14945 HAB: Check if IVT valid before authenticating image"
removed as this patch addresses the issue.
There are some changes to support ARM64 i.MX8M platform in this patches:
1. The hab_rvt base and function vectors are different as i.MX6/7
2. Need to bypass an workaround for i.MX6 to fix problem in MMU.
3. The x18 register needed save & restore before calling any HAB API. According
to ARM procedure call spec, the x18 is caller saved when it is used as
temporary register. So calling HAB API may scratch this register, and
cause crash once accessing the gd pointer.
On ARMv7, the r9 is callee saved when it is used as variable register. So
no need to save & restore it.
4. Add SEC_CONFIG fuse for iMX8M
When current EL is not EL3, the direct calling to HAB will fail because
CAAM/SNVS can't initialize at non-secure mode. In this case, we use
SIP call to run the HAB in ATF.
When loading kernel image, the image size is parsed from header, so it
does not include the CSF and IVT.
Add back the authenticate_image function to wrap the imx_hab_authenticate_image
with calculating IVT offset and full image size.
Prior instantiating RNG we have to ensure if the CAAM job rings are
available. Avoid hardcoded job ring max size and use the definition at
fsl_sec.h
Prior calling sec_in32() we have to ensure CAAM clock is enabled, the
function sec_in32() is reading CAAM registers and if CAAM clock is disabled
the system will hang.
The CAAM output ring size register offset is currently defined in fsl_sec.h
as FSL_CAAM_ORSR_JRa_OFFSET, use this definition to avoid hardcoded value in
i.MX common code.
This code was originally developed by Raul Cardenas <raul.casas@nxp.com>
and modified to be applied in U-Boot imx_v2017.03.
More information about the initial submission can be seen
in the link below:
https://lists.denx.de/pipermail/u-boot/2016-February/245273.html
i.MX7D has an a protection feature for Manufacturing process.
This feature uses asymmetric encryption to sign and verify
authenticated software handled between parties. This command
enables the use of such feature.
The private key is unique and generated once per device.
And it is stored in secure memory and only accessible by CAAM.
Therefore, the public key generation and signature functions
are the only functions available for the user.
The manufacturing-protection authentication process can be used to
authenticate the chip to the OEM's server.
Command usage:
Print the public key for the device.
- mfgprot pubk
Generates Signature over given data.
- mfgprot sign <data_address> <data_size>
Signed-off-by: Raul Ulises Cardenas <raul.casas@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Add regs used by CAAM
Add imx8mn_evk_defconfig to be maintained
Typo fix
Signed-off-by: Peng <peng.fan@nxp.com>
Both i.MX8MQ B1 and B2 should use default LPDDR4 script, while B0
has another dedicated script.
i.MX8MQ B2 also has fixed value in OCOTP_READ_FUSE_DATA register,
so it does not support "fuse sense" command like B1.
i.MX8MQ B2 is using same value in OCOTP_READ_FUSE_DATA like B1, so
we have to check the ROM verision to distinguish the revision.
As we have checked the B1 rev for sticky bits work around in
secure boot. So it won't apply on B2.
The value of Unique ID in uboot and kernel is different for iMX8MP:
serial#=02e1444a0002aaff
root@imx8mpevk:/sys/devices/soc0# cat soc_uid
D699300002E1444A
The reason is that Fuse Addresses of Unique ID of iMX8MP are 0x420 and
0x430.
Signed-off-by: Alice Guo <alice.guo@nxp.com>
Users reported LPDDR4 MR12 value is set to 0 during PHY training,
not the value from FSP timing structure, which cause compliance test failed.
The root cause is the CATrainOpt[0] is set to 1 in 2D FSP timing
but not set in 1D. According to PHY training application node,
to enable the feature both 1D and 2D need set this field to 1,
otherwise the training result will be incorrect.
The PHY training doc also recommends to set CATrainOpt[0] to 0 to use
MR12 value from message block (FSP structure). So update the LPDDR4
scripts of all mscale to clear CATrainOpt[0].
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
Update fuse path to disable modules correctly.
For dual core and single core iMX8M parts, the thermal node and PMU node
in kernel DTB also needs update to remove the refers to deleted core nodes.
Otherwise both driver will fail to work.
There are 3 part numbers for 11x11 i.MX8MNano with different core number
configuration: UltraLite Quad/Dual/Solo
Comparing with i.MX8MN Lite parts, they have MIPI DSI disabled. So
checking the MIPI DSI disable fuse to recognize these parts.
Add dedicated defconfigs for iMX8MN low drive mode which set the VDD_SOC
and VDD_DRAM to 0.8v, DDR at 1600MTS (800Mhz clock) and GPU at 200Mhz.
Add support for iMX8MN LPDDR4 EVK board which uses 2GB LPDDR4 and
PCA9450B PMIC.
uart clk has been enabled, no need enable again.
Currently PCA9450 might have address 0x25 or 0x35, so let user
choose the address.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
On i.MX8MN, we can only support DLL-ON mode only, so update the timing
to support 2400mts & 1066mts setpoint.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
There is a frequency/timing limitation for SOC and ARM, if SOC is OD
voltage/OD freq, then ARM can't run at ND voltage/1.2Ghz, it may have
timing risk from SOC to ARM.
Current VDD_SOC is set to 0.95v OD voltage in SPL, and kernel will
increase bus clocks to OD frequency before it increases ARM voltage.
So to conform to the limitation, we'd better increases VDD_ARM to OD
voltage in SPL.
Clean up the including headers
VDD SOC normal run changed to 0.85V
LPDDR4 freq0 change from 4000MTS to 2400MTS
Signed-off-by: haidong.zheng <haidong.zheng@nxp.com>
Use more safer refresh time value for 6GB LPDDR4 on this EVK board.
Update the parameters for every frequency point.
After switching to new LPDDR4 firmware 202006 version, have to
update the LPDDR4 timing accordingly from RPA tool.
Tested-by: Sherry Sun <sherry.sun@nxp.com>
Tested-by: Jacky Bai <ping.bai@nxp.com>
Add inline ECC support for lpddr4 on imx8mp-evk. And add a config which
can enable/disable inline ECC feature for lpddr4 on imx8mp-evk board.
Signed-off-by: Sherry Sun <sherry.sun@nxp.com>
Add fdt_addr_r fdtfile which used by distro boot
Clean up environment
These files should not be in U-Boot repo
Update PMIC to use PCA9540, the legacy board not supported by NXP
Update LPDDR4 script to sync with v2020.04 u-boot
