These accessors are not overridden by any board, and even if they were,
this is something which should be handled via DM now, so remove the
weak alias option. Moreover, drop the inline keyword, as the compiler
can decide better.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Inline all the functions from the header file, as they are not used
outside of the driver or the standalone EEPROM example.
Note that this does introduce considerable amount of duplication in
the standalone EEPROM example, however that one has to be rewritten
anyway, roughly such that the SMC911x driver would expose DM EEPROM
interface and the standalone example would use that.
Pull the MII interface registration into separate function to avoid the
ifdeffery in smc911x_initialize(). Moreover, adjust the fail path such
that we use goto labels.
Fix memleak in the init fail path, where if allocation or registration
of MDIO bus fails, then ethernet interface is not unregistered and the
private data are not freed, yet the probe function reports a failure.
Invert the logic in the aforementioned functions to reduce indent,
no functional change.
Rename the function to keep the naming scheme consistent,
Replace combination of malloc()+memset() with calloc() as the behavior
is exactly the same and the amount of code is reduced.
These functions are never used and are likely a pre-DM remnant
from times long past, just remove them.
The rtl8139 driver is derived from Etherboot driver, which is in
turn derived from Linux 8139too driver added in Linux 2.2.18pre14.
An undocumented change in Linux 2.4.10.2 added a new field to the
driver, MODULE_LICENSE("GPL"); . According to current Linux kernel
licensing rules, Documentation/process/license-rules.rst, quote:
"GPL" Module is licensed under GPL version 2. This
does not express any distinction between
GPL-2.0-only or GPL-2.0-or-later. The exact
license information can only be determined
via the license information in the
corresponding source files.
And since the code does not contain any "future" clause, the tag
is therefore GPL-2.0 only.
Just move functions around in preparation for easy DM conversion,
rename rtl_bcast_addr() to rtl8139_bcast_addr(), no functional change.
Finish the checkpatch cleanup of the driver, fix the remaining issues
in probe and init function and in global variables, rename the probe
function to rtl8139_init(), no functional change.
This hardware reset and reset-wait implementation was twice in the
driver, factor it out into a separate function. This really should
use wait_for_bit() eventually and return -ETIMEDOUT, but thus far,
handling of any of this is missing from the driver. This must be
added later. Thus far, no functional change.
Rename the function to rtl8139_stop(), clean up checkpatch errors in
the stop polling function. No functional change.
Rename the function to rtl8139_recv(), clean up various checkpatch errors,
line-over-80 conditions, and malformed comments. No functional change.
Rename the function to rtl8139_send(), clean up the TX polling, the TX
OK condition at the end, overuse of typecasts, and various line-over-80
problems. No functional change.
Rename the function to rtl8139_reset(), clean up the reset polling
and various line-over-80 problems. No functional change.
Rename the function to rtl8139_set_rx_mode(), use unsigned variables
where applicable and inline mc_filter[] values. No functional chanage.
This string of macros is exactly the same thing as rtl8139_rx_config,
so just use rtl8139_rx_config. No functional change.
Rename the function to rtl8139_read_eeprom() to keep the naming
consistent, keep the variables sorted in reverse xmas tree. No
functional change.
The macro assumes ee_addr variable to be present when it's being
used. Rework the macro into a function instead and pass it an
argument specifying the register base address, to make it future
proof for DM conversion.
Clean up the horrible register definitions in the RTL8139 driver.
This does create a couple of checkpatch errors, but the driver is
full of them anyway, and those will be cleaned up later.
The DMA may attempt to write a DMA descriptor in the ring while it is
being updated. By writing the DMA descriptor buffer address to 0, it
is assured the DMA will not use such a buffer and the buffer can be
updated without any interference.
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
Cc: Patrice Chotard <patrice.chotard@st.com>
Cc: Ramon Fried <rfried.dev@gmail.com>
Cc: Stephen Warren <swarren@nvidia.com>
This patch prevents an issue where the RX packet might have been
accessed by the CPU, which now has cached data from the packet in
the caches and possibly various write buffers, and these data may
be evicted from the caches into the DRAM while the buffer is also
written by the DMA.
By invalidating the buffer after the CPU accessed it and before the
DMA populates the buffer, it is assured that the buffer will not be
corrupted.
The current code polls the RX desciptor ring for new packets by reading
the RX descriptor status. This works by accident, as the RX descriptors
are often in non-cacheable memory. However, the driver does support use
of RX descriptors in cacheable memory.
This patch adds a missing RX descriptor invalidation, which assures the
CPU will read a fresh copy of the RX descriptor instead of a cached one.
Currently the code only flushes the first RX descriptor, not every entry
in the RX descriptor ring. Fix this, to make sure the DMA engine can pick
the RX descriptors correctly.
This code programs the next descriptor in the TX descriptor ring into
the hardware as the last valid TX descriptor. The problem is that if
the currenty descriptor is the last one in the array, the code will
not wrap around correctly and use TX descriptor 0 again, but instead
will use TX descriptor at address right past the TX descriptor ring,
which is the first descriptor in the RX ring.
Fix this by adding the necessary wrap-around.
The RX descriptor field 3 should contain only OWN and BUF1V bits before
being used for receiving data by the DMA engine. However, right now, if
the descriptor was already used for receiving data and is being cleared,
the field 3 is only modified and the aforementioned two bits are ORRed
into the field. This could lead to a residual dirty bits being left in
the field 3 from previous transfer, and it generally does. Fully set the
field 3 instead to clear those residual dirty bits.
Replace the adhoc debugging ifdeffery with debug_cond() and an
internal SROM_DEBUG macro to select the debug level.
Move the functions in the driver around to better fit future DM
conversion, drop function forward declarations. No functional
change.
Rename these functions to dc2114x_{inl,outl}(), use u32 values in
them instead of plain signed integers as all those values are in
fact register values and the driver code does bitwise operations
on them. No functional change intended.
Replace these macros with static functions to permit the compiler to
do type checking on the functions. The INL()/OUTL() functions have to
be moved in this patch as well, as those DE4X5 macros are using them.
Clean up the remaining driver code, macro space alignment, function
declaration indent, replace __attribute__((aligned(32))) with plain
__aligned(32). No functional change.
Clean up the SROM accessors to bring them up to standards with
U-Boot coding style. Sort variable into reverse xmas tree. No
functional change.
Clean up the send_setup_frame() to bring it up to standards with
U-Boot coding style, invert the loops where applicable to cut
down the level of indent. No functional change.
Clean up the driver halt code to bring it up to standards with
U-Boot coding style. No functional change.
Clean up the driver recv code to bring it up to standards with
Clean up the driver send code to bring it up to standards with
Clean up the driver init code to bring it up to standards with
U-Boot coding style, no functional change.
Replace the PCI IO access with PCI memory access, the card
supports both, but the former does not work with QEMU SH4.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Replace mips-specific UNCACHED_SDRAM() macro with standard
map_physmem(), which permits the driver to work on other
systems than mips.
These macros are not used by any board, remove them to simplify
the driver. The EEPROM accessors are still retained however, as
those might still be useful.
These macros guard one switch-case statement, which grows mips malta
by some 20 bytes if debug is enabled, and even less if it is not. To
make the code simpler, just support all the NICs and be done with it.
If the DM_ETH is enabled and netdev.h is included somewhere, the
struct eth_device may not be defined, yet it is used in the header
file as an argument to fecmxc_register_mii_postcall. Add forward
declaration to remove the warning.
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-07-rc2
This pull request contains bug fixes needed due to the merged changes for
EFI secure boot.
Patches are supplied to identify EFI system partitions.
- DM ACPI support (Part A)
- Improve support for chain-loading x86 U-Boot
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2020.07-rc2
mmc:
- Fix dt property handling via generic function
clk:
- Fix versal watchdog clock setting
nand:
- Fix zynq nand command comparison
xilinx:
- Enable ubifs
- Sync board_late_init configurations with initrd_high setup
- Make custom distro boot more verbose
zynq:
- Kconfig alignments
- Fix nand cse configuration
zynqmp:
- Fix zcu104 low level qspi configuration
- Small DT updates
- Add DM_ETH support for DPAA1, DPAA2 based RDB platforms: ls1046ardb,
ls1043ardb, lx2160ardb, ls2088ardb, ls1088ardb.
- Add GICv3 support for ls1028a, ls2088a, ls1088a.
- Add lpuart support on ls1028aqds.
- Few bug fixes and updates on ls2088a, ls1012a, ls1046a, ls1021a based
platforms.
Add a few notes about this feature, which is aimed for development.
With chromebook_coral we normally run TPL->SPL->U-Boot. This is the
'bare metal' case.
When running from coreboot we put u-boot.bin in the RW_LEGACY portion
of the image, e.g. with:
cbfstool image-coral.serial.bin add-flat-binary -r RW_LEGACY \
-f /tmp/b/chromebook_coral/u-boot.bin -n altfw/u-boot \
-c lzma -l 0x1110000 -e 0x1110000
In this case U-Boot is run from coreboot (actually Depthcharge, its
payload) so we cannot access CAR. Use the existing stack instead.
If U-Boot is running from coreboot we need to skip low-level init. Add
an way to detect this and to set the gd flag.
