2020-07-31test: sandbox: add test for erase commandPatrick Delaunay
Add test for the erase command tested on ENV in EXT4. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31env: ext4: add support of command env erasePatrick Delaunay
Add support of opts erase for env in ext4, this opts is used by command 'env erase'. This command only fill the env file (CONFIG_ENV_EXT4_FILE) with 0, the CRC and the saved environment becomes invalid. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31env: ext4: introduce new function env_ext4_save_bufferPatrick Delaunay
Split the function env_ext4_save to prepare the erase support. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31test: environment in ext4Patrick Delaunay
Add basic test to persistent environment in ext4: save and load in host ext4 file 'uboot.env'. On first execution an empty EXT4 file system is created in persistent data dir: env.ext4.img. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31configs: sandbox: activate command env select and env loadPatrick Delaunay
Add support of environment location with the new env command: 'env select' and 'env load' The ENV backend is selected by priority order - 0 = "nowhere" (default at boot) - 1 = "EXT4" To test EXT4 env support, this backend is selected by name: > env select EXT4 Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31configs: sandbox: activate env in ext4 supportPatrick Delaunay
Activate ENV in EXT4 support in sandbox. The sandbox behavior don't change; the default environment with the nowhere backend (CONFIG_ENV_IS_NOWHERE)is still used: the weak function env_get_location() return ENVL_NOWHERE for priority 0. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31cmd: env: add env select commandPatrick Delaunay
Add the new command 'env select' to force the persistent storage of environment, saved in gd->env_load_prio. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31cmd: env: add env load commandPatrick Delaunay
Add the new command env load to load the environment from the current location gd->env_load_prio. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31env: the ops driver load becomes mandatory in struct env_driverPatrick Delaunay
The ops driver load becomes mandatory in struct env_drive, change the comment for this ops and remove unnecessary test. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31env: nowhere: add .load opsPatrick Delaunay
Add the ops .load for nowhere ENV backend to load the default environment. This ops is needed for the command 'env load' Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31env: correctly handle env_load_prioPatrick Delaunay
Only update gd->env_load_prio in generic function env_load() and no more in the weak function env_get_location() which is called in many place (for example in env_driver_lookup, even for ENVOP_SAVE operation). This patch is a preliminary step to use env_driver_lookup()/ env_get_location() in new function env_select() without updating gd->env_load_prio. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31env: sf: avoid space in backend namePatrick Delaunay
Remove space in ENV backend name for SPI Flash (SF) to avoid issue with env select command. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31env: ext4: set gd->env_validPatrick Delaunay
Add a missing initialization of gd->env_valid in env_ext4_load as it is already done in some other env device. Set gd->env_valid = ENV_VALID in env_ext4_save() and env_ext4_load(). This patch allows to have a correct information in 'env info' command. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31env: add absolute path at CONFIG_ENV_EXT4_FILEPatrick Delaunay
Add the absolute path to the default value of CONFIG_ENV_EXT4_FILE = "/uboot.env". This patch avoid the error : Saving Environment to EXT4... File System is consistent Please supply Absolute path Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31env: add prototypes for weak functionPatrick Delaunay
This patch adds prototypes for several weak functions: - env_ext4_get_intf - env_ext4_get_dev_part - env_get_location It solves the following warnings when compiling with W=1 on stm32mp1 board: board/st/stm32mp1/stm32mp1.c:849:19: warning: no previous prototype for 'env_get_location' [-Wmissing-prototypes] enum env_location env_get_location(enum env_operation op, int prio) ^~~~~~~~~~~~~~~~ board/st/stm32mp1/stm32mp1.c:876:13: warning: no previous prototype for 'env_ext4_get_intf' [-Wmissing-prototypes] const char *env_ext4_get_intf(void) ^~~~~~~~~~~~~~~~~ board/st/stm32mp1/stm32mp1.c:889:13: warning: no previous prototype for 'env_ext4_get_dev_part' [-Wmissing-prototypes] const char *env_ext4_get_dev_part(void) ^~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-07-31test: efi_selftest: Do not force serial# settingTom Rini
As part of the EFI self test we set and check the serial# variable. However, we should not be forcing this setting. In the case where we are allowed to change the variable it will change, and we will pass the test. In the case where we cannot change it, force may or may not be allowed, depending on further environment restrictions. Drop the -f flag here as we do not need it. Cc: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-31test: do not rely on => being the promptHeinrich Schuchardt
In our tests we should use the customized prompt for testing. Reported-by: Tom Rini <trini@konsulko.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Tested-by: Tom Rini <trini@konsulko.com>
2020-07-29Merge tag 'dm-pull-28jul20' of git://git.denx.de/u-boot-dmTom Rini
Use binman instead of one of the Rockchip build scripts Refactor to allow any arch to create SPI-flash images New button uclass
2020-07-29Merge https://gitlab.denx.de/u-boot/custodians/u-boot-stmTom Rini
- fix SPL boot issue due to early dbgmcu_init() call - fix SPL boot issue due to dcache memory region configuration - add support of CONFIG_ENV_IS_IN_MMC - add specific SD/eMMC partition for U-Boot enviromnent - enable env in SPL - use "env info -q" to remove log during boot - remove env location override for dh_stm32mp1 - update management of misc_read - check result of find_mmc_device in stm32prog - use regulator_set_enable_if_allowed for disabling vdd supply in usbphyc - enable CMD_ADTIMG flag to handle Android images - device tree alignment with Linux Kernel v5.8-rc1 - remove hnp-srp-disable for usbotg on dk1 - add reset support to uart nodes on stm32mp15x - use correct weak function name spl_board_prepare_for_linux - use cd-gpios for ST and DHSOM boards - add seeed studio odyssey-stm32mp157c board support - move ethernet PHY into SoM DT - add DHSOM based DRC02 board support
2020-07-29Merge branch '2020-07-29-add-brcm-ns3-support'Tom Rini
- Add initial Broadcom NS3 SoC support.
2020-07-29arch: arm: use dt and UCLASS_SYSCON to get gic lpi detailsRayagonda Kokatanur
Use device tree and UCLASS_SYSCON driver to get Generic Interrupt Controller (GIC) lpi address and maximum GIC redistributors count. Also update Kconfig to select REGMAP and SYSCON when GIC_V3_ITS is enabled. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29arch: arm: use dt and UCLASS_IRQ to get gic detailsRayagonda Kokatanur
Use device tree and UCLASS_IRQ driver to get following Generic Interrupt Controller (GIC) details, -GIC Distributor interface (GICD) base address and -GIC Redistributors (GICR) base address. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29configs: ns3: enable tee and optee driverRayagonda Kokatanur
Enable tee and optee drivers. Signed-off-by: Vikas Gupta <vikas.gupta@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29drivers: tee: broadcom: add optee based bnxt fw load driverVikas Gupta
Add optee based bnxt fw load driver. bnxt is Broadcom NetXtreme controller Ethernet card. This driver is used to load bnxt firmware binary using OpTEE. Signed-off-by: Vikas Gupta <vikas.gupta@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29board: ns3: add development keys used in FITPramod Kumar
Add development keys used in FIT. Signed-off-by: Pramod Kumar <pramod.kumar@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29board: ns3: add FIT image its filePramod Kumar
Add FIT image its file. Signed-off-by: Pramod Kumar <pramod.kumar@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29configs: ns3: enable FIT configRayagonda Kokatanur
Enable FIT config for NS3. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29configs: ns3: enable sp805 watchdog driverRayagonda Kokatanur
Enable sp805 watchdog driver for ns3. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29configs: ns3: enable EXT4 and FAT fs supportRayagonda Kokatanur
Enable EXT4 and FAT fs support for ns3. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29configs: ns3: enable gpt commandsRayagonda Kokatanur
Enable gpt commands for ns3. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29configs: ns3: enable mmc commandsRayagonda Kokatanur
Enable mmc commands for NS3. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29configs: ns3: enable BCM IPROC mmc driverRayagonda Kokatanur
Enable BCM IPROC mmc driver ns3. Enable DMA for MMC Host to have better reads and writes. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29dt-bindings: pinctrl: add ns3 pads definitionRayagonda Kokatanur
Add NS3 pads definitions. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29configs: ns3: enable pinctrl driverRayagonda Kokatanur
Enable pinctrl driver for ns3. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29gpio: do not include <asm/arch/gpio.h> on TARGET_BCMNS3Rayagonda Kokatanur
As no gpio.h is defined for this architecture, to avoid compilation failure, do not include <asm/arch/gpio.h> for arch bcmns3. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29drivers: gpio: add broadcom iproc gpio driver supportRayagonda Kokatanur
Add gpio driver support for Broadcom iproc-based socs. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Signed-off-by: Sheetal Tigadoli <sheetal.tigadoli@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29MAINTAINERS: update maintainers for broadcom ns3 platformRayagonda Kokatanur
Update MAINTAINERS for broadcom ns3 platform (TARGET_NS3). Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29doc: add README doc for bcmns3 platformRayagonda Kokatanur
Add README doc for bcmns3 platform. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29include/configs: ns3: add support for flashing imagesBharat Gooty
Add support for flashing images into QSPI and eMMC. Signed-off-by: Bharat Gooty <bharat.gooty@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29include/configs: ns3: add env variables for Linux bootBharat Gooty
Add env variables and commands for booting Linux. Signed-off-by: Bharat Gooty <bharat.gooty@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29board: ns3: limit U-boot relocation within 16MB memoryBharat Kumar Reddy Gooty
By default relocation happens to a higher address of DDR, i.e, DDR start + DDR size. U-Boot shall be used to collect the ramdump. Restrict U-Boot to use only the 16MB memory, so that this memory can be reserved. Limit relocation to happen within 16MB memory, start 0xFF00_0000 and end 0x1_0000_0000 Signed-off-by: Bharat Kumar Reddy Gooty <bharat.gooty@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29board: ns3: define ddr memory layoutRayagonda Kokatanur
Add both DRAM banks memory information and the corresponding MMU page table mappings. Signed-off-by: Bharat Kumar Reddy Gooty <bharat.gooty@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29dt-bindings: memory: ns3: add ddr memory definitionRayagonda Kokatanur
Add ddr memory definitions. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29configs: ns3: enable GIC_V3 ITSRayagonda Kokatanur
Enables the Generic Interrupt Controller (GIC) V3 Interrupt Translation Service (ITS) Locality-specific Peripheral Interrupts (LPI) configuration table and LPI table. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Signed-off-by: Bharat Kumar Reddy Gooty <bharat.gooty@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29board: ns3: program GIC LPI tablesRayagonda Kokatanur
U-boot programs the GIC LPI configuration tables and enables the LPI table. Signed-off-by: Bharat Kumar Reddy Gooty <bharat.gooty@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29board: ns3: default reset type to L3Rayagonda Kokatanur
Default "reset" from U-Boot to L3 reset. "reset" command with argument will trigger L1 reset. Signed-off-by: Rajesh Ravi <rajesh.ravi@broadcom.com> Signed-off-by: Bharat Kumar Reddy Gooty <bharat.gooty@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29board: ns3: add api to save boot parameters passed from BL31Abhishek Shah
Add API to save boot parameters passed from BL31 Use assembly implementation of save_boot_params instead of c function. Because generally ATF does not set up SP_EL2 on exiting. Thus, usage of a C function immediately after exiting with no stack setup done by ATF explicitly, may cause SP_EL2 to be not sane, which in turn causes a crash if this boot was not lucky to get an SP_EL2 in valid range. Replace C implementation with assembly one which does not use stack this early, and let u-boot to set up its stack later. Signed-off-by: Abhishek Shah <abhishek.shah@broadcom.com> Signed-off-by: Rajesh Ravi <rajesh.ravi@broadcom.com> Signed-off-by: Vladimir Olovyannikov <vladimir.olovyannikov@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29dt-bindings: memory: ns3: add memory definitionsRayagonda Kokatanur
Add NS3 memory definitions. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29configs: ns3: enable clock subsystemRayagonda Kokatanur
Enable clock subsystem for ns3. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-29arm: cpu: armv8: add L3 memory flush supportRayagonda Kokatanur
Add L3 memory flush support for NS3. Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Simon Glass <sjg@chromium.org>
