2020-04-20t208xqds: add support for backplane krFlorinel Iordache
Add support for backplane kr on t208xqds: remove board specific fixups on t208xqds for ethernet interfaces specified in device tree as supported backplane modes. Signed-off-by: Florinel Iordache <florinel.iordache@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-20lx2160aqds: add support for backplane krFlorinel Iordache
Add support for backplane kr on lx2160aqds: remove board specific fixups on lx2160aqds for ethernet interfaces specified in device tree as supported backplane modes. Signed-off-by: Florinel Iordache <florinel.iordache@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-20ls1046aqds: add support for backplane krFlorinel Iordache
Add support for backplane kr on ls1046aqds: remove board specific fixups on ls1046aqds for ethernet interfaces specified in device tree as supported backplane modes. Signed-off-by: Florinel Iordache <florinel.iordache@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-20phy: add support for backplane kr modeFlorinel Iordache
Add generic support for backplane kr modes currently available: 10gbase-kr, 40gbase-kr4. Remove platform generic fixups (armv8/layerscape and powerpc) for ethernet interfaces specified in device tree as supported backplane modes. Signed-off-by: Florinel Iordache <florinel.iordache@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-20armv8: ls1028a: define esdhc_status_fixupYinbo Zhu
This patch is to define esdhc_status_fixup function for ls1028a to disable SDHC1/SDHC2 status in device tree node if not selected. Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-20board: fsl: lx2160a: unused variable gic_lpi_baseHeinrich Schuchardt
If the board is configured without CONFIG_GIC_V3_ITS, an error occurs: board/freescale/lx2160a/lx2160a.c: In function ‘ft_board_setup’: board/freescale/lx2160a/lx2160a.c:673:6: error: unused variable ‘gic_lpi_base’ [-Werror=unused-variable] 673 | u64 gic_lpi_base; | ^~~~~~~~~~~~ Let's define the variable as __maybe_unused. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-17configs: ls1012afrwy: fix board nameBiwen Li
Fix board name for ls1012afrwy Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-17net: fm: fix build error when not using nandFrancois Gervais
If CONFIG_CMD_NAND is disabled, get_nand_dev_by_index() is not accessible. This fix allows the build to succeed in this case. Signed-off-by: Francois Gervais <fgervais@distech-controls.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-16Merge tag 'arc-fixes-for-2020.07-rc1' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-arc This is pretty minor set of changes mostly touching HSDK board: * Enable on-chip reset controller on HSDK * Add possibility to turn-on & off L2$ on more recent ARC HS processors. * AXI tunnel clock calculation on HSDK
2020-04-16Merge tag 'efi-2020-07-rc1' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for efi-2020-07-rc1 This pull request * provides an implementation of UEFI secure booting * fixes a problem with the rsa_mod_exp driver which stops some boards from booting when CONFIG_RSA is enabled which is needed for UEFI secure booting * enables the EFI_RNG_PROTOCOL if DM_RNG is enabled * fixes some function comments
2020-04-16ARC: HSDK: CGU: fix tunnel clock calculationEugeniy Paltsev
We set wrong tunnel PLL frequency when we request 125MHz tunnel clock. Fix that. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2020-04-16ARC: HSDK: Enable on-chip reset controllerEugeniy Paltsev
As the driver of on-chip reset controller became available we are ready to enable it. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2020-04-16ARC: CACHE: mark IOC helper functions as inlined_cachefuncEugeniy Paltsev
Force inlining of IOC related functions used in other cache functions. This is preventive change. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2020-04-16ARC: CACHE: add support for SL$ disableEugeniy Paltsev
Since version 3.0 ARC HS supports SL$ (L2 system level cache) disable. So add support for SL$ disable/enable to code. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2020-04-16Merge tag 'dm-pull-10apr20-take2' of git://git.denx.de/u-boot-dmTom Rini
Functions for reading indexed values from device tree Enhancements to 'dm' command Log test enhancements and syslog driver DM change to read parent ofdata before children Minor fixes
2020-04-16dm: core: Read parent ofdata before childrenSimon Glass
At present a device can read its ofdata before its parent has done the same. This can cause problems in the case where the parent has a 'ranges' property, thus affecting the operation of dev_read_addr(), for example. We already probe parent devices before children so it does not seem to be a large step to do the same with ofdata. Make the change and update the documentation in this area. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Ley Foon Tan <ley.foon.tan@intel.com>
2020-04-16test: fdtdec: test fdtdec_set_carveout()Laurentiu Tudor
Add a new test for fdtdec_set_carveout(). Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Drop blank line at EFO: Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-16fdtdec: support multiple phandles in memory carveoutLaurentiu Tudor
fdtdec_set_carveout() is limited to only one phandle. Fix this limitation by adding support for multiple phandles. Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16dm: core: remove the duplicated function dm_ofnode_pre_relocPatrick Delaunay
The content dm_ofnode_pre_reloc() is identical with ofnode_pre_reloc() defined in drivers/core/ofnode.c and used only three times: - drivers/core/lists.c:lists_bind_fdt() - drivers/clk/at91/pmc.c::at91_clk_sub_device_bind - drivers/clk/altera/clk-arria10.c::socfpga_a10_clk_bind So this function dm_ofnode_pre_reloc can be removed and replaced by these function calls by ofnode_pre_reloc(). Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Simon Glass <sjg@chromium.org>
2020-04-16dm: core: refactor functions reading an u32 from dtDario Binacchi
Now reading a 32 bit value from a device-tree property can be expressed as reading the first element of an array with a single value. Signed-off-by: Dario Binacchi <dariobin@libero.it> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16dm: core: support reading a single indexed u32 valueDario Binacchi
The patch adds helper functions to allow reading a single indexed u32 value from a device-tree property containing multiple u32 values, that is an array of integers. Signed-off-by: Dario Binacchi <dariobin@libero.it> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16dm: test: add test case for dev_read_u64 functionDario Binacchi
Add test case to cover dev_read_u64 and dev_read_u64_default functions. Signed-off-by: Dario Binacchi <dariobin@libero.it> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16dm: core: Add a way to skip powering down power domainsSimon Glass
When removing a device the power domains it uses are generally powered off. But when we are trying to unbind all devices (e.g. for running tests) we don't want to probe a device in the 'remove' path. Add a new flag to skip this power-down step. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-16dm: core: Add logging on unbind failureSimon Glass
This failure path is tricky to debug since it continues after failure and there are a lot of error paths. Add logging to help. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-16fdt: Fix 'system' commandTom Warren
'fdt systemsetup' wasn't working, due to the fact that the 'set' command was being parsed in do_fdt() by only testing for the leading 's' instead of "se", which kept the "sys" test further down from executing. Changed to test for "se" instead, now 'fdt systemsetup' works (to test the ft_system_setup proc w/o having to boot a kernel). Signed-off-by: Tom Warren <twarren@nvidia.com>
2020-04-16sandbox: enable CMD_BOOTEFI_HELLO and CMD_EFIDEBUGHeinrich Schuchardt
'bootefi hello' is used in one of the Python tests. efidebug can be used to verify the correct initialization of the UEFI sub-system. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromum.org>
2020-04-16sandbox: implement ft_board_setup()Heinrich Schuchardt
Currently we are not able to test reservations created by ft_board_setup(). Implement ft_board_setup() to create an arbitrary reservation and enable OF_BOARD_SETUP. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromum.org>
2020-04-16sandbox: add reserved-memory node in device treeHeinrich Schuchardt
For testing the handling of memory reservations create a reserved-memory node in sandbox.dts and sandbox64.dts. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromum.org>
2020-04-16patman: Apply the cc limit to the cover letter alsoSimon Glass
Quite often on a series that has clean-up patches, the individual patches may fit within the cc limit but the cover letter does not. Apply the same limit to the cover letter. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Chris Packham <judge.packham@gmail.com>
2020-04-16doc: driver-model: there is no UCLASS_ETHERNETHeinrich Schuchardt
%s/UCLASS_ETHERNET/UCLASS_ETH/g Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16configs: sandbox: enable LOG_SYSLOGHeinrich Schuchardt
For testing purposes enable the syslog logging driver. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16test: log: test syslog logging driverHeinrich Schuchardt
Provide unit tests for the syslog logging driver. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16test: log functions with CONFIG_LOG=nHeinrich Schuchardt
If CONFIG_LOG=n, we still expect output for log_err(), log_warning(), log_notice(), log_info() and in case of DEBUG=1 also for log_debug(). Provide unit tests verifying this. The tests depend on: CONFIG_CONSOLE_RECORD=y CONFIG_LOG=n CONFIG_UT_LOG=y It may be necessary to increase the value of CONFIG_SYS_MALLOC_F_LEN to accommodate CONFIG_CONSOLE_RECORD=y. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16log: output for CONFIG_LOG=nHeinrich Schuchardt
If CONFIG_LOG=n, we should still output errors, warnings, notices, infos, and for DEBUG=1 also debug messages. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16log: syslog driverHeinrich Schuchardt
Provide a log driver that broadcasts RFC 3164 messages to syslog servers. rsyslog is one implementation of such a server. The messages are sent to the local broadcast address 255.255.255.255 on port 514. The environment variable log_hostname can be used to provide the HOSTNAME field for the messages. The optional TIMESTAMP field of RFC 3164 is not provided. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16log: correct CONFIG_LOG_TEST prerequisitesHeinrich Schuchardt
An error undefined reference to `do_log_test' occurs for CONFIG_CMD_LOG=y, CONFIG_LOG_TEST=y, CONGIG_UNIT_TEST=n Make CONFIG_UNIT_TEST a prerequisite. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16dm: core: Move "/chosen" and "/firmware" node scanPatrick Delaunay
Use the new function dm_scan_fdt_ofnode_path() to scan all the nodes which aren't devices themselves but may contain some: - "/chosen" - "/clocks" - "/firmware" The patch removes the strcmp call in recursive function dm_scan_fdt_live() and also corrects a conflict with the 2 applied patches in the commit 1712ca21924b ("dm: core: Scan /firmware node by default") and in the commit 747558d01457 ("dm: fdt: scan for devices under /firmware too"): the subnodes of "/firmware" (optee for example) are bound 2 times. For example the dm tree command result on STM32MP1 is: STM32MP> dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver firmware 0 [ ] psci |-- psci sysreset 0 [ ] psci-sysreset | `-- psci-sysreset simple_bus 0 [ + ] generic_simple_bus |-- soc ... tee 0 [ + ] optee |-- optee ... tee 1 [ ] optee `-- optee Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16dm: core: remove redundant assignmentHeinrich Schuchardt
Variable count is initialized at the start of every round of the while loop and it is not used after the while loop. So there is no need to initialize it beforehand. Identified by cppcheck. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16dm: core: remove redundant if statementHeinrich Schuchardt
The value of parent is not changed in the first if statement. So we can merge the two if statements depending on parent. Indicated by cppcheck. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16sandbox: also restore terminal settings when killed by SIGINTRasmus Villemoes
Hitting Ctrl-C is a documented way to exit the sandbox, but it is not actually equivalent to the reset command. The latter, since it follows normal process exit, takes care to reset terminal settings and restoring the O_NONBLOCK behaviour of stdin (and, in a terminal, that is usually the same file description as stdout and stderr, i.e. some /dev/pts/NN). Failure to restore (remove) O_NONBLOCK from stdout/stderr can cause very surprising and hard to debug problems back in the terminal. For example, I had "make -j8" consistently failing without much information about just exactly what went wrong, but sometimes I did get a "echo: write error". I was at first afraid my disk was getting bad, but then a simple "dmesg" _also_ failed with write error - so it was writing to the terminal that was buggered. And both "make -j8" and dmesg in another terminal window worked just fine. So install a SIGINT handler so that if the chosen terminal mode (cooked or raw-with-sigs) means Ctrl-C sends a SIGINT, we will still call os_fd_restore(), then reraise the signal and die as usual from SIGINT. Before: $ grep flags /proc/$$/fdinfo/1 flags: 0102002 $ ./u-boot # hit Ctrl-C $ grep flags /proc/$$/fdinfo/1 flags: 0106002 After: $ grep flags /proc/$$/fdinfo/1 flags: 0102002 $ ./u-boot # hit Ctrl-C $ grep flags /proc/$$/fdinfo/1 flags: 0102002 Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16sandbox: Update PCI nodes in dts filesTom Rini
The way the PCI nodes are written today causes a number of warnings if we stop disabling some of the warnings we pass to DTC. As these warnings aren't disabled in current Linux Kernel builds, we should aim to not disable them here either, so rewrite these slightly. Update the driver model doc as well. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-16sandbox: p2sb: Silence compiler warningSimon Glass
Some compilers produce a warning about 'child' being used before init. Silence this by setting to NULL at the start. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-04-16serial: Set baudrate on bootSean Anderson
Currently, the baud rate is never set on boot. This works ok when a previous bootloader has configured the baudrate properly, or when the baudrate is set to a reasonable default in the serial driver's probe(). However, when this is not the case, we could be using a different baud rate than what was configured. Signed-off-by: Sean Anderson <seanga2@gmail.com>
2020-04-16Merge https://gitlab.denx.de/u-boot/custodians/u-boot-x86Tom Rini
- Provide serial base clock speed via getinfo() for ACPI SPCR - Initial ACPI support from DM core by leveraging existing ACPI support in x86
2020-04-16test: Add hexdump.h to the unit test headerSimon Glass
Since ut_asserteq_mem() uses bin2hex() we should include this header in ut.h to avoid errors. Add it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-04-16acpi: Add support for DMARSimon Glass
The DMA Remapping Reporting (DMAR) table contains information about DMA remapping. Add a version simple version of this table with only the minimum fields filled out. i.e. no entries. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-04-16acpi: Add a central location for table version numbersSimon Glass
Each ACPI table has its own version number. Add the version numbers in a single function so we can keep them consistent and easily see what versions are supported. Start a new acpi_table file in a generic directory to house this function. We can move things over to this file from x86 as needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-04-16acpi: Add an __ACPI__ preprocessor symbolSimon Glass
The ASL compiler cannot handle C structures and the like so needs some sort of header guard around these. We already have an __ASSEMBLY__ #define but it seems best to create a new one for ACPI since the rules may be different. Add the check to a few files that ACPI always includes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-04-16x86: Move acpi_table header to main include/ directorySimon Glass
This file is potentially useful to other architectures saddled with ACPI so move most of its contents to a common location. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-04-16x86: Move acpi_s3.h to include/acpi/Simon Glass
This header relates to ACPI and we are about to add some more ACPI headers. Move this one into a new directory so they are together. The header inclusion in pci_rom.c is not specific to x86 anymore, so drop the #ifdef CONFIG_X86. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
